View Full Version : LT1 Based Engine Tech
- Noid light best way to test PCM firing injectors ?
- What length O2 sensor extensions do I need?
- Buying 95 Formula
- Would 3 in. true duals be overkill for my setup?
- Who is R&D cam's to put the LT1 in the low 11 N/A 355cid
- Anyone ever buy a X pipe from here? price is right!
- LT1 911! Overheating, coolant spilled out of reserviour spout
- OTVC Wires!!!
- high idle ??????
- backfire at 4000 rpms, help
- Alternatives to CLoyes True Roller.
- does anybody leak oil behind the crank pulley?
- Where to get new 02's? $$
- black hose to air intake???
- If you've taken off your AIR please read. 93 & 94 specific
- Spark Plug #8 & Passenger Wires
- Converting to an A4 from M6, who's done it, what do I need
- whats reasonable
- what is the normal idle speed for a 94 lt1?
- Anyone got one of these laying around???
- Seafoam
- any good f-body shops in bay area,ca?
- Another engine noise question
- 350 transmission let me know??
- Cranks wont start
- 95+ opti-spark
- What is the best way to degrease my car after a main seal leak
- what now??? I have about $400 to blow??
- fastest stock LT1s with juice
- white smoke from intake manifold
- about to pull my motor
- GM847 Cam Purchase!
- Moroso CAI adapter?
- what fuel pressure ????
- ABS Problem
- Those with MAC headers (or any header for that fact)
- Starter keeps grinding on flywheel, need thoughts
- Gasket time again: need P/N for EGR valve and intake bolts
- BMR K-member and SLP Headers?
- Walbro 255
- I got Farm Insurance on my car
- Converter locks at WOT in lt1s...not ls1s. Why?
- Traction control on 96z
- anyway possible to stop rear gear noise?
- Question?
- LT1 wiring harness for engine dyno
- loss of power
- How to hook up alternator wires for custom application
- Tryin to put it back together
- Stock Stereo?
- Gear Pull
- Just got a 95!!
- ported intake gains
- Where to jack up motor for oil pan change
- exaust diameter
- headlight wont come up with switch or manually....
- motor mounts? poly, rubber, stock?
- tensioner pulley
- Gonna do major tuneup to car, anything else I need
- Nice GM Quality
- LT1 Alternator Relocation Bracket TESTING
- Performance Shift Mode
- strange ?
- Am I loosing power?
- Clogged Cat?
- Your opinion on my 383 project
- Is phoenix stalls any good!!!!!!!!!
- Oil in the COOLANT?!
- iac bad?
- Help With Air/Fuel Gauge Install
- Low oil psi, no oil on topend! :(
- Best place to buy ECM?
- Lt1 performance issues (after warm up wants to die)
- My Rear is Acting Up!
- Somma Biach!!!!
- Codes that I cant find definition of inside......
- slp hood vs. gm resto hood
- mufflex catback systems
- Is open header bad?
- Passing Emissions
- New to board
- E.T. Expectations???
- valve lash
- Hooker LT vs. RK Sport debate!!!
- _____Mouth, what muffler replacement?
- people who know delteqs
- 11.4x or better all motor...who has done it?
- Just bought my First Camaro!!!!
- EGR tube Question...
- Maximum bore on LT1 block.
- whats the speed limit on a 94 lt1
- Thermostat housing
- Anyone ever get rid of the coolant tank under the battery?
- dynatech lt's and true dual Q's
- Nitto 555R 245/60/16
- What size bolt for Belt Tensioner?
- RPM jumps around at WOT
- Head work with stock cam?
- Felpro Gaskets.
- Oil pan torque specs
- air intake charge cooler
- Finally!! problem solved
- Dynomouth question
- Nos
- Possible RR problem??
- fbody going the drain
- Warning Lights comming on?
- Battery died TWICE within month.??
- recommmendations for a new oil pan and oil pump for a 1995 lt1 formula
- Oil Leak
- Front left wheel sensor?
- becool radiator for a 1995 formula lt1. anyone using one?
- What is involved with deleting the EGR and Air Pump?
- Used LT1 1993
- Ccv??
- 12" or 9.5" stall converter for weekend racer?
- LTCC help please
- car stumbling in low RPM
- lt1 idling
- AWESOME JeG's TORQUE ARM* better then BMR kind of like MAC
- Timing cover install.....
- People with Hypertech PPIII
- Running Rich
- #1 Reason to replace lifters w/new cam....
- How much $???
- msd6al and coil or accel 300+ ignition for a 355 ci supercharged car?
- Open headers or not??
- Why does aftermarket cams never have year spec.?
- Water pump rebuild?
- I need a check list for the Delteq
- hestations problems plz help
- A Couple Questions
- Detatching the chassis wiring harness from the firewall?
- Gaskets???
- Will SLP 85 mm maf work
- What kind of power would you need to trap over 120mpr
- Gauging Interest with custom intake elbows
- any aftermarket rear brakes???
- Plugging A.I.R. on headers?
- Come in... What do you predict
- Anyone have custom cat-back to exit in front of rear wheels?
- Estimate my machinework cost for my rebuild.
- ramdom ticking after head swap
- harmonic balancer question
- Modifying a WS6 hood
- With ~500 flywheel HP, how much will stock cat-back hurt?
- Dal vs. GM Direct, I thought Dal would be cheaper; What about Jason C. ?
- Sieman Deka injectors any good?
- cant find some things
- straight pipe or dynomax bullet?
- LOW RPM stumble problem solved!!
- Fixed the rear finally !!! Then blew my tranny , need advice .
- Finally pulled the diff cover to check out the carnage...
- Still Smoking!
- Loose Lash on Solid Roller
- Should pressure do this?
- LT1 Cat-Back advice needed!
- Things to wathc out for at Engine rebuild shop, questions to ask?
- 383 Stroker Kit, is this good?
- 2 weak cylinders after rebuild
- Plug wire/Header clearance
- Anybody with sound clips of true dual and stock manifolds
- air/fuel ratio gauge install
- Help needed ASAP, slave cyl. won't go in
- car sounds like a 2 step@ high rpm after cam install
- Need Help! Pass. side motor mount removal.
- Dying water pump do it myself or pay for it.gm pump or other brand..??
- How to clean IAC
- problems after installing CC305 cam
- What side of m6 is the reverse lights
- Next Mod
- Rear O2 not hooked up!! Help please
- 383 help
- ASR reverse switch wiring
- Question about a few parts
- To boost or not to boost??
- Whats Wrong Now?
- remove blue cap on accel injectors?
- What happens when you DON'T run a harmonic balancer?
- No Spark after Opti Install
- what size freeze plug for the timing cover w/p shaft hole?
- Does a header leak and noisey rockers have the same ticking sound
- question about gm846 cam
- Leave (_Y_) stock-Build Top What CAM !?
- VIPER T-56 STEEL or ALUMINUM FLYWHEEL ????
- stream linning1997 lt1
- Help w/ torquing aluminum heads
- looking for a good, emissions legal cam
- Are Cut outs worth it?
- Dyno numbers w/Ultraflow
- E.t.
- Dyno's what's the diff's
- Quad Tips on a Flowmaster
- Cleaning the Throttle Body
- delteq or ltcc
- my 97z vs 2003 vett who would win
- Will any SVO injectors fit our LT1's?
- Dynoed today - new numbers...
- bought Showen04's formula
- parts questions on rebuild
- Window Motor....
- 224/230 Dyno Results...Your Thoughts
- Would fouled plugs cause arcing?
- CAI Restriction?
- Please, I need some help badly
- Bought a 97 SS today....
- Rocker arms hitting springs?
- CC305 and 1.6 RR help
- Fired up the BEAST tonight!!!
- Went to the track today.....
- went from rice to LT-1
- New Dyno Numbers
- Update on my Car. Thanks to everybody!
- Misfire help, extremely strange...
- Idling problem!
- Car cranks, but won't turn over.
- Blue Smoke
- More on the LT4
- scaned my car today
- Can I do this?
- Cleaning Filter?? all people with SLP CAI help?!
- ACDELCO oil filter part number?
- MSD ignition help
- Urgent help on convertible top latch!!
- why is my antifreeze brown and chunky lol
- Worth it for me to upgrade to 7/16 roller rockers?
- pulley removal ?
- In The Middle Of Fuel Pump Install......quick Question
- Need some exhaust help from the experts!!!
- True Dual guys
- Hypertech Power Programmer
- can you put a regular muffler on loudmouth?
- Anything im missing?
- Cat. problem on 96Z
- where to jack?
- MAJOR PROBLEM! Lip on timing cover chipped, am I screwed?
- Can a non-vented OPTI work with OBD2?
- Cam guys....question
- Transmission
- ZZ4 cam in a vented opti LT1
- OVC Wire lengths?
- shoebox gotta header ?
- Urgent, Can't get opti seal off!!! How do I get it out?
- need help fast
- Rear end ABS Sensor
- What did this motor come out of?
- Spring cleaning/tidying up
- I think I damaged my Rear end! Help with new clutch too!
- Anyone try the pacesetters yet
