View Full Version : LT1 Based Engine Tech
- car having trouble starting??
- Infant Restraint System?
- Car decided to stop working properly...
- Part number help on plug wires
- Who sells AS&M headers?
- LCA's
- My car won't crank after having the door open 5 min's WTF?
- speedo jumps a lil when subs hit., please help
- Differential Cover Installed! Need info on Limited Slip Fluid!
- 0-60 question
- Daily drivers and 400 NA rwhp inside please.
- where abouts will this cam peak power take place?
- Scan Master LT1
- help me find a part number...
- Best Y-pipe to use with LT's?
- Turn signals not blinking? Any ideas?
- Day Time Running Lights? how do I add?
- My goal with the '95 Z28 I own is to make it a low 13 second car...
- keyless entry question
- Quietest cat-back w/ Headers?
- Anyone wanting 1.7 rockers...
- whats the REDLINE on a 1994 TA
- IS G-Tech acurate???????
- rocker adjustment
- How much RWHP can I expect???
- Line Lock install difficulty
- Which asp pulley?
- Check out some pictures of my TOTL exhaust (using a Dyno max Ultra flow Muffler)
- can IAT affect emission? i failed smog test
- True Dual Setup Questions
- stock timing chain okay??
- quick question
- Earls stainless brake lines
- accell or ford injectors?
- brakes in the rear...
- Cam install???
- LT4 hot cam curve shift?
- Installing headers and looking for tips
- What are good compression test results?
- pushrod question
- 440 rwhp heads and cam LT1!
- where to buy window motors??
- won't start after rocker install?
- Vibration coming through center console
- Will a 93 Holley TB work on a 94-97 Car
- AFR 1.450" valve springs
- PArt # for stock exhuast
- Anyone running skinnies up front and how are they?
- can I use 93 slp headers on my 94z?
- Shift Knob Problem
- LOUD rockers
- who is the best hot cam tuner?
- Dynaspark worth a maybe???NOT
- Part number
- need tuning but PCMFORLESS site is down?
- Fuel injectors
- OBDII to OBDI conversion (OBD2 OBD1)
- Clutch master/slave cylinder
- security light
- Throttle Body
- A/C Compressor: What others will work for mine?
- Spohn TA and Hooker LTs
- where to buy AFR 227's???
- Oil leak in my 94Z
- Possible problem after cam install
- Which injectors do I need?
- LT4 hotcam kit, How high RPM?
- GM Parts Prices
- True Duels
- Signs of a dead opti...????
- No emissions:50/50 street,drag: what cam would you go with
- Is the LT1 motor an "interference" design motor?
- where to get a custom belt
- i would like to know about SP brakes.
- How to install WP driveshaft
- 1.5 roller rockers on 93 LT1
- valve cover pcv hole
- Clutch slipping in high gear
- ? about rear defroster
- BEST CAM TO GET FOR STOCK HEADS?? please reply
- help please...cant find termostat
- Headers...
- Oil pump?
- AS&M 54MM Throttle body
- What do I do next???
- Engine Swap
- windows wont go down, hood and trunk dont work!!
- Polished valve covers
- i think my trasmission's losing it...
- Cut out question
- Polished alternator
- no power to fuel pump???
- GM847 cam and LT4 head swap how much $$?
- low oil pressure almost at redline??
- need help ASAP, regarding 93 programming for cam swap - pcmforless?
- tranny
- Need part # for hood struts
- new alternator still low voltage
- Best Cat-Back Poll
- need help fast?????
- 383 Questions
- cutouts
- head/cam swap
- PCM numbers?
- 93 heads same as 96?
- Anybody here
- What will 320-340rwhp do to a car?
- How streetable is my car?
- opinions on FAST, MOTEC, and DFI
- LT4 knock module? Where to get one?
- scanned codes
- Canton Oil Pan - Gm baffle
- K&N air filter
- Before/After Flow #s Iron LT1 heads by L.E.
- stock lifters????
- LT4 cam
- used 1.6 Roller Rockers on stock springs and cam.
- Hard to start(sometimes)
- crank hub problem
- Opinions on my options needed
- Tach problem after cam install
- LS1 fuel injector in LT1?
- Take out LM resonator?
- EGR and Cat, Low RPM/Lean Stumble theory
- A/C delete pully, Q's::
- My Horns Full Of Water
- Waterpump leaking at piss hole?
- Milled heads/new combustion chamber size??
- Making a noise when turning right?
- Monkey Balls!!!!!!
- Grr.. WTF is wrong with my car?!?!
- hmmm...started fine 1st time then...
- Desk Top dyno
- installing hooker lt's
- Air bag light -- What connections to check?
- Need help to take off my rear glass
- Stalling and SES light
- 97 lt1 high idle/high temp question
- 383 piston selection
- window motor
- Major Problem
- Fuel P reg w/ egr delete
- Super Rich then Super Lean! Help.. (long)
- Should be something obvious... ?
- largest tire on stock salad shooters?
- Tire mounting "tricks" for 11.50 x 16 ET Streets?
- Failed Emissions in NJ few questions...
- Jet Hot LT's ???
- Venom 400 Control Module
- Waterpump shot?
- Where to get Injectors cleaned/flowed?
- Another problem after clutch install... car can't find idle
- Which is better - CAI or SS Hood Airbox??
- how much drop
- checking bad fuel press. regulator-which vac hose?
- GMMG, Corsa, or Borla?
- dumb question?
- Low Oil Pressure
- What is stock Fuel Pressure
- Engine parts cleanup
- Crank shaft postion sensor
- Oil Pan Removal
- water pump gear
- Head, cam install guides
- 95 pcm in a 93????
- anyone ever move battery to the back?
- Please help me determine what is wrong
- Timing chain question for upgrade...
- Shoebox can you help
- Fuel injector/weird part #-Shoebox-Anyone??
- Mufflex 4" and Global West Traclink... no good :(
- Dumb oil change question
- Weird ticking
- Catco Part # for a cat?
- I know you guys get tired of these...(dyno guess)
- 93 Hardened pushrods, good for 6200RPM?
- Knock when i floor it
- Worried about taking injectors out - dirty!
- True Duals on my 95 Z
- My MPG is great! Am I just lucky?
- anyone bought rotor's from ebay,inside please....
- what times do u have with cc306 and stock heads
- dose anyone know the difference between a ls1 k-member and a lt1 k-member
- keyless entry
- 96 WS-6 performance?
- thinking of going to a mono blade
- Can anyone host a sound clip for me PLEASE??
- Clean Iriduim Plugs?
- engine missfire just read the codes need interp help
- converting from side mount to top mount battery posts
- Ss Led 3rd Brake Light
- Should I buy a New Posi when doing gear swap?
- fuse blowing need opinions please
- This sound like a bad opti ta you?
- Obligatory new headers pics inside
- cant get crank hub off!!!
- How do you remove this knock sensor???
- Which headers to buy?
- B&M Shift Plus for any 4L60E tranny
- LS1 in a 96?
- need part #
- Cam install - AC condensor
- Will I see 350RWHP?
- p/n's needed please
- GM 847 Degree Questions
- PN for rear springs
- clogged cat
- Hot Cam HP increase?
- Just installed SLP cai and have a ?
- Help needed, car misses around 5500 RPM's
- Just Replaced My Coolant Resevoir..
- stroker questions
- 305 cam question
- how much hp with this cam
- Which tires would you recommend?
- Runner length and diameter LT4 intake
- do i need this
- Quick Question bout sensors...
- Will LT1 Hooker Shorty's work with stock 95 Y-pipe?
- LT1 Sounds
- dash lights flicker
- $3100 to spend
- Oil leak from the opti?
- OPTI problem solved
- Ignition Boxes?
- How much compression on pump gas?
- Removed HVAC... do I still need the vacuum tank?
- How close to 300 rwhp will I be??
- Valvetrain Noise/P0303 Code
- How much HP will I make?
- anyone using Kumho Ecsta ASX
- Injectors
- idle problems
- Stock Rockers
- Ground Effects making my engine overheat...
- 160 deg thermo causing bad mileage?
- I need to know how to install lifters
- wiring in oil pressure and water guage
- Cold air intake question
- Front shock threads
- Whats wrong with this??
- Opti Problem
- Bassani MetaliCats ?
- Any stats on F-Body fatalies?
- Remove coolant for Head Removal?
- Gas in my oil, and oil in my gas!
- Did search still have stall convertor question
- stall??? yes or no??
- cc305 question
- Aftermarket gauges
