View Full Version : LT1 Based Engine Tech
- What degree thermostat?
- gears feel the same?
- How do I take the steering wheel off
- timing chain
- The 227/233 is in!!!!
- Possibly messed up Opti
- help with clutch on ebay
- Measure valve spring height for LT4 hot cam?
- Gears/ What's a good ratio for my car
- Plug wires too close to alternator??
- Dynoed car today for the first time question
- need help with a coolant fan fuse
- Need Help!
- If you had my mods, what would be the next thing you would do?
- Rear Deck question
- new valves, what brand? (2.02",1.60")
- Lt1 Opti-direct Ignition Systems
- Oil cap (not on)
- EverClear.. an octane booster?
- Weight of LT1 intake manifold...
- What are the best spark plugs for the LT1???
- Do Granatelli MAF's advace timing?
- 700R4 MONSTER MOTORSPORTS TRANSMISSION should i get this?
- piston not TDC when carnk pully at 12 0'clock
- code 16 and 18 on scanmaster
- header bolt stripped heads.....is it screwed?
- Water Pump Hose Question! Urgent Help, Please!!
- need a pic of injectors in manifold
- Stock replacement clutch?
- NFB What the ???
- Super Ram on LT1 in 3rd gen?
- Hose Kit, Hi-Miler differences
- Battery Issues
- keyway
- Compression Check?
- ram air under the car to cai
- shoebox injun, and anyone else, got an idea
- Pacesetter long tubes
- Need info on LT1 heads
- LT1 Accessory Brackets
- Optimum Air Fuel Ratio to shoot for for power?
- Ion here?
- new best at track
- Vents no worky after a night at the track.....
- Delteq Opti-Direct Stage 2
- radiator hoses replacement instructions
- Cam install question?
- 1997 Z28 Car running rich 1000-1900RPM's
- Is the stock trans. gasket cork or rubber?
- Do E.T. Streets have to have tubes???
- How can i tell Pink Rods from PM rods?
- Hard Start
- Not down shifting?
- Crank hub install
- problems with directionals
- Oil Pan?
- Problems...
- skipping and popping from idle to 2500
- Blinkiing Lights
- help, car and owner are confused
- Converter lockup switch???
- Ghetto Ram Air.
- How Do I Protect My Wiring ?
- splayed two bolt mains
- lowering the transmission down from the car without removing the torqe arm- few Q's
- My hatch attacked me!!!
- lts leave any o2s?
- C-5 rim fitment question
- GM Part #
- The Standard Question of How much horsepower/torque am i making?
- 368.7 rwhp and 379.3 rwtq
- Two squeaks down, one to go
- coil packs
- Need help, car will not start.
- What headers go good with SLP Loudmouth
- Operation Smoke Screen
- Headers and Borla
- Exhaust Heat Shields?
- Best Fuel Injector Cleaner
- Block drain plug won't go all the way in
- Foglamps
- Do i have to use the stock balancer with an underdrive pulley???
- Est HP after mods
- The %$#@ing car won't start
- New stock head hotcam dyno numbers
- Good Idea?
- Underdrive pulley question.
- trany help
- #8 spark plug, HELP!!!
- Hooker LT install!
- Need some help Quick!
- Car Won't Idle
- k im new too lt1's
- TB bypass
- need help asap
- Dynomax: Bullets vs. Ultra Flo
- Alternator Diagram please
- such thing as"hi per" fuel filter?
- Quick coil / ground strap question...
- hokker LT VS jethot LT anyone any better than the other.
- subframe connectors & strut tower brace
- Gas in oil?
- Going to the dyno this week
- stupid roller rocker question.
- Gonna order Jet Hot LT's, do I need to order anything else for the install ?
- Where to get higher octane (unleaded)
- crank bearing question
- Need help removing knock sensor....under car now!
- scanmaster codes
- Here are my videos!
- TB Bypass-Not the same question ask
- Almost 100K what should i do
- 160 Degree
- I Hate My Car!!!!!!!!!!!!!!!!!!!!!!!
- Broke my converter or my tranny?
- length of OTVC wires
- When Will It Stop!!?
- 60' times with pro kit, and no LCA brackets...
- vaccum system on 1995 350
- lca bolts
- Converting to Heated 02s, How much Voltage for 02s?
- AI's Econo port vs. Full port.
- cc306?
- Good place to get Taylor OTVC wires?
- Engine questions??????????
- Best Sub Frames
- TCC lockup switch doesnt work
- how do you change the !#*!*$/#*@ knock sensor?
- im a idiot
- Window Switch Wire, where does it GO???
- AFR heads
- LT1 header guide?
- How much $ for ignition switch replacement?
- intake manifold leak...
- Quietest mufflers for true duals (except for the XR-1s)
- Tunnel Brace
- How do you know if your opti is gone?
- Canfield Heads
- Autotap
- Timeslips!!!!
- Dynomax Ultraflow Report
- where to buy new flywheel?
- Hesitation at 2k rpm
- My Cruise Control doesn't work
- T/A owners w/Valentine 1 . . .
- Ordered TA Girdle, But recieved DTS Girdle???
- need help figuring out problem
- 911!Help ASAP! Middle of Header install
- cam install - now car won't start
- Symptoms of a bad map sensor
- CSI Electric Waterpump Blowing Fuses, HELP!
- power steering fluid bath (crazy PS pump leak)
- Engine Compatiblility Question 95lt1-96lt4
- LT4/SLP lightweight setup vs Mcleod
- Best Way To Weld In Sub Frame Con.
- whats is this
- just got my car back and OMG!!!!!!!!!
- intake manifold install
- iat bypass. Is this for real?
- Emissions
- thermostat
- coolant senser
- door hinges
- Floppy Bouncy T/A Headlights
- Best exhaust system I can get for $300?
- jet hots on a 97 z
- CM 912 springs
- Almost 100K what should i do0
- someone chewed some wires ! Help !
- brake problem, need help quick!!!
- Fuel Question
- Machining heads
- impala ss head gasket-which side up?
- Clutch install now speedo won't work???
- okay fixed my car 100 percent, but still ses
- Powdercoating Vs. Ceramic on Headers
- What is "dino" oil??
- please help want to kill truck lol wont run
- Windshield wiper arms
- 80,000 miles too much to do filter and fluid
- cleaning cylinder bores
- Code 46
- Salvage Yards
- Need RPM signal
- High Ouput Coil kills opti?
- O2 sensors
- gears from b-body
- Which wires?
- Exhaust Gasket Reccomendation/Pricing
- Need a straight answer....
- pcm batt fuse
- power steering pump
- bearing replacement
- Rocker and Opti
- Need Fuel Injector help
- pacesetter LT headers!!?? COATING???
- 383 questions
- .029 gasket help
- Exhaust shop and !cat question
- how much Ujoints cost (parts & labor)
- Looking for a link
- Stock Tach not working but Scanmaster shows RPMS.
- ws6,ss,slp springs
- She faked an overheat
- how to convert to cruise control?
- Arao Heads
- lowering question
- vented or unvented optispark?
- fuel pressure question
- finally..all done
- Reliablity
- what are hotcam specs
- LT4 Hot cam dyno numbers
- Need help Picking a Cam.
- volt gauge
- anyone runing XE 221/227 cam?
- camaro question?
- will my stock tc handle a xe 230/236?
- finally got website updated
- What is this part? from kinda behind the stereo area.
- tb bypass
- Emissions
- How much $$ to check and resurface heads?
- MisFire Questions on 93 Formy..
- Need help on upper console
- Fans work in Speed denisty mode, but not when coolent gets hot?
- Oil Passages on Lifters
- Where can I find OEM brake rotors??
- information on high lobe lift version of the xe230/236
- where can I find OEM part #'s for my ride??? nobody can find them it seems
- Help, Hard starting
- How do I upgrade to a 240km/h (160mph) speedo with my 1993 LT1?
- smoking
- NGK plug or Ac delco
- Please help me with some OBDII codes
- where can i buy wiper motors?
- 96Z starting weird
- thoughts on '93 F-bodies??
- knock sensor bypass...
- Alternator relocation bracket???
- What is the function of this part??
- Help!!!! Problem after heads and cam install
- Fuel Injector Q
- CSI Water Pump Electric Hookup, HELP!
- what hp/tq i'm looking at
- LCA question
- Where to get the cheapest hotcam kit, or cc305 kit?
- wiring problem
- TrickFlow Heads for LT1?
- Checking for bad Valve cover gaskets
