View Full Version : LT1 Based Engine Tech
- Not A Good Start
- Went to the Track. What do ya think?
- First time ever to the track
- question for any one that knows air/fuel mixture issues
- High Mileage Motor Oils.....
- Walbro worked for 2 days
- camshaft pin question
- Initial thoughts on GM 847
- 383 tuning questions
- Wide band dyno tuning
- LT1 Headers w/more square then D port
- GM847 and 1.6's
- where does teh wires that plug into the MAP sensor go?
- Thinking about going with true duals...
- Is it possible
- mufflex catback part # for dual cats..
- runs bad after 10 mins, low oil pressure problem?
- 1995 LT1... OBDI or OBDII ???
- Off Idle stumble/Rich after head gasket install?
- Ignition problems.....
- nasty stumble
- Car won't stay running please help me out....
- Air not working
- Car would not start and now will....
- Code 48 - MAF sensor circuit
- Wtf...?
- larger injectors needed for a 227/233 cam?
- Is this normal Oil pressure
- making a shoppin list.....build me an emissions compliant nasty LT1
- Help me!! Car is stumbling at WOT and backfiring!!
- Removing AIr on OBDII car?
- calling all 227/233 cam'ed LT1s
- New to the LT-1 gang....?'s about making 375hp
- Spark plug check
- EGR valve problem
- Vids of tanners car or other 9second fbods...
- Rear main seal or oil pan gasket?
- i think i figured out how to get rid of the HI RPM MISS atleast on my car
- What new motor for my '95 z28?
- Injector Duty Cycle hitting 104%?
- tb air foil problem
- Has anyone actually -cured- high rpm miss with opti replacement?
- Tach jumps during high RPM miss... clue?
- roller rocker adjust ment question... did the earches... need to know ASAP!!!
- New cc306/heads dyno #s!!!
- Need help!
- New Times: Great Work by Gearhead Garage in Gilbert AZ!!
- dyno tuning
- My gas in the tank of the Z is "Boiling"? Scary!!
- DTC P1371 Please help.
- Couple Questions....need answers!
- heat problem
- y-pipe
- Scanmaster reading help please
- TPIS ZZ9 cam, too small?
- replaced all ign. components, still no spark
- o2 sensors. freescan log
- Here's PROOF on how gearing will affect your cars times
- Might buy z, need help w/ some ?s
- Is this the correct Part Number for the Front O2 sensors?
- Starting Problem, think fuel related.
- engine build
- raidiator question?
- AIR pump & true duals/cats
- Anyone know if the Delco-Remy CS-144 alternator will fit on our cars?
- Hooker LT Exhaust leak?
- Loss TQ with 4inch Mufflex?
- question about new LCA's
- What Is Needed For Air Pump/EGR Removal Mod?
- 93 guys with 383s, what O2 sensors are you guys using.
- Lift or Duration
- HOT Cam Experts in here!
- Did I screw up my exhaust?
- cc306 and lloyd heads guys inside (tuning ?'s) probs also
- The finer points of true duals....???
- lt4 afr 220 what spark plugs ??
- Delphi/Lucas vs SVO
- Do I need a tune with this cam?
- Header gasket and bolts
- High RPM stumble, rev limiter???
- Burn the valves????
- LT1 camshaft wear....
- air fuel guage
- tryin a new approach to the age old question of what makes an LT1 miss and hesitate
- LT4 Knock module tech question....need info please
- Difference between 93 o2 sensor and 94-97 sensors
- Bosch 02's
- installed hypertech 160 stat some questions/problems??
- Head Gasket thickness?
- gas mileage
- Bad ICM maybe?
- Urgent Stock Computer&comp Cam
- Want more Lt1 knowledge
- oil leak
- O2 sensor diagnosis help please
- Miss while crusing?? This is weird
- Where did my 2 quarts go????
- need help hart to start / wont start at all
- header leak
- Dealorship says there is not LT4 Knock module
- fuelrails removal
- timing set off one tooth!!!!
- CC306 cam Identification numbers
- Pacesetter LT's
- Pilot bushing help (need part number, can't find one)
- no low speed coolant fans...
- Question about Taylor plug wire set for LT1
- custom ram air on a formula
- Need Help Fast PLEASE!!!
- searched, no lights no relays (CSI)
- MAP problem ???
- How do I keep the crank pulley from spinning
- Coolant fans keep turning on, why?
- Fixed
- Spark Plugs???
- How To Test ECT?
- True Duals
- Next Mod. (SUGGESTIONS).....
- Weird Noise coming from the Optispark...
- Header Questions
- Speedo Correction
- Noisey lifter?
- Omg...stumble Solved!!!
- Help with estimate on engine builders cost
- Upgrading cam-Can i get bye with--??
- Quick Question Here...
- Wont Idle, Help please
- Problem after cam and opti swap
- need help on instructions for installing cyloes double roller
- 9.3 stock, 9.3 hotcam with blown head gaskets and burnt wires, 9.3 fixed lol
- Help!!
- Buying stall converter, what RPM range does the LT4 Hot Cam operate in?
- Hi-Flow cat question. Hooker shorty guys can help here.
- Mild Power Combo
- Best place to buy CSI WP?
- Anyone maybe shoebox have a pic of a headlight mounting bracket?
- Do I need to attach/support a new cat to the frame?
- Torque specs
- 847 with emissions
- help launching my car...
- Need Help! Please! Read!
- WTF!? Look at my MAP sensor!
- Optispark... OR VATS Module???
- 3/5 Lugnut Studs are BAD!
- can someone post a picture
- WTF is wrong with my car? SOMEONE PLEASE help!
- With all this talk about spark plugs lately
- OVC or Stock routing
- Routing plug wires
- Wiring diagram
- Rear Bumper Support Removal
- probably a stupid question, but
- What I thought was my ignition switch gone bad ended up being...
- Piston choise
- reinstalling crank hub and pulley, few questions?
- found something odd inside the intake
- help.. dont know what gears i have...
- question about slp headers and gaskets
- Cylinder 3 misfire Code #po303
- how much whp???
- Fuel pump making weird noise....
- am i at 300rwhp???
- Modifying waterpump housing? (could save your opti!)
- Need Cam Help
- thanks for all of you that help me!!!!!!!
- hooked starter back up and now its bein stupid
- lt1
- lt1 swap
- Friggin Emissions HELP!
- Casting numbers ?
- DYNO #'s where should i be at?
- Coolant won't flow...
- 1le
- Missed Shift help
- Car wont start/everything replaced/possibly fuel pump?
- header bolts
- $600 to burn, What should I buy?
- SLP Loudmouth
- Would an H pipe affect performance/sound that much compared to a X pipe?
- URGENT! need some help figuring this one out!
- need help very short. this is after opti install
- IAC testing?
- How do I reset the low coolant light?
- Pistons for 396 stroker?
- Hooker Cat-back and LT install
- best LT for 94 6-speed
- O2 wire diagram
- cc305 and 383 stroker
- performance loss??
- powerbreaking
- Part number for rear main seal retainer?
- O2 sim mod
- 02 (oxygen) sensor
- Installing a Cam
- whats this sound?
- timing sets
- ss air box gasket
- Headlight Upgrade
- Header Leak
- Driveshaft Seal?
- Replace waterpump?
- Cam Install This Saturday!!
- Getting my car scanned
- lt4
- How to install water pump?
- Need Help With Opti
- Cam surge
- Valvetrain advise
- alternator bolt, reverse threaded or standard?
- Thanks again guys!
- who's got UNcoated headers???
- does the BMW oil plug blockoff work with the MAC Mids?
- something wrong with my car??
- electric cutout...does motor burn out often?
- '96 LT1/4L60 into '94 Z
- Possible starter problem?
- What could be causing this
- UPF1218 oil filters?
- mac exhaust
- autozone chrome alternator fan
- anyone willing to look at a freescan .csv log?
- Anyone use a dye + UV light to track down oil leak?
- im having probs with plug # two! help
- car just stalled
- Weird stumbling when stoping
- Car wont start, dead battery?
- headers vibrating
- Where can i buy a...
- Weird Vibration at idle and get worse with the heat on...
- Noisy valve train
- Serious Engine Issues
- My Ignorance Your Help
- 383 stroker kit?
- alternator problems?
- Question Related to Tempature of each Cylinder...
- Oil in antifreeze??
- All Hooker LT install pages, parts list needed for friend.
- Y-Pipe ? ...
- Cheapest place to get LT4 KM ?
- towing will make engine blow?
- diameter of pipes after primaries
- is there a lt1 engine building book?
- rpm hesitation
- LT4 Hotcam Kit
- Jet Hot LT driver side primary?
- how long/how much for head removal?
- What can cause a Code 11 MALF ?
- Changing Optispark - Does balancer need to come off?
- Poor starting.
- ahh, knock retard!
