View Full Version : LT1 Based Engine Tech
- So since I have to pass visual emissions testing......
- a/c fuse keeps blowing!! Need help
- fans won't come on, done much searching
- 6 cylinder auto trans
- Fixing intake oil leak....
- Are CNC profiled chambers worth it?
- Need to replace A/C.. info needed
- Read this ... see where I can be saving money ...
- O2 sensor thread size
- what offset rims?
- what legnth O2 extensions?
- What kinda #'s would you expect from...
- What else in addition to LT4 Hot Cam kit?
- car studdering bad. need help
- Code related question
- Borla & AS&M Rocks!
- Flow numbers...
- TSP Rumbler arrives tomorrow!
- When to clean filters?
- Racetronix pump and fuel pressure problem
- Jet-Hot LT problems
- Engine block ??
- Pacesetter Long tubes and BMR k-member??? Anyone have this set-up
- See if we can solve this...
- crankshaft position sensor
- Edelbrock Headers....Opinions?
- BMR K-member won't work with SLP's....
- hypertech programer Q
- JH header bolts/ fel pro gaskets?
- IP Dimmer fuse: Does any its wires enter engine bay?
- CSI Pump question
- Can you put an opti on wrong?
- After MSD otvc wires, all of them are arcing...
- Help please!!!
- LT1 Exhaust...NEED HELP!
- Leaking Oil!!
- Tip for people thinking about an OVC kit.
- Anyone had heads ported by Lloyd Elliot?
- Couple quick question that I need opinions on
- Valve and seat angles and widths
- Next mod
- Fule presure Regulator help
- besides check value, where else is a common vacuum leak?
- Click! CLick! Clack!
- 400rwhp 350
- stage 8 header locking bolts
- Lifters from a 94 different then 97?
- Unplugging Air Pump on 95' Z
- pistons pins. pressed or bushed?
- anyone know the differences in a wide band O2 and our stock 4wire?
- Pushrod length
- mods to beat an LS1
- OBD1 SES Problem
- anyone running T&D shaft mounts
- Horespower guesses?
- LT1 to LS1 Conversion
- Inspection Probs??
- stroker rotating assembly-best way to balance
- installing crankshaft hub
- Hey shoebox???
- HELP quick ? about catback size of piping??? 3 in or 2.5?
- OVC Wire Boots... just a rant
- green or orange coolant?
- Starting Troubles
- ovc kit needed with rksport middie headers?
- annoying rear brake squeak
- What do you think of these heads?
- lt1 intake elbow
- crank pulley removal ?
- Hot Cammers in here please!! (or others)*****
- Please TAKE A STAB at this and PLEASE help me out
- signs of blown head gaskets?
- DTC=PO151
- Car needs to be FASTER!!!!
- 383s and the Cyl head/Cfm need to feed them
- best cam
- Different color valve cover
- Fuel Pressure Tester
- sent heads to Lloyd
- Can i get a good set of heads for 3000.00
- need some part #'s please
- Plz!! need quick help with Manual fan switch install
- Friggin Starter!!! #$^@#
- reinstalling opti help
- Racetronix Pump & Harness is teh Schizzle
- Any way to make Crane Gold SA rockers work with 10-degree retainers/locks?
- Help Me! Codes, Maf! Please
- Oil pressure situation. Advice needed!
- Removal of AIR pump hard lines?
- Heads and Cam Install
- Will CC magnum 1.6 SA rockers fit stock valve covers?
- help with exhaust and engine
- LE3 with a 383?
- lt4 km worth it right now?
- header installation question
- idle on decel
- 210 normal for coolant temps on a regular day?
- Anyone have flow #'s for trick flow lt1 heads?
- Real lt4 roller rockers
- son of a ..Bought the wrong rocker arm nuts
- 1.6 Rockers, adj
- MAF dying
- backspacing on 15x10 Telestars
- a little help here please...
- Replaced opti, still have a miss
- Flushing coolant passage
- Car vibrates t-tops off windows up
- Dropped a cylinder
- after head/cam , car still isn't fast ???
- timing cover install question
- Could Flywheel screw up while running?
- Opti spark takes a swim
- New 355 Problems!
- Stock Replacement Lifters or Comp R's
- rk sport headers?
- brent, specific question for you...
- can u run cc305 on stock converter safely????
- cc305 or hotcam kit plz help!
- High speed vibrations
- crane gold RR & stock valve cover ?
- Fuel pump going out...signs?
- who's changed from LT's to mids or viceversa?
- Tach won't work after LTCC install
- Optispark
- Is my new thermostat stuck?
- Exhaust Question
- 300rwhp
- New fuel pump needed?
- Specs on a GM 847
- studder, hesitation...
- in park the car revs up
- Fyi
- going to Seafoam my car tommorow...
- Guide to removing and installing new heads
- Fuel pump replacement
- shorty spark plugs with LTs
- Rounded header bolt
- Exhaust leak...
- Is the 98 lower a-arm the same as a 97 lower a-arm?
- Motor dies at random
- I'm a cam dummy!
- Help me choose a cam!
- No Vacuum Check Valve!!!
- Where can I get center caps for my 16"s
- Turn Signal/Backup Light Fuse Blowing/Melting VERY ANNOYING! Help Please!
- Help!
- Which Autolite plug for this setup?
- what 1/4 times?
- Question about Free Scan
- Long Tubes + Custom Y-Pipe and now HALF as loud!?
- What clutch?
- My lt1 is very inconsistent for mph help.
- Important Thread- ARP Main bearing Bolts
- Fluid dampers on EBay right now
- LS1 or LT1
- How much HP?
- Power and ground wires for headlights
- Thermal Expansion on valve lash question
- Sensor for Temperature Gauge
- My Lt1 Just Died On Freeway
- lt1vsls1 bore & stroke
- comp magnums vs pro magnums
- What the Heck just Happened to my Car?!?! Need some Help!
- Tq # for crank hub bolt?
- Programming PCM after cam install???
- gasket set for LT1?
- how much hp?
- Edlebrock LT1 head & cam package
- DMH Electric Cutout
- GTP-6 cam
- What are my Options- ARP main studs dont work with Windage tray.
- Proform Valve Covers on AFR 220s?
- Where can I buy O2 sensors?
- Help! How to take off wiper blades?
- Hooker Longtube Installation Tips
- shoebox, come inside please
- CSI Electric Water pump-Cheapest price?
- How much more $$$ for this
- Hot car....
- Back fire at high revs
- For Guys who Bypassed there knock sensor
- oil leak? Again?
- a little white smoke from exhaust only sometimes
- Pcm?
- Anyone drop LT1 with Sportslines and 2.5" duals?
- inconsistant idle
- valve spring install cost
- What am I missing? Hooker LT Install
- Which is a better camshaft Hot cam or cc306??
- water pump gear
- Scat 9000 383 guys: Did your balance job come out this bad?
- Single Cat Conversion, Need part # for AIR Part?
- What's an R bit?
- springs with new shocks?
- LT1 Dyna Tech Headers worth it?
- doing cam swap, waht all will i need, and
- Has anyone run a POWERBOND balancer? What about JEGS?
- SHOEBOX, need quick part #
- 4.88 Gears
- Help WIth Cold Air Intake System
- A/C delete??!!
- agressive clutch chatter after cam instal
- Can LT4 springs handle the lift of a C305 and 1.6 RR's?
- Diff from ebay ?
- what the hell? Ignition issues?
- does anyone make a 3" cable operated exhaust cutout??
- HP/ spring pressure limit on a stock timing chain?
- 236/242 @ 608/576 on 111LSA too much for stock bottom end??
- temp. questions
- adjusting your idle speed
- Cam
- What happens when you have a bad oxygen sensor???
- washed engine. wont start
- dynomax exhaust, good or bad?
- Oval Exhaust
- LT4 1.6 rockers with crane 10308 springs
- Crane HI-6S ignition problems
- 1.6 RR on on redone stock heads and springs?
- Power window fix (not the usual one)
- bilstein, KYB, kokico?
- which headers?
- shoebox, I have a question......
- Help! No Compression!
- Serious closed loop problem please help!
- fuel pump replacement
- Quick Hooker LT question
- 7/16 Pro-Mags and stock valve covers?I
- Help with miss
- SS brake light question
- rpm stuck at 4500 ??
- Thinking about a budget 355, but some worries have me thinking twice now.
- need tranny removal help
- Is this the kind of trust I can put in Comp "R" lifters?
- a/c stops blowing air when there's load on the engine
- atlernator bracket question
- Cam?
- Trick flow intake elbow
- Why does my vehicle speed sensor crap out all the time
- water pump mech./elec.?
- Pics of the Track yesterday at RT.66 Raceway Joliet IL
- 75mph and the fans
- Just bought a car
- rebuild kit
- 1997 timing cover part number
- Dead Soft Aluminium???
- Help With Cam Decision...
- Fastest N/A LT1 with stock style intake?
- MG some help with a 355 build up
- RPM surging
- Free mods
