View Full Version : LT1 Based Engine Tech
- anyone from upstate new york,,
- Why does no one make a single plane intake for the LT1??
- LT1 long tubes and Y-pipe ???
- Front crank seal on LT1...
- comp 26918-16 spring # numbers?
- help w/ o2 sensors
- AFR Heads dyno'd / Combination Motorsports
- Want to do 1.6 RR's but need some help, Please
- combination motorsports
- where do i get this? how much?
- help with tune up
- Put together a video of my launchs, tell me how they look!
- PCV valve on a 93
- Disconnecting exhaust from Y pipe
- Difference between 95 and 97 LT1 motor???
- Another Dual Exhaust question
- Running an open loop tune with a cat
- LT4 Cam
- Clunk 1-2 minutes after shutting off the car
- Engine Vibration under load
- Need some quick steps for replacing rear main seal please...
- MRG-5716... ok for alum heads
- best place to find an ignition hot 12V...
- 94 z28 "cd holder" cuby whole behind shifter, how do you remove?
- 1995 camaro z28 firing order...
- Part #
- Bleeder screws
- Those with 3" duals....
- Colapsed Lifters
- Doh! Broke extension while trying to pull crank hub. Now stuck! Any ideas?
- Temp Sensor Wiring Harness
- Electric WP wiring cause ignition problems?
- 383 oil pan
- Thick head gaskets???
- cost of refreshing the motor?
- 383 oil pan
- Ported LT4 Intake and LT4 Hotcam
- Just went to the track..How do I get better Top End??
- reinstalling opti... is it supposed to spin freely?
- IS my OPTI SPARK GONE? IF so LTCC GUYS get in here!
- How to get block drain plugs out, having troubles!
- Smoke?
- overdrive?
- How Much?
- Dynatech LT's any good?
- MRG-5716 head gask, ok for alum heads?
- Best LT1 shortie headers?
- tore the motor down
- i'm getting faster, trying at least
- Tightening rockers with motor running?
- Suggestions for next upgrade.
- I know I need the tune, BUT.....
- LT1 bolts????
- What can i expect?
- What are the signs of a bad lifter?
- Fluke Water Pump Death
- Major problems!
- Tips for improving gas mileage?
- where to buy OEM type motor mounts??
- GTP heads/cam
- Question About Crate Motor In 94 Camaro????
- SES help?
- New dyno #'s!
- Sudden power loss at high RPM's?
- Advanced Valve cover question
- Coolant Anyone Ever Use This Stuff?
- Catback..sounds
- if you guys had a choice between....
- Flow #s from Lloyd Elliott heads!!
- Jet Hot MAC Mid Headers/ORY or GMMG cat back?
- Help compute compersion ratio
- Mezierre water pump, keep water pump gear in?
- O2 sims and emissions
- Quick. Walbro fuel pump on ebay, good deal?
- Fuel Filter
- $1000 Need to GO faster
- check fluid levels?
- injuneer
- y-pipe fitment on LTs?
- 383 LT1 stroker kit questions please...
- guide plate question
- What do you think it will run?
- Programming Stuff - BLM's, PE mode, SVO injector settings in Tunercat
- help me decide what to do
- 15degree heads on lt1?
- 96 Lt1 start problem
- Mallory Ignition *685*
- Replacing alternator and starter
- Ack! Smog!!!!
- new tb troubles
- Do these times seem right?
- Start laughing: I need help with Airfoil install....
- Fuel tank question. V6 and V8 tanks...
- LT4 Intake Question?
- vat's
- i need help car runs nasty after headers install?
- what size plug for O2 bungs?
- fuel shutoff
- A few more piston ?
- emailed program from pcmforless how do I do it
- bigger valves a good thing on an lt1?
- Should i get an LT1?
- Changing AC Compressor....
- How many miles til she blows?
- Someone please tell me why my car doesnt make more torque!
- 3.8 Cola Cranks 388 stroker
- Hearing a vacuum leak around the injectors..
- car idled rough, threw a code and now wont start
- 96 Z28 STILL misfiring, need help diagnosing
- where do the vented opti tubes go?
- Temp Sensor
- Tips on porting an intake.
- going catless
- IAT Sensor
- Intermittent Starting Problem..
- how long does it take to change the water pump?
- 388 Ci...question about cpiston compression hieght
- Cam Head and Tune Question.
- AS&M TB GP recipients
- warranty on msd wires?
- 226/226 383 =480fwhp??
- Getting richer...
- LE Heads????
- How fast would a cracked head/blwn heag gasket leak presure out?I held 17lb for 10min
- Any body have a good write up on how to R&R fuel injectors for 95 Z28?
- Is it my water pump
- Bad codes
- Looking at buying a '94, low oil pressure?
- AI heads that much better than Home ported?
- spec's on a 1997 trans am
- Need some part numbers
- Centerbolt Valve Covers, Universal??
- Cat delete questions
- Oil level switch?
- Fan switch and OBD II
- My LE1 1/4 times ..
- IF i am getting a mail order tune what infor about my heads do i need to know?
- check gauge light comes on at wot
- who has a low cost rebuild kit?
- Opti seal part number needed
- Has anybody ever had an MSD 6A ignition box go bad?...
- SLP 1-3/4" headers and BMR k-member
- Going to Get Injectors.. Few Q's
- When should the Opti spark be replaced ?
- Low Volts, even after new alternator
- Exchaust Cut-Out... Gain Power?
- Let's talk 383 oiling setups...
- Changed Water Pump & Now Have Oil Leak?
- FLP & Borla
- Track time guess
- Part # on springs
- Bent PushRods and Scuff Marks!!
- Car shudders on 1-2 shift - ABS Inop light comes on
- Horsepower guess?
- Ignition switch circumvention
- which governor springs for 6000rpm shifts
- Forged 383 parts ?s
- Found my problem!
- Intake Manifold Leak.
- CC 306 power band
- easy LT header install
- spun a rod bearing, whats the best option for fixing my car?
- 1.7 RR's and CC 306 cam
- good H/C setup for some low 12's and a few ?'s
- Where can I get a fuel pressure gage and how much should it cost?
- Where ca I get the elbow that goes between the MAF sensor and intake plenum?
- 500 bucks...
- EGR Block off plate questions.
- wiring harness splicing question
- Deleting the coolant crossover tube??
- Most horsepower an LT1 block can handle?
- plugged cat
- Questions About The Opti's?
- KYB AGX Shocks?
- Wires for OVC kit
- Problem with new stroker
- pushrod question...
- Wiring issues???
- Best cam for stock setup??
- Electrical problem, shoebox?
- Need help on decision
- lt4 pressure plate vs. stocker
- LS1 lid and Fast Toys Ram Air
- Success!!!
- dowel pin
- 3.42's or 3.73's for my auto?
- Shoebox? Low Oil sensor. Has a black and brown wire connects to it.. but
- Retard At Proshop, Having Problems With Install Of 3.73 And Locker Set
- car did something weird today...
- gears anybody?
- Possible reasons for smoking y-pipe( cat?)
- need some help, surging problem, need some advice
- No owner's manual...
- Carsound Cat
- Knock .....
- fan switch and 160 t-stat
- Will Corvette T56 fit into F-body???
- Valve spring question and off road y pipe
- Ford SVO injectors - Problems?
- Help...Ticking at low rpms
- Installing my Jet Hots...
- Cutout on single cat car
- HELP!! EGR Valve Part # Confusion
- rocker adjustment
- Question about Holley AFPR??
- Long Tube Exhaust Setup.
- XE224/230 110LSA, stock heads dyno results!
- Who to grind a custom cam???
- Dumping exaust in middle of car
- Pacesetter LT Install
- New e/t with the wife's Z!
- are ls1 and lt1 mafs .......
- Anyone have this exhaust setup on there 94 Z? HOK LT's HOK offroad y pipe w/SLP LM
- Overheating questions?
- Fuel Injectors
- shifting problems
- Car missing under load but not at idle???
- Pushrod lenght question
- Question about racetronix fuel system install
- Fuel Problem (Kinda Long)
- still takes a couple cranks with rebuild?
- pcm help
- *Anyone convert to LS1 CAI*
- Flushing radiator
- High Mileage H/C cars...
- How are these headers?
- 1.6 Roller Rocker guys needed
- teach me hot to launch ET Streets ! M6 ?
- Plugs too hot? Informed opinions wanted
- Need help and opinions ASAP please!!!!!!!
- AS&M... RK SPort Headers....
- oil pressure question
- Are these Flow #'s any good?
- Brake light bulb harness
- Are all stock LT1 cranks cast? And how much hp can they..
- Firebird popup light cog
- O2 sensors...
- replacing the turn signal switch on column
- Its the fuel pump!!!
- service engine soon code 29
- Adjusting the cruise control cable?
- Check your throttle cable
- How to remove T56 bellhousing?
- low rpm stumble eh?
- need quick help...how to take the crank position plate off...
- what length header bolts w/ 3/8 flange
- Weld my header together???
- Doing first LT1 ATI install,have ?'s
- Hypertech Power Programmer Plus
- Rattle and pop under my Z
