View Full Version : LT1 Based Engine Tech
- Brake pads you use
- Rear Suspension Sags to Passenger Side
- Suspension
- Engine dip around 3400-3700RPM
- induction question?
- Please help me diagnose my problem
- Need Help!!!
- How hard is it to do this?
- Would a skinny work as a lightweight alternative to the factory spare?
- My reverse lights dont work 95 Z M6 help please!
- Bad cat
- Engine Miss at Part Throttle
- hatch light
- Burning oil...
- fuel tank
- Can all the crossdrilled, dimpled, and slotted rotors be cut like regular rotors?
- GOING CRAZY with the squeeks and rattles and creaks.
- symptoms of a bad fuel pump
- best rear shocks and springs for traction?
- My MAC single cat headers are on!!!
- Hooker LT's Custom made.... not a stocked Item?????
- Hooker Catback
- water proofing car
- Opti question
- Fuel Pump Install Problem
- 160 hypertech?
- installing hooker lts
- Will an LS1 muffler fit an LT1?
- Where is my power?
- Can a Tech Tool read opti res. pulse?
- Canadian Guys - What Tranny/Rear diff lube are you using?
- Help locating parts
- Attention Moser 12 Bolt Owners - Motive gears Installed Equals Quiet
- Going to the Dealership - Hesitation
- cleaning fuel injectors?
- Installing new Guage Face
- T56 manual and starters, just can't do it
- Arizonia Speed & Marine Headers
- exhaust too quiet? or just right?
- Removing A.I.R. pump system....
- Heater Core Hose sizes, also questions
- Oil or Dirty F'ing coolant system?
- Possible Bad Fuel Pump?
- EXHAUST in Col. OH
- What?!!? I have Cruise Control? Why won’t it work?
- Make stainless slp headers look good?
- What is everyone's favorite exhaust tips?
- what coil do i use
- what do u think?
- How long does it take untill a tranny temp gauge moves
- All my antifreeze poured out in a Target parking lot...
- ls1 brake swap...bleeding??
- Cat Replacement on 96 T/A
- Best aftermarket heads for GM 847?
- what timing set?
- accel 32 lb injectors
- Which fuel pump do I need?
- reprogram
- vavle cover?
- how much coolant?
- How good is Road Dyno?
- Gauging Interest - Race Oriented LT1 Headwork
- Auto-rx and wiper blades, where the hell can i get em!?
- what should i ask for my car
- Coolant leak... ?????
- whats a good bottom end??
- Milky White Junk?!
- I hate my car...WTF is wrong with it?(OPTI?)
- Gross HP, Net HP, and Rear Wheel HP
- Anyone Running the GM LT1 to LT4 Upgrade Kit?
- o2 sensor question
- TB bypass
- Trans problem 2: Knocking noise now gone??!?
- put a lil 2 much oil in car
- Nitto extreme drags aren't enough...time for e.t.'s??
- TTS Synch Problem
- How would a lighter governor affect my shifting?
- code 36
- lg motorsports "G2" underdrive pulley
- High beams don't work
- oil pressure sender
- RTV on header gaskets?
- Torquing headers
- rear cover ?
- Tach wire
- Starting up stored car...
- ARP 12pt SBC bolts on LT1 intake
- Service Engine Soon Light Came On
- 1993 Coolant Level Sensor
- Which head gasket?
- coolant leak...need help now!
- cleaning the heater core
- How tight did you torque your header bolts?
- Vortech Elbow Problems !
- times with bolt-ons!
- Rough running at low RPM solved!
- Perf and Handling Upgrades
- Whats ICL compared to LSA? need help with a custom cam
- Intake and head removal...
- LS1 Brake upgrade question
- Is it possible to switch the connectors for the speed sensor and reverse lockout?
- selling the HPP and getting custom tune
- bbk 52mm probs
- 383 Block Clearancing
- Post a picture of your rear T-top "pin hole"
- After Heater Core R/R AC Doesn't Work
- Fuel Pump died, which one to get next?
- removing long tubes for head swap
- Those who have switched to LT4 springs w/ 1.6 RRs
- crank pulley
- I have the 2 series carrier, will the 3 series gears work in it?
- Are long tubes a lot harder to install than shorties or midlengths?
- Almost done with cam install, couple questions??
- Fiberglass valve covers YAY or NAY?
- LT1 intake gaskets are HAZ-MAT through summit ?
- ET with this RWHP
- quick question
- Recieved my: Lloyd Elliot heads & Flow #'s
- what can cause my knock?
- Oil question
- pacesetter long tubes for 1993 cars
- Ultra Copper rtv around intake ports?
- 97+ tail lights on a 93-96 Camaro? How/what are the differences?
- exhaust fumes
- Want to verify I'm buying the right rings...
- How to test coolant system
- So what's in your A-pillar gauge pod?
- LS1 coils on a LT1?
- Why are my turn signals not working?
- Dynoed the Purple Car today....
- Do I have an exhaust leak? Please help!
- Fuel Regulator install
- 265 cid LT1
- Possibly the Opti?(yes, i've researched)
- Those w/ Elec WP experience, help
- Pantyhose mod
- Best way to remove a broken manifold bolt?
- Aluminum drive shaft or stock?
- Yet another LT and X pipe question, how did u attatch them?
- Lloyd Elliot Heads & GM847 Cam Dyno results!
- intake assembly problem??
- intake manifold repair - will there be fuel in fuel lines?
- O2 sensors; Bosch or GM?
- Smoke from AIR tubes
- Bad BCM
- Delteq's Opti replacement
- Cam rotation direction. Clockwise or Counter clockwise?
- removing heads
- Loud grinding / Whining Noises.
- Lt4 hotcam kit w/ stock heads, stock tune and spray
- Air/Fuel Ratio Gauge
- Alrighty then
- Good spark plugs?
- Tail lights!! Please help
- header bolts......breslin owns stage8!!!
- LT1 Info
- true dual ideas
- This is my third time posting and i NEED this before tommorrow!!
- GM Memo and MAF Cleaning
- Tranny Temperature Gauge Wiring help
- 95 LT1 - Crank position plate?
- Mufflex 4" sound clips - Spintech/Flowmaster
- CSI GPH vs stock
- crank pulley
- Crower RR
- Compression test results; Where should I be?
- Manifold (stock ) LT1
- Strong T56 Buildup
- Someone with a good AC system, need some help...
- LS6 cam in an LT1?
- Another question on Z rated tires, how long do they last?
- Cant get my slps off
- Car Making Noise When Turning Left
- head still leaks
- where to get flywheel to pressureplate bolts
- Single Cat Mindlengths for my 97
- Header gasket ?
- What does PI charge to restall a converter?
- help asap (head swap)
- problem with rockers and retainers
- LT1 Air Intake system converted to a LS1 style? Anyone ever done this?
- knock sensor reading 0?????
- Anybody tried to Mickey Thompson drag radials yet?
- best muffler
- Best Y pipe for Jet-Hot LTs and Hooker Catback?
- Need a quick Opti Plug wire verification
- Part # for Ram Air K&N???
- Bellhousing bolt thread size? (m6)
- M6 swap help
- Rearend problem please help!
- Mac midlength headers
- new cam and headers, what should i run?
- Plugging up the silencer hole
- Thinking About A Cam......
- Engine vibration only at 40-55 mph and disappear
- Speed sensor and car dying on long road trip!!!!
- Difference between stock Drive shaft and 1LE shaft ?
- Rear end swap out questions
- LS1 springs, on my LT1?
- How many times can an LT1 flywheel be safely resurfaced?
- POS 10 bolt!!
- Only Got 14.1 in 1/4 mile...dissapointed
- a few problems with my z
- Smog-Legal Headers That Fit LT1
- Anyone have pics of their Jet-Hot LT1 headers?
- 160 T-Stat
- Air pump system is blowing my fuse
- SBC in LT1 car
- Autotap
- Midwest Converters?s
- coolent temp sending unit (for gauge )
- goodyear serp belt
- Anyone tried different rotors with good results?
- Taylor Over the Valve Cover Wires
- What should my time be???
- Jet Hot LTs question
- LT1 differences between the years
- First Start-Cold stumbling...
- Am I missing anything?
- stock tire height
- Any good LT-1 technicians in DFW?
- Power Seat prob, need switch part#
- Coolant consumption?
- my car came with california emissions any diff?
- best cold air intake
- Loud Clunking after doing clutch/headers
- Anyone here using a "Direct Hits Ignition" system on their LT1's?
- Strange off-line bogging
- I need the tranny support nut size.
- Looking for sound clips of...........
- Do you need an instal hit for a Loudmouth on a 97 LT1 if...
- hotcam question
- Will memory reset when discon. battery?
- How to confirm Opti is gone?
- another flowmaster testomonial
- Anybody make a 1 7/8" Header Besides Hedman?
- Wanna build up an engine :-D
- 224/230
- Anybody With Impalla SS.
- gunk in fuel
- Connecting rod!!!
- --The LT1 Header Gains Thread--
- Help! No Oil Pressure when braking
- Driveshaft stuck HELP!!!!!
- More LS1 brake ?s, pics needed
- carsound highflow cat..
- Should I get a bullet?
- What are good Z rated tires for 17x9.5 wheels
- IS my engine heading south or am I just paranoid?
- stumbling at low speeds
