View Full Version : LT1 Based Engine Tech
- Track And Dyno Results - T56 vs 4L60E
- Aftermarket bumper support
- Off the line bog?! also intake backfire
- Help my choose a cam.....goals inside
- Anybody using Samco silicone radiator hoses?
- Need help! How to get pulley off
- Best Wires?
- Another Thumbs up for PCMFORLESS
- Car wont start after water pump removal
- odometer read out
- Cold misfire/hot and cold performance?
- Here, TPIS LT1 Ported Heads Flow numbers
- Synthetic oil for first time on higher-mileaged LT1?
- How to take apart alternator?
- AFR190 54cc Heads Intake angle not right, what to do?
- Im at a complete loss...need some help out guys..
- TTop Conversion, Yes or NO, No turning back
- anyone deal with performance-curve?
- Aftermarket Throttle body???
- Going rate of vented opti from Dal or Jason Cromer?
- Has anyone tryed the new "super turbo" exhaust kit?
- A video of my true duals!
- Do i need rear end additive if i go synthetic?
- Alternatives to opti..
- LT1 Fan problems
- Should i finish in 3rd gear?
- Spark Plug Problem, any ideas?
- aluminum head iron valve guides?
- would dead TPS cause this???
- mystery tapping
- SES question
- what can i expect
- 9mpg...wtf
- is there a difference
- LT1-->LT4
- Getting a CEL how to find out what's causing it?
- Tranny going out?
- Heater core question
- Are 1995 Pushrods okay with CC306 and milled heads?
- Eletrical Problem - Blinkers/headlights/wipers
- need help
- dump the flow master?
- hey need help finding block number (engine number)
- How much should it cost to hang my exhaust?
- 383 Spark Plug Help!
- Is anti sieze need on header bolts
- My car barley runs when its cold
- Coated headers: Worth the cost?
- Something to wrap my spark plug wires with
- Those with 236/242 what is your idle set at?
- New on this board.
- To go or not to go....
- rocker arm question
- New Opti, Now no start
- need some cam suggestions
- Gm 847 too big for stock bottomend?
- Rattling CAT?
- Dyno Sheets
- Lt4 Conversion Questions
- weird vibration at idle
- Part Number Help!!Please!(Pic)
- 97 Trans am engine knocking!
- Car Dies, Ignition? Urgent
- cc305 vs cc306 power/gas mileage/driveability??
- Help! A4 on the fritz
- Just changed opti, problem not fixed :(
- Help!!! Cracked Head Gasket!!!!
- AC or No AC who still has it who doesnt??
- cam surge... 112 deg. lobe separation vs. 114
- Unplug Alternator?
- Underdrive Pullies, Electric Waterpump
- What's the fastest STREET TRIM LT1 F-body?
- Christmas/early Graduation gift ($3500 to spend, help me want LE setup)
- luke warm heat (nothing more) advice
- Speed limiter removal (who can do this tomorrow/rent Hypertech) DE/PA area
- 383 close to done
- Great..now heater coil BAD?
- safe to mix coolant of a different brand?
- Quick piliot bearing problem.. need clarification.
- Short idle video of my cammed up CARBED LT4
- Should my IAC be THIS dirty? *Pics*
- Need info on stock waterpump ASAP.
- For those who have a carbed SBC in a 4th gen
- Steering linkage removal
- Iron LT1
- Fuel pump trap door walkthrough link?
- Where to buy a flanged 3" turndown?
- Putting EGR back on the car
- burn-out broke my 96 z28
- Urgent! - Flywheel Pulley Removal!
- Can you Dyno with a speed limiter?
- Coolant Crossmember Problem
- Clearing Valve Covers with 1.6's
- I Finally Finished My Rebuild! (Video)
- Kook Headers!
- ported Throttle bod and tbs
- lt4 valve springs
- Y-pipe options
- Deceleration backfire pop?
- Spark plug popped out of hole!?!?!? HELP
- lt4 valve cover gaskets?
- PCM question
- Interesting Electrical Problem...
- Can someone check out my logs?
- Battery Has Blue Foam
- 1.6 roller rocker question.
- ignition problem
- How many miles on your LT1?
- LT1 intake thermal coating
- Is a cutout worth it???
- Bleeding Cooling System
- 847 cam??
- Mcleod Adj 139001?
- Few questions on clutch install
- LT1 vs. LS1 sound
- Header bolts....
- Thinking alternator??
- Lots Of Choices
- Best Cat-back
- what will i run with this setup?starting to wonder
- Gains from porting stock heads w/stock cam?
- EGR Removal Questions
- 52 Mm Tb
- Vaccuum pressure seems low???
- Cant take out moroso air filter
- engine makes a weird noise when shifting WOT!!
- I have a few problems!!
- What do you call this part...
- Amsoil
- Is adding power going to leave me with less or no car?
- need help have multiple miss fires
- Twisted fuel line, is this ok to do?
- Throttle body blade adustment
- RAM clutch?? Yes or NO????
- Which front O2 connectors 97 SS
- New Opti Arrived! Few Q's...
- which would be louder?
- guys with MAC headers - what kind of cat are you running?
- Can ANYONE tell me where to find replacment LT1 Rings
- Need the list of tools for rear-end swap
- MAC header question
- Hot air inside car?
- LT1 Piston Ring Size? mm?
- How can I force open loop
- Cylinder Head bolts leaking?
- a few questions
- Noise/rattle when off the clutch?
- Block off plate
- k&n FIPK concerns
- 8.8 out of 1997 F150, any way for it to work under F-Body?
- Question about SS airbox
- What to do with vent line to opti when switching to Vortec elbow?
- ***Compression ratio with dished pistons....***
- How do I know if my egr valve is bad?
- Hot cam with a knock problem...
- Slp 2otl
- Coolant leak..but where?
- Machining question per 6.0 rods?!?
- Engine ticking?
- Water spitting out of the exhaust?
- A few general questions??
- TSP rumbler worth it?
- Where can i get a long air filter? (yet another custom intake)
- Mac midlength install guide?
- Jason Cromer - Emails?
- no spark lt1
- I want the loudest exhaust possible,...... help me out;-)
- Balancer squeeking? It's dancing all around...
- got car back from shop
- Won't pass 4k
- Camaro Z28 1995 won't idle
- 800 mile 383 motor blew up!
- To dual or not to dual
- Injectors?
- Longtubes finally out the back
- For 100 extra my head guy said he will port the bowl area, worth it?
- Simple Heated Oxygen Sensor Conversion Question...
- any Delteq bare bones kit buyers?
- Why does my car stumble...please help me
- Exhaust Junkies
- Mod Reviews and Suggestions
- Question on changing U Joints?
- Radio Shack blows. Help me find a resistor to bypass knock sensor!
- Will a 94pcm work in my 95?
- Just got quoted for plugs and wires.
- Opti,Cap&Rotor,Fuel Pump replaced, car won't start
- marble like sound comming from electric water pump, is it the bearings?
- Custom ram air setup from non ram air hood... need help
- Mallory 685 ign box on an LT1, need help
- Oil temp sending unit...Importance???
- Shavings in oil (very small amount) - normal?
- heater still not working
- Am I Running About Where I Should Be Or Should I Be Faster?
- Ethanol to help pass emissions
- lt's or shorties?
- Questions from my Dad... 94 Z28 vert
- Valve seal size question
- Midlengths installed... got ????
- Finally going to the tracks!!!
- Valve Lash
- Bored out throttle body...
- Need some help
- Do I really need a new timing chain?
- 30lb injectors plenty for Lloyd E H&C setup?
- 1.7 RR's installed ??????'s within
- part name??
- When my car's cold and I turn the key, the engine cranks but doesn't fire up.........
- code 22?
- 233/242 .569/.587 115 Lsa too big for stock heads?
- Does anyone make good rings in the stock LT1 size?
- loading pcmforless without floppy
- Stock injectors with CC306?
- How Can I Get Rid Of My Opti?
- Is this a good idea?
- Fuel Line O-rings...
- jackstands under pads?
- stock piston size???
- Looking for the bolt-on pulley set-up that replaces the power steering pump...?
- starter and mac headers
- Harmonic Balancer/flexplate... vibrations..
- Help me choose my exhaust setup...
- Engine oil cooler
- Electrical Problems, opti maybe?
- how high?
- Few problems on 95 Z28
- Help LT1 stumble (long)
- car wont stay on
- Dyno Tune with New Mods
- finally made it to the track this year hypertec is junk
- Long tube, ORP and Borla owners please....
- Fule rail removal - urgent
- Benefits of converting to OBD1
- Trying to remove IAC..Stripped the bolt...
- Will this cause overheat?
- CC 230/236/112 idle question ?
- What year did they switch to the smaller rear wheelhub?
- Antifreeze smell after jet hot lt's install
- What am I missing
- Oil sending Unit location
- What are the limits of the HR cam
- th350 shifter
- timing chain question
- 10 second LT1s...
- Mustang dyno work for my car?
- couple questions about LT1s/LS1s and ordinary SBC's.
- Is this normal?
- MSD Wiring
- Dyno results...whaddaya think...?
- Header leak or Valvetrain noise ?
- how can i reach the 12's?
