View Full Version : LT1 Based Engine Tech
- Not a typical Head Gasket Question......
- Error code 99 low tach output
- Wrecked the car and airbags deployed. What do I do to get them reset?
- Good cam for stock 350 LT1 motor with 98,000 miles...
- going in for my dyno tune wednesday....got some ??'s
- Do I need a new Optispark?
- Alternator rebuild questions
- My car is overheating
- Edelbrock/BBK 58mm tb any good?
- fuel pressure drop
- Felpro header gasket number, not the 1406
- lt1 spark plug gap?
- 3.42's with cc305 and LE heads?
- Need help with Car
- Times with LT4 conversion Kit??
- Magnaflow install not as good as expected.
- Car missing again, it's back! Please help!
- quick question????
- Alternator Getting VERY HOTT!
- Running Rich
- General 383 advice
- help, engine sounds real bad, sound clip inside
- Set of Jegs Stamped Rockers as a temporary substitute?
- Anyone using chambered mufflers?
- Is there a trick to removing an ATI balancer?
- weird SES light
- Not good.....
- Third brake light question,..,,.,..,,..,,
- Setting valves, getting stumped.
- Injector Problems
- how big is my cam?
- Hoses after EGR Removal
- new owner/opti spark help
- How to remove the amber turn signals on a 95 TA?
- Drive Belt Tensioner squeek
- Check Engine Light
- Did injector swap and now car barely runs. Help!
- Hooker Catback, 2 years old and exhuast mount lets go!
- 1994 Lt1 Firimg Order
- 1.6 long slot rocker?
- back from track/help, weird noise at the rear end??
- How much does a stall help?
- Shop is pulling heads to fix stripped plug........This sound right?
- Rocker Arm Options
- Sealant on water pump gasket?
- do u guys know what my powerband is??
- 7500$ to spend on stroker? Where do I start?
- First time at the strip......
- 94 Timing Set Options
- A very special thanks to Brent94z
- Braided Fuel Line Parts ?
- Which size of injectors? please help
- High RPM miss under load.
- Doing the LE2 cam install this weekend
- Post-Heads/rebuild issues
- Headers yes or no?
- Lots of KNOCK at the track..pleae your input
- STRIPPED spark plug threads in head....freaking out.....HELP
- Car Just Died......Please Help
- Passenger side header touching tranny
- 96 Ws6
- ICM Bolt Fell Off - Size of new one?
- Long Trip need advice
- EGR delete
- lt1 to lt4 conversion
- Please help... Need engine rebuild!
- Oil leak from valve cover bolts
- Relocating MAP sensor?
- Worth going to O/R Y-pipe on a 97 car?
- help me choose mods please!!!
- help
- Strange metallic sound prior to and during starting
- What Valvesprings do i want?!
- I step on the gas and the rpms dont increase? WTF?
- 230/236 110 cam dyno numbers
- Dropping Oil Pan
- ICM cooling mods !!!
- Coolant reservoir
- SES light came on then went off
- coolant crossover seals
- 94 Z28 Camaro 4 Sale
- RR's
- Taking off balancer for the first time with M6...
- Stock fuel line questions
- Best Lightwieght Battery w/ manual fans????
- How to FIx A/C leak
- Possible Blown Heat Gasket?
- is this a fuel system problem?
- is this a good buy???
- got a LT-1 For $200 NOW WHAT??
- Fuel line question
- Magnaflow Hi-flow Cat - any good?
- Install Header on LT1
- Drivetrain Loss on a M6???????
- Whats safe biggest valves on stock heads?
- How to program fans?
- which combo to run
- Underdrive Pulley's
- Will LT1 lifters work in L48/L82?
- smoke from vents
- Help me choose Injectors and a throttle body please!
- 4-bolt main caps
- Help determine lift #s
- LT1 Edelbrock heads
- o2 extensions?
- Slightly Lower Oil Pressure! Aaahh!
- How many miles are stock injectors good for typically?
- Do I need 2 cats?
- Need some advise
- Do you need to Soak Lifters before install? Torque on oil pressure sending unit?
- Stock injectors w/ hotcam?
- oil consumption...
- need temp fix to get oil pan to stop leaking
- does not start sometimes
- Anyone make Valve Cover Spacers for Centerbolt covers?
- shoebox....
- problem with my new 396 lt1 #help#
- Opinions on Manley Forged H-beam Rods
- Computer is turning off!!
- best place to Dyno??
- Shaky oil pressure...
- Taylors OTVC ******* Sucks!!!!
- Fuel pump and no start problems
- loud clacking noise
- Someone please help, code P0400??? EGR flow???
- HP Estimates?
- Tell me what to buy and where to buy it
- Vibrations... Vibrations...
- LT4 Starter
- valvesprings! big cam! need advice!
- everybody with the cc305 look!
- Wheres the cheapest place to get the LT4 Conversion Kit?
- Ram Air Debate (again)
- Differences b/w '94 and '96/7 Z28 wiring harness
- noise when I turn off headlights.....
- codes 32 and 43!
- o2 code and misfiring.. PLEASE HELP!
- 227/233 On 111 Lsa??
- Jumping in car
- timing cover seala
- DEFINITE cost of a rebuild!
- All Lt-1Fans Please READ!!!!
- part # wanted
- Quick question about overheating fuel pump
- can anyone near birmingham alabama help
- Pacesetter LT Part #?
- LT1 question
- Best Lt1 Head Gasket For Lt1??
- Running with no oil.
- whats wrong?? 1/4 mile time of 14.1 @ 98-99 mph???
- Motor Building
- 114k on car just bought, what to do?
- What cam with my setup?
- I need Help picking the best Fuel Injectors for my 1997 Z28.
- where to get 22mm drain plugs for air fittings ?
- Running Rich Please Help!
- Be Cool Radiator fitment......
- 200 bucks to play with
- Optispark questions and must-do's w/ motor out
- Just got 96 SS, needs clutch, but what's this mean....?!
- Lt4 Intake Gaskets...which Ones?? Please Help
- Cam Install Price..?
- Seafoam and EGR
- anybody make a scatter shield
- resurfaced my heads
- PART # for a LT4 Harmonic Balance
- Who has run AFRs on a stock bottom end?
- Idle speed way to high after motor install
- mis-firing?
- HELP!! Dipstick tube broke off in the freaking block!!
- G Load Brace Help!
- tdc and cam install
- obd-1 or obd-2??
- Autometer A/f gauge install
- Dent in the oil pan?
- Fuel Pump
- Intake Vacuum Bungs
- tune up time
- What else can I do???
- Code 16, Slow start, and low end surge
- Bad coolant hose causing overheating?
- what gaskets to use with rk sport/as&m headers?
- Can a loose MAF connection cause a no start
- Playing with fire????
- header install
- pluging the timing chain hole
- It has happened...
- bosch oxygen sensors
- what length pushrods with milled heads?
- regular sbc timing chain with elec. water pump?
- DTC code help
- effect of gears on hp/tq numbers
- Piston Question
- Wiring PCM <--> Cabin *Help*
- code 1732?
- DataMaster Run
- Heads milled .015", what gaskets?
- Break in and Block prep
- Huge problem I need help!
- Car heats up with A/C on only under load?
- scanmaster code pull
- Performance upgrades
- How many CFM does stock cat-back flow? What about aftermarket?
- A/C problems
- Oil Pump Recommendations
- instructional guide??????
- Doing Heads and cam on 110k mile motor what should i replace
- homemade cai question
- Got some problems...
- Why does MAP spike when lifting throttle?
- Pics of LT4 starter next to an LT1 starter
- How do you pre lube a New Engine?
- v6 & v8 A4 4th gen ****ers
- another CSI pump question
- Will my stock injectors handle much more?
- rocker arms
- cam question
- Head removal question...
- Magnaflow Cat- Back Install
- PLease Let me know what you think..i m out of IDEA's
- Pacesetter Y-pipe Misaligned Nightmare
- Delco Rapidfire #14 gap question
- Everyone's electric water pumps still working?
- LT4 cam question
- probably a stupid question
- Is the LT4 kit worth it?
- When opti is dead......
- Adjust rockers using TDC method or let the car run?
- Is the Mallory Hyfire VI CD #685 plug and play?
- stock exhaust
- ? about impala heads
- heads off... valves are fine? hmmm
- GM piston rings
- I have OBDII?!
- water leak
- Which pistons should I choose?
- DAMN CAR, i think its dead
- scanmaster connections?
- Cost of used engine/rebuild?
- How to install a Meziere water pump??
- Need thicker head gasket
- Build me a motor!!!
- Which is harder....
- Car runs like crap. Need help
- Mac Y-pipe not fitting properly.........
- Slp Cai
- What about this idea?
- Llyod elliot Cam package?
- LLoyd's Results Inside
- lt1 carbed
