View Full Version : LT1 Based Engine Tech
- will my pacesetter y pipe fit up to stock 2 3/4 I pipe ?
- $3,000 to spend!!!!! ideas
- how much $$ did i need to keep a Z06
- Vette LT1 vs F-Body LT1
- which cat-back is best?
- Engine shut off when A/C was turned on
- wide band reading a/f ratio of 14.7 when cruising, is this right?
- have fuel in my oil HELP
- Quick o2 sensor question, P0153
- Plug Wire Arcing?
- Which cold air intake to buy??
- BG Fuel Pump
- Strange intermittent electrical problem, shorts out entire car?
- Lifter Tick...
- followup to lt1 mystery
- Dynatech Headers? Who has them
- Screwdriver meets cylinder wall...Picture
- Pin hole leak in coolant line
- How hard is it to install a cam?
- my cam selection...
- Cylinder head experts
- ?'s About O2 Sims And Cat Removal On 97's.
- Am I expecting too much out of my heads/cam LT1?
- whats wrong????
- Relocating ASR/TCS???
- Taking off Main cap bolts, They need to be dipped in oil right?
- Starter Solenoid help!
- Will 94-95 style BBK shorties AND y-pipe kit work on my 97 dual cat car?
- throwing a code - po152- bank 2 sensor 1 o2
- Tuning??
- Running after-market heads on a stock cam.
- strange noise on startup
- Now what?
- What's next?
- Intake Oil Leak Revisisted
- Quick Tuning Question!!
- Rearend Problems-Upgrade?
- Can a random tech cat get clogged?
- gm847 help!!
- Custom Y-pipe, $125-$150
- AIR is only in use when car is cold, right?
- guys w/3.73's, got a question
- Grounding Kits for LT1?
- Track times
- A lot of clunks and rattles after LT header install... normal?
- Blew head gasket, need help
- vacum line location from elbow?
- How to hook up a air/fuel gauge?
- What about a throttle body?
- zz4 crate motor???????????
- Opti Spark
- Stock heads on a 383?
- thanks shoebox....
- Ohio Machine Shops?
- Stock cam = roller cam?
- Does a LT1 run better uncorked? (open header)
- LT1 vs LT4 intake?
- knock sensor falling apart...4 times. Why?
- Clutch Problems that WILL not go away!!
- Shift knob raises up, Trans Mount??
- Where can I locate Lloyd Elliot to port and polish my heads??
- how to route opti hoses
- Correct part # an fitting to shrader valve?
- what to do? tired of opti problems.
- need help
- What brand of injectors?
- Vats?
- Needing ideas...new goal of 11.28 all motor
- 224/230 timing ?'s
- 160' thermostat
- convince me to buy LT's over shorties please........
- MAF is dead
- DTC 24, anyone know what it is???
- air/fuel ratio on datamaster
- SLP Loudmouth...
- My engin'es toast UPDATE !! (with pic's)
- Tested tonight....longtube 1/4mile results
- Need help asap on which pistons to buy
- Dismounting tires by yourself
- Green wire on the drivers side spark plug harness?
- Delteq or no?
- cooling system problems (maybe headgasket?)
- Brake Light re-adjusting
- torque on lugnuts
- low coolant & service engine light is acting up
- Car Question
- Idle problem
- AS&M/Rksport header ?'s
- Fuel injector Questions...
- Cleaning the MAF...
- adj. fuel pressure reg. and guage
- ses light!!!
- Purpose of Resonator tube?
- SRP Piston/wrist pin/rod assembly???
- Anyone else have an MSD problem?
- oil pan gasket
- header flanges
- Gauge lights blowing when I put car in gear...
- Sweek....help
- Summitt Racing X-Pipe???
- Tuning a '93 Z28
- jet fan switch
- unlock a steering column on 97 z28
- Knocking sound coming from engine
- help with trouble code P1441
- any tuner besides LT1edit for obd2 cars?
- Removing SLP header.
- having somone do the cam install for me?
- Exhaust Low Cost
- Cam install update #1 + questions
- machining heads for 987-16 springs
- How much horspower should this setup give me???
- Arcing woes... those who have experience pls help me!
- LS1 injectors
- Rocker arm nuts coming off hard.
- stock cam part #
- What else needed in a Cam Install?
- ASP Pulley Squeek!!!
- Mpg Omg
- Another what will i run!
- Mechanic can't remove my crank hub
- Clicking noise
- Cam Advice and Opinions
- My specs from freescan in a WOT run (1/4)
- Anyway to test an electric waterpump?
- oil pump question...
- need ideas on my starter problem
- gaskets
- Track today (rt 66 IL) and KNOCK!
- 383/396 guys inside, post your NUMBERS
- Whats the difference between LT1 aluminum and Iron heads?
- Another exhaust question!!!
- what do u guys think i will run?
- How many break in miles?
- i need help!!!!!
- How much flow...
- Good cam for my setup?
- LS1 rearend in a LT1?
- will my SFC's get in the way of true duals?
- Switching From A V6 To Lt1???
- Timing and its effect on exhaust popping?
- Car wouldn't start? MSD Dig 6?
- Just MotorVac'd my car - Details inside...
- Wierd Lean...
- Head info...
- Is this combo worthy of 12's??????
- Cars bleeding badly....
- Knock Readings?
- Who has a pinion snubber, does it work, and where can i get it?
- increase gas mileage
- What are wrist pins and spiralocks?
- Valve Covers, How much taller for T&D Shafts?
- do i need 30lb injectors?
- comp cams 1.6 magnum rockers
- LE2 Head flow numbers
- AS&M header collector size?
- what size# injectors are these?
- Oil Filter Question
- 97SS Are cats plugged or shot
- happy
- Borla Exhaust Hanger
- AC line is touching #2 primary
- GM parts supplier
- RK sport high flow cat dosent look high flowing
- Stock Bottom, Big Cam Guys!!
- Importance of IAT sensor?
- need some help, running rich
- New Tstat?
- Hollow out Cat?
- RWHP limits of stock fuel pump?
- Head install Questions
- HELP! Car dies on freeway
- Summit Elect. Water Pump vs Meziere
- High RPM Backfire When Hot
- 396 M6 w/ 3.23 gears. How much am I leaving on the table?
- car wont start
- Ordered Magnaflow Cat-Back
- Oil Leak?
- valve train noise
- Low RPM stumble after electric cutout install........why??
- Bin file for lt4 hot cam kit (I need reallly bad plz).......
- How much of engine can I put together so it fits thru top
- Door panels
- Need HELP with the combo, 383 what do yo think..
- $546.96 gone......A couple Q's to help me out.
- headstuds Vs Head bolts
- Got a new Z28
- Is the LT1 rotating assembly internal or external balanced?
- LT1 Computer question
- Do these stock dyno numbers sound right to you?
- What solid roller lifters can be use in an LT1?
- please help! fried wires , and need advice
- OVC plug wires touching other wires
- LT1 Guideplate question
- Installed cam but can't adjust valves properly.WTF!!!
- Engine Swap Questions
- PVC Vacuum Port Best Place
- hooker lt
- ugh! my brake lights only work "ocasionally"
- Ram-Air Part #'s
- Those with Sportlines, what exhaust?
- Could hydraulic lifters collapse at high rpm and bleed off oil pressure?
- Exhaust popping due to bad O2 sensors?
- AC Compressor Pully - Is this normal with engine running?
- Speedo gears in a 93? shoebox?
- Help..logging specs via freescan
- How much I'm I looking at a bored engine to a 355 or 383??
- 1" ARP Header Bolts? where?
- cam timing
- diagnosis
- Max Rev 383 LT1?
- Want to spray a 100 shot NX and want 400rwhp, is this okay on an LT1???
- How much extra Horspower should this compo give me???? is it worth it???
- Will ASR axle fit in NON ASR vehicle ??
- What a hack job
- P&P heads on stock Cam?
- Question about a pipe on the backside of the motor.
- Low Idle Problems
- Velocity Numbers?! Why Does No Head Porter Post Results?
- how to bleed air out of cooling system
- help please window problems
- which cam should i go with?
- What is a good streetable stall converter for a CC306 cam?
- Cell #16 BLM 160!
- nothing but air comming out of top bleeder valve when car is ideling
- by-passing the heater core good or bad and how
- Why is my car so slow
- Is this a Good rotating assembly for nitrous???
- Rear main HELP PLEASE!!
- What would cause left bank to run rich?
- Gas smell in intake? Why?
- M6 Basic Questions
- Worked On Alt. Now A/c Doesnt Blow Cold.
- Can I pass emmissions without EGR?
- SLP Header help please.
- Hyptertech and a Shift Kit
- Intermittent Problem From Hell (very long)
- Replaced Two Alternators in a year and a half?
- Distributer Seal Leaks Oil
- ET Change Going to 1.6 Rockers
- OTVC Wire Question? Pic inside!!
- smoke comming out of my rear passenger side tire!????
- anyone w/ stainless works y-pipe?
- still got a vacuum leak somewhere...
- Pacesetter Long Tubes - Reviews (LT1)
- Terra-Clean VS MotorVac Carbon Cleaning
- Flow results. Reworked heads
- How to stop my QTP electric cutout from leaking??
- RR cyl heads and intake
- What all is needed for a full tune up?
