View Full Version : LT1 Based Engine Tech
- Insight needed on trouble codes
- Slp Cai
- Brake Question
- Have 97 Camaro/want to go with 94-95 headers?
- XE 224/230 - What Springs/Rockers/ETC
- need pic of holley tbody for 93
- quick question
- *HEAD WORK* need info on them.... ganna be doing them next week
- Head gasket selection, list em all
- What is a "cutout?" What is a "offroad" pipe?
- compression on my 383??
- 335's in the back
- 0w40 or 5w30
- 383 Lt1....stock oil pan?pump? inside!!!
- Tunercat ?s
- engine trouble, can't figure out what the problem is
- Some thing is about to break
- which gasket for CANTON Oil Pan!?!?
- Need Help ASAP Exhaust
- best price for lt4 heads ??
- Ok to install new Cam and not new Lifters?
- Dyno Tune?
- Dyno numbers for my 93
- Comp Cam Pro Mag 1.6 RR's
- xe 230/236
- AFR 227's too big?
- iat free mod for my 93
- fuel pump
- Am I being too cautious?
- Aftermarket Transmission dipstick tube?
- Do these times sound right?
- SES light after TB Bypass!
- Quieter Borla?
- Engine coming out.....front clip too?
- Wow Are U Serious?
- What is the stall speed of the LT1 corvette automatic cars?
- Hypertech AFPR adjustment.
- For those seeking taller valve covers
- Just got my SLP Clutch & PP...
- 160* thermostat
- Need To Scan
- Quick question about removing passenger exhaust manifold
- Z06 Rims
- need pics of low mount alternator no A/C no P/S
- Another heater problem
- Were there any inertial supercharging hoods offered for a '95 Z28?
- 18x10.5 on all four corners ?
- Where to get best deal on Stock replacement clutch?
- Cooling fan setup for project
- Immediate TBB Help please!
- Should I switch to synthetic oil?
- Lt-1 Need Help Fast!!!
- Chirping Valvetrain when cold?
- stock air box myth?
- all those with troubleshooting missfire/injectors inside please.....
- Headder gain
- how much metal in oil is considered "normal" wear?
- Q: about Fuel line disconnect tool
- How long LT1 lasts
- These LCA's any good ?
- engine swap 93z for 93vette
- bought proforms off of Ebay
- Superchips programmer dilemma...
- Anyone Currently running CC305?
- 15W-50 THAT's It...I've had it!!!!
- How hard is it going to be to do a MAC header install?
- Bigger air filter on K&N FIPK system?
- fuel pressure
- Car stored during winter, should I start once in while or not?
- $2500 to spend?? What to do?
- Triple Pillar?
- 245/40/ZR17 on 9.5" wheel?
- 2.5 to 4 in y connection ????
- OPTI/timing install questions
- Oil all over bottom back of motorand tranny?
- Shock
- Shielding power wire from interference (radio)?
- 383 questions
- hotcam or xe 224/230
- cant find a certain right up
- Smaller power steering pulley
- No SES?
- !Air???(I already searched!)
- speedo cluster swap
- Only getting 13-14mpg
- So does anyone actaully think this will work?
- Should I mod my 94z or save for a LS1?
- Maf sensor test granatelli, stock, ported
- What would you ecpect to pay from this heads/cam package?
- Backspacing on a 96 camaro for 15x10
- Summit rebuild kit
- kyb shocks
- i started on my headers install
- Where is the crankcase breather filter?
- Should I replace the opticrap?
- Roll Cage
- Tips on changing motor mounts?
- True Duals
- Comp cam Extreme 218/224
- Torque Arm Angle measurment
- Went to the track, good&bad news
- Cam without Torque Converter?
- I need some help with this one?
- Whats best for my stock setup
- Check Gages light coming on after 3500RPM
- optispark/cam dowel pin
- What exactly does the MAF do?!
- Ok, I'm going to be ordering my comp XE 227/230!!!
- Length of 10 bolt rear ????
- Tach goes to zero and moments later car dies
- what will cause a fan to come on when first started
- Educate me on Rocker Arms
- What heads to use on a stock LT1 that will also work with no header modification
- umm FIRE came out of my car!
- 160 stat fan temp recommendations?
- what fuel filter do you guys recommend?
- weak airflow from Hvac
- Do automatics have rev limiters/fuel cutoff?
- Fuel rail/ intake manifold question
- Need help have possible rebuild to do
- water to coolant ratio
- inch pounds to foot pounds??
- Legal implications of no cats
- Is this a good beginning stall converter?
- Question on exhaust
- LT-1 or LS-1? What's the big diff.?
- widest tire on 17x9
- How are the BBK shorty headers?
- Car Wont Start! Im Stuck At Work!
- knock sensor
- o2 sensor problems??
- Low Voltage at idle only
- Lokar Dipstick
- 1LE driveshaft Question
- MAF problem...
- lt4 intake
- Any LTCC users using the Retard feature?
- to cut oil pan gasket or not?
- 30# Fuel injectors
- intake fix, rtv setup time question....
- Possible EGR problem...
- battery connection
- Secret to drilling into a bolt?
- new reluctor ring for gear swap?
- Intake
- Newbie has some questions
- Rear gear/converter with HOT cam
- Stumped...Ignition??? Long :(
- SLP 25# injectors. Flow like SVO 30#?
- Prothane tranny mounts...
- anyone here have true duals with cats
- Window Trim
- How much power should my 355 handle?
- lt1 to ls1 brake convert? need info.
- Need your thoughts on this shortblock
- Adjustable FPR
- No First Gear selection on Auto
- What to expect from just a 355 or 361ci LT1?
- Upgrading SLP Resonator
- Long tube users!
- would longer lower control arms help traction?
- carbed LT1 for the chevelle?
- Optima Yellow Top install?
- Please help me with obd2 code
- Would this help.....
- Interior removale question for installing shocks
- datamaster help please
- Engine management for 10's N/A & Accel gen 6
- Holley Throttle Body???????
- Totally new ignition, car keeps dying.
- How to keep down exhaust/rattle noise inside the car???
- Edelbrock 58MM throttle body??
- lt1 throttle linkage/ trans linkage
- Best mod(s) ( no forced induction) for $1000
- V6 vs V8???
- will 02 ws6 springs work on 96 ta
- A4 shifter
- headers
- Just Came from AutoZone (Parts Quality)
- Crate engines OR re-build
- T/A cover and stud kit worth it???
- Crate Motor
- Running Like Crap
- Valve Clearance
- its coming.......
- Fuel injector rubber seal
- Brake fluid cap
- Electric Cutout
- Considering these two mods...worth it??
- Really need some Opti Help here...
- catalytic converters
- Diff between lt1 & ls1 catbacks
- Tranny issues jerry springer style...
- Does HPP3 really make that much of a difference?
- Firehawk Shocks
- Remove HPP3 Programming before KM install?
- 0W-30 weight oil???
- Remove and install new Water pump
- Where do you mostly mount your cutout?
- 1/4 mile times for automatic '95 Z28?
- DMH Cut-Out
- is there a wrong way to do a cam?
- How to check clutch master and slave cylinders?
- What to use to connect LS1 Airlid to LT1 Throttle body??? Pix Inside...
- Question about my Posi?
- Need opinions on tires......
- No Forward Gears
- TunnerCat or Lt1 edit
- For those that have relocated battery...
- bad timing/exploding starters?
- Lube or sealant? (rocker studs)
- Power Antenna possible on camaro???
- what exhaust should i get?
- Checking for header leaks and LT4 KM question
- SS Airbox install problems...
- Dent in my exhuast
- squeek after shut down
- Anyone got pictures of Edelbrock catback?
- OMG NOT GOOD! Broke a waterpump bolt! What to do?
- TPiS zz409 vs. XE227/233
- reusing bolts '97 LT1
- which electric cutout????
- Fuel filter for an 02 Trailblazer
- Torsional damper
- Reinstalling Opti...how to line up the holes? Please help
- 92 v-1 vortech from vette fitr my 95 trans am??
- Hose with bleeder valve is leaking...how do I fix?
- Exhaust Leak????
- duel cat or not
- When installing the main and rod bearings............
- My Exhaust
- What shocks are you all using?!
- what size bolt on stock y pipe??
- rebuild on 93 lt1
- what's easier pull motor or leave in
- Anyone with XE227/233 dyno graph?
- 3rd GEN 9-bolt rear
- strange AC stuff
- Very Upset With AS&M...
- I think I'm going to use the copper header gaskets that came with my MAC's
- How do I remove crank pulley?
- XE224/230 Guys inside plz!
- Flush your reservoir
- Opti Problems/Questions
- Is a 93 automatic throttle body the same as the 6-Speed car tb?
- Optis lasting only 2-300miles
- Question regarding MAC mids
- mileage on cc306...
- My car is in storage, anybody answer theses few questions?
