View Full Version : LT1 Based Engine Tech
- Best way to Bleed Brakes?
- curious about flowmaster sound clips?
- adjustable fuel pressure regulator?
- running without o2 sensors?
- Why is the non vented opti more than the vented opti?
- Clean A/C compressor or power steering pump in solvent tank?
- descreen the map sensor
- Porting 58MM TB
- problem with 1.6 roller rockers...
- 1.6rr's...all the same?
- 95-97 Opti on a 94?
- Looking to enhance my power, if you will
- Any tricks for finding a rubbing exhaust?
- what should i get for my lt1
- EGR tube to header gasket?
- 1LE Elbow ... Any proven gains ?
- should a 2000 gt mustang be able to?
- Which Headers?
- M6 OBD1 Computer Question
- I need a picture of a PCM..
- Bottle to spare conversion
- thottle body problems
- wheels
- starting problem
- What brand O2 sensor to get?
- Making sure im not missing anything here...
- MAF screen removeal
- Madwolf Programming
- Dark Brown water in coolant system ?
- Fuel in oil Question
- Carrier Size 2 or 3
- C5 brakes and WS6 wheels
- Meziere pump hot to the touch
- Anyone with an Aftermarket Y-pipe
- In a non vented opti....
- Where is my power?
- Weatherpack for 1997 MAP
- Car troubles
- Difference between LS1 and LT1 muffler?
- 97SS, or 98z28
- Everyone with MSD 6A or 6AL inside, please
- Aftermarket alternator to allow tall valve covers?
- Where did you get your X pipe?
- Help Me Please!
- looking for lt1 exhaust sound clips
- Question about coil
- keyed hub install
- cutting OTVC universal wires
- LTCC Manual
- Hooker Long Tube PN?
- No Spark
- Install Help: TransGo / 1LE DS / MSD Wires / Fan Switch
- Computer causing opti code??
- No whine/noise from gear drive install, should I be worried?
- Belt size for march crank pulley?
- Lt4 Hot Cam
- Anybody use a Flowtech x-pipe???
- Quiet exhaust?
- has anyone tryied the splitfire plug wires?
- brake rotors
- Cam install costs?
- 11.5" slicks will these fit???
- Has anyone welded the drivers side MAC shorty?
- how to tell if 02 sensor is bad?
- Long Tube Installation?
- Fuel Injector Size???
- Sbc Lt1?
- Shattered Piston Rings?!?!?!
- Anyone have a street driven solid roller?
- GM Color code for teal blue?
- Need help FAST!!
- OVC wire looms and wire's
- mods
- better coupling for space between CAI and stock elbow
- New track times with Pacesetter LTs
- where can i buy a grill for my lt1 "Chrome"
- Plugs, big difference????
- Going to the DYNO in the morn, what should i expect????
- Att: Injuneer/everyone else....Here's my car's scan
- Temp. Fix for Opti Problems (Moisture Related)
- witch is the best on a A4 2.73 or 3.23 or 3.42
- Which CAI is better
- Max lift for stock springs
- Finally have the full exhaust totally complete. Yeah!
- Get bent
- Anyone replaced your fuel pump lately?
- heating/coolant problems on 95 z28
- Can a beginner tackle a Hotcam kit install???
- LT1 Head bolt same as regular SB?
- Car missing, Passenger side
- bad bog
- solid roller lifters, oil issues?
- MSD Part Number
- question..
- Radiator Fan switch install...weird problems, HELP
- Two piece timing cover for LT1?
- Which O2 sensor??
- Any way at home to get a tire off a wheel?
- got a clip of my LT1 w/ new heads, cam, gear drive, rockers, lifters and more
- Running Rich
- Why is my car running bad?
- New Found Lost Power, No BS!
- Scanner Question???
- Did I get sold the Wrong NGK plugs?
- Overheating!! Cant figure it out!!
- Need your help guys....
- Please Help on CAM Selection
- Changing lt1 plugs
- Dose Anyone Know if A
- Lack of power in upper RPMs?
- Car won't start,
- Video clip of my heads/cam setup
- Power seat
- Finally back on CZ28!
- Anyone with pics of 01 10 spoke SS rims on a TA?
- Seafoam and other cleaners...
- 95 z28 with lt4 cam 1.6 roller rockers need spark plugs
- flowmaster pulse tech scavenger collectors????? 15hp???
- CSI leaking
- doggy and vibration in 4-6th gear-is this engine or drivetrain?
- Magnaflow Exhaust ???
- quick question, need help (only car to drive)
- Free Mods
- How much to port and polish lt1 heads
- Running with just opti connected
- Broke a wire what is it?
- Oil not getting to the top of the heads.
- Having problems starting car.
- Corvette Rims on a Camaro
- Do I need?
- Spec
- Motorvac carbon clean before or after tuneup?
- break in?
- new cam break-in time
- Battery relocation problem (ground)
- 340 rwhp & 365 rwtq from new 383 stroker!!??
- engine serial numbers
- Need Answer Quick- Weight Of 4l60e!!
- optisparks for 20% off summit price
- Free Jet Stage 2. Should I throw it on?
- Lakewood LCA's
- HELP! Where is the fuel pump relay?
- Throttle Position Sensor
- Umm...why do I have oil in my exhaust tips?
- Lucas....
- Anyone tried programming out ALL of their oxygen sensors?
- Any experience with the cc306 cam?
- Air bag and HVAC Removal
- Can a GM847 cam work with an a4?
- 11" tires in rear 9.5 in front
- 93 Camaro Z28
- Let the fun begin
- ANyone know if a LS1 will fit under a OEM SS hood?
- Urgent Help ASAP! Please....
- Splayed 4 bolt main, dipstick wont fit.
- Holly Stealth Ram Motor in a 4th Gen
- Which to do first?
- problems at W.O.T.
- Gas Milage with LT4 Hot Cam & ? on Install
- Back Firing/Popping from Exhaust
- cam install vs. engine rebuild
- Anyone have one of these leak?
- Car still not driveable after heads/cam
- ZR1 wheel & tire size? How Big?
- engine fans
- Need an answer fast please!!
- Copper Seal Head Gaskets, need a retorque?
- Racetronix Pump Install... AFPR Needed??
- How does an SS Air Box fit on the LT1?
- Starter or battery?
- OVC wires and SLP headers
- Me or a 2000 Gt
- 97 30th aniiv. need help
- 350-400hp ?
- Some one help me with this code.
- 17 x 11 wheels fit with modification?!?
- Can I???
- Need Help Asap! Wtf Do I Do?
- PCM 4 Less HP Gains??
- AutoXray Capture Results
- Porting Heads
- X-pipe H-pipe Crossover on True Duals Why???
- Fuel Pump Replacement
- crank hub bolt length??
- yet another holley TB issue
- cam selection
- spark plugs?
- my new problem (drivetrain)
- will this be the cause of my miss? pic inside
- How much lower of a time if...
- Cat back sound clips
- 160 thermo
- quick yes or no question
- well i blew the crap out of my opti
- IT STARTED!!! (Does the happy dance)
- SHOEBOX: I unhooked the right vacuum lines right?
- Header primary touching brake line
- clutch choice
- plug gap and type on 12:1 383 with MSD
- Anyone know this guy?
- How are OVC wires routed?
- Timing cover gasket question
- 383 Piston Selection?
- LT1 Alternator Relocation Bracket is DONE FINALLY
- Which gear should I buy? Please help!
- what brake fluid to use?
- will these 3rd Gen rims fit my car?
- Part # for accelerator cable??
- Does anyone still port throttle bodies??
- worth goin to Gm847 from XE236/242?
- So me and this LS1 kinda played around.
- Driveshaft Balancing
- Electric waterpump install tips
- IS it worth it
- coolant temps low with FAST
- Those with Comp "R" lifters, please help!
- HELP car won't run after cam install!
- How nasty is the HOT CAM with gas mileage?
- GM replaced the oil filter!!??
- Burning out....smoke was coming into the car
- o2 wiring.
- Gonna run the new cam tonight
- My AC switch is acting funny..Advice needed..
- Guys with 383 Strokers...What TB are u using? 52mm or 58mm?
- Torsen take out diff?
- Is it true you can use LT1 knuckles for the LS1 upgrade?
- brake line bending
- Has anyone switched rear ends?
- high Idle!!??
- boxed or tubular
- How do I plug the exhaust port on the rear of the intake?
- When I hit a bump, my interior light turns on...
- Bore TB or buy new
- are these injectors compatible with lt1?
- Which brand is better.
- Thanks for all the help!
- What other suspension mods?
- Weird stumbling...
- vacum line undr the TB what does it do? i broke it
- starters 93 to 97 camaro / 9* impala/roadm
- A4 tranny
- degreeing a cam
- 58mm tb problems
- 1 3/4 Slp
- Anyone running the Comp 915 beehive springs with a CC306 cam?
- Cam or no Cam?
- Tci Ssf3500???
- best fuel filter?
- traction?
