View Full Version : LT1 Based Engine Tech
- Another Spark Plug Question
- Diagnostic help/advice needed. 94 Z28 dies then usually won't restart for a while.
- Right bank showing very lean
- 95 lt1 hard start
- car just died
- Heater hose - Help!
- Lets have a discussion
- car still running rough
- injectors
- Intermittent Spark Issue??
- BAD miss
- a few refresher questions.
- Broken Rocker Arm Stud
- Fuel injectors lb!!??
- Dry sump oil system?
- lt1 swap starts but wont run
- Will too high fuel pressure kill fuel pump?
- Cam help
- power ball park
- Tach Quit
- 1993 lt1 ecu
- 94 z28 fuel pump r/r-no start
- 94 lt1 hesitating when hot
- 94 LT1 will not start...
- Car Wont Start PCM DEAD?
- Leaky Water Pump
- 93 Z28 all stock
- car wont turnover 1 outta ten times
- Does anyone want to to the pickins for me?
- Need an elbow for the intake whats better?
- 94 Z28 running rich
- new car... to me
- lt4 Knock module
- finding the cause of a dtc p0174
- Heating problem
- What's to keep you from putting an SBC block in?
- 95 camaro Z28 head gasket
- Engine surges 1995LT1
- inlet flow rates
- Obd2-obd1 cps
- whats my horse power
- couple of questions
- Too many miles?
- isd this just my luck or what!!!!!!
- 94 z28 motor swap with a 95 trans am no spark
- "You need a cage. Go see tech."
- 94 Camaro, runs like garbage after 30 minutes, hard start
- trying to help a friend
- got an odd one for ya
- best upgrades
- first things first
- Lt1 swap
- no spark after engine swap
- How much improvement?
- violant vibration between 1500 and 1000 rpm
- Starter exploded
- Installed new opti now car just backfires!
- Cut out or no cutout
- Custom Exhaust Setup Questions
- Getting alot of vibration at 45-50 mph at low rpm.
- what will my power be?
- Do You REALLY Know LT1 Stuff? Guess The Bolts!!
- vaccum line
- Ground Strap Location 93 Z28?
- 100% synthetic oil filter for Chevy engines [VIDEO]
- Anyone use Speed Pro LW2256F30 Pistons?
- Starter
- Timing chain a tooth off?
- Tpis springs and cam
- 6000 rpm shifts
- Will OBD cord work?
- help on mods
- Cleaning Tops of Pistons
- Code 32 diagnostic
- 1994 Z28 AC Compressor
- Throttle body size
- Can a 396 be reliable ?
- Help - Starting Problem
- Ture dual 3 1/2" exhaust 96 transam
- Alternator Keeps going bad -3rd one in 72 hrs
- plugs
- Need Help with heads
- Replacement Radiator Question
- LT4 conversion timing chain?
- Need help with Oil Leak and Coolant leak (with pics)
- HELP! intake backfire and dead cylinders... No Bueno Baby
- pilot bearing.
- Blown head gasket
- Standard Brand o2 Sensors.
- Bad o2 sensor ?
- Numbers on the end of a GM847
- running rich
- ported heads.
- valve spring discussion, Lunati gold kit, Patriot extreme gold kit
- fan question
- Help with this trouble code.
- Need to purchase a new optispark or switch to conventional distributor. Where to go?
- Riddle me this......BAD exhaust popping under odd conditions
- 94 Z28 stalls while driving
- Anybody running low 11's or 10's on motor with a lt1
- Racetronix/Siemens Injectors?
- How to test the crank trigger and sensor?
- backfire/pop at low rpm's?
- Engine Swap Question
- ARP bolt torque vs Stock bolt torque......main caps....
- replaced water pump and now have a oil leak
- Ignition fuse keeps burning after I jumped the Batt
- Intake Nut/Stud question
- idle air control connector???
- 93 Throttle cable
- Intake Bolts torqueing
- 383 or supercharger
- torque specs for rod bearings ? ft lbs ?
- LT1 GUrus,, IS this Normal?
- Anyone had a solid roller Nitrous cam ground?
- Few questions on my build
- Intake!
- rattle sound from fron right valve cover?
- 93 LT1 Priming oil pump and motor
- Help with PowerMaster starter
- any tips for figuring out a miss fire?
- Another diagnostic tip for bad LT1 behavior...
- Roller Rockers w/ stock valve covers, and valvetrain noise...
- Kinda long, but I need help.
- no noise at idle ,but just past idle getting slight noise sounds like rod bearings
- H/C full bolt on lt1 with a 150 shot
- LS7 lifters with a GM 847
- i wanna get 400 ponies! help
- oil leak
- 3 wire 02 sensors in 93?
- new engine first start codes?
- installing roller rockers for the first time
- Help Please
- 93 z28 maf conversion
- 93 z28 overheating problems
- new motor first start... advice
- Dumb question - tranny overfill
- best cam upgrade choice
- Car runs alright for about a minute then dies
- Ses light on
- Rattle when deaccelerating?
- Rocker preload question
- NGK R5671-A7 spark plug issue....
- Bad motor mounts...
- crazy things happening
- flow numbers??? are these good?
- Need help making a decision! Should I do it?
- Stumble and pop?
- 96 camaro fuel smell in vents
- High RPM Miss Must Be Solved...With Your help!
- Any way to check opti out of the car?
- engine tick?
- 95 impala ss ecu/pcu
- Changing spark plug wires ?
- Backfiring and no power, any suggestions?
- Starter Compatibility
- Leaking coolant
- Car dies and restarts instanly at cruise and sputters....
- getting sick of this car!
- started her todaY!!!
- ATI superdamper Balancer Torque specs for center
- Radiator leak when idling...
- cam question
- idle issues...
- Thanks!
- making your own intake gaskets...
- Z28 dies and starts back up all while driving
- Engine quit while driving. 97 z28.
- Tell Dart to build the big bore LTx block already!
- LT1 Fuel line removal from intake manifold & engine removal questions--Need help
- Help!!!!!!!!!!! Datamaster File inside
- LT1 not starting on first try
- Heating up at idle
- dipstick issues
- $3900 for Longblock rebuild?
- Weird Throttle Problem
- Broken Manifold Bolt!! Uggghhh!
- Ticking noise upon start up... Goes away when warm...?!?!?
- Mass Air Flow Sensor DTC 48
- Maf?
- Help!! Heavy vibration at 3grand with a/c on...
- Manual Rack and Pinion question.
- 95 camaro z28 no oil
- LTCC directions? Anyone have a copy?
- Leaking water pump drive shaft seal
- cold air intake
- LT4 hot cam?
- 94 Z hub reinstall
- Proper fuel pressure for my car
- Decision Support Needed: Opti Replacement
- 383 cost
- 96Z engine/trans into 94Z
- What push rod for hot cam lt1.
- 96 LT1 into a 69 Camaro
- Can timing chain wear cause Check Engine light?
- 94 LT1 swapped into 70 camaro
- Throttle Position Sensor
- lt4 intake gaskets
- Just purchased a 1997 Z28...A few questions.
- Optispark questions
- PCV Valve Elbow & Codes 0174/0171?
- Where to vent optispark
- Cast iron head lt1
- Budget Rebuild
- Motor swap done.
- Help z28 is over heating
- Is this common with Pacesetter Longtubes?
- Ohm tested 22lb LT1 injectors
- Starter?
- whats this part?
- My 383 build
- Codes 26 and 32 on a 93
- Weird lookin stuff in top of throttle body
- 94 LT1 Problem HELP!
- 96 z28
- Headers?
- Multiple Codes: P0174, 0100, 0171, 0420
- Will a roller cam from gen 1 sbc work with a lt1?
- 1997 Z28 Overheating
- I need some serious help
- Guys remember me with my crazy story?
- boost vs. N/A
- Evap system & intake elbow issue
- what # injectors?
- Please Help problems with 94 lt1
- o2 sensor
- rough running/loss of power
- opti problems
- spark plugs burning uneven - Pic Included!
- Diagnosing LT1 Running Rough after Head Gasket Replacement
- Higher RPM problems.
- 1995 lt1 camaro header questions...
- cold air/ram air
- noicy lifters?
- 95 z28 running rough
- 95 z28 lt1
- Anyone know where I can buy just one poly motor mount?
- Bad miss after washing
- motor mount..
- PCV hose, can you help me find the part?
- what all needs to be done to run a top mount distributor?
- water pump oil seal
- head to block mating surface how clean
- New 383 Golen LE2 set up - couple of LT1 swap ?s
- ...discovery while setting rockers...
- LT1 to LS3 Swap with new gen trans
- SLP 1 3/4" headers for 97 dual cat cars
- Bad oil leak just happen...
- Swapping the opti this weekend
- Problem when accelerating hard
