View Full Version : LT1 Based Engine Tech
- Rear End?
- replaces optispark
- a little sand left in my intake from sand blasting.. HELP
- Edlebrock Headers
- Lt4 Production Cam
- Replacing Water Pump
- LT1/M6/4.10 Car -- 1/8 mile times?
- Need help with temp gauge.
- Two questions (exhaust and shifter)
- Shifter knob for Pro5.0 Shifter
- Different CAI for traction control??
- after jet hot install, rattling...
- torque on rocker arm studs?
- pro and cons on programer
- quick-coolant crossover line-how is it held to the manfold?
- cam/head stock bottom A4 runs 11.63 on drag radials
- Cranking compression questions
- How loud is your Hooker?
- question for oil experts
- Best engine cleaner/degreaser?
- changing valve springs
- pcmforless weirdness?
- good deal or not?
- better heads to work?
- Remove s-pipe to switch between ORP and cat?
- Removing ASR / traction control -- UPDATE
- Quick question...need answer fast!
- When to upgrade Throttle Body and MAF???
- 94 Z-28 Q?
- oil pan gasket
- Calling all opti experts..
- Valvoline Durablend
- TTS Headers the Best???
- If i don't have a M6 or a 4l60e what should i have??
- Ls1 Speeds Open House
- TPIS Long Tube Headers
- wipers
- Are our Z28's IROC's???
- throttle body
- firebird tail lights
- would u ever buy this car?
- prepping OTVC wire w/o headers in car-good idea?
- running 15w40 mobile 1
- Rebuilt Shop in MD/PA/NJ area
- 95 Lt1 - Blown gasket / warped head - REPAIR??
- ARP 100-1201... are they chromoly?
- Help me pick a tranny.
- OBD I or OBDII
- SLP loudmouth
- How would this exhaust setup be?
- Window Sill disconnected
- Cut my cats off today
- Stg3slpbsflw
- Best subframe connectors to go with?
- can this be fixed????
- Poly motor mounts.. Engine Hit Hood?
- o2's
- Washed my Lt1 today
- Electric Cut out
- Drilling TB IAC hole?
- TraCtioN help...please!!!
- slemmed into a curb(laterally) stuff broken, help
- A little problem with the new TB
- LT1 Camaro
- Need some RPO codes
- need help installing 1993 afpr
- LT1 Scanmaster worth the money?
- Timing question
- question about emissions and headers
- Torque spec for motor mount bolt?
- Need Help
- ride height help
- Comp Cam 305
- ever heard of aerospace components inc???
- should I be alright running stock injectors?
- install cams
- Tranny mount
- Cam to big????
- Setup Suggestions????
- Many questions
- Coolant fill procedure
- Header Removal?!
- GM847 Cam Guys Inside
- 3/4 turn to tighten RR too much for stock lifters?
- does jethot offer 2 paymnets?
- Bolt ons, ported heads, HOTcam- spark plug suggestions plz.
- LS1 fuel injectors
- thread chaser ?'s Shoebox please help
- Is the MAF used in open loop?
- removing cats?
- Did anyone ever figure out the LT1 hesitation problem?
- Question about the 1LE aluminum driveshaft.
- Some HVAC Questions...
- stock muffler part#
- squeaking from front driver's side
- Anyone seen Dave from DMH?
- help! coolant line leaking
- SES light flashed on..
- what is this
- How rare are hardtops?
- 3200 Coan Stall 98-02 LS1 will this fit my LT1 4l60e???
- whats the difference.....
- Who has manuel fans?
- Rate my 355
- How many automatics out there?
- how hot do they really get
- edelbrock cat back
- Is this clutch worth it?
- LT1 with GMMG
- 35th Anniversary Rims
- Finally got my Z paid off... first mods?
- anyone of pics of their edelbrock headers/ypipe?
- Forged bottom end needed in 383?
- y-pipe question for LT pacesetter headers
- Dumb Question ? Need A Smart Answer
- What plugs do you run?
- whats a fair price for this car?
- HELP: Suddenly leaking coolant and don't know from where!
- pulling motor quickest Times.
- Tuning options
- how to keep egr flange from leaking??
- 3.73's or 3500 stall??
- MAC Header Accessories Questions...
- Magnaflow 15620 for single or dual cat LT1?
- X-pipe from Summit
- installing ASM's
- Dead CraneHI6 - DId this kill it?
- Fully ported AFR LT4's vs. fully ported LS6
- Anyone know if the mac sfc fit a VERT?
- Well im half way done with my header install.
- Rules for adjusting the headlights?
- Security Light!!!!!
- Anyone have Lloyds LE2 kit?
- BMR or SLP SFCs
- Thoughts on adj. LCA's
- Can I take off TB without replacing all gaskets?
- I think might have found my Problem!
- Anyone with Pacesetter shorty's
- Severe wandering steering problem (not loose or sloppy)
- brake caliper removal
- push rod length check
- reasonible selling price??
- Car cutting out- details inside
- Quick inline fuel pump wiring question..
- Anyone running Crower Cam?
- EGR and AIR PUMP????
- I need a dual exhaust pic with cats.
- 1994 LT1 Build
- About Joe O.
- shorties or long tubes?
- torque lb for balancer hub
- What header bolts should I get for my Jet Hot LT's?
- Dyno results Help!
- TPIS pulley sets?? Are they any good???
- ATTN: JJJ93z
- What can i use to hold the window up
- Stock throttle bodies...all years the same?
- Should I go 4 bolt mains with this set up?
- Anybody using the AEM ECU?
- coolant leaking!!!!
- Car is missing and running like crap...
- anyone running this cam
- Ugh! Should I just replace it??
- PCM edit verus Electronic Ratio Adapters...
- 1.6 rocker question
- looking at a higher milage lt1 today, what to look for?
- Is it worth porting my heads?
- Anyone run a MAC catback?
- did I hurt my car by running stock PCM?
- Car wont start... SECURITY light.
- Slotted rotors on Ebay....
- Bad Opti?
- Washer Fluid Pump? I think it died...
- losing gear??...in an automatic??
- Battling a weird miss/hesitation need help!!
- dyno graph have fun
- A really asinine question
- how to get crank pulley off?
- will cam 2 help me?
- locked keys in car. help?!?
- guys with ASM headers
- Calling Joe Overton!!
- Fuel Injector install
- Dtc P0300
- Steering wheel part #?
- i thought K&N didnt make this
- why's it doing this..?
- 3rd gen subframe connectors on lt1?
- Need some electrical help
- msd 6-btm ?
- True Dual Time
- Ebc Rear Pads Wont Fit Over New Autozone Rotors!!!
- I might of ported exhaust ports too big
- Over valve cover wires NOT over the net?
- Crate Engine
- Pcm
- To those of you considering a header install
- Where to buy opti and over the valve cover wires?
- LT1 Comp Wire harness
- does it matter which studs the rocker arms go on?
- Putting Long Tubes on a 93 LT1, Quick ?.
- miss when warm after cam install?
- 2 short video clips of the Z28 --- SLP Loudmouth
- MAC Truefit ????
- How many miles on your cam?
- Xe 224/230 114 Lsa
- need electrical help please!!!!!!!!!!!
- quick T/A question...
- If my O2 mV's are 70, that means? + other fuel trim ?s
- Opti-spark
- Can I rig the SLP ASR/TCS switch to work?
- Got the car back, now ?'s
- Quad Driver Failure
- Lt1-ls1 Steering Racks
- Accel 300 + ignition system wiring
- Spark plug socket?
- flushing coolant and moving opti vent line
- Question about installing head gasket
- WTF??? LOL's
- Which Ignition box, best for nitrous???
- Piston slap when cold? Anyone else?
- two quick questions
- Tested coil with shoebox's coil test
- Headers
- Complete exhaust system
- sometimes it starts, sometimes it doesn't
- Shoebox or anyone else please ~~~~>
- After Installing a Cat, how long...
- Hp and Tq #'s for LT4
- Adjustable fan switch on a 96 up fbody?
- Did search, Car starts, Car does not start, Car Starts,
- Trying To Make The Belts Stop Making Nosie
- OBDI to OBDII swap
- Welding oil pickup/screen to pump?!
- people with jethot headers please
- Stock 93 LT1 rocker arm ratio?
- Couple of rebuild questions
- Car won't start when it rains!
- crankshaft sensor failure
- What plugs to use with my current setup?
- Possible head gasket :(
- Making My own Sub Frame connectors?? Bad Idea??
- Will the ZZ4 forged steel crank work in the lt1
- HELP! rear calipers have locked up!
- Running in speed density?
- Stroker kit from Ebay ....
- why are trans am's worth more?
- Brake Failure
- Everyday Stall Driving
