View Full Version : LT1 Based Engine Tech
- what fuse to pull to reset computer?
- NO FUEL PRESSURE need help!!!!
- crankshaft seal
- header gaskets
- jet-hot headers
- Water pump replacement
- For those who already did THROTTLE BODY BYPASS
- What are the symptoms of a misfire?
- getting hot, overheating?
- cast iron
- Is my AIR deleted right?
- please help before i give up
- My GTP S2 LT4 flow #s suck!
- Engine oil temp sensor?
- Magnaflow on E-bay??
- opti spark / ICM questions
- exhaust systems
- cc306 or GM847
- machining for bigger springs with heads on car?
- coolant light?
- using 94 cam in a 96 car
- Another belt tensioner question?
- Old thread follow up: IDLE problem
- consequences of adjusting rockers too tight?
- Horsepower loss over time?
- Anyone running dual Bullets w/ a cam? (Especially the CC306)
- spun hub while re-installing. problem?
- im in trouble, please help
- valve adjustment after cam & rockers swap?
- MadZ28 Tune turnaround AMAZING!!!!
- OPTISPARK elimination. What are all the options?
- What the hell am i STILL losing power from!?
- shouldn't do WOT in 5th? WTF?
- Are dealer O2 sensor same as AutoZone ACDelco O2s.
- Side Mirrors
- 52mm bbbk tb
- What Crank, rods, pistons are people using for a 396 LT1?
- MPG problem
- EGR Troubles
- gas tanks
- 93 knock module
- exhaust question
- gm performance hot cam kit
- steering and tranny flush
- LTerms and STerms crazy while cruising?!?
- *NEED HELP QUICK* Which RTV for intake?
- Header Install.......
- lower control arms
- Got programming, but car still idles high?
- Different size belt
- cam what parts do i need
- pcv valve
- Need quick help!
- need help guys
- Guy claims to "pull" something at the back of the intake...
- what should my o2 sensor readings be?
- header help
- Checking various engine sensors
- Where to buy engine sensors?
- Transmision slipping
- Ported MAF problem!!
- Need your opinions on motor build
- Block and head casting #'s, what to look for?
- What is this tube on my lt1..questions..
- rear main seal
- Tearing down the top end
- Cheapest place for plugs/wires?
- anybody have a guide for changing the wiper/turn signal switch?
- Why dont Stock LT1's or LS1's come with 6" rods??
- After-Market Valve Covers??
- What years had hardened pushrods?
- Notorious GM847, what kind of gains on stock heads and intake?
- o2
- LT1 Water Pump New or Reman?
- Replacing water pump drive seal question...
- CSI Customer Service
- Going to go thru madz28 for conversion
- 1500-1900 hesitation?
- o2 sims needed on a 94?
- Can a Blown Head Gasket hurt your O2 Sensors?
- crank, pistons and rods, oh-my...
- DO I have to change to obd1
- will I get any gains out of 1.6 rr and hardened pushrods
- Mac header help!
- fuel pressure
- SS airbox mod
- Royal purple in my LT1
- Ford 1.7 RR work on my LT1
- Is it my starter, PCM, or Ignition cyl???
- SS air box fitment issue's!
- need help for f-body presentation
- Water pump driver shaft o rings ?
- I recieved 1.7 RRs yesterday
- can the oil pan come out from the bottom?
- Getting Dyno'ed Today...any # Guessers?
- Jason Cromer v. GMpartsdirect.com
- 1/4 Mi time does this seem right?
- Springs?
- Header install comparision 4th vs. 3rd gen
- blows oil when you let off the gas?
- Question on LT inastall.
- fuel pressure gauge
- Best Valve train
- what's better for gas mileage low rpm heavy pedal, high rpm light pedal?
- What causes idle speed to increase every 10 seconds?
- 2 questions- Need Help for programming remote!!!
- motor mounts..rubber or poly..solid or stock??
- removing the silencer on elbow
- RTV Question (waterpump/thermo)
- True Duals (X-pipe) for 95 LT1
- Question about Headers
- My car
- edelbrock headers
- opti-spark HELP
- Lot of Valvetrain Noise
- Will the cable work?
- 12 pin connector?
- Ahhh yes, another timing chain thread...
- what kind of times and numbers is my car putting out
- 94z28 is runing rich? plugs smell like gas!
- Hooker catback soundcli
- shorty headers install
- hotcam with 1.7 rr's
- weird problem: car won't shift out of 2nd at WOT with shifter at 3
- Engine re-build
- ABS Light, Help!
- need cam advice...please assist
- 383 LT4 guys cam and flow # ???
- LT4 Gas mileage
- spark?
- Any cons of TB Bypass?
- Vac pump to bleed coolant?
- Anyone w/ Pacesetter LTs & True Duals..???
- Maf ends questions
- oil pressure?
- Comp Cam Extreme cams
- Electric water pump swap
- 7/16"-20 hardened nut needed or not?
- ASM Monoblade
- Mess of cooling system
- Looking for a new radiator..what are my options
- how long until retorquing header bolts?
- What should this combo run?
- my steering power is very hard sometimes???wtf?
- Plug wire resistance
- coolant leak after opti install help!!
- Whats the difference between open-loop and closed-loop?
- About to give up, unable to get car to run properly. Anyone ?
- CAI from stock box??
- Change Oil after Seafoam?
- OMFG!!!!!! its alive
- Filter Mag? Reduced Wear?
- BLACK residue on my tailpipes!!!
- Shoebox, come in please.....~~>>
- flushing engine after head install?
- quick question
- 2.73's
- Data Error
- Need Help!!---dead ignition
- passenger side cylinder head
- cc305 part #'s
- what hose is this?
- where to boy felpro gaskets?
- 160 stat
- my car wont start 9out of 10. wierd problem, help needed.
- Bummer, but maybe a good thing?
- Replacing coolant bleed screw
- cam?
- Single cat MAC headers on 97 complete! Couple of Q's though..
- fuel filter, how hard to swap out?
- What tells the PCM which RPM it's at?
- need guidance with computer tuning...
- Gas Mileage Question
- For anyone worried about HOTCAM emissions
- my timing chain broke (pics inside)
- my break in plans (cam+heads)
- Exhaust sounds AWFUL
- Can I use different O2's on each side?
- How do you get the low oil pan sensor off?
- Autozone Optispark, Yeah or Neah
- car overheats only when at idle or stopped
- 6AL mounting location?
- air fuel ratio gauge
- Do '94's have a crank sensor?
- Prices and Info on 383???
- clearing service engine light?
- service engine light on?
- hits redline bogs and then black smoke
- Leaking injectors??
- what should my track times be?
- O2 Sensor Extensions: For lazy people?
- O2 sensor voltage high??
- Vented opti swap harness ?
- explain how I am hitting almost 6300 rpm?!?
- Finally got TTS Datamaster working, Please take a look at my log.
- cheap parts
- Timing chain for non-vented opti
- Car Died Need Help
- testing for a broken pcm sensor wire
- What injectors to get???
- Jet-Hot LT - Last minute check..
- I think I collapsed the lifters on my 383...
- Hypertech lt1 powerscan cartridge questions is it vin locked.??..
- LT1 Ram-Air Airbox
- constant misfire problem 95 trans am
- Getting SES light
- speed density vs maf
- exhaust
- Idling problem
- throttle body gaskets
- First runs at the track with the XE 227/233 cam --- please help me out guys!
- Opti-Swap...where to get parts???
- Barametric Pressure
- True Duals
- Whats the best cam 4 me
- Please help, smoke coming from exhaust!
- 110LSA vs 114LSA comparison
- Can I run a walbro 255 w/my mods
- Opti, Waterpump and misc questions
- what are all the free mods
- Gas guage needle is stuck..please help
- stumble
- Pulling the front end up with 3.42's??
- i am dumbfounded......
- So What Is It
- What size sweet thunder to replace resonator
- Cam questions..
- rusty color scum inside oil refilll cap !
- AC delete bypass pulley
- Interresting Finding - IAT Sensor
- Injector Cleaning...
- is my water pump going out?
- LT1 Cam timing questions
- Anybody running 2003 Mustang Cobra injectors?
- o2 SIMULATORS.......
- Good ONLINE alternative to gmpartsdirect.com?
- swapping ecms; need help!!!
- Opti install?
- I'm out of ideas?? Anyone have any more?
- Dumb question or not?
- Duals louder than a cutout?
- Technical ?s regarding Hooker LT primary lengths
- manuel fan help
- 94 Camaro color breakdown
- Fastest mph with untouched heads?
- part
- Doing headers. What plugs and wires to use?
- Is the GM 846 a strong cam?
- Optispark theory of operation (and general ignition theory)
- what's bad, timing advance or retard?
