View Full Version : LT1 Based Engine Tech
- 4L60E vs 700R4 tranny
- LT4 knock module
- Backfire from intake
- What Fuel Pump?
- do you need to use cam lube on a new roller cam?
- Which mufflers for duals?
- car only starts on second try after head swap
- 4- point vs 2 point strut bar
- tunercat PCM_EE version AX ???
- Time for a rebuild????
- Would a leak like this cause a problem?
- IAT mod
- Replacement in-tank fuel pump?
- where can i find this cai and elbow
- delteq questions
- Results from the HOT ROD Pump Gas Drags!
- A piece of metal fell off of my car
- Crank hub help?!?!
- Bad EGR?
- son of a ***** - tiny hole in side of radiator-- recommendations
- Oil ring Question. need help assembling !!
- problem after head $ cam swap
- Not a normal header question!
- lt4 cnc ported heads
- tunercat- speedometer calibration -- not working.
- Will timing retard with open headers?
- Anyone using the edis box
- whos running a HEI distributer
- What will my 94z run?
- new cam timing
- XE 224/230 WITH Heads
- found a header bolt to be missing, problems from that??
- All RKsport/ AS&M header users...got some Q's for you.
- cc306 vs this cam
- Bulb Replacement
- Thunder Racing O2 extensions - bad?
- Coolant pouring out of the bottom
- Help!! Trying to install Accel 58mm TB
- power adders
- Who 's running largest cam with a Closed Loop tune
- Mobile One and Castrol
- Where the hell is my coolant going?
- 94 LT1 running like a dog after plugs and wires
- fuel pressure setting???
- New Exhaust!!!!
- heads cam install, now won't start!
- Does this thing work?
- O2 Sensors unhooked...need help
- Do all '95 Z28s have the "ASR OFF" light on the display even if the car is not
- 1997 Camaro SS 30th anniv what is it worth?
- What cam with stock heads??
- Cutout setup?
- tfff tffff tffff what is htat
- Part Number for GM's LT-4 1.6rr for the LT-1
- Royal purple vs. Mobil 1
- T-56: Rebuild or Buy Brand New?
- need help with Codes
- Time to go crazy! Help please.
- clutch diff for LT1 then LS1 vettes and camaro's?
- What happens if you run w/out o2?
- cost of water pump?
- I started, and on the first try (head swap done)
- intake elbow question
- LT4 Kit
- Radiator Fans
- Cam?
- Shop scrooged my exhaust.. help!!
- crank balancer
- Rocker arm questions,pushrods,etc.
- fuel rail covers
- Compression Ratio
- Help!
- Misfire = backfire?
- Please send me links to tune-up steps for LT1 (plug/wires)
- Power window to manual window swap, anyone do it?
- electric water pumps
- Is this normal for Fuel Pressure?
- No AIR or EGR codes in OBD1?
- Stupid Fuel Line Question
- alignment with eibach springs
- Different types of "X" pipes.
- Update - Race Prep 383, Vette Doctors DFI tuning
- Poor Fuel Ecomony
- ground clearence with mac headers
- Weird exhaust question
- need help hooking up intake manifold
- Want to paint Valve Covers...need advice.
- Engine Findings
- which retainers and locks?
- prime oil system
- S**t!! Don't know if I have a pilot bushing installed
- To put tips or not to put tips..........
- Anyone think synthetic oil is no good?
- Wiring an electric water pump to a thermostat switch??
- what mod next
- how to test a 93 trans am?
- cap&rotor botton
- How to check for fouled plugs?
- Allright guys im stumped
- How to adjust rockers with covers off?
- valve cover - 1.6 rr' ?
- Timing cover install, Drop pan??
- Gettin' new rotors/pads: what is the best place/brand/how to?
- LT4 KM You got to get one
- vibration issue...
- felpro part #?
- About to mod this 96LT1 What else do I need?
- My Second Trip to the Track
- ? about intake elbow
- shift light
- Rewired AIT sensor
- stearing linkage
- would lt4 heads from a vette fit
- Racing my 94z, what should I suspect?
- Hooker LT's to RK sport questions
- Loss of power.......what happened
- Difference between the vette lt1 and f-body lt1?
- Edelbrock 58MM Throttle body
- Tire size affecting gear ratio
- opti spark
- Front main cap?
- Car won't start ASAP
- Airfoil Install? Plus Donkey Dong delete
- Ahhh! NO OIL PRESSURE.
- What CFMs (heads) are ideal for 383
- Need ODBII Drive Cycle for 97Z28
- What Next???
- Anyone use Warlock mufflers?
- Summit Universal X-pipe system on LT's (pic)
- Ordered my Pacesetter Lts, should I get different header bolts?
- oil preasure
- Got my head info finally!!
- air to fuel gauge install ????
- where do i get one plug wire?
- 3inch collector gaskets?
- Getting a flowmaster put on my 396 LT1 tomorrow...bad idea?
- code 42
- O2=rich?
- ?? about LLoyd Elliot
- yes or no
- where is "bank 1"?
- Near stock 93 LT1 + 125 shot = 11.90 @ 116mph!
- Throttle body???
- Build me a cheap yet effective head/cam combo guys! I am in!
- Everyon read please!!
- got my 15" centerline telstars in the mail today
- compression on pump gas
- Car stumbles off idle
- problem with connecting the vented opti pigtail to the 94 harness
- oil
- would a knock sensor cause a check engine light?
- hot cam kit ?
- timing?
- Whats a good Injector
- Nick Agostino Taking Care of Business
- Found my problem!
- No collector gaskets....How bad is this?
- starter?
- quick need hellp
- csi soldering connections question
- code#1351?
- Part # or size of "hot" Alternator nut...
- I want to make a fan switch but dont know how
- Length of stock Connection Rods?
- Lunati timing chain
- car goes dead when i turn the key...?
- Normal Oil pressure
- shoebox i need your help
- RK Sport help?
- Anyone done a front breather conversion?
- Problem with Shift Light.
- Exhaust question
- Stutter when its hot out
- Difference in Rearend gears between auto and standard cars
- Need help FAST!
- car hangs up at 2000 rpms sometimes...
- Whats a better operating temp 160 or 180 degrees?
- Smog Help
- Do I need new valve springs with 1.6 RR's?
- walbro 340 pump-how much hp?
- opti change out
- "y" pipe robbing power?
- Trick Flow heads?
- Part Number Needed
- Lt1-383
- No muffler, bullett, or hooker???
- need help !!!
- GOing to dealer next wed. for surging, what to look out for?
- Where to get heat tape?
- Timing chain question
- My new T/A !!
- Steel versus aluminum rocker arms...Pros and cons?
- Exhaust Cut-Out
- smog help
- What main caps?
- Safe To Use RTV On Header Gaskets?
- True Dual Exhaust?
- GM 847 in a 383. Streetability questions within.
- Need serp. belt part # for und. pulley.
- Airfoil fit in 58mm TB?
- part number for ngk spark plug
- MAF readings at idle
- brake problem
- How much should this cost (header un\install question)
- hotcam and LT4 timing chain?
- ATTN: Shoebox/others, Line lock Question.
- Amsoil
- Correct gap?
- pcm wire
- Opti-Direct Ignition
- Change Optispark, now leaking
- fuggin lost 3 ARP head bolts
- O2 values before startup L0.514mV R0.451mV
- My exhaust smell burns my eyes
- ICM Question
- intake manifold bolts
- tested fuel pressure today and....
- Tensioner assesment
- can a speed sensor be tested?
- biggest cam people pass emissions with
- need specs on xe 230 236 112, and valve springs
- EGR valve harness......
- thermostat
- Times with this combo
- 224/230 or 227/233 on stock heads
- Thunk noise
- Hard Start
- Where do the air solenoid vacuum lines go?
- Which Header Bolts?
- Rhoads lifters.
- Best Header Size and Muffler
- Front Alignment, am I getting screwed by this shop
- best head gaskets....
- 383 running really hot!!
- Codes 16, 41, & 42
- 94 Z28 factory options
- Limits of stock injectors
- Exhausting exhaust Q's
- eibach spring install
- ANOTHER egr block off question
- Hood question...
- Quick question about SVO 30# injectors
- electical problem?
- Blinker Problem - HELP
- Question about a Fuel Pressure Regulator
- going to scann my car in the 1/4 Mi what should i record?
- 93 TV Cable/ 52mm Throttle body question
- Odd question about shifters
- Guys with 10308 crane springs
- Off road Y pipe for stock manifold and dual cats?
