View Full Version : LT1 Based Engine Tech
- Serpentine belt keeps falling off
- How do I port the intake manifold to 58mm
- Anyone know HP or 1/4 Mile Time??
- Jethot LT + Hooker Y Clearance issues
- GM Part Number : '95 LT1 ?
- Backfires and no power
- where can i get a perty new oil filler neck/cap??
- broke fuel line[ need help fast]
- need help with trouble codes
- Safe to switch to synthetic
- Are the front O2 sensors used at WOT?
- Water Pump Install
- HP Gain with ????? mod
- how did you install your exhaust cut out?
- Oil FIll tube -- very loose why?
- new true dual pics under axle
- what does clutch chatter sound like???
- LT4 vs LS1
- Looking for th350 swap info
- Stereo just stopped working
- Hotcam Dyho Numbers (Mustang Dyno)
- Bushing help needed ASAP
- does LT1 intake fit LT4 heads???
- Anyone running Trickflow heads?
- anyone from OHIO want to help on my cam install?
- Can someone PLEASE IDENTIFY THESE ASAP!
- who said TB Bypass was easy??
- CAr runs kinda hot with a CSI
- Anyone using Hayden 404 Tranny Cooler?
- set valves now wont start
- first problem
- Who's done the LT-4 conversion ?
- Gas smell inside car ???
- Header hitting A/C line...
- cant get car to start!!!!!!! ahhhh
- opti spark question
- How would these heads/cam react to a 383??
- Just failed emissions HELP!!!
- Discharged A/C--Now what?
- Input Shaft
- pics of my (home)ported heads
- help! SES light on. scanned car but can't figure out code.
- I can't get to this ****ing bolt!
- Checking plug wires - Getting ridiculous readings, Help!
- Optispark broke at vaccum connection!!!
- elec WP question
- This is not good....Update on new motor/progress
- ordered from gmpartsdirect no part and no email response????
- cheapest place to get LT4 KM?
- head bolts
- Thinking about saving up for LT4 conversion. Need some input.
- 96 T/A missfire, whats the problem???
- Gas tank removal
- Mixing Valve Springs?
- Shoebox need to ask you something
- pics/sound clip of my custom true duels
- V6 to V8 conversion
- Is anyone experienced in designing a CAM?
- Cheapest place to buy....
- Balance prob...
- Please Help...Again....
- Going form 3 inch exhaust back to stock. Will I notice any difference?
- 10 mpg after hot cam
- What's your favorite final gear ratio?
- How come my A4 doesn't have first as an option?
- Oil level
- gears?
- Ring(s) bad on 1 cylinder & engine only has 25k miles - what are my options?
- Oil pan selection
- Stroker Kit
- Anyone know any free/cheap mods???
- DIY boxed LCA's and Panhard bar..opinions, experiences..
- Anyone know the Thread Size for holes on the top of the Intake Manifold?
- battery teminals
- Bent Y-Pipe
- Hotcam, do i need a stall?
- Egr Tube
- First header bolt, passenger side, #2 primary
- Optispark wire harness problem
- what causes arcing? Please help (brand new plugs and wires)
- What do I do about the EGR tube?
- low speed fans
- Not revving past 5500rpm ??
- Removing door panels
- Help Asap!!!
- How are these flow numbers?
- I need wiring a replacement sealed beam harness
- Stock Tranny Cooler?????
- exhaust hanger
- Ticking Noise
- Code 82 QDM or shift A solenoid
- Please help with header install ASAP
- Need some help
- Just replaced GM Tranny mount with Energy Suspensions Poly
- To much coolant
- Help! low voltage and abs light tripped
- Need Help
- Were To Get Headers
- First drive with the 227/233 Cam today - to the gas station
- Stock suspension, what hole to use on relocation brackets?
- Codes 32, 48, 64, may have found source of skipping and hesitation inside...
- CC306 suitable for a 396 stroker?
- tb bypass question
- security light blinks
- 93 to 98+ firebird nose conversion
- Torque Thrust 2's question
- Need Gm Part#'s
- How to replace lights in an auto car?
- Car went nuts and just died ! please help
- question for people with LTs
- Does mileage affect your performance
- changing coolant
- Changeing themp gauge sensor
- How fast should my car be?
- Wanting to buy lt1 got some questions(please help)
- accel retard box
- Who has an oil leak ? ?
- Throttle Cable Install?
- valve spring life with ~.600 lift
- Y-pipe
- Advanced Tech's, I am a total loss. Please help.
- Need help with replacing the clutch MC...
- K-Member Not Dropping Enough
- Burnt another wire
- llyod elliot email
- for test, can i turn on my car without installng the water pump??
- "Traditional" vs "XE" cams
- Headers and sensors
- torque spec?
- Running Rich
- Aftermarket steering racks?
- Will it be worth it?
- need advice on shifters (especially this one) please
- Dyno Numbers for SLP Shorties
- Another 4th to 2nd Gen Question
- Fuel pressure question....
- Questions about tools needed for opti removal
- High Stall no 1-2 shift
- 1995 LT1 Camaro fuel pump removal
- question about gmmg exhaust
- need to buy coil
- How to replace wheel studs?
- Installed Cutout!!
- MAF research
- valve springs
- Help: Cant Figure This Problem Out!
- wher can i get opti end terminals???
- Gear Ratio Question
- pcm idle
- Got to ask "what do you think it will run?"
- fuel pump check valve
- LT1 vs LT4
- Dual Springs & valve seals
- driveshafts
- Cylinder head removal???
- Ported throttle body
- How do i know if a used TQ is Good?
- Stock rockers with after market cam.....
- Service Engine Soon light came on
- Car won't go when I hit the gas.
- high idle???
- Front Lower Control Arm Bushing Replacement
- Picture of true dual dynomax ultraflow
- What setting??
- what locators for 987 springs
- Help;headlight doors open when....
- motor stumble
- DIY LT1 Porting
- !!--Car Problems after storage and new plugs--!!
- crooked stance, sway bar or frame?
- How are the 4.10 gears on a M6(few ques. before I order)
- New dyno numbers 439.2/403.9
- when is the stock MAF a restriction?
- Open headers sound clip of my Joe Overton cam!!
- running rich?
- theft deterrant relay
- Easy way to change plug wires?
- Rough Idle, and doesnt want to hold RPMS
- exhaust combo
- 3" stainless steel exhaust pipe
- ROUGH IDLE/Sluggish acceleration. Need help.
- Hotchkis or Bmr
- stock injectors ?
- feeling a little sluggish
- SCAT crank
- Best Long Tube Headers for the LT1
- Does BMR make Xtreme sub frame connectors??
- LT4 push rods part#
- Front Sway bar
- ABS INOP Light on
- What's louder: SLP 2otl, or Hooker cat-back
- Cat back shootout ?
- got my slp shorties in
- MY GVWR is 4200 lbs
- K&N cold air induction for traction control LT1?
- head TQ spec question
- Trouble Starting Up 500-1500
- Leaking from coolant crossover pipe
- OBd1 to OBD2 Tranny Convertion???'s
- dropping the motor out the bottom
- My coated pacesetter LTs are here!
- HID headlights
- Can a bad intake manifold leak cause a flutter/stumbling??
- Will 38 mm offset work w/ 17 in wheels
- Does this sound like a moisture prob?
- 160 thermostat
- 350hp and 375tq with stock heads possible?
- LOW IDLE!! Please Help
- Does this diagnostics scanner look ok???
- Strange electrical problem....
- Going to do some engine work soon and some help
- Opti and radar detectors
- Cars running rich. Why?
- spec clutch customer service
- What do you guys think?
- S.E.S. light
- Headers
- 5th gear problems.
- Car heated to the red zone for a second before I turned it off
- idle differences b/w park and drive
- Window
- Hard start when wet/moist
- I need help quick - Thermostat
- TPiS ZZX CAM IN STROKER
- How many qt to fill T-56
- IR cursed. Exhaust fell off 2x yesterday.
- well I guess I put too much coolant in after the cam install
- Idle problem
- 93 Guys and Those Interested
- new noise w/ trans mount
- Radiator Cap Part #?
- Soldering battery cable ends...
- I have video of my Coolant Leak...Need Help
- NGK Plugs
- DO i need my air pump??
- water pump is off but I didnt see any O-RINGS!!!!
- tire balancing question?!?!
- Which catback with your mac mids?
- engine coolant flush how to?
- Has a Stock shortblock LT1 every hit the Single Digits in the 1/4?
- light brown engine coolent?
- Knock sensor circuit error light help.
- Wheel stud for weld rims
- Subframe Connectors Needed?
- Light surging/fluttering @ 1.5-2k, very annoying!
- New engine is going.....but horrible stumble comes with it, I need some help
- 1.6 RR's
- Ideas for my engine rebuild?
- My car stinks...
- edelbrock headers--O2 extensions needed?
