View Full Version : LT1 Based Engine Tech
- Anitfreeze in cylinder??
- LT headers w/ SFCs.
- Bolt size on dust shield
- what can happen if the seat PSI is too high?
- Rockers
- Spark plug gap...
- emissions with 1.6RRs, stock cam, but hotcam tune?.
- Swiveling spark plug socket?
- Throttle Body dissesmbly
- dash light ?
- Advanced Induction & Joe Overton
- Stumble and clatter getting frustrated
- eBay Throttle Body
- Throttle Cable
- Chasing Down DTC Deamons
- Quick question....with felpro 1406's work on pacesetter LT's
- What tool for opti screws?
- thermostat
- Header problem
- EGR - Pinhole Leak?
- EVAP system flow during non-purge?
- a GREAT link on fuel systems troubleshooting.
- My first time at the track tonight
- BBK 58mm Throttle Body Idle Issues...High Idle on 383 stroker...
- Put me into the 13's!!
- modifying the inlet elbow
- Dyno #'s and SAE Corrected???
- Throttle Body Bypass for '94 Z28
- Free Mods
- engine started with ~15psi oil pressure.. are the bearings shot?
- Ordered my SLP 160* Thermostat
- Removing heads??
- Main fuse block..
- Water pump replacement for preventative maintenance?
- car dies after 5-10 minutes at idle
- Gm847
- Need to pull oil pan.. is there anything i'm missing?
- What is this thing/what is its purpose?
- Question regarding PCV system
- Help... Pulled my oil pan and...
- grand national injectors in lt1??
- How to remove the dipstick...
- What oil to run? (First time after rebuild)
- changing the rear left abs speed sensor
- please help
- Heads & Cam additional requirements
- locks and retainers? what ones?
- summit or jegs for head bolts
- Mac Header Sound
- computer scanned for SES light, whats this mean?
- www.ls1speed.com
- Failed Emissions horribly....
- GM MAF warranty memo
- What is an avarege cost for a stock rebuild?
- Q about Engine detailing
- 0 oil pressure under hard breaking????
- Ported vs Stock LT1 heads
- best gear for these mods....
- Sensor Free Mods?
- pulled out the plugs and its running rich
- Any way to bypass the knock sensor?
- Roots Blower on an LT1
- Aeromotive inline check valve??
- A general engine rebuild thought for ya'
- LT1: OHV or OHC?
- Ultimate Intake
- need flexplate bolt size ASAP.
- Airbags Life Span
- head/cam package
- How do dif gears make me go faster?
- taylor plug wire repair kit
- Problem of not starting
- How safe will it be to spray a 100 shot on an LT1 with stock internals?
- scanning for codes
- Comp Cams Spring #977-16 Installed Height
- Still Stumbles after speed dens. check, o2's ruled out?
- Trickflow or Vortech
- tell me what is wrong...also rebuild prices in Orlando Florida.
- Cam is in, and it runs! Video within!
- Proper break in procedure for GM 847 Cam
- Piston Rings
- What?? Pcm Possibly Bad Or Something Else?? Weird O2 Readings And Other..please Read
- Longtube or Shorties??
- Heads- If you increase CFM & Velocity u will gain hp.?
- Will Stock 96 Exhaust Manifolds fit a 94?
- Single plane intake's on LT1's
- Carbed LT4 with XE224-230..what'll it do
- Could false knock feel like a very bad miss?
- Jet-Hot header A.I.R. fitting problem - sent the wrong thing?
- Another guess my time question
- Single cat vs dual cat MACs
- Track Times and Dyno
- Intake Tube
- LT1 Running Rich
- 97 ws6 modifications
- what causes low coolant light?
- Diagnostics say continous misfire....
- Assembling my LT1 shortblock
- Anyone Run stock convertor with a cam?
- Engine hoist ideas
- SOMEONE please help!! is it IAC??? OR TRANNY OR WHO KNOWS....
- Help Car running like crap (Multiple choice lol)
- looking for info on 23 degree heads
- Chambered Muffler True duals (GMMG type mufflers) anyone researched it??
- Would 2.5in. duals, x pipe, and bullets be much quieter than 3in?
- Anyone in the PA NJ DE MD area.........
- adjusting rockers w/ engine running
- CR help
- Austin Qwik Stick Pics
- MSD Coil a good mod??
- question about PCV valve...
- Header Install
- hooker longtube install
- New dyno numbers
- squeaking
- Timing Chain???
- oil and tranny fluid
- o2 Sensor
- money!!!!!
- suggestions on plug wires?
- Just scanned car, please decipher!
- need help???
- LT1 codes and passing VE Test's?
- Found a busted thread on the head
- question...general question about 1990 Toyota truck, gas in oil???
- DYNOED the TA today, a freak bolt on LT1 !!!
- My 383 Dyno Numbers
- Custom Ram AIR
- Here kitty
- Pacesetter LTs vs MAC Mids
- Borla electronic control link?
- Tune-up?
- no start condition
- Running solid lifters on a hydraulic cam (roller)
- Help me guys, im fed up....
- Comp 941 install height
- Help with MAC header install. STUMPED & NEED HELP
- What The Perfect Cam For My Lt1
- Going to the Dyno...What should i do..
- Spun bearing...
- Idle air control (IAC)
- Can I remove the intake with the fuel rail attached?
- two different kinds of GM pushrod guides for LT1?
- Diagnose my car for fun...
- Questions after Long Tube Install
- Finished XE236/242 install, now BIG problems...VIDEO WITHIN!!!
- maf vs. speed density
- Oil pressure
- relocated asr? if so where?
- MBA Fuel Rail Covers with LS1 coil brackets
- miss after cam swap
- tuning cords..which one from these 2
- Flywheel or no?
- Nice to be running on all 8 cylinders again.
- TrickFlow LT1 Cylinder Heads
- Low RPM Stumble
- MAC hassels...
- must be opti?
- Thank you to everyone!!!
- Car runs like s***, HELP!
- Spelled Toluene right???
- madz28 tuner question
- I just took my cat off
- Pulling Dowel Pin out of Cam??????
- K-Member
- Aha!!! FOUND IT!!!!
- CLICK CLICK CLICK CLICK CLICK and Seafoam tip!
- check out these cme ex tips
- Normal/Safe engine temp?
- Bosch Oxygen Sensors
- Tming cover question, I need a quick response please!!
- Throttle cable removal question
- re-adjusting rr's again... should they be a little loose when motor off?
- Throttle Body
- mac midlength headers
- looking for Hi-temp hose for air pump
- Heater core bypass Q
- *HELP* Just finished cam swap, only 2 cylenders are firing!!!
- oil pressure help!
- I have the following mods - ANY MODS I SHOULD GET RID OF FOR BETTER PERFORMANCE????
- I think I am screwed.
- Quick EBCM question
- SES Light, Diagnostic Codes: Po101, Po300, Po400
- Hooker LT Installation
- Where should the Wide Band Oxygen Sensor go for a Dyno tune?
- rebuild first...top or bottom?
- Can our cars be tuned to run 87 octane safely?
- summit part #??
- Hot !!!!!!!!
- **Please Help Spark Plug Nightmare!!!**
- car wont start
- OMG I think I need a rebuild!!
- Popping / Backfire from exhaust
- Is anyone running the CC .224/.236 114 Extreme cam?
- DO i need to progrma the PCM if put on new gears
- what gears came in the 97 ta 6 speed
- Spring fitting
- Gasket problem
- Need some quick Optima battery help!
- LT1 and L98 motor mounts
- LT4 Conversion passed emissions!!
- Cheap mods?
- disable egr and smog pump?
- front O2 sensors
- Any tips on OVC taylor kit?
- Have a LT1/sbc question, really could use some help on this one
- Engine going in, what can't be attached
- What do you guys think?
- Rough Idle After Hard Braking
- SES Light Appeared
- descreening MAF
- AC delete, what do I need?
- Spark Plug Recommendation
- I think its broken
- Bad Performance,bad gas mileage, and more exhaust fumes?!?
- Can I relocate my coil and/or module?
- NEED HELP QUICK! tranny cooler
- labtop tuning
- How to adjust rr's
- engine stumble
- header recommendations
- stripping the car
- Roof falling down
- optispark?
- TB bypass (question)
- wiring harness
- Gasket for oil filter adapter?
- Z-dimensions
- What would this cause?
- Quick throttle
- question
- Under the hood pics of '96-'97 SS factory inertial supercharging intake setup?
- nub ?
- 383 Build worth it?
- Comp 'R' lifters, CC Pro Mags users
- Simple Scanmaster wiring question
- Got my PP93 T/A Dyno Tuned......Something seems off....
- reasons the car wont idle
- Removing catalytic converter
- Dyno Tune Question???
- Manual fan switch kicking my arse!
- First Run!
- Thinking about a cam.....
- Almost thought I blew a head gasket
- comp r lifters,,,hydrallic ?
- is it easy to change injectors on a 93 LT1? also - would 24# from a 94 work in a 93?
- No Backpressure????
- Oil Pressure
- 94 LT1 in a 96 Z28?
- suggestions on changing oil pan gasket
