View Full Version : LT1 Based Engine Tech
- What's this bracket?
- Is this my starter or something else?
- Sluggish response
- after my jet hot longtubes didnt prog pcm for egr air del...inside
- car backfires, etc (inside) when it reaches driving temp, thenSES comes now runs good
- Still having fuel problem?
- Belt Tensioner
- Oops, are there alignment shoulders on the rear oil pan studs?
- lt4 extremeduty timing set costs more than individual parts?
- How Does Pinion Become Loose!?!?
- ABS over-reacts, then ABS inop (not a false alarm)
- Air Filter on throttle body / ducting
- thunder racing ovc kit and coolant questions
- HVAC Vacuum Check Vavle
- lt1 radiators
- Problems with O2s
- transmission problem?
- Overheating Problem
- serious misfire
- useless or not?
- Fuel Pump?
- misfire PLEASE HELP
- Racetronic 255lph Pump & Wiring
- got 22lb leaking injectors
- Shocks or LCA's?
- pass. side o2
- opti delete cover
- which ignition box do I get?
- Piston to wall clearance ??
- airbox gasket
- Where to buy NEW opti ?????
- Which exhaust is quieter?
- Where's everyone getting opti's from lately?
- Header question
- Running wrong size injectors, how much loss of performance?
- 3/4 turn to much preload for stock lifters?
- Can only get master and slave together..
- Any difference between lt1 and ls1 lifters?
- 5100rpm missfire
- Need help finding...
- SStrokerAce, update on LT1 intake?
- Cam "walk-out" plate?
- Whats my 389 gonna make
- 97 intake on a 93 lt1
- Spark Plug wires...
- 93 LT1 OBD1 Trouble Code Process
- Injector Question
- SLP Spark Plug Socket?
- Low oil pressure?
- Best Place for heads and Cam Gaskets
- Y-pipe/header install to convertible 6 sp.
- granatelli 85 mm MAF...? inside
- How to wire up SS spoiler ???
- Spark Retard Question...
- This happens only when I drive for the first time of the day...
- piston rings?
- Compression Test!! Confused about Results...
- Some advice for those removing exhaust manifolds.....
- 94-97 intake on a 93
- LT1 help.
- Tuning for SVO 30# injectors???
- Should i Change this????
- Electrical Problems
- What kind of headers to get?
- Starter/Wire ques.
- flywheel shim
- Glove Compartment Question
- Car goes slower after headers?
- engine running to cold?
- How big should i port my Throttle body and intake manifold?
- Pacesetter Headers
- Jet Hot LT's defects
- Some food for thought on shorties vs. long tubes
- Is anyone running o2's or o2 simulator on hooker lt's?
- Stock manifold bolt keeps loosening.
- New Balancer
- Want to hear cars with the XE 227/233
- lt1 fluid capacties
- Which direction do I install pilot bearing?
- Aahhh, Can't Decide What Headers
- Vortec heads?
- gettin ready to buy a 94 fornula,console, window, ecm questions??
- How do i check if my thermo is bad
- Gains from Headers
- What else do I need for a Z28 - SS Conversioin?
- new to atlanta
- MAP reading under Nitrous
- How to repair a broken window?
- fuel injectors
- Banjo bolts
- Exhaust gaskets
- 93 LT1 brakes on an 88 iroc
- Pacesetter Install Questions...
- anyone have pics of pass o2 sensor wires
- mid to high rpm skip
- pacesetter long tube egr problem!
- How much does wheel weight effect 1/4 time?
- Opti Need Dal"s Number Asap
- Fuel Pump Whining
- Rounded off oil pan bolt??
- Jet-Hot Owners (plugs issue)
- post header install problems...
- Which Injectors Can I run on my 383 Stroker?
- idle value
- post cam csv or datamaster file...can someoe shed some light
- plug and wires just finished/WOW!!!!
- How can you tell if you have good compression on a motor???
- tranny prob at higher RPMs
- SVO Injectors Install
- no start
- o2 sensor replacement
- Intalling GM 1.6 RR with engine running
- 1/4 turn or 1/2 for rockers?
- a4 problems at track with stall
- Cheapest performance upgrades
- Air Conditioner drainage tube?
- Car dies when hot!
- What are the chances?
- Trouble starting has me confused....
- egr
- quick cat question
- any free mods for my car?
- Decided on Magnaflow, now where do I buy it from?
- factory oil cooler?
- Cam cause spun bearing???
- seafoam substitute?
- attention ion madwolf
- Just got done putting on my Magnaflow.
- B&B tri Flow Tips For LT1
- Low Oil Pressure
- Trucks almost done... Need some HP and track time estimates....
- Motor bites the dust after cam install
- bad miss
- cam question
- online places to buy plugs/wires?
- Rpm
- WTF (a4 issue)
- Please Help new LT1 Problems
- Differences between exhaust 95 and 96??
- smoke from oil dipstick tube
- Low oil pressure when idling
- car does not want to idel
- Cooling FANS
- prices on porting heads
- just installed my TA rear diff girdle. some ?'s
- new engine problems...oil pressure
- cam prices on lt1
- Exhaust question?
- Hrmph! Not good times. Help me pick apart 1/4 probs
- American Thunder?
- 355 stroker
- 355 stroker
- Hard Starting
- Need some Help on bearings
- Open Header???
- Windshield Wipers point up when i turn them off!
- Is my fuel pump going bad? 40-30 psi?
- Where to get new coolant hoses?
- How can I test 02 simms to see if they are working correctly?
- How many miles is too high for LT1?
- Will 02 simms function on an OBD1 PCM?
- Did a Comp "R" lifter, valve lash test today on my Z. Findings within..
- upgraded to 30# injectors, NEED HELP!!
- Question about low oil pressure
- Single OR Duel Electric Cut Outs?
- intermittent code 42
- Wiring up a shift light?
- 383 re-tune
- any1 ever had a MAP sensor go bad? read..
- Opti Swap, have some questions.
- O2 Sensor??
- Running rich - new fuel pump
- lt4 conversion on a 93?
- Great! small bolt wedged in header collector! HELP!!!
- CSI Install Questions
- car got hot hot hot
- Camshaft uproar! I'm playing with fire here.
- What the best Smog Legal Headers?
- alternator only putting out 2v at 2Krpms, please help!!
- Advice for the Track
- Need Help Pleasee Read!!!!!!!!!!!
- Coolant in oil but nowhere else
- Odd cooling system problem...
- o2 sensors
- Air foil
- opti install???
- which opti?? ASAP
- Bad intake leak?
- rocker lash setting poll
- Exhaust mani bolts...impact or ratchet off? Reinstall torque specs?
- hard start B#@#!
- Best sounding cat-back for money?
- Recalibrate TPS???
- Single Cat y-pipe fits dual cat camaro?
- MAF not working
- Best aftermarket ignition box mounting locations
- Dangers of the LT4 KM
- hooker headers
- Having major problems with voltage and A/C.
- Plese Need Help Cc305 Prob
- valve springs
- ses light comes on, jerking stumbling backfiring
- where is the air pump located?
- headers
- PCM Programming Question
- air pump fuse?
- Engine problem (loud ticking)
- Oil Spray or Power Steering Spray?
- "You've gotta weak #5 cylinder"...?
- Is this a good deal on GM 1.6 RR?
- Whats the quietest, least restrictive muffler I cna replace my Flowmaster with?
- Why Does This Happen
- Difference between AFR 1100 &1101 series 210cc heads??
- Ex. Manifold Gasket Change Advice
- o2 sensor voltage readings
- Good header/cutout combo?
- Security Light
- attn: madwolf
- Where can I see a '95 Z28 LT1 power curve?
- **Getting my car back from the shop!!**
- STILL intermittent lack of power??
- Is there an alternative to cleaning a K&N filter?
- header tuning?
- How much does your 60' time affect your 1/4 ET?
- What times should I be running in the 1/4
- Its like I'm hitting a wall at 3K RPMS and not wanting to climb any higher!!!
- Cooling
- what kind of gains should I see from 1.6 RR's, LT4 Valve springs, Comp Push Rods?
- OTVC Kit installation??
- Starts Sluggish - Old starter?
- Question about stock manifolds
- "Charcoal" Canister PN and cost?
- Purpose of Heater Valve ASM #10188036
- My car is now stripped what to mod
- Flowmaster Exception?
- Shoebox, Can you help me with a couple of part #'s please ??
- need some help! ignition issues.... grrr!!!
- Best place for 02 extentions.....?
- Buddy's Car Running Bad Code 36 & 42
- Start it up or be cautious
- will 93 V6 springs work on 97
- Heater core by-pass
- temp gauge ?
- Oil Pressure Sensor Loose
- Help with plug and wire change needed
- Need alt part number
- JET HOT Long TUbeds. INstall!!!!
- Glasspack muffler?
- Where to get Racetronics Plug N Play fuel pump?
- car dies after tb install
