View Full Version : LT1 Based Engine Tech
- anyone have the lous short stick w/ 25 degree bend????
- Driving with air filter off...
- What is the optimal A/F ratio under WOT
- feul injectors
- radiator suppose to leak???
- Synthetic gear lube and LS additive?
- Powersteering Resivior Cap Leaking
- Help me make a list of all the bolt-ons for our cars...
- XE218/224 vs 224/230 on non P&P heads
- Rear Sway Bar Help with 12 bolt???
- X or H pipe for True Duals??
- lt4 head part #
- What would be more cost effective?355,383,396...
- msd fuel injectors
- heads
- time to replace the shocks
- Will my car still pass the sniffer without the AIR system?
- short belt/AC
- What kinda numbers would you expect to see...
- Wanting a different muffler, Which one?
- Guys with 355's in!
- What lifters, rockers, push rods, etc
- Will Accel 30lb injectors work in A 1994 z28
- How much for a rebuild after a spun bearing
- NGK TR6 plugs on bolt on car...
- AFR Heads
- headers
- Necessary to replace springs with 1.6rr's???
- Fabbing fan to stay on for given time...?
- LineLock Install---bleed brakes?
- How long will an lt1 Last?
- Cam FYI
- 355 with high lift cam?
- gains out of 3.73 on A4???
- Need 2.5" Muffler Ideas
- Tune Up!!!
- Bumping on floor board underneath pedals?
- Vacuum at idle with the Hotcam
- Autozone still do free PCM scans???
- Any new Hooker Catback and Hooker LT sound or vid clips??
- LS1 driveshaft install tips
- Just started car after Heads/Cam Install, Few Problems...
- SLP intake elbow
- comp cams 503??
- smashed driver side mirror
- should i ditch the slp lm and go x pipe???
- Stability/Aligment
- windshield wipers won't park
- Anybody have a Sound Clip of LT4 Hot Cam???
- Removing Manifolds
- impressions of my 230/236 cam w/my 6 speed swap
- For all throwing the P0100 code
- ? getting 450 rwhp out of 355
- Nitto tires
- Which Heads with my set-up?
- Tire Question
- 94 Z Cutting Out Help before I donate it
- High RPM Miss
- Cooling Issues
- how do i launch at 3k rpm on an a-4??
- Difference between FlowMaster American Thunder and their other LT1 exhaust ???
- I won't settle for less than 400rwhp NA.......help me get there
- Borls Installation Problem
- Long Tube Install ?'s
- tts datamaster problem
- Solid rubber lca bushings?
- Tubular K member-yae or nae??
- Anyone have pics of LTs with custom y-pipe & dual cats??
- 52 or 58 which is it
- Forget what size serpentine belt is for underdrive pulley.. anyone know
- Well its not the Opti...could it be a loose rocker arm or bad injector?
- 12 bolt or lt headers and intake
- anyone ever used these tires?
- '95 Z28 Automatic Transmission Problem
- 355 budget buildup opinions wanted
- whats wrong ? tranny??
- FLP longtubes and BMR trak-pak?
- Cool; Just installed cai, airfoil, new 160* hyperstat all in one fell swoop
- Rear drum or disk?
- spark plugs
- SES light burnt out
- Dtc#29
- What Mods Next?HELP
- drivers side headers wont go in!!!heeeelllppp!!!
- EVAP Canister Purge Solenoid Valve
- Center consoles...switch plates???
- Metal on metal sound when I turn
- Which hawk brake pads have little to no dust?
- LT's and AIR Tubes
- ILE vs Stock Trans mount
- How much for an OBDI scanner for a '95 Z28?
- LTs
- h pipe
- Need your help !
- LT1 rebuild help!!!
- "off brand" tires? other sizes can I use?
- Which valve springs?
- this sound about right? (problem)
- heads on roller rockers off
- Driven Water Pump Shaft
- ARP rod bolts w/out reconditioning, or reuse stock bolts?
- Rear passenger axle slightly bent
- Intake manifold question
- hamburg pans rule
- Wiring phantom a/f gauge ?s
- car idles high then low for about 2 mins.
- Disable brake! light?
- Long Tubes and Inspection/Emission problem ...
- really simple question...
- 95-97 style mac midlengths
- Bad Vibration
- suspension pop
- Is my car (1st des) or (2nd des)
- A$ -->M6 wire harness
- where to jack up the motor??need to get these headers in
- help with proform valve covers
- need quotes for maintenance in the spring...
- How to lift car to weld SFC's?
- will keyless entry work with obd1 conversion?
- 160* Thermostat not opening, any ideas?
- how can you tell....
- Examine my new slip!
- 120+ mph stock shortblock, NA
- Beehive Shape Ovate valve springs. Can they be used on LT1's?
- Need p/n Shoebox? :-)
- Building up my LT1
- vortech or trickflow elbow??
- Shoebox Help please
- Pillar and Gauge Questions.
- Kind of disappointing dyno day
- Volt gauge dips under load - lights flicker
- A.I.R pump removal/deletoion
- Oil pan drain plug stuck...oil leaking
- panhard bar brace
- 6AL ignition
- 97 Y-pipe removal
- 4th gen
- ASAP heat problems?
- ? about Combination Motorsports reputation
- How fast can I go on stock heads?
- switched to 3.73s today
- small block in a 94
- car trouble please help
- no heat.
- lights shorting out
- Running rich
- Need advice on modding the LT1
- How much is rebuilt stock short block$
- N20 Cam and emissions...
- homemade cai guys
- Arrrrgfgggh! Exhaust leak. Can't fix
- drivers side header bottom??or top??
- HVAC stuck on top dash vents, no matter what position!
- Can't buy just front brake lines?
- digital-6 plus
- Injector Problem? Computer programming problem?
- Speedo freeking out....tach too!!!
- Seems like my car is LEANING!!
- why more $ for 421 ci
- help fast! coolant resevoir suposse to leak?
- New Dyno Numbers
- 1.6RR with STOCK Cam? Worth it?
- 4.3 Liter LT1?
- Freeze Plug for W/P
- need some help injuneer, shoebox, ls1 to lt1 k-member
- Autozone couldn't connect with my computer
- Programming differences? LT1 vs WS6
- where to get silicon spray?
- heads and cam in car but problem
- Makeing Custom Cut Bends in Exhaust, Will it Effect Flow?
- Delphi or Ford SVO?
- dealership made my car slower... any ideas?
- CCV Valve & PCV Valve
- K-Member
- Can you make an O2 extension?
- Dark gray TA...
- headers
- Gmmg Kicks @ss!!
- how much to rebuild heads
- LT Headers safe?
- It works!!
- How do I install oil pressure gauge?
- Spintech mufflers...
- Borla with LT's worst combination ever
- Help me find where the smoke is coming from
- priming a freshly built engine???
- cc306/ optispark
- dynomax headers
- car dosen't start after RR install
- Changed oil before storage, change again before startup in spring?
- Air Pump Question Please Help!!
- Quick help..short block question??
- 10-15 hp for $130?? does this actually work??
- Difference between high volume and high pressure oil pump.
- what kind of brand headers are these
- 383 guys.....what kinda oil do you run????
- Edelbrock RPM Air Gap intake...Will it fit on a LT1 ??
- 2 problems: car is stumbling,hesitating/Headers hitting k-member
- Vented Opti upgrade?
- over valve cover wire kits
- Ok to switch between synthetic and dino?
- Keyless entry install Need help
- lt1 cam timing
- Rear brakes proportional blocks.
- Right Borla Tip Crooked
- 1/4 mile times from last summer
- About scared myself to death today.
- Big day tomorrow... Need some last minute help on CC306 install...
- Centerforce disc - unsprung hub?
- Universal Triple Piller Pods.
- $800 to spend
- injuneer shoebox help again
- who's car
- HELP!Car STILL runs like crap when it gets warm!
- valve spring compressor
- Abs Inop
- 0w30 oil?
- what ah cool!!!
- Complete Car issue run-down - VERY LONG - At a total loss now!
- Gettint the Harmonic Balancer off of the freagin LT1
- Pro Built automatics
- Very bad hesitation after Hotcam install.
- hits and misses all new ingnition!! HELP ME
- Key switch ignition problem
- re-use header gaskets?
- Question about mail-order tune
- SES light, surging, arching, rough idle after lifters & valve springs
- What Time?
- A Good Racing School???
- 4.10's in an A4...
- i need help Newbie
- Cam ONLY / STOCK HEADS guys please (rockers OK)
- putting a 95+ exhaust on a 93
- lt4 head question
- Alternative companies for Header coating?
- How long would aluminized offroad pipe last/which is best fitting?
- new opti problems
- is a kn oil filter worth it?
- whats the part number for the kn filter?
- car wanted
- what Cam for mild port & polish
- What rpm is everyone launching at?
- can a clogged cat cause a misfire??
- What do you guys think of this???
- Larger Lift Cam with 1.52 Rockers.... Does it Matter???
- Better output on stock heads: CC305 -vs- XE 224/230 -vs- XE 230/236
- Ideas for mods
- Thunderracing...
- Help me pick betwen theys 2 gear Packages
- Comp "R" lifters question
