View Full Version : LT1 Based Engine Tech
- Blown Headgasket
- Has anyone cut valve releafs in the stock pistions
- Head Studs?
- So before I reprogram...
- unplug the front o2s?
- Car won't start, electrical smoke underhood
- PCM re programming
- noid light
- Time Drawing Near!!
- 94 Z Help!!!! PLS!!!
- Need help with AC
- Just installed Pace Setter long tubes and duals.....
- 48mm vs 58mm track results inside
- slp manual fan switch
- lt4 valve spring question install related
- Solution so simple yet so hard!! ARGH!
- 383 guys, I keep running rich HELP PLEASE!!
- LTCC Question
- Need some help...
- Any tips for removing frozen crank pulley?
- Cat is smoking = clogged?
- coolant leaking near passenger side firewall!
- Electric Fan Question
- Its official...my car is now a cruiser
- SES light goes on and off on occasion...more inside?
- web page
- Blower HP increase?
- Need info on cats & 02's for 97 Z28
- jet hot headers
- Optispark
- loyd elliott
- o2 senors
- Real Hp
- Tach, Speedo, Security, and a major promblem
- Lt4 Clutch : Need Quick Answer!
- EGR Stuck
- radiator replacement??
- HELP. ABS LIGHT always on
- No SES light when I'm down a cylinder?
- stripping paint and decals
- Orientation of oil pick up tube
- Will a 40LB speaker box hurt my track times?
- Flow bench numbers on ported intakes.
- starter gear position ?'s
- spintech or loud mouth
- pro mags + 150 wet shot
- I'm Clueless, need opinions please.
- Tune-up Questions
- could this be the opti?
- Throttle problem
- Cam decision time. which ones to choose from?
- Rksport headers or ASM which Y pipe
- O2 simulators for a 95 lt1
- single cat headers on dual cat car?
- Do you think I will hit 375rwhp w this combo?
- Idle surging, loud knocking at bottom end...now what's wrong?
- Change Cam with heads still on?
- Timing Chain Question
- where to get a good dynotune
- Low Rpm Stumble and Rough Idel
- mac midlength headers
- GTP LT4 Heads
- My Car is Dead
- throttle body brand
- Which one to go with
- lt4 valve springs??
- Part no. for this? Shoebox?
- Rear Seal Problems!!!!!
- header question
- 93Z, $4650 what do you think?
- What is the diameter of y pipe that comes w/ slp headers?
- Checking Codes?
- Hooker LT and gasket porting Question
- EVAP system question (Injuneer or Shoebox maybe?)
- Solid roller cams
- heads and cam predictions
- Exhaust size question
- PCMFORLESS "Load it Yourself"
- Occational rough idle
- headers and o2 delete?
- B&M Transpak
- problem with brakes
- ok check engine light, heres symptoms
- New Z onwer! LT headers question
- Installed my Pacesetter Lts today...thoughts within..
- Will F-Body accessories work on Y-Body bracket?
- Unending Overheating Problem
- Help me find this problem..
- stock Z at 4400ft elevation track times???
- 7/16 rocker studs
- Oxygen Sensor..- can i run with one?
- 396 Lt1
- Do bad 02 sensors hurt power?
- Help removing motor
- Has anybody here sonic checked an LT1 block?
- Fans wont turn on after header install
- Oil Pump
- need some help with my setup
- Bought these headers/y-pipe ... do i get to keep my cats?
- single cat?
- new dyno numbers
- Anybody exempt drom emissions in the chicago area?
- car is a pos....
- Puff of white smoke when you get on the gas
- Lt1 Help Asap
- Need some gasket part numbers.... blew head gasket
- Stall w/ LT4 Hot Cam?
- Installing ICM
- Lt4 Hotcam Or Cc305?
- Pushrod length for a 383
- Help with Engine Trouble Code!!!!
- Reluctor ring p/n please
- just tore motor apart
- opti spark or another problem???
- TunerCat v1.98 demo needed
- Where is cheapest K&N?
- which to get first....
- 3 series in 2 series carrier gears
- BBK Twin 58MM Throttle Body
- trouble starting?
- Loudmouth?
- Question about removing AIR pump...
- guy with duals what mufflers are you running
- Harness help
- figured out why my engine was stalling...
- What should I tq my header bolts to?
- CODE: P0420 Three Way Catalyst (TWC) System Efficiency Below Threshold (Bank 1)
- 428rwhp/441rwtq from hotcam with stock ex. manifolds!
- Fuel injector fuel percentage changes...Fred, etc?
- Whistling sound when I start up my car????
- Solid Motor Mounts & Knock sensor
- Fuel pump
- Ok... Has this been done before?
- Aftermarket ignition?
- Heads and Cam or Forced Induction?
- vacum line from tank broke?
- car almost blew up
- Delteq installed!!
- What is everyone's mpg
- Clutch Install Question???
- Could I have an exhaust leak?
- Heads and cam complete!!!!!!!
- you guys pick! 224/230 or nx wet kit?? 125 shot
- cc306 ???
- Problem with Throttle Body Bypass!
- Oil pan options for LT1
- looking for a cam. help
- secret to removing bezel??
- Fuel problem
- Where to get Ported LT1 intake?
- poor idle when cold
- Best 383 400HPish rotating assembly
- 383 buildup have some questions?
- Is This Valve Float?
- 383 Dynoed today
- Mobil 1 SUV/Truck
- Take a whack at what Will I run
- 383 LT1 issues, help please
- Nick Agostino is taking care of me
- 1LE Elbow, worth $45?
- HELP plastic blocks fell off oil ring
- Will this Hooker setup fit?
- How much HP is the stock crank good for?
- 30lb injectors on stock tune
- Pics of my GMMG
- rounded off nut
- weird problem
- 1.6 RR from summit
- Code 44 help please, Scanmaster readings inside.
- Hesitation under acceleration
- In the middle of t56 swap, have some questions
- Shorter o2 sensor
- SLP instal kit???
- head bolts,,where to get them??
- Need part numbers
- Help me prove the dealer is full of it!!!
- Header bolts - help..
- Custom set of valve covers
- LT4 heads, where and how much?
- Can anybody refer me to a 3 Step Colder Nitrous plug?
- Which one do I have? OBDI or OBDII ??
- throttle body bypass question
- code P1626, need help
- true duals w/cats = bad idea
- Picking a coil...
- car not running right...
- Bad gas mileage+real bad studder=o2 prob??
- HELP!!! Car died, won't run! Optispark?
- Twin intank pumps
- Help with O2 Sensors problem...
- Cut out
- Cooling fan keeps running
- Need Fuel Pump Diagnosing Help on 95 Z28
- 93 LT1 Headers
- Temp gauge is not working
- Automatic Hotcam guys.. Question
- What is the best ignition?
- I want 300+ CFM LT1 Heads
- Can the springs and RR's from the hotcam kit be used with the CC306 cam?
- QTP or DMH cutout?
- starter wont ingage
- heads and cam???
- retro fit lifters?
- Adding 1.7RR to 230/236/112. Will the car lope harder?
- O2 Simulators, Gutted Cat, Emissions
- LS1 Plastic Gas tank.
- Lucas Fuel Injection cleaner
- Installed Pro Form 1.6 aluminum rockers, lots of noise
- how to tell year of block and main caps ?
- T56 rebuild kit?
- should i put new bearings in or not? please give me info
- Might put nos (should i, can The motor handel it SAFELY)
- Heater Core Hose question
- Question about the Comp R lifters
- Sleeper94
- part numbers
- No spark !
- Time to get rid of SLP headers which long tubes to go with?
- borla
- Need help fast, please!
- Pro's & Con's of porting the LT1/LT4 intake
- i have proof my opti is bad, but can you all check me? did a scan
- Has anyone ever driven a car with a very large cam
- Just wondering, whats behind the ex. manifold bolt holes in the head?
- NGKTR55 plugs
- Intake/Exhaust Install Questions
- Jet-Hot long tubes problems ???
- I am ready to give up,car wont stay running!
- stalling
- Started my Jet-Hot Install today... how do you think I'm doing??
- Problem with Summit order
- Inspection Sticker
- timing chain damage
- car has no fire
- Website with LT1 Seafoam instructions?
- Not Fair!!!!!!!
- o2 sensors
- Who actually likes their LT1?
- Shoebox type question
- Fuel Pressure
- 93 O2 sensor part number
- 02 sensor part #?
- Broken plastic piece on cruise cable-
- WaterPump Question
- Corroded radiator drain valve
- 1996 lt1 missfire on #1 and#2 bad
- 93 o2 sensor extensions?
- Comp XE vs Crane
- cut out effects
- EGR valve question
