View Full Version : LT1 Based Engine Tech
- Need Help! For You LT1 Masters
- Fan Relay Location?
- Siezed 95 LT1
- How noisey are your crane gold 1.6 rockers ?
- Can a distributor be use on an Lt1?
- Electric Fans Wont Come On
- Comp Pro Mag Non Self Aligning RR and Comp R, 875 - 16 Lifters. Lash ???
- Stock CC sizes for LT1 Heads ? (alum + Iron) need info for compression ratios..
- What Does Descreening Maf Mean?
- Fel-pro 1406 vs 1470 header gaskets
- What Are The Easiest Ceramic Shortties To Put On
- Scanmaster Guys or Scantool guys Poll
- Opti seal, can it be swapped w/o removing the timing cover?
- Any power loss with the intake oil leak?
- Gears
- needing TPS numbers so I can set mine
- tHROTL BODY ????
- the is any other ignition part behind the optispark?
- 93lt1 oil sending unit question
- Powermaster Alternator
- MAF reading low????
- So it was the coil
- car is going crazy. someone please help
- Whats this tube
- kind of at a crossroad...
- will stock rack work without the pump?
- Water pump? help asap
- Need bearing advice!
- What is the Stock fuel preasure?
- where does this go?
- Piston to valve clearance???
- Possible Warped Head ? ?
- Bigger Injectors?
- Engine Vibrates Around 3k And 4k When I Rev It???
- ??LT1 intakes and AFR??
- Hesitation problem fixed!
- Part Number Needed
- Car just dies, big race coming up... Help.
- Where to buy 12" O2 extenders for 95Z?
- driving w/ front 02's unplugged?
- Who has the best price on 30# injectors?
- LT1 Presidential?
- BELT & PULLY CHANGE
- Window switch ?
- Road debri tore a hole in my intermediate exhaust pipe...need help!!
- Just ordered my MAC midlenghts
- Final stage of droping motor few Q?
- Are JetHots and Hookers Primaries the Same?
- Pcm?
- ls1 in a 93-97 z
- Oiling problem
- Knock Retard!!! I just found out!
- a few unrelated questions if someone can help.
- Springs for CC306 on stock seats.
- 3.75 crank with 6 in Eagle H-Beams
- which catback to get?
- What did you pay
- CFM flow related to HP #s??
- Going to go with XE 224/230 cam, but..
- Modding question... please help me...
- When Purchasing Salvage Title car how much do you take off from the value of the car?
- when should a xe230/230 112lsa make peak torque?
- My WInter Project...HELP ME!!!!
- No Start
- Started Died now wont start
- Would new plugs & wires make a difference?
- Headers and Heads
- excessive header exhaust heat, what could it be?
- Modifying spark plug socket for lt1 spark plug change
- Lt1 start up
- correct GAP for plugs?
- I feel like TP..my car craps on me so much!
- hesitation when cold...fine when warm
- Drag Radials!!! WOW.
- shoebox need your help once again!
- CC306 Owners
- Mac headers Jet-hot
- rebuilt 355 problems, need answers
- part number for timing cover/chain/gears
- To comp "R" or not to comp "R"?
- How much in your area for a rebuilt LT1?
- No oil pressure
- MSD Ignition.......
- Alright, I need some serious help, possible pcm problem....
- which valve cover?
- More on the Cat before I proceed with repairs.
- Haha D@MN OPTISPARK PT2!!!
- Clogged exhaust
- looking to rebuild a 93 LT1
- Just took apart optispark after misfire problems... (pics!)
- Coolant loss-boilover. Car overheated. Help
- What might be wrong?
- woops i missed that part
- fpr replace how to
- Oil pressure problem...sometimes.
- Ahaha Autozone
- Couple of LT1 Head ?'s
- Engine damage.. low oil pressure, blown head gasket, some knocking
- EGR pipe bolt?? quick response please
- newbie needs help
- What is this tapping noise?
- oil pressure drop & "check gages" light when hard stop?
- buying heads, but have no core
- Before I start thinking of opti etc...
- low oil pressure
- what is a cut out
- HELP!!! LTCC question
- Cam surge with 847?
- Connecting back up steering column
- What Clutch Should I Get????
- what throttle body do i use
- Mister Shoebox Oh Mister Shoebox Part Number Question
- Rear end question
- droping motor got a ? about trans elec. conector
- Where can i find info on how to wire up msd6 btm
- New Water Pump probs
- Pressed or Bushed Rod Pin?
- People with XE cams.
- Rods..dots point in or out?? HELP!
- 95z28 cammaro running hot
- Can the 2OTL exhaust be loud as the SLP Loudmouth
- 24 hour gM parts?
- Rebuilt engine woes, please help!!!!
- AIR pump removel?
- serious wot only oil leak, better suited here
- how do they machine heads
- Dipstick removel
- mods?
- Timing chain for 95 LT1
- Why is the tb hissing???
- High RPM stumble
- Poll: Market for a 1 3/4 to 1 7/8 stepped LT1 header?
- How do our motors relieve internal pressure?
- Is it time for bigger injectors?
- Air Pump?
- What would happen if I...
- 94 LT1 Rebuild Kit
- Update: dyno numbers/afr from 396
- This is getting old...
- Which plugs for heads and cam car?
- Made it to the track
- oil pan dent NEED HELP ASAP
- Dip stick screw...
- How do I trigger the Monitor mode?
- Where did you find your car for sell?
- WOT engine stumble ??
- Crank position sensor question
- hooker exhaust question
- How much do ya think?
- comp cams 977 springs good for this??
- got my heads form loyd today heres the flow #s
- HELP! Car is starting to hesitate a little bit
- plug and wire change
- Nasty vibration at 4000 rpm, even in neutral
- XE 224/236 dyno results
- which shorty hedder to use
- Mototron 60lb. per hour High Impedence fuel injectors... any good?
- 92 rs with an lt1 swap
- Radiator Questions.
- Stock exhaust removel question
- Best place to buy XE 224/230 kit
- springs to use with cc306 cam
- Oil Filter
- Intake Manifold
- Dyno results and video
- Double Checking my pinion angle...ASAP
- wheres the temp. sensor for fans on a 94 Formula
- Need help very fast, trying to remove steering shaft
- Car won't turn over
- Crank position sensor and smog check??
- D@mn Optispark!!!!
- Rebuild
- 383 .20 or .30 over??
- Differences in LT1 blocks 94-95 96-97
- REmoving Balancer!!!
- Hooker Or Jet Hot???
- lt1 turbo kits?
- how decent is the stock coil?
- 3rd and 4th Dont work
- Typical/Highest RWHP Full Bolt-on LT1 #'s?
- Need Help Fast
- Press in EGR diaphragm, car does not stall.. but egr does hold vacuum at valve.??
- High RPM Problems Need Info/Help
- Was driving and car just died.
- Comp R lifter users inside please. Question
- question on timing
- LT1 Valve Cover Bolts
- Whats some good scanning tools.
- Gonna be changing spark plugs / wires
- Gas gauge changes too much.
- Hell with these cars
- Ever hear this noise when....
- Am I leaking Antifreeze?
- Opti Spark???
- Compression Check: How many PSI?
- It's like riding a bull
- Got a couple codes need advice and knowledge.
- Dimmer fues keeps blowing.....why?? HELP!!!
- Temp goes up, I purge the system, Temp lowers then goes up, then I repeat , HELP!
- Vibration?
- Combination Motorsports cam kit?
- Is this normal?
- Diagrams/Photos Needed!
- Scanmaster Install in AC vent
- Gas Milege?????
- Go Racetronix PnP system or just pump & assembly?
- how to make more space (headers) passenger?
- How does one get ahold of Paul Barry, these days?
- Racetronix Pump and Wiring Harness owners.....
- WOT rpm problem.
- Please help,problem after csi wp install.Car is overheating!!!
- Help!!! Car Is Dead!!!
- Comp Cams 941-16
- Scanned car, all data here..need help
- Coolant Bleeder alternative
- doing 50 then hit WOT and bounced of rev limiter after putting HPP+ back in???
- New setup almost back in. Alot of changes
- Intermittent starting trouble (with a twist)
- whats wrong with my car now???
- Two questions...
- Do I have a fuel issue?
- Baseline Dyno results
- Need help from 58mm TB guys.
- Never seen this kind of lifter before.
- Tranny or engine question :P
- No cat? Half cat? New Cat?
- Code 32 problem
- Oil Pump Drive Question.. Help....
- Which Cold Air Intake?
- Help Please!
- Dynaspark questions
- BULLET (Dynomax) Is it worth it?
- what is a pocket port job?
- proper start up procedure?
- m6 to auto harness...
- What Head Gaskets Are You Guys Using??
- 2-8 degrees of KR during acceleration
- Starting Troubles
- What kind of headers are these?
- Car acting funky...
- New to 4thgens : FAQ or tech articles?
- Which cold air intake?
- .:Faulty Spark Plug?¿:.
- Oxygen Sensor Data
- What does your voltmeter read?
- revving up when clutch is pushed in
- Does this pushrod look bent to anyone else?
- Just got my car, problem?
- Ocean of Oil
- Do these cam timing marks look aligned to you?
