View Full Version : LT1 Based Engine Tech
- Missing Under Hard Acceleration
- LT1 Valve Covers???
- installed spark plug wires backwards on one engine bank...
- 98+ headlight wiring on a 95 trans am what wires to i use!!! HELP ME
- Bad IAC or what?
- White Goo in Valve Cover
- A.I.R pumps really work- spent night in hospital
- a4 1st gear bock
- Loud Ticking Noise Under Hood While Engine Running
- Car Sounds Like It Is Choking When Idling In Drive Sometimes
- Replace slightly used lifters in new engine after a spun bearing?
- Question about CC305??
- Those of you with slp headers, how do you not burn plug wires?
- running rich...
- Hypertech AFPR users!!
- What the hell is this?
- "ABS INOP" and BRAKE light is on
- Lt1 distributor
- is a thermostat really needed when running an electric waterpump?
- power stearing/power brakes question
- Planning on a Cam install
- AFPR Aeromotive = Junk??
- curious on hp/times
- braking problem
- HELP!!! tuned up my car now no clutch
- Fuel Pump Humming/Fuel Filter Change
- Driving long distance with 3000+or higher stall
- Head Bolt Size Locations??
- What kind of RWHP with my new set up?
- Coolant in the oil AND the exhaust
- xe 224/230 guys...
- hawk hps
- Suspension Suggestions
- Help SES light is on
- SVO injectors
- switching to obd1 conversion,can i use 1995 timing cover w/out crank sensor?
- LS1SPEED.com in IL, up to par - cam choice?
- Should I do 4.10 gears with LT4 kit (heads, cam, intake) making 425hp?
- any valve cover clearance issues???
- How to get to 375?
- 4l60e from v6 camaro will it bolt up to a lt1
- 96 Z28 and 3k for mods what to do?
- Bad oil leaking
- Pulled heads - does this look normal?
- gas milage and 847 cam
- LT1 head torque spec's
- Why won't it run...
- 95 LT1 heads on standard small block?
- 93 Z28. Auto, 3.23's, 2800-3000 stall. Help me pick a cam!!!!
- LT4 Valve Covers
- LT1 motor/SBC radiator.....BIG PROBLEMS
- NEW MOTOR squeaking from under valve cover HELP!!!
- PROBLEMS with INGNITION. POSSIBLE ALARM PROBLEM NEED HELP!!!!
- How to tell for sure if fuel pump is dead?
- plug wire arcing?
- Hooker shorties & !AIR
- bullets too loud?
- to !CAT or not to !CAT, that is the ?
- Which cam for my 383 Stroker
- removing CPU, help!
- pick my next mod!
- Question on catalytic converters
- Seriously Ineed Of Help!!!
- resistor for skip skip eliminator question
- Rear tailights on Formula: "black" peeling away from the inside
- z28 newbie needs some advice
- Why do 160* Thermostats violate emissions?
- Checklist for LS1 brake swap?
- 12 pt header bolts. 1 inch, so how many heat cycles?
- Height of your car?
- Trimming the dipstick tube?
- Intake Manifold Leak - Which RTV?
- heads
- Gauges Mounted, where?
- Search Button
- switch pics?
- Waterpump?
- does this sound like a reasonable setup?
- How to calculate times from high elevation to sea-level?
- NR White face guages
- ngk
- draglites...what size?
- Car jerks at 2000 rpm
- Installing a vacuum cansiter
- need help with surges at low rpms
- Is this what I need to make a obd1 exhaust
- cam or headers? more power?
- Smoke after any freeway drive...
- Hypertech Power Programmer III
- '97 and '98 fuel guage wiring
- Iridium Spark Plugs
- When to do plugs on LT1???
- Any good Power in 4.3 V8?
- lt1 engine swap problems ( fast idle )
- What is wrong with my Z?!?!
- 94-95 jet hot header install guides
- Holley 52mm TB Problems
- Arizona Speed & Marine Cold Air Induction
- LT1 Miss
- loudmouth interior sound levels
- What size Intake?????
- engine rebuild question
- replacing shocks
- Does this sound like an OPTI symptom? Please help
- How hard would it be to Turbocharge an LT1
- Cam and Computer
- Diagnostic Computer
- cheapest pleace to get.....
- How to %uck AirPump & StayClosedLoop?
- Ran car into a ditch, body panel questions
- What's it called?
- cc306 or close to it, .... in here
- in/out cats size
- Fuel Pressure Drops to 0 at Key off
- Cam Install
- Broken tranny mount....I think...
- 94 Trans Am driverside taillight
- injector duty cycle
- A serious problem with my clutch
- Oil leak in 94 z28
- Best Sounding Cam
- hooked up battery and car jummped forward
- Nitto's in back/Kumho's in front
- Narrowing Down The Possibilities Concerning My Arcing Problem!
- fedex just dropped off my jet hot lts!!
- can the cap be removed from the opti with it still on the car?
- Will an LS1 MAF work in an LT1?
- New Problem
- LTs are in! questions
- just got my 94z28 camaro
- Cam questions....
- Hit a curb, what did I bend? lol
- any free pcm writting tools?
- How much are used 1.6 crane gold self ajusting rr's worth?
- CC Pro Mag RR
- how many ppl have 396's
- Richmonds and noise?
- finishing up the 355...which oil pump to get?
- anyone near chicago dyno tune a 93?
- Haven't driven the Z since November. Any problems?
- bad t-stat?
- Top end power loss?
- Fuel pump install???
- Need Help...Emissions Exempt
- Resurface Alum LT1 heads everytime they're removed?
- how easy is it to install quarter panels?
- Valves
- !EGR and !AIR
- Is Madwolf Still in Business?
- rr's too tight? or cam just make more valvetrain noise?
- advise a clutch disk
- What is the Max HP a Racetronix kit will support?
- whats the cheapest a T56 swap can be done for?
- New best...
- Hypertech Programmer
- bolt on offroad pipe?
- Electric cutouts?
- Coolant bleeding guide
- Is it Possible?
- 1/8 mile times?
- AFPR and injector sizing question
- Real bad miss/stumble between 4k-5k rpm, HEEELLLPPP!!
- Light Switch in my 93 Camaro Information Needed...
- What is cam LSA and its affects??
- Lowering through Eibach, anything else to watch?
- Datamaster run and fuel injector advice
- Why are my TRAP speeds so LOW?
- 112 LSA w/ Nitrous
- 02 sensor fittings welded in?
- Have Biult Sheet, How to Read? Do I Have 1LE?
- Frozen Rad.
- Flowmaster sound?
- SLP? Trac. control?
- price of long tubes?
- What size pistons for 396???
- Bad dealings with DMH Performance
- ss hood ?
- ran 13.4 at 104.7
- Valve Cover Breather
- Car turned off on me!!
- Impala Intake Elbow
- need help
- Heads,,,info
- You think my 22 lbs. Injectors are MAXED out @ 400 HP?
- GM header gaskets PN
- How long will the as&m coating last?
- ls1 lid/lower airbox on lt1 firebird ram air hood
- Help/Opinions with Exhaust Cut Outs
- Anyone That Wondered What's Inside the T56
- Complete headers + exhaust system
- Recommended K&N Air Intake System for '95 Z28?
- opti change opti, tune up & diagnostics $2000+?
- opti change, tune up & diagnostics $2000+?
- Annoying electrical problem.
- LT1's SUCK!!!!!!!!
- Best Spark Plugs
- What all is needed for successful A4 to T56 swap
- anyone wrap there headers?
- White smoke....no coolant loss
- Electrical Geniuses
- FP and opti tests
- Knocking in the morning
- BFGoodrich G-force KD's
- GLOWING exhaust manifolds
- Any way to get codes from the car without a scanner?
- Hooker LT, cheapest place online?
- Car Won't Start--Fuel Pump Issues--Help
- Fat oil leak on driver's side...
- question about 97 and up tail lights
- Tb Gaskets
- Biggest High Z inj and oppinions on them?
- Changing PCV hose
- should i switch to 10w-30?
- What Do LCA's Do?
- 1/4 difference from 2400 to a 3600 stall?
- Something's knocking in my engine
- Police interceptor?
- Jet Hot Long Tubes. Easy to install?
- Bank one running rich
- cheapest place to get stock plugs&wires...
- 1994 0pti Spark Question
- Which K member to go with?
- TB upgrade question
- limits of the stock lt1 crank?
- TB question
- Will my rear hold with 3:73 and 2800 stall?
- 98 ws6 rims on 93 formula
- SS Air Filter with SS hood on a Z28?!
- Walbro FP Question (Jack?)
- Interesting exhaust Ideas Purple Hornies and LTs
- 200 MPH Conversion kits?
- 383 Stroker
- Problem with the Z
- what next?
- ASAP, rear caliper bolt size?
- porting throttle body?
- why would car miss only at 2K rpms and less?
- Question about Percy's Header gaskets.
- My car is a freak
- Fuel pump going south????
- Not sure if any of you can help me but its worth a shot
- is this normal
- Out of curriosity
- Happy Hooker
- trying one more time to get dash vents
- hi Im having a miss at high rpms plz help!
- Ok what will it dyno?
- Still getting black smoke...
- T-Top Conversion?
