View Full Version : LT1 Based Engine Tech
- O-ring Gasket Replacement
- Timing Chain Questions
- Does a 95 T/A call for posi fluid in rear end?
- Need some help with double roller and OBDII
- A sign of a bad opti?
- 1300hp nitrous kit?
- need pic or visual
- Opti Price questions
- o-ring for water pump and opt
- OMFG, please tell me my calculations are wrong.
- exhaust will this fit a 1994 Z?
- Urgent help
- EVAP (code P1441)
- Cut A/C line, need help reconnecting.
- Im Puzzled
- HP on stock bottom end
- HELP! ASAP water pump plug!
- traction via suspension
- ECT Sensor for temp guage broke off - part number needed! could this hurt anything?
- Made it to the track finally...
- DOH!! one keeper stuck half way down retainer
- Lt4 Conversion
- forcefedhighperformance.com
- What's wrong w/ my LT1!! (Starter related)
- best plug wires for AS&M headers?
- How important is a Knock Sensor?
- Front bushings stock, 1LE, or poly
- changed anitfreeze now overheating?!
- Z28 water pump/IMPY ss water pump
- Where does this connector go!!??!
- Anyone here use that Dynotune Spreadsheet???
- timing chain cover
- Got Hooker cat-back welded to my catless Y pipe + LTs
- Quick Rear O2 Sensor Question...
- SES Code P0400
- BMR bolt in lca relocation brackets
- Keepers won't budge.
- What rim should i mount Slicks on?
- new engine bogging
- Uh oh, ticking on startup
- Just got the car Dyno'ed...tell me what you think
- Best/cheapest place to buy a SPEC clutch online?
- GM 847 cam
- Differnce between 93-96 and 97-02 Side mirrors??
- paging jason cromer
- 93 Computer Troubles
- Finally found and fixed my low rpm under load stumble/flutter.....inside
- injectors ticking?
- Lokk what just arrived today...
- Spark Plugs???
- Doing the LS1 Intake and Airlid swap: Where do I get the Hose to do this?
- Need LT1 dual intank fuel pump
- Dyno/Tune
- Code: EGR vacuum not flowing properly
- part #/ cheapest place 4 94 nonvented opti and coil
- Lower alternator mount cracked
- 1995 Mac Headers on a 1997- Air tube problem
- New car new problems.
- 4.10's and a 10 bolt
- ABS INOP light came on?
- shifting so high with pcmforless?
- Got a new opti, where to get cap/rotor?
- low oil pressure
- Wow...I changed plugs on Jet Hot LT for the 1st time!
- Please Help!!!
- 11's?
- Crank hub wont budge!
- 1.6 RR install.....sorry....
- Trickflows New Heads
- 94 Opti DIY venting
- Free Mods?
- stoker kit on a budget
- 93 to 96 lt1 swap
- Newbie!
- a.s.m mono blade question
- Need Help!! Brake Light
- Cylinderhead Questions
- Comp. Trans Am
- Tech Pages
- RPM activated cut out?
- compression ratio
- 3:73 Gears How to tell?
- A/C compressor bearing making noise...unlubricated. what to do?
- Engine revs itself in neutral
- Those with MAC Header Exhaust Leak, How did you Fix it?
- Capping off EVAP hose???
- Installing Driverside Window, any diagrams, tips or tricks?
- rwhp??? out of my setup??
- Car Bogs Down From Idle
- Electrical Cutout Purchase
- cams and lope
- Brake problem
- weld in exhaust or just clamp?
- How would this setup run?
- afr heads and small cam?
- PM connecting rods
- HO2 Sensor
- Annoying rattle!
- part number needed (AC delete pulley)....
- Subframe Connectors - Bolt-on or Welded?
- Lt 1 polished electric H2O pump, Summit
- Oil pan install before timing cover?
- Email For Jason Cromer..???
- stumbling when cold
- Weld +skinny's
- What to do when stud spins and lugnut doesn't
- RWHP (how much do you think?)
- Having problem with the shift from 2nd to 3rd
- guide my AS&M header install please
- ?'s about swapping 94-95 PCM in a 93
- where to pu bullet mufflers?
- help diagnose steering pop
- Limits for Head/Cam Combo
- Do the Fans cool the car that much?
- fanswitch: done! but pcm issue
- Comp Cams TS224XL Camshaft 224/236
- LT install issue. Bolt hole needs tapped/threads cleaned up :(
- is this time possiable?
- Its finally alive again!!
- Driveshaft Length
- Help!!!! 15.1 @ 93mph
- My buddy said I could use his Wideband O2 sensor and A/F meter.... where to put it?
- Cruise Control
- Oh look, another cat back sound question: Hooker, Magnaflow, Flowmaster..
- Brake pedal and gas pedals
- 24mm rear sway questions..
- got a question for you all?
- Finished w/Pacesetter longtube install
- Question about pulling the LT1
- how to adjust cruise control cable on LT1?
- Infamous sun visors
- Cheapest opti?
- GM put out a bad bunch of opti's?
- Ported Heads
- Easiest Way????
- New best 9.57@140.10 all motor lt1
- FelPro Oil Pan Gasket: Use RTV or NO
- crankshaft hub seal repair sleeve?
- Low Track
- I T S A L I V E !!!!!!!!!!!
- Jason Cromers new address
- can a 48 mm TB be converted to a mono blade?
- Bosch or Lucas 42# injectors
- how strong?
- Rough accel/hesitation gets progressively worse when warm
- harder....headers or cam?
- Best programmer and chip for '95 LT1?
- jet chips suck
- Compression Test Results
- Belt problem after cam install
- Car is way down on power, any ideas?
- Which of these exhausts would you buy next?
- header gasket ?
- **UPDATE**Possible bad Fuel Pump
- Pulling crank hub.........revisited
- 93 trans line pressure
- mallory hy-fire vi q's.
- Starter?? turn key and nothing.
- About to kill myself.....someone help
- Want To Upgrade To Bigger Injectors???
- Rear brake question
- front main
- Problem! Vibration in the steering wheel
- Help Me!! i need to know if my diff is done
- Quickest N/A 4th Gen=LT1!
- elec waterpump gains?
- Which rocker stud to use
- Post Yo Soundclips
- #2 plug install with edelbrock headers...how the hell is it done?!
- heres some t56 swap help.
- Alarm honks after I lock... why?
- gm847 done
- how hot do headers get...and need p/n#
- "More Perfomance" Melling vs. RaceNet's Canton oil pumps?
- For those looking for gasket sets, I made up a helpful chart
- Timing Chain advice
- where to get....
- Project is done...MY GOD!!!
- need to remove oil cooler to get to oil pan
- Pinout for pcm..tach signal wire..adapter..?
- was the stock k member designed with oilpan protection in mind?
- Whats the purpose of this line??
- Golen Engines
- Fuel lines being a danger? (exhaust help)
- dyno numbers, are these unheard of
- What do you think of my future mods?
- Whats the point???
- 94 Z28 Police Interceptor
- LT1 Bolt ons and Exhaust?
- fuel injectors
- cold air induction
- stumble/breakup under heavy throttle after cam swap
- Plugs
- O2 Sensor Help Needed
- Found hesitation problem...how to repair o2 & misc wire harness to PCM?? (Burned)
- Dowel pin length from Cam Sprocket face
- Shoebox/Ingneer Electrical fire help.
- Ignition box
- Quick Question! Help Asap
- 95 and 97 throttle linkage differences?
- 96/97 SS air filter?
- What bites better.
- Vacuum lines
- computer programming
- water pump shaft seal on timing cover
- Motor Mounts
- Sound like an Opti?
- performance/budget engine rebuild
- Gmmg with gutted cats
- Powerband of a 230/242 or 236/242 XE Cam??
- Holley TB won't go WOT
- remove cats
- 1/4 times with my 383.....sucked.
- Puddle of water on passenger floor board
- How much race gas?
- My day of hell....need help fast...
- DYNO of THREE Z28's
- which fuel pump to get??
- hose replacements
- Intermittant No Spark, Cutting out
- after opti install
- Intermittant spark
- Please Help
- Backfire/Surge/Miss
- A/C Compressor question
- Anyone using SCE ProSeal head gaskets?
- future advice for all
- How to differentiate whats causing my ticking?
- cheapest place to get slp headers
- GMMG: LT1 vs LS1
- Get my to hook.
- questions about new car
- New Compressor
- Quick cam lube question!
- What kind of times should I run?
- Should I be worried?
- 1994 Heads
- Is this right??
- Removing the Cat
- what do I need to hook up?
- Should I buy a new MAF?
- Routing OTVC wires.
- Questions on Installing my trickflow elbow
- Installing a vacuum gauge need help
- help quick 1.6 rr prob
- TPS volts with closed blades.....
- Brake pad installation - do it yourself?
- BMR/Spohn parts install. Need Help. Please!!
- Added a few mods today!!!
