View Full Version : LT1 Based Engine Tech
- what lifters to buy?
- MAF Problem PLEASE HELP
- Hole in radiator - running hotter?
- Car just shut down- now won't run
- Cam install - Problems running now
- Supporting the motor?
- shift kits
- Putting my new 383 together have a few quick ?'s
- what do u thin with these mods
- How Tight to Tighten Plugs?
- Timing Question
- How Much Power Is Lost From Knock?
- Is there anything on the f-body that's problem free
- how to change pass. side spark plug wires.
- Madz28 Tuneing Question?
- need A.S.A.P fbody dead?
- Thinking about switching headers
- fuel line sizes: question
- True dual exiting out before front of back tires
- Is there a safe way to clean the MAF?
- Spark Plug Change Help
- Stumble...bad.
- FIPK Or STOCKER SS RAM AIR
- how much horse you think ill put down?
- What motor mounts for the LT1
- Trouble with hood and tower strut!!!
- o2 Extensions - 97 Z28 - do i need flat or square?
- Cat-less ?
- Knock retard slowed me down???
- Intake Manifold Overhaul
- 1le AC delete pulley and ASP ud pulley which belt????
- What Oil should I use?
- rims
- Rebuild suggestions....
- SLP loudmouth exhaust
- LONG TUBE PICS AND ?s
- Cai
- Pacesetter LT guys, how long did it take for yours to show up?
- engine rebuild/removal/installation
- MSD Coil Pack Bad?
- Is the LT1 Manifold Restrictive?
- Accel 58mm TB
- best 58mm TB?
- HELP! Right 02 reading 999, etc. Scanmaster!! PROBLEMS!
- k member question
- Push Rods?
- Is this the death of my tranny?
- 2.5" duals from a 3" collector...????
- update on my 97--with dyno sheet
- any good or bad info about nutek
- IAC Questions
- How much cam surge can be programmed out?
- 2-series carrier
- head ?s
- LT header install ?
- Bfg or nitto Dr's?
- diameter of pcaessetter y-pipe
- LT1 Scanmaster guys in here!
- My TA on 87
- car keeps stalling...
- Chomemoly or Cold Forged Pushrods?
- intake manifold and head porting
- question about my new dynomouth
- Made for you side mount....
- what springs for Crane 210/224
- high RPM cutting out almost sounds like a 2 step
- My horn/lighter fuse keeps blowing out
- Racetronix!!!! Help!!!!
- problems getting off the second piece on the balancer (hub)
- The official "I'm screwed" thread
- opinions on next mods
- Problem With Underdrive Crank Pulley
- What is this?
- Opinions on valve springs and pushrods
- Dyno tune for just headers?
- How exactly to install OTVC wires?
- Car runs for 10 seconds then stalls, injectors turning off???
- Low Coolant Light
- leaking fuel rail
- Removing EGR and AIR
- What is the biggest Cam that passes emissions?
- Slow.. All of a sudden, major dropoff
- T56 Swap
- short throw shifter lower 1/4 times?
- need help w/part number
- someone with lt1 edit...
- High Flow cats...
- Is Redline Performance Closed?
- Just removed the EGR Valve and found cut/missing vacuum lines. Loss of performance?
- Clogged Cat?
- #1 and #8 cylinders misfiring, why???
- engine build up
- Car feels sluggish, ways to tune it up??
- How much for cam install?
- bogging
- Low RPM Stumble/ Hesitation
- no start, HELP
- Keyfob not working right? Fixed!
- Shift Light install on a 93
- Vigilante install... nightmare! i give up
- Autolite plugs
- What sensor did I break? Located on drivers side underneath exhaust manifold.
- Valve cover breathers
- BIGTIME knock problems
- <-- Any1 w/ play in steering in here ( have fix )
- OK very weird problem with car not starting
- which crane ignition?
- Need one last carfax
- cat back exhaust
- Did auto lt1s have vibeshaft problems..
- Can't decide borla versus magnaflow.
- Optimal shift points on a stock LT1?
- Need stock MAF size
- harmonic balancer
- Those who have installed SVOs...
- Emissions
- What engine fluids would cause a flash fire.
- Dumb Question
- bad valve train?
- Anyone know where to get...
- Is it hitting the rev limiter too soon??
- Rockers....
- tune up....?
- Signs and Sounds of a collapsed lifter
- 94 LT1 TA stock M6 gearing,,, 3.42?
- does anybody have this catback from slp
- How can you check fuel pressure?
- How hard is it to....
- newbie buildup questions
- Which one first?
- Thanks for the help Its alive!!
- anyone know why our cranks arent keyed?
- old style 350 head gasket on an lt1?
- How rich do these things come from the factor?
- hesitation
- Granatelli Motorsports MAF
- Hoe the heck do you get the exhaust manifold EGR plate on?
- Can adjusting fuel pressure affect air fuel ratio?
- reverse flow coolant tube HELP!!
- Security system problem and question
- CC pro mag RRs..7/16 or 3/8 studs needed ?
- new best times
- anyone have a hooker aerochamber muffler?
- Help! Where does this connection go?
- Code P0133
- Mac headers question...
- quick opti question
- CC306 too much?
- I think i broke something need help!!
- Oil Leak.....ggrrrrr!!!!!
- Primary Lengths?
- Rear Axle Oil Seal
- Shoebox, need two part numbers.
- 2-series Gears?
- Installing MclEod Street twin, HELP PLEASE
- DTC code
- To Y-body or not to Y-body?
- Any predications on what my car should run ??
- Rear end gear
- Last minute Header install Questions???
- best headers for my flowmaster 80 series
- loudest exhaust and headers?
- Best LT1 Heads for the Money?
- TB-bypass
- Info help, rear ends
- Thanks Shoebox....!
- car now stalls
- MSD Coils
- Caamro electrical systems SUCK...
- Viper Tranny?
- Gaskets on heads and cam swap???
- Gears as my next mod...?
- Air Filter fell off!! Drove without it for some time, BAD?!?!
- Air/Fuel Testing?
- T56 problem
- Anybody Using March Underive Pulleys Please Read
- Mobil1.. anyone using 15W50??
- Video clips of my car
- Lca Relocation Brackets....
- Outer Door Handles are loose
- Emergency Help!
- 96-97 Camaro SS How to find what # you own?
- Felpro 1406 question
- alternator rebuild Kit
- how tough are opti's
- Did Comp R' lifter look different before?
- lt1 shift light install
- fuel pressure?
- Pulley set...
- Got my car dyno'd
- How do LT1's Hold up to Mileage?
- What you think of these dyno #'s
- Could this Be!
- How to tell when Posi is on it's way out.
- Custom CAI: What Filter?
- Header question..
- 1993 opti install
- Good places to buy GM parts Online...
- NEED some serious oil experts here!!!
- My hawk has been in storage for 5 years! What is the chance........
- i keep fouling the plugs!
- Just a few ???'s
- Those of you with loads of HP come inside...
- caprice LT1 head gasket?
- I GOT MY TIMES!!!(How did i do)
- WTB Lt4 valve springs....
- Pullies install
- cam install question
- LT-1 shortblock
- Wiil 1.7rrs be better than the 1.6rrs with the hotcam kit??
- Adjustable roller rockers?
- where can i get this gasget
- cooling fans
- Is this setup worthy of high 12s????
- cold forged rods or the chomemoly pushrods
- Anyone have trouble with Aeromotive Fuel Pressure Regulators
- New RR install
- Anyone using Moroso Solid Mount w/ BMR Tubular-K?
- reliable
- Need hp gesstimate...
- What kind of gains from 1.6 rockers will i see?
- Took off air pump some questions..
- Help me figure out whats wrong with my car.
- How weak are our auto trannies??
- How do I set the Timing...
- New tune Question
- Oil temp gauge
- Car starts, runs 5 seconds or so then dies...
- 2otl
- What part is this???
- Went to dealer, couldnt find cause of surge! Please help
- Need a Help..!~
- need horsepower numbers or adlease a guess
- Head and Flow Number questions
- Exhaust leak question
- 96/97 LT Headers ... o2 sims?
- Why is my low coolant light on if im not low on coolant?
- Doing hotcam kit, what gaskets.
- Got the car dynoed....
- SLP headers and burnt plug wires
- Can I reuse the stock head bolts??
- Soundclip of idling in my ride
- missfire?!?!?!?!? Please help!
- Ok, Can someone help me?
- what size bolt
- Blownup DS
- 100k mile stock LT1 rods and crank - worth reconditioning and reusing?
- Quick Carb Swap:can It Be Done?
- is it worth it to get an electric water pump
- Headers
