View Full Version : LT1 Based Engine Tech
- Is it worth doing forged pistons without the rods?
- Heads/cam LT1 feeling low on power...help!
- how do i gut a cat....not the animal
- Anyone have the Hooker shorties? Question about o2's
- am i getting reamed on prices?
- Ok pulling out hair time.
- New to the forums..
- Jason Cromer New Phone#?
- Stock TB Porting.....
- Will a bad EVAP cause a no start
- tb air foil
- using MAC Starter pipe with stock CAT??
- Where to get OBD1 codes scanned?
- Need a good machine shop
- My LT1 finally did something right...
- stock z28
- Which one do I want?
- I need some part numbers (tried downloading the manual but my pc wont do it)
- natrually aspirated or super charger
- Where is Fuel Filter???
- What Does She Run!!!
- Fan Wiring Question
- Cam and heads
- intake manafold gasket
- 1.6 and 1.7 rr's in the same engine?
- Everyone with PaceSetter LT's ... What do you think ?
- The Pacesetter LTs go on FRIDAY!!!
- O2 Sensor locations? Quick Question
- Help me build by true dual exhaust setup!
- y-pipe question
- What do I set the rev limiter at?
- I GOT 5000 DOLLARS !! ! Need to fix a few things then...
- SVO Injectors? Stock Replacement?
- Can you change out motor mounts in the driveway?
- 52mm or 58mm Throtle body?
- bore or lt4 manifold
- How fast can you safely spin stock internals?
- What is "lobe separation?"
- 400+rwhp thru stock 3.42's
- TN-227XL 227/233 duration, .560"/.569", 112lsa
- LT1's here I come
- adjusting rockers while idling
- oil shot out of dipstick...
- car running bad after cam install, help!
- Need help determining pushrod length
- horsepower question
- Disappearing coolant
- car not starting!!
- Best place to buy short block???
- lt4 conversion
- Car started stalling....PLEASE HELP!
- gm847 parts?
- ngk plugs or shold i get different?
- Need tech help, FAST
- simple manifold question...
- tranny temp gauge
- 383 Crank shaft compatabilties(newb)
- anyone dynoed a cc305 with stock heads
- Fog Lights
- 94 z28 unfixable problem?
- Panard rod bushings
- Seat Question
- Snap-on Scanner results
- replacing coil springs on LT-1 ?? I NEED ADVICE
- Taylor wires w/ LT's?
- anyone know where i can pick up some crocus cloth?
- Cruise Control and Bulbs
- Doing head swap:will it run before reprogram?
- Max rwhp on stock 24lb injectors?
- What's this? Opti?
- 700R4 Won't shift!
- how do you tell if your MAF is fried?
- Low Oil Pressure, Please Help!!!!
- LT1 underhood fuse block ? quick!
- How do I properly BLEED my new MASTER CYLINDER...
- Need Y-pipe Fab....
- RPM Stumbling, Hesitation when warm. Is it the OPTISPARK?
- Rattling sounds when shifting
- Who Makes A Y Pipe For My 96 Z With No Cats
- Hit speed bump now SES light is on...
- What happens with a cam that has a small LSA?
- 4:10's????
- Service Engine Soon
- intake oil leak/oil pressure
- PCV question
- suggestion on belt
- timing cover and seals question....
- Dissapointed in new times, does this sound right?
- Chicago Lt1érs inside..
- Stock LT1 dyo2k file?
- Shims/Seats for K-Motion K-800 valve springs
- Can you repair header primaries?
- Bodykit is on and the car is getting hot....
- just finished the true duals over the axle with bullits
- would you buy used rear gears???
- Stock Elbow?
- Just got my FIRST Camaro!!!!
- help with waterpump and pulley!!!!
- Aftrmarket Tach. just stoped working??
- Knock sensor code 43 problems
- K-Motion K-800 valve springs (Atljar)
- Oil Pressure gauge not working
- no start. Electrical problem.
- What Heads should I go with for my application
- Looking for a STOCK LT1 dyno chart
- Engine squeal
- whats that sound
- removing air
- Best LT1 Rebuild Gaskets
- Best Header Gaskets?
- Best for torque increase?
- Car finally cooperated (head swap)
- Where should I program max RPM?
- oil cooler
- 97 SS hp/tq numbers
- LT4 cam?
- Anyone remember Part #s catalog download web address?
- Dynoed Today and MUCH better #'s "kinda long"
- Cold air temp vs Warm air temp
- P/n
- Can I buy 1 rocker arm 1.6 gm?
- Dyno #s, What is up
- Attn: those with 1LE intake Elbow
- GM 847 PPL, are you satisfied with your cam?
- Another Roller Rocker question
- Quick question about removing the AIR system...
- header wrap??what to hold it on??
- What are the typical problems with the LT1???
- How much milling to hit 11:1 with Impala iron-head gaskets?
- i dynoed my car...
- Horsepower guesses?
- Injector ??
- Roller Rockers for LT1
- What angles for 3 angle valve job?
- Need more vaccum??
- Miss and Detonation
- 1" or 3/4" Stage 8's?
- Friggin Check Engine Light
- Golen Engine Service???
- At what RPM, does this cam make max power?
- swapping opti spark
- Need Extensions for MAC Headers?
- Need help. Tapping nose under car.
- Descreen MAF?? Yes or No?
- Injectors for 396 Stoker
- Joe Overton Cams
- No Speedo, No Reverse Lock Out & No Cruse?????
- MSD Digital 6 problems?
- oil passages in block
- Nitto NT-555R Drag Radial Tires
- Oil Pressure dropping at WOT
- "Ain't Nobody Told Me Nothin'...I'm ordering 1.7RRs
- when doing heads and cam....?
- lt4 intake mainfold
- Got a bad vibration, help me please!
- csi install ?
- what would be best gas milage wise--read
- Cat delete pipe
- engin instaall an bottom pully
- Can I have a cam made like a CC306 but with a 110 LSA?
- Msd
- What size K&N filter works on a 3 1/2" CAI?
- Car revs by itself
- Can stock oil system support 450rwhp ?
- Crazy PITA misfire...need advice.
- Installed new fuel press. reg. now car wont start.
- cat or no cat, gutted or hi flow
- check engine light came and go,,,whats the deal?
- Guage Help
- open loop and closed loop
- Question about extending O2 sensor wires...
- dis for lt1?
- Passenger side rocker panel
- MSD 6A improvments?
- Help friend
- Going to true dauls, but what size exhaust?
- LT1 in an '80 Camaro
- Which Long Tubes give the best ground clearance ... This IS my last ? Sorry ...
- Crane Cams PowerMax2050?
- what usually breaks on an opti?
- Lt Header Poll
- headers...just how hot do they get???
- Anyone with dyno results from LT's ?
- K&n Cai
- Any good starters out there?
- throwing code 32, egr code
- Whats a good exhaust with the TPIS LT Headers and no cats?
- intake manifold
- injectors and plug wire noise
- Need help with Accel injectors
- Engine Sensor problem.
- Need Help
- MAP wiring harness problems! Help
- More performance ... anyone dealt with them and their Y pipe ?
- Sound Clip of Stock vs Hooker Catback with MAC Midlength Headers
- What do you all think about this CAI on ebay?
- Need pic of 93 IAC...
- will a 3rd gen rear bolt into my car??
- oil leaking from bottom of slave cylinder
- Stock LT1 specs?
- Will reseting my Pcm mess with Pcmforless or dynotune
- cam/exhaust eith emissions
- how to reset PCM? dark soon help!
- Bad Alternator Cause Power Loss?
- hooking up rev. lights after auto to m-6 conversion?
- RPM drop
- where does this hose go
- Got a problem with car, need help!
- Pin length on camshaft
- New combo coming up...opinions?
- short catalytic converters ... ? length wise
- Ls1 brake conversion
- what wire for ACC on switch??
- steering shaft
- cheapest place to buy a radiator?
- what should i run
- tubes in slicks or not
- TB By Pass Question
- Motor will be out soon, what should I do while it is out?
- What causing a spun bearing?
- Whats wrong with my car??
- Everyone with longtubes, please read ...
- Shifter cable help
- Tps
- somethings screwed, what is it????
- EGR Malfunction??
- mechanic cant even figure out problem with my car
- rtv the oil pan
- 1994 z28 Build numbers
- Rich only in the rear cylinders
- Agostino Night Two
- Water pump removal...
- HELP! SS air filter part #
- Quick question about oil pan
- Stainless Works Y-pipe
- best heads out there....
- Has there been a recall for the Air Pump on the LT1?
- Agosino Nightmare One And Two
- What Will She Run?
- I want to do 1.6 rr amd springs but know nothing
- GM847 question...
- speedometer unacurate
- Update - Hesitation Fixed: Solution inside
- Too much oil?
- What should I run in 1/4
- Cheapest place for CC306????
- Cheapest Place For EGR Block Off Plates & AC Delco O2's?
- Universal X-Pipe
- LT1 optispark Usage
- How to get manifold AIR nut connections off
