View Full Version : LT1 Based Engine Tech
- DRL question/problem....
- Engine harness ? Need help ASAP
- Anyone have pics/guide for a spring/shock/coilover install?
- Cant find exhaust leak.. How can i find it?
- afr 210cc lt4 race heads
- removing thing holder
- gear installs
- Turn signal problems
- gears, series carriers help , quick please
- LT-1 missing?
- Will a 94 timing set work on my 96??
- visual differances between stock lt1 and edelbrock
- best gears?
- gears help , someone answer quick
- can someone tell me...
- No O2 sensor bungs on my longtubes?!?
- Valves
- rearend width
- digital 6 question.....
- wide wheels, +45 offset and slp level one package..
- Opti question....
- whats the fastest CARB legal car out there (non nitrous)
- NGK TR55 or acdelco iridium
- could u stroke an lt4?
- I got the hub pulled off about 1/2"... how can I rotate the crank now to get...
- LT4 Hotcam and OBDII....ANY 96-97 LT4 hotcam experience pls respond...
- Is the replacement part of the cam swap easier than the removal?
- while coasting 1300 rpm idle?
- Why won't LT1 Edit work on my car?
- Opti replacement decision
- Is 278cfm @ .550 good for LT4 heads?
- what's this button do?
- Just got my new 98-02 "honeycomb" tail lights for my '93
- Drivers Side Window Stuck
- Nasty Stumbling only when BONE COLD
- Fuel Pressure doesn't hold
- I hooked up an A/F gauge...now I'm scared!
- Wheelspin
- Perfect gears for still wanting acceleration, but top speed most?
- Lloyd Elliott heads/hotcam dyno numbers
- 96 F-body Hypertech work for 97 F-body?
- 24mm rear sway bar
- how much you pay to get LCA brakets welded on?
- anyone have a pic?
- newbie question on stall converters
- Took off hub...did i mess this up?
- Miss at Idle
- Any more suspension mods that I can do?
- broke a bolt doing headers :(
- Motive Gears from National Drivetrain
- Borla with headers?
- Difference in Blocks
- Need Throttle Body gasket part numbers...
- Loudmouth is rattling my console
- PCMforless help...
- Opti plug part #
- Install Guide for Springs??
- AN adapter for fuel rails?
- lt1 oil dipstick
- Where is the part # located on fuel injector?
- jet hot headers(tapping floorboard)
- CC305, 1.7s and comp 985 valvesprings?
- Using cherry picker to hoist LT1, where to hook on to?
- Unbolt Knuckle For Shorties?
- SES for how long?
- removing wire harness
- Right cam?
- Can an Opti becaome "over heated"?
- lt1 short block
- Header Flanges
- Anyone have a link for LT1 edit?
- Next Mod?????
- Loud Mouth Knock off??
- popping backfire at idle, erratic idle
- Intake Manifold
- Is the LS1 trans mount the same as the old LT1 1LE mount?
- Question about spark plugs and heads....
- longtubes with emmission question about leaks
- disc or drum?
- Relay for elec. waterpump
- Piston questions on stock BORE!!!
- took the opti off, does it matter if the shaft turned inside of it? AND - hub puller?
- Coolent lite comes on
- Gaskets????
- Could this be False Knock?
- True Dual
- Who's the "Jason Cromer" of Akron, OH?
- rear end noise
- Too Much For 10-Bolt?
- What all do you need to make a 8.8 rearend work?
- 94 Cloth to 98 Leather
- Help please! Car wont start!!!
- Anything quiet a noisey water pump?
- gains from stock manifolds to jet hot longtubes
- 3.73's on a 93(speedo)??
- Oil pickup tube question
- Fuel Filter???
- GM 847 cam tuning question
- Head Gasket?
- LT4 Hotcam and TC???
- Question about Hypertech Programmer
- 93 M6 folks, speedo questions
- ls1 parts
- Check it out
- Timing cover freeze plug size?
- Gears
- High RPM Miss
- tires and rims
- Brake Upgrade Pics
- Which muffler is everyone running?
- Throttle body questions...
- Paging LSUxBlake (56K Warning)
- Cleaned my maf
- EX Components Springs
- Those with gears, how does your car pull on the freeway?
- Good Pizza Bad Opti
- SLP Loudmouth Trouble
- Motor Pulling Question?
- 93 ram air conversion/need help??
- short block?
- Tranny cooler questions
- Guys with e-cutouts, In here
- LT Headers install on an LT1???
- Desensetizing the knock sensor?
- Any inside mount fuel pressure gauges less than $100??
- 01-02 steering wheels
- Meziere water pump enough for street?
- TB and Coolant Bypass
- need part numbers
- Anyone have a pic of the back of a 93 intake manifold? EGR questions!
- cc306 vs. hotcam on stock lt1 heads???
- should i have them turned
- Cleaning TB and piston tops
- Upper Radiator Hose foir Oil Cooler LT1?
- Help Help Help
- Which cam should I get GM847 or Comp 306
- compression ?'s
- abs inop and tcs off light both on please advise
- whats the best thing to do
- Which BF Goodrich to buy, the KDW or the KDWS
- what tranny to buy?
- How to get overflow hose out off coolant reservoir?
- What's a cutout?
- Preload on Comp High energy lifters and CC306??
- SS ten spokes
- MIght have bad plug...sounds like its on 7 cyl, and backfires on decel...help
- Gears???? help me guys
- Guys with 236/242 cam inside please
- Best $200 spent EVARRR!!!!....
- Please help! Headlight problem...
- Anyone running 1.7RR on the their LT1?
- plugs and edelbrock shorties....
- proform rockers with LT4 springs....
- OVC taylors
- quick question...hopefully easy answer...
- Jason Cromer Staying at Sam Taylor
- Hal shock install questions and tips.
- draining the coolant - valve on bottom pass. side opened - rad. cap off - what else?
- What type of tranny fluid? Dextron III or V?
- advanced induction packages
- P/N anybody?
- What should I do for more power.
- BOLT ON GUY vs A STOCK C5
- LT4 Hotcam
- wait..no...yea...yup im pritty sure its a turd
- LT4 Package HP???
- Mod question for this spring.
- Power loss and rough idle
- Front wheel stud replacing
- How can I tell if i have a bad lifter??
- ordered 12 bolt with 3.42 M6, mistake??
- Anything Special Needed In An LT1 Shortblock to Handle 425rwhp?
- when pulling the crank pulley off, does it matter where the arrow is pointing?
- Going with no emissions lt's, what do I do about EGR and AIR??
- Best trans mount?
- clutch pedal lets off high
- quick question regarding motive 4.10's.
- Whats Yall's Guess at my 1/4
- Clearance for Valve Springs?
- Oil Leak...Pan or timing cover?
- Pacesetter Long Tubes w/pics
- will sea foam clean out fuel on plugs?
- Anyone have a link??
- CSI Water Pump Install ??
- installing slp exhaust
- anyone ever notice if their alt. pulley has a slight wobble in it?
- Car running rich on only driver side cylinders
- shoebox is this the right # for 1LE end links
- CC306 on Stock TC
- Cam swap. Must I upgrade the timing chain?
- Used tires and rims prices
- cam selection
- Best header bolts for SLP shorties?
- shock change, how much to it?
- How much am i looking at?
- on a 93 LT1, is the fuel schrader valve on the drivers side of the intake?
- 4th gen wheels on 3rd gen
- tunercat: tuner or RT tuner?
- Help please...
- Anyone running an adjustable timing controller
- What can cause a piston to brake?
- ?rwhp gains of Jett Hott Coated LTs over SLP shorites for '96Z
- Good Shifter for T-56?
- Valve Spring install question...
- a clutch slip?? or something else?
- another cam question,thanks!!!
- 75-90 shot??? whos done it on small mods.
- This came out of my door... what is it?
- what should I leave off for my header install?
- o2 extensions
- LT1 heads...I need advice
- i have a pm and what do i do?
- Mystery miss: Found
- LT's in:)
- Instrument cluster replacement bulbs part #?
- SES lights, OBDII emissions, et al.
- LT1 to LS1 Wiper arms
- Anyone sale Over the axle pipe?
- Its Alive!
- Removing Front Clip
- McCord PowerPlate 2
- options for alternator dressup
- Opti Crap!!!
- Jason Cromer question
- E/T, is this where I should be?
- Ses Light Help!!!!
- Best silicon for LT1 intake manifold
- lt4 heads
- Is there an advantage of 3.73s over 4.10s on a M6?
- Gauges in creative places?
- Massive Wheelhop
- Best CC305 Cam Kit Price?
- LS1 engine into LT1 car possible?
- Problem! Clutch or ignition related?
- Pete Jackson gear drive?
- where to get a dyno tune?
- primary fan problem?
- What happened??
- question about sub-frames
- Dtc 77
- car running wierd
- my car is turning into a edelbrock car
- Stupid passenger side header!!!
- Picture request please!!
- Shoebox a lil help please
- Vigilante 2800+cooler+shift Kit+???
- How to block off heater core
- lifters?
- P0151 sensor circuit low voltage. What does this mean?
- Spohn roll cage anyone have?
