View Full Version : LT1 Based Engine Tech
- Would my SLP Y-pipe work with Jet-hot LT headers?
- Rebuild?
- Water Pump and Opti
- high beams w/fogs
- machine shop scared me for a bit
- Vats
- Hpp3?
- General 383 Question
- Which Hooker Muffler???
- ! exhaust heat shield?
- A Perfect Freescan Log
- Where to find exhaust ball flanges
- P/N for Thermo at AutoZone
- Oil pump?
- Finding an enjoyable street cam, the first time.
- Opti convervsion q
- Strange Knock Retard Issue
- 383 review, ples help
- Speed Bleeders Wrong Size???
- Anyone see this new Dynojet Wide Band A/F setup??
- Waterpump!!please Help
- Random choppiness in high RPM...
- Warped rotor question
- Anyone run Comp XE 224/236 NA?
- Car Up have a quick question. O2 sensor.
- What would be the effects of a failing Throttle Postion Sensor and Engine Coolant Sen
- Need Help buying Fuel Injectors!!!!!!
- tire height???
- Hooker? Magnaflow?
- Reconnecting vented opti.
- Vibration under decelleration
- Lingenfelter
- PACESETTER LT1 headers - where to buy and fitment issues?
- Finally got some times...
- Strange knock coming from M6 transmission?
- 500 rwhp
- Locker for weekend warrior.
- What to clean injectors with?
- Which vavle springs?
- Weird issue after Cam/Heads Install
- To Lt1 Tech Mods And Members
- 94 "unvented" opti, vacuum vent through drip hole?
- Is this normal???
- bleeding the LT1 clutch master cylinder
- 93 MAC Headers on a 94 LT1
- gears?
- MAP Sensor Readings - Stumble
- what do you guys think?
- What's up with the one wheel peel?
- Pro-Magnum GP!!
- CSI Waterpump Failure !!!
- Problem with a hesitation. Have a datamaster log.
- Ok, Ok, Another "Whatcha Think It'll Do" Thread
- intercooler?
- very poor mileage
- electrical problems
- 2 lt1 cam/ head new bests
- Differential Reinforcement Cover - Clearance Problem
- wipers
- AIR Pump
- Help! asap..engine oil temp sensor
- ANyway to find out what is causing knock retard?
- Goodyear GS-D3s or NITTOs?
- 97 WS6 or 98 T/A
- Upgraded Mechanical Water Pump?
- low oil light came on, just changed oil??????
- Problems with my LT1
- Hole in Timing Cover!!!!
- LTCC conversion
- Tie Rod install problem.
- why does the intake/throtle body get so dirty inside?
- Jet Hot LTs
- Check This Out
- any1 run before, stock, and after jet hot install? and have the 2 diff. numbers?
- 96 opti change
- Hey got a question about 95 LT1 cars? opyi vented?
- Any dyno numbers with Hooker catback and LT's??
- Rebuild 93 to 94
- Sub Frame
- 4 bolt main or 2 bolt??
- Gears for stock rear end
- How do i know if the w/p seal is busted?
- First time to track..Times inside
- Ford 4.6l injectors fit LT1?
- valve adjustment???
- How much for a y-pipe and which one?
- CC306 and which heads?
- Help Quick! Car won't start after intake manifold fix
- Whats car worth??
- fouling spark plugs
- Taylor OVC wire kit, how to crimp opti ends on?
- 9.46 in the 1/8!!
- How much should I sell my car for?
- CC306 & 1.6 RR's
- 1" stage 8 locking header bolts...where to buy
- Third brake light
- How much water/coolant to fill block and radiator?
- Mas
- Question???
- car problems
- How much does 1 Salad shooter rim weigh?
- weather stripping on ram air box-ok to remove?
- selling airbags
- Stupid Welder!!
- Anyone have picture/description of clutch safety switch?
- repairing 4th gen seats(please help)
- Is My Temp Gauge Off?
- would I be ok to block off my egr and air HERE? Can't get tube out of pass. header
- Plug Wires
- Getting Intake Manifold Powder Coated, a few questions...
- New best ET & MPH for Lloyd Elliot heads/XE cammed car
- Whats Wrong With My Ta Transmision.
- Battery in the trunk, starter question
- Best headers
- When you signal left or right what would cause both lights to blink at the same time?
- mass air flow sensor question
- Passanger Header Problems
- A Big Performance Boost!!!
- hypertec thermostats 180 or 160
- Pacesetter LT's + Y-pipe
- Throttle Position Sensor ????what does it do?
- oil help
- OBD11 scanner for$99.00
- 52mm TB or 58mm TB?!?!?58mm too big??
- Fog Lights Mod?
- To Bolt Or To Weld
- Fuel pump install pics, through the hatch!
- Front oil gallery plugs need oil hole or not?
- Oil Dipstick Pull It? Help Please
- Corvette forum???
- Best Mod for Quicker Acceleration
- 94Z rear end fit my 97Z
- Can the LT4 intake work on LT1 heads?
- what to do
- whining in rear end
- LT1 SS Hood Baffle Removal?
- 6psi at idle
- Put my new Pacesetter Headers on !!!!
- 97 Z28 running to rich and missing.
- Throwout bearing went, clutch forks jammed forward, what do I do?
- shifters
- LT1 guys - set this moron straight
- 98+ Airbox in 95Z
- What happens if a knock sensor is unplugged?
- computer tuning
- Getting Off the Flywheel?
- VERY Quick Copper Header Gasket Question. Help!
- What to get
- How much HP at the tires?
- cam install problem?
- Soundclip of a Joe Overton cam car
- Metri Pack Connectors
- difference between these two cams?
- Random Tech muffler only
- 97 Trans Am fuse box..
- How do I spin the motor by hand?
- Opinions Please
- Dyno Results GTP S2 LT4's and GTP-6 cam
- Help with smog
- Removing the timing chain
- Racking my brain!!! How to get boot to slide over plug wire (the opti end of wire)??
- spohn torquearm
- Wtb: Gm 847?
- guys with LT4 heads & 383's ????
- how much more can I get?
- spark plug gap
- A/C lines in the way of motor mount thru bolt? WTF!
- which gears to get?????????
- Do ceramic headers smoke a little at first?
- rear diff problems
- Centerforce, yes or no ?
- Blocking AIR Tubes On Headers
- Installing new speaker?
- Pothole! Please help.
- Antifreeze Question??
- LT1 Ram Air Duct
- PCM or TRANS??? HELP.
- Headers - do they improve fuel economy?
- LS1 brake swap?
- NGK TR6 or TR55?
- wOOt! Changed my spark plugs last night.
- Anyone running sidepipes?
- Ordered 2 of my 1st mods yesterday...
- SVO 32lb Injectors...
- LS1 brake upgrade..How long ir take you?
- Help!speedo dead
- How hard is it to change 94 cam to 95 cam?
- LCA won't come off
- Composition of stock LT1 pistons, rods..
- "Do a search" Commentary
- Throttle to start cold
- will an 87 up 700R4 work in a 93 F Body?
- OBD2 Scanner for $189. Worth it?
- Spring and lifter change, need help ASAP!
- what cc heads?
- Dots aligned on chain, #1 or #6 at TDC?
- Did a great headlight mod
- 383 knocking and screeching!!
- header/cai gain
- main bearing cap bolts threads
- People with large signatures have tiny.........
- no wonder the crank hub dident come off...
- Mti
- who has experience with the cc306 and comp 987's?
- Ok, need ideas on what to do next...
- Anyone have pics of boxed subframe connectors installed?
- Egr Damaging Intake Manifold Gasket
- LS1 forum growing faster every day. What will happen to the LT1?
- cheapest place for roll bar?
- Does this sound like tranny mount?
- timing cover?
- those with 4.10's i need advice
- Rear Main oil seal
- Looking for an Old Post.... Help plz
- Firebird headlights?
- Can the LT4 intake accept a 58mm throttle body?
- Strange hesitation when cruising.
- Best bang for the buck...
- Hypertech Thermomaster
- shiping help
- opti-spark question?
- Why would someone want this?
- difference between 1.7RR BBC and 1.7RR SBC??
- Best SLP shorty gasket?
- opti spark?
- My Jet Hot Ypipe just arrived for my LT's. (Pics. inside.)
- MSD box users
- Whats the difference between a roller cam and a hydrolic cam? Which one is better?
- Advanced Aerodynamics....
- T-top conversion, do I need rear trim pieces?
- Please help with strange speedo calibration problem...
- help!!!!!
- Worst luck ever oil pan leak!
- Removing cam pin in one cam to install in another
- removing old oil pickup tube to use on new pump
- 210 deg in town
- Getting a 96 Camaro B4C, i got some questions, please
- Got a question about shifter noise.
- Opti Uh O..
- DFI users: quick question
- Gas inside throttle body/intake?
- hooker lt's and o2 sensors
- tunercat - the simple changes?
- Higher Compression=Better MPG?
- Cant Get Passenger Side Motor Mount Bolt To Line Up!!!!
- My home ported lt4 heads
- will cc306 like 100 octane?
- where to get felpro 1406
- Need part number!
