View Full Version : LT1 Based Engine Tech
- Adjustable or Non-Adjustable
- Power Steering?
- opinions on hooker super comp shortie headers
- Pcmforless tune on the money
- Replaced broken tranny mount w/ ES poly mount...
- FUEl?
- AIR fittings on headers.
- Weld Racing Lugs
- Which Delco Filter?
- Best/safest way to clean O2 sensors?
- Are Crane Gold roller rockers self-adjusting??
- Lt1/Lt4 question...
- OK to run straight Y-pipe?
- Custom Air Intake - Good or Bad?
- Is a loud fuel pump bad?
- Removal of A/C Vents and rear speaker grills
- SES light
- Water Pumps? Safest alternative?
- Building my LT1
- Porting my intake for my TB: Can I cut into those "bumps"?
- forward intake
- AI heads+JoeO cam+LT's+Loudmouth=Idle
- Anymore Bolt on's out there????
- Xe 224 230 Dyno
- car wont start(think its optispark)
- fuel pressure regulator?
- DTC#61 got questions on A/C
- coolant crossover seals
- 24lb or 30lb injectors for N/A 383
- Which maf for 383??
- Broken torque arm!?
- coil mounting bracket
- Talk about service
- Arizona Speed and Marine CAI
- Cam Questions on a 94 lt1
- Here's a real dumb one for ya
- Opti swap write up?
- Can taylor 10.4MM wires go OVC?
- LT header question...u guys are prolly tired of this
- New Stock-Headed LT1 Best - 12.4 @ 110.8
- LT header install: Top or bottom?
- Honing?
- Valve question on lt1s
- Relocating the MAF
- Need Input On Plugs And Wires
- Where did my tourqe go?
- Short tube headers: From top or bottom?
- Whats this code mean?
- True Duals + [2 mufflers]?? choices inside..
- Just bought 96 M6 Maro what mait. should be done?
- Routing plug wires OVC with emissions hook-ups - Possible?
- Waterpump troubles...
- Should fuel pressure do this?
- Just Dynoed
- still having starting issues!!!
- opti spark?
- Replaced Optispark------>Results inside
- msd coil
- Car is running bad someone please look at scan numbers
- Stock cam, will I max it out??? Help!
- MAC Midlength Header DYNO results!!!
- What oil for rebuilt engine?
- Shift at what RPMs?
- Injectors - SVO vs Accell
- Real quick Oil Cooler question...
- nternally balanced 396, nuetral balanced flywheel???
- rod/main bearings?
- expected power output/performance numbers????
- God Almighty!!!
- HELP!! Blue O-rings on Opti pin?????
- ARE RESOLUTION being taken care of
- procharger
- 15 lbs of boost @ 10.1:1 CR!
- Supercharger & Nitrous = ???
- Holy crap 135 MPH
- dowel press?
- Opti Install ??
- Which ASP Pullies?
- spittering and sputtering, HELP PLEASE
- New Denso O'2 sensor (lead safe)
- Back To 180
- Sent Headers w/o EGR&AIR
- disabling EGR w/o removing tubing?
- running rough! please help!!!!
- Car Still Wont Fire HELP!!
- SLP Loudmouth
- high rpm miss and maybe smoke?
- car revs higher than it should when cruising
- Setup expectations?
- how do I pick a crank?
- Rattly Kinda Noise seems to be coming...
- Header install
- Worth it converting to vented opti?
- Urgent Help needed! Car wont run/idle
- Low oil light
- Ticking sound?
- What tool to use....?
- Exhaust Tube Size!! need to know by tomoroww
- What is a Knock Sensor?
- Forged Speed Pro Pistons?
- How much HP loss - removing MAF
- Has Anyone Bottomed Out With Hooker Lt
- What to do about my optispark?
- TPIS LT y-pipe
- car wont start still... new opti and plenty of fuel pressure
- Informative engine Diagram
- Got a cam recommendation today
- Need Moroso Part# & Source for single motor mount for BMR K-member
- disaster BIG decisions
- question about LT4 hotcam
- UPS lost my new fuel pump
- ? Exhaust port header matching ?
- A/F what should it be at idle and WOT?
- E.G.R. delete for lt1...
- Just Installed K&N FIPK
- Lt4 Hot cam is it a good cam
- 3.5" mandrel tubing (for intake/exhaust)
- dyno numbers
- '95 T/A runs like its only on 4 cylinders
- Will 1.6's fit under stock valve covers?
- Anyone want to take a crack at what kind of 1/4 times i'll get?
- TPS help
- Mail order tune...obd1 or obd2?
- Another what should I run thread....
- what do i need?
- what is an "optispark seal"????!!!!?
- Anyone know the Exact weight of Stock internals? pistons,crank etc
- LT1 balancing, judt need some people to verify it for me
- Cam mileage??
- Long tube headers and plug wires?
- 12341093 Roller Timing Chain Kit
- whistling sound of a turbo ah just help
- Bolt on questions
- need advice on car repair /exhuast
- Comp Beehive Ovate Valve Springs
- Some annoying things need some tips.
- Hooker !catback
- Harmonic balancer question
- how much tranny fluid?(A4)
- What is THE valvespring to run?
- NGK non resistor plugs
- any mainstream auto places sell fire sleeves?
- how to solve the dreaded rear end clunk
- Anyone going fast with Comp Solid rollers?
- Best way to tape oil pan w/out removing?
- fly wheel help
- cc305 or hotcam w/383?
- Replace Cat with race muffler?
- Lines from radiator to trans
- Would using 1.5 RR's help lower emissions?
- Interesting Hesitation - sinking pedal at 1500 RPM in OD
- waterpump install page?
- what to do now
- Inlet Size 4 Borla Rear Section
- Running slow!????
- Just bought new cam, with 1.6 RR's???
- Opti Spark Part #??
- Understanding How Headers Work
- fans dont turn on anymore....
- after headers...
- Will this chip even work ..
- 2 exhaust questions....(93 and 96)
- Where can I buy pushrods?
- dont side step the clutch with a street twin and drag radials
- Horsepower Increase??
- Just did the RAM AIR mod!!
- header gaskets installed dry??
- What do you guys think?
- My AS&M 58mm TB came in today! *PICS* Other things too.
- water pumps?
- LT1 vs LS1 engine mods
- ATTN Shoebox please help me out....
- fouled out 2nd set of plugs in less than 10 minutes! help!!!
- egr disable..block off or just plug intake line??
- what kind of mods to get to 300rwhp on an automatic car?
- Is this a torque converter problem?
- New opti 2 months ago/Today replaced opti again.Is this possible?
- help ASAP
- coolant leak is still there!!!
- AS&M header help
- mac header/ovc plug wire questions
- Long tubes on lowered car???
- Anyone have Pacesetter Longtubes???
- Possible to purchase electrical connectors?
- any ideas on times for this combination?
- Motor mount replacement
- Has anyone done this yet on here?
- Strange starting problem
- weight on the driveshaft
- ASM header to y-pipe gasket size?
- Idiot check
- coolant in AIR?
- Car will not start. Need direction.
- Where to buy just MAF screen?
- Is it hard for a shop to make a y pipe?
- Should I install an H-Pipe?
- **New Cam!!!**
- Whats wrong?! Codes 310? 420?
- starter Question
- Whats wrong with my car!
- Valve cleaning idea..good or bad?
- What to use for granatelli fuel pump hoses.....
- Bosch +4s
- What is the difference in the way the car will re-act between these two?
- how much could i sell 1.6 RR from hot cam kit
- Dynomax Bullets
- Porting Intake Manifold
- oil volume
- Want 1.7's. Please read. Not a duplicate
- What causes idle to increase every 10 esconds after going into closed loop?
- Best place to buy AFR heads?????
- thumping feeling behind passengerside floorboard??
- MAF reading 0 on Scanmaster
- traction ctrl removal
- ? about repairing damaged lt1 head
- need .2 for 11's, whatya think of this plan.
- how to get marsh underdrive pulley off?
- $10,000 to build new setup...
- Anyone ever extrude honed their heads?
- Anyone else have these leaks??
- Anyone heard of a Sunrey Crank?
- What to replace first at high mileage
- Aggressive cam
- GM Double Roller ??
- Car won't idle.... I'm stumped.
- What the heck is an Opti?
- any other oil leaks with stroker motors?
- chambered muffler
- exhaust questions
- Larger valves with the CC306 change
- sx fuel pump
- installing new rocker studs
- codes 27, 32
- Using a PCM program downloaded from another
- i think my car is dying
- those running 218-224 112 cam on stock heads
- LT headers,cam, exhaust for 94 have questions
- GM 847 Too Radical?
- Oil Pressure help...FAST!
- Hypertech Tuning
- Which Pill To Use
- need help
- Ran out of gas...
- broken bolts: this is a new one to me
- lt4 hot cam springs with cc306
- Maf P/n
- 95 Camaro
- estimate how much hp ?
- How do you get the knock sensor off
- Z06 Mass Air wont work on 94 Formula...will it??
