View Full Version : LT1 Based Engine Tech
- 96 trans am timing
- Possible exhaust leak?
- Opti cam pin length questions (did search)
- Power Shifting?
- Who has a Vigalante 3500 stall?
- how much should i expect to pay...
- Best place to get a lt1 cam on 110LSA????
- 1 stage colder plugs or stock?
- autozone distributor...
- stumble after cam - check out this DM file
- where will these mods take me?
- Is it the fuel pump?
- Hotcam Kit, Rate my track times!!!
- 4.10 gear ratio
- Monitoring Problem
- My Radio only goes off when pass. door opens
- White face guage cluster
- 3.73 gears
- Opti vent & vacuum hose harness, is this the right stuff?
- What kind of power will this put out???
- Converting to vented opti
- Help... ****** up parking brake
- 95 opti spark on a 94 (no spark)
- Spohn Drag Race Rear Sway Bar
- Koni SPA1 drag shocks on EBAY.
- Nos??
- Code 36???
- LT1 Z28 help
- rear end advice please
- 0 for 2 on Pass. side manifold bolts!!
- What's your dumbest mistake?
- plz help I think this body shop's trying to screw me!
- I blew a head gasket :(
- Rate my Tires
- Ignition lock cylinder problem...
- Whats the biggest cubic inch LT1 possible?
- doing plug & wires.. how do i jack motor up?
- Fastest LT1
- OK...WTH else could it be!!!?
- New fuel pump not cycling (Please Help!!!)
- soundclip of 224/230 cam?
- Intake question please respond fast!!!!
- LCA and BHB install.... torque specs???
- Possible lifter malfunctioning...I need some help here quick.
- Fixing to build up my motor...need your help
- GTP heads. Comments and suggestions.
- SLP Loudmouth Catbacks (Muffler)???
- MAJOR problem!!! Please help!!!
- Air bag #'s
- Lifters really nessacary?
- How to keep slip flanges from leaking...
- Replacing window motor??
- 1998 FENDER fit a 1994 ?
- good place online to buy wires?
- Harness test
- Spark is missing
- ordering my cam today, which 1?
- Coolant Temperature Sensory(Pics) in Water Pump
- Could worn out lifters or even damaged ones...
- Question about tuning and who to go with??
- Longtube Exhaust suggestions
- Can an LT1 motor and 4L60-E be removed together?
- Could I do this?
- Radiatory Question for LT1 swap?
- dtc 29 & 84 solved, but how?
- Descreen MAF? IAT Mod?
- Quiet Even With Headers
- Stock converter and tb?
- 17x9.5 wheel, tire suggestions?
- Blew up my rear end. What are my options?
- new times
- Oil pump? Shoebox??
- pushrods on a decked block
- Will 325/50/15 drag radials fit?
- Sound like opti to you guys?
- Can a stock OBD2 PCM run a OBD1 LT1?
- Window Motor
- Axles?
- CAGS help ???
- $2000 for 94 T/A Formula
- 93 diagnostic "paperclip"
- Anybody tried this?
- What The Hell...changed Opti And Still Having Problems!! And Now Rattling Noise Also
- Just finished headers..now what?
- (Fuel pump) Purpose of bucket, and other questions
- fuel pump gone bad?
- what slicks/rims to get?
- Roller rockers
- need wiring help quick please.
- Roller Rocker help
- Lowering My Z
- HEAD LIGHT KITS? where can i get em, i just crashed 8-(
- Fried + bat. wire to alt.,, shoebox part #?
- how many mvolts are o2s ????
- Car wont start
- Help, TA problems!
- best cam for stock motor?
- Need help with WBA
- I just changed the rear end and manual transmission fluid with Redline...PITA
- Need help mounting crankshaft position sensor exciter ring
- headers! headers! headers!
- Throttle question
- Best place to buy Borla or Triflo?
- Where to get race tranny?
- Sweet Injector sizing charts that I made up!
- ...whats a lt4 knock sensor...
- a question on how the wiring for the starter goes
- Have an XE 224/230... should I upgrade again?
- when your OPTI goes, does it.........
- 300 hp?
- Longtubes installed now I have some ?'s
- Website for LLoyd Elliot?
- 2 vacum issues
- What to look for in valvetrain for something wrong?
- Mufflex ypipe, what's the diifference?
- How to get the alternator Fan off???
- Intermittent SES
- Will a bad o2 always throw a code?
- 1.7rr's on stock motor
- door mirror replacement
- header leaks??
- Getting Dyno'ed...what do you think?
- Gear install prices
- Summit oil pump problem
- Crank hub differences
- Fuel injector sizing
- Plugs & wires
- Front grills..
- top throttle body gasket?
- How can I tell if my spark plug wires are bad?
- SHOCKS, balljoint's, Tie rod ENDS ALL THIS WEEKEND..any tips??????PLEase
- Need some OBDI/Cloyes issues resolved..
- Welding a motor mount, electrical damage?
- SLP 2OTL install ? Help please, hanger ????'s
- Balancer hub bolt hole stripped, what do I do?
- Swapping parts from OBD1 94 LT1 to OBD2 96 LT1?
- Running rough. HELP!!!
- po100 : Mass Air Flow (MAF) insufficient signal activity
- top speed
- tranny fluid and me
- plz help me i need to get to work!!!!
- Should I go with a Y Pipe?
- some part numbers
- throtle body bypass
- How many MPG are you guys getting?
- Dash rattle fixed!
- Location for O2 sims
- Going to change oil sending unit do I need?
- Bad fuel filter
- Solid Roller or Hydraulic
- Comp Cams factory replacement lifters good enough with LT4 Hot Cam
- Tight Crank to Cam Sprocket Clearance?
- Is my Opti Done? Have picture...
- Odd problem car wont quit cranking
- part number for stock GM lifters?
- blow by
- O2 readings
- Oxygen Sensor Socket
- what kind of voltage does the fuel pump get from pcm and when?
- What fuel pressure?
- Where is the company who sells LT1 to LS1 front clip conversions?
- rpm problems scarred need help plz
- Lingenfelter Ported LT4 Heads
- Help me pick a cam...
- Engine smoking!!!!
- Are Super Rams benificial to LT1's?
- EGR please help !!
- What's the best way to do a leakdown test ?
- Rich? Thick black residue?
- Which year LT1 would you buy???
- Anyone have the chance to install those new Pacesetter LTs?
- anyone straight up removed baffles in valve covers?
- Mild heads 1.6rr but stock cam.... shooting myself in the foot?
- Another "what's it worth?" post
- Help! car overheating
- Which head should I get
- 1.6 Roller Rockers
- Tapered crank?
- All problems fixed...wheres my performance?
- custom cam with stock lt1??
- Solid Roller Duration with 383?
- Car won't idle, already replaced IAC
- longer spark plug wire for #8 needed!
- question about cam install
- G2 Cai?
- car wouldnt start, fans or pump turns on???
- What else would I need...
- timing chain; which one?
- Replacing Opti?
- 383 conversion problems~!
- Mods & 1/4 Estimate?
- Full hooker exhaust or true duals?
- Help! rskrause, madwolf, Injuneer, Live for TAs
- engine diagnostic codes
- anyone ever put 94-95 headers on a 93
- How streetable (feel) does hyper have over forged internals?
- what gears do i have?
- forget the cam, heads
- Reprograming the fan
- weld on relocation brackets
- mac headers
- what can mix-n-match between lt4 and lt1
- What is it capable of ?
- How hard to build my own engine...literally...
- Is is possible to get crank hub off w/out air tools??
- Pings
- What Should It Be...?
- air bag?
- Idle adjustment screw
- help, Oil pump change suggestions
- which torque arm for me?
- 396 update. I need some more advice
- removing #8 spark plug with AS&M headers - impossible, need help
- is the 360$ opti come with cap and rotor.?
- SLP Loud Mouth
- Trick Flow head Idea????
- How much power will this setup make?
- Occasional Stumble Weird??????????
- heater core shot?
- Where is my Opti?? Anyone have a picture??
- vaccum
- Timing chain and cam dowel pin orientation
- I Hate The Stumble!!!
- Hawker PC 545(10.8lbs WOW)
- Removeal of motor
- TB By-pass question??
- ls-1 valve springs on lt-1
- Buttery popcorn?
- BMR w or w/o hardware?
- Hard Start Idle Air Control Valve?
- Questions about flywheel
- Does any parts store carry the rag joint.
- HELP Hub Problems!!
- Pass Headlight Keeps Burning Out
- Will you lose any power dual cat to single cat
- Ktre ?
- Cheapest Hookers?!?!?
- New Member Question: Anyone Know if Ion is Available?
- Still misses after opti install
- Are the LT1 Core supports differnt from the LS1? Trying to do intake swap.
- 396 head flow numbers-need some advice
- Torque converter questions?
- Fully Ported LT1 heads and GM847???
- calling all GMHTP LT1 shootout members!!
- Is my oil pressure bad?
- Can I relocate my opti vent? Trick flow Purchased
- cc306 or GM847 cam???
- Wiper Problem
- Code 48? MAF sensor circuit....help
- build #s???
