View Full Version : LT1 Based Engine Tech
- CC306 vs CC305 on stock motor?
- Dyno Comparisons
- How much $ for plug and wire install?
- Dynamic Calculations - Avg ET by Cam/Stall etc.
- 52mm throttle body?
- fix it or switch it
- New non-lowering Spring Recommendations?
- offroad pipe question
- TPIS Longtubes users...plug clearance?
- LT1 Magazine (didn't know where to post)
- need part# for opti seal on timing cover
- brake pedal straight to the floor
- fuel pressure woes
- Guideplates question
- Emission Cheating Guru's HELP!
- motor oil - 5w30 or 10w30 or what? quick poll
- Multiple Cylinder Misfire, but I don't think so
- cant start 93 trans am
- vibration after new clutch
- Not a newbie, but why all the "DO A SEARCH"
- EX components double roller chain questions...
- What size T-Clamp or part # for LT primary Slip Fit
- the gm 847 cam
- Will stock 3:42 gears fit in my stock 2:73 rear
- LS1 Moser 12bolt in an LT1
- Moser 9" ver 12 Bolt
- no muffler, no balls?
- spoilerdepot.com????
- what do I need to change on my fuel system for the new setup?
- Technical cam question
- DMH E- Cutout (kind of long)
- stock PM rods w/ARP bolts (balance ?)
- Fuel pressure problem?
- 396's what are they like
- shifter question
- Going to buy air bag for rear spring(s), get the set or just one?
- 1.7 RR's affect on gas milage?
- Got my car fixed but vibration please help
- cai systems
- LT1 valve spring keys and retainers on LT4 springs?
- All N/A guys
- Trap speed, up or down with traction?
- carfax report
- To the guys in hawaii...
- Were can i find
- I lost 40 hp with long tube install!
- Is this a good price for a valve job?
- porting rksport primaries??
- HyperEutectic, how much HP do you think they can take ?
- auto meter guages
- why arnt the as&M headers fitting on my car????
- Hardend Pushrods or not
- My '95 Z28 has the Delco/Bose AM/FM Stereo and CD player...
- Which year LT1 had PINK RODS
- How much does a LT1 and 4L60E weigh?
- 93/94 whats the difference???????
- what kinda project car
- anti theft system
- Which belt to use after installing A/C delete pulley
- gas odor
- Weight of Rear end Complete???
- 396 cam and afr heads
- Popping from the muffler
- service engine soon light, fans stuck on. help
- How do you check for a spun bearing?
- MSD BTM problem, and a question about it......
- Fastest Times on the cc305 cam and stock heads?
- catalytic converter questions
- SLP 3.5 Tips and 2.5 dual/dual Tips
- to my *4th gen v8 * boys hows your rear holding up
- Custom 3" mandrel bent Y Pipe... ??
- hot cam roller rocker
- wrong firing order?
- So does anyone make lca re-location brackets besides BMR?
- next on the list?
- Best 383 Short Block for the Cash ?
- true dual setup done.......and first burnt wire
- subframe connectors?
- 93 LT1 M6 Stock .bin tune desperately needed!!!
- Is there any warranty on new opti's?
- How many pounds of compression should a stock LT1 have ?
- 3.73 gain
- Comp Cam?
- swapping rear end
- diagnostic circuit check
- tune up time
- I have money, but I don't know where to spend it.
- Ok wet opti...would it cause this?
- Rocker stud question
- What do you think of this price for true duals?
- How much better does the LS1 respond to mods than the LT1?
- M22 DRain plug
- Anyone have experience with going to high altitude
- Header Install
- Anyone know where to get eagle f1 gs-d3's??
- Fuel injectors for a power adder LT1
- Alright someone help me decide!!(modding)
- Coolant Temp Sensor
- Tuning Question
- Flowmaster American Thunder Exhaust System
- What should the resistence be on my plug wires?
- Steering?
- Slp Cai: V6 & V8
- 96-97 Shorty headers on 93
- Code 16, low res opti. But I have spark at the plug??
- 4 bolt main caps - HELP
- Fuel pressure tester
- Starting for first time after cam install
- choice..headers
- Install prices for exhaust..these good?
- Cc305
- Buying MAC Headers! Anything I should know?
- Engine miss vapor lock?
- Anyway to tell engine status...
- Where can i buy the adapters that plug the poluction into the BBK Headers?
- Window won't go up
- Front timing cover?
- still fighting Primary Tube leak on LT
- New AC Delco Fuel Pump on Ebay. Good Deal?
- lt4 knock module $$$$
- engine problems
- 97 10 bolt Outside Diameter on the Carrier Shims
- weird noise
- Intake Manifold Question
- Can this be done?
- Low Coolant Light
- Lost all power
- How much preload for Comp R lifters?
- BMR K Member and Lower A Arm Challenges
- Need the location of the Daytime running lights module...>>
- which cam???
- import or domestic
- Strange Electrical Problem
- Blow-bye??
- Roller Cam and Moly Graphite Engine Assembly Lube
- Intake Manifold
- Top hat fuel pressure regulator help
- Emissions - A bit Too Close for Comfort
- Car Idles Funny After Nitrous Install
- What type of exhaust is the best?
- Successful tuneup in under 4hrs...I'm proud
- hotcam kit, or long tubes
- Symptoms of the vibeshaft acting up?
- Brake pedal play
- Anyone have this brake kit from TR?
- Long tube trouble
- Pacesetter shorties/catback ?
- Old plugs gapped to .70, what difference woud this make?
- Ignition upgrades??
- suspesion bumping question
- stay M6 or go A4
- fuel problems on 383
- breakin' in LT4 cam kit
- struts suck
- Looking to buy an LT1
- who would win in your opinion?
- Need some Suspension help!
- over the valve cover wire kit install guide??
- stall wall or not?
- Low Water Light....!!!!
- Intake manifold bolts need to be retightened?
- bbk shorties y-pipe vs. stock y-pipe
- new tires
- OTVC with MSD 8.5mm wires
- Dynoing?
- stupid flowmaster question
- Question about cam vs. emissions
- Fuel Pressure
- Experienced cam guys inside....
- How much oil can an oil pan gasket leak
- More LT1 help
- Cheapest place to get SLP
- Changing Stearing Wheel, do I need a hub puller?
- warranty on opti
- True duals or y pipe with LTs?
- please help with wires
- Dropping the gas tank... (During rear swap)
- How long for PCM for less to make a tune?
- Whats louder Borla or SLP LM?
- LS1 Exhaust sounds
- Advice for part selection
- Omg! Shoebox In Here!
- SLP Paddle Kit necessary for 4:10's??
- Big Rotors
- Tire fitment question...
- lt4 spring seats
- OBDI conversion
- Whats a good power adder for $500?
- Stock Pistions
- VERY low oil pressure...??? serious?
- california smog questions
- Widebands and catalytic converters
- Building a custom cam
- Door panel problem
- first time dyno
- Jackstands on all 4 corners?
- Lowering springs
- Engine won't stay running
- ARP's SBC Accessory bolt kit worth a crap on LT1?
- Pics of my IAC and TPS (are they bad?)
- Heads
- alternator not charging
- suspension again
- Replacing factory gauges with autometer
- Quad Camaro exhaust
- New cc306/heads times!
- LS1 Brake Upgrade Problems
- Cutting B&M Ripper!
- Yet another LT vs. Shorties question!
- Ensuring Both tires spin during burnout?
- ever heard of the Tomahawk package
- Too much Cam?
- Cam question
- Performance mode shift on a ´96 z28
- Got me a Project
- need help w/ k-member
- ATF in engine oil safe for flushing crap out?
- racetronix install problem
- Pistons and crank
- Heat soaked starter from LTs?
- coil wire?
- Bad Injector?
- carfax report
- Spec Stage 3..............
- Plug wire heat resistance question? OVC kit best?
- Is there any real difference in the two LT1 intakes (not LT4s)
- Anyone heard of MetalMaster?
- knock retard = power loss?
- What calc figures how much air consumed by motor at certain RPM
- DTC code 36, issues on a month old opti?
- found noise, wheel hub
- leaking seriously!! need help.
- Car wont start SOMETIMES but starts most times???
- head gasket question
- What size are the motor mount bolts??
- found car, need exhaust!!
- Which one first???
- Whos better Hawk or EBC??? PROOF??
- Cutout at headers? or after Y?
- dmh cutout leaking
- Would I benefit from an LT4 Knock Module?
- problems with my car!!!!!!!!!
- exhaust
- normal wheelspin from a roll
- Better to use a shift kit or PCM tuning?
- eibach pro kit on, not that much lower??
- Carb engine with 4L60E?
- Pics of my wrecked '95 Z inside...
- muffler
- Car died while driving
