View Full Version : LT1 Based Engine Tech
- bbk underdrive pulleys
- Starter is almost dead, where can i find a cheap one
- Carbed SBC conversion
- Holley TB Gasket
- Need help with engine!!!!
- Which pushrods to use?
- Double roller timing chain rubbing cam retainer plate?
- Scat 9000 or stock for my setup?
- needsome help bad!!!!!!!!!
- car sputters......
- Heads on a stock motor?
- 96 to a 94 body
- Taking off TB to clean, what clean I clean in the intake?
- Dtc 26
- mystery miss ?? *
- Changing motor mounts and oil pan gasket
- Manual Rack ?
- cc305 vs. cc306
- Which TB to get?
- Pacesetter mids to Pacesetter longtubes?
- jessel SBC shaft rockers on an LT1?
- Best Way to Drain Coolent from my engine?
- SES wire help plz
- Question Concerning Opti/Timing Chain Replacement
- Ok to splice electric lines in the fuel tank?
- Free mods how?
- LT1 options list
- Record for fastest stock lt1?
- Edelbrock Performer Heads
- rocker arms for LT1 w/trickflow heads and CC306 cam
- anyone with a bit of information...
- Valvetrain Labor...
- Dual cat to single conversion on a 96Z
- Anybody have an install guide for installing a walbro 255 intank?
- 3.4L To LT1 Swap - NOW NO START
- stroker or blower?
- PCV Valve or Valve Cover Breather?
- Lt1 + Rain = No Go
- Cam
- alternator
- Is there an ext.bal LT1 damper around?
- Brake fluid capacity
- Problem
- sputtering at half throttle
- O2 ? can you use these on a 95?
- LT1 and LS1 Alternator Difference!?
- Coolant in the cylinder?
- Who makes this spoiler???
- How close is too close for exhaust to fuel lines?
- Anyone ever heard of this??
- Newbie
- Score: Transmission 3, John 0
- cam question
- What are the best pistons to get?
- Where you buy Poly motor mounts?
- Help ! can't see misfire with madz28 tune
- Bare block wieght?
- LT1 ---> LT4
- Long tubes and no mufflers
- Strange Problem W/ 93 Z28
- Anything special to tell the machine shop tomorrow???
- need optispark
- Brake booster barb part number?
- ARP stud kit for heads
- :confused: Help plz car is running crappy
- Which head would be better?
- The balancer that makes 15hp
- q's
- Those with Cloyes Double Roller Chains Please Inside!!!!!
- Stock or ARP rod bolts? NEED ADVICE FAST!
- advice on 396
- second try..HELP!!
- bent valve symptoms...
- Serious shifting problem, everyone I know is stumped...HELP!
- LT1 Rebuild Gaskets List
- P0122 code
- Thoughts for Engine Rebuild
- Kooks headers are here!!!
- Any gain in power switching to LT's in a 355..
- Killians Head Porting Warner Robbins GA
- '93 owners, please post some motor shots
- still have high rpm power loss, help!
- Is my car running to its potential?
- 2.02/1.60 seats
- Installing a 10-12 gallon Fuel Cell, ever been done?? We might try it.
- Fixing to put my car together, TELL ME WHAT YOU THINK about this setup!
- 2.5" or 3" at the y pipe
- opti question
- LT1 Swap
- checking squareness of k-member?
- 355 buildup Parts list, help...
- PCV valve tube...
- Driver side MAC header removal question.
- Major problems, high end studder/cutoff..dyno inside.
- EVAP Purge Solenoid vent hose
- SES Light came on then off, got it scanned, more inside...
- Main Bearing???
- WTH?!? Help me diagnose this...... I need my car for work/school
- Damper Question
- Smog pump and egr delete?
- A4 + 4.10 = crazy
- Protocol for people with problems!
- motor just dies???
- Are these CAIs worth a crap?
- Bearing replacement and pulling motor questions...?
- What have people seen out of this setup?
- anybody have the GM # for the '97 Z cluster?
- Runs Rough After P&P heads install
- Fuel odor...
- HELP, Oil pressure less than 10!!!
- Trick Flow Elbow
- Anyone ever try that engine restore stuff?
- Stock fuel injector size?
- seafoam goes where?
- intermittent problem
- Car getting hot in traffic.
- Best exhaust?
- Bad mis 1-2k rpm or whenever a load..Opti?
- SLP Headers?
- Manualy cleaning injectors question?
- Open headers?
- I need a new in tank fuel pump.....
- Oil Leak, how can i tell what
- Rebuilding a Motor?
- installing a procharger system
- 1996 lt1 air pump removal question
- Car misses for about 20 seconds then runs great. Fuel related. HELP!
- TR55's making the car run like crap??
- Urgent help, valve spring related...
- Battery relocation, what gauge wires ? is 2GA too small?
- ****!! I think my motor is about to blow up.
- slp and rksport?
- Dyno Results - What do you think?
- Why does my car sound like it has a blower???
- Opti Dead inside of 7000 miles
- anyone hear of speed pro electronics?
- Do the Granatelli mafs say Ac on them?
- What's easier: opti swap or plug change?
- Felpro Part Number Question
- Will A Dirty MAF...
- Please Help If You Can
- 2.055/1.625 valves in LT1 heads?
- If you remove the air pump, what happens to the O2 readings?
- LPE Super tubes on sale
- Problem with Caliper
- LTCC Users HELP NEEDED!!!
- Need a set of LT1 SS Extrude Honed Exhaust Manifolds
- Dyno Tune Results
- How to wire up Trans am mirror switch to the Camaro mirrors?
- march pullies
- Dip Stick Leak
- 355 kicked butt, but not anymore...
- Weird miss...
- three dead cylinders, new delteq & wires, any ideas?
- rev limiter on crane box doesn't work!
- Anyone ever had this problem?? HELP!!
- Question regarding Crankshaft placement...
- Crank Position sensor question
- Need some info on Optispark
- Car is flooded?
- Engine Noise
- Quiet down pacesetter LT/magnaflow
- Comp pro mag poly lock broke???
- where can i mount my msd digital 6 plus
- Gm 846
- What do you do with the air pump connections on Hookers LT's?
- weight reduction tips??
- !@$! waterpump gear
- Open Headers? question about smoke too
- vapor canister vacuum leak
- Anyone ever re-used rod bolts?
- Converting a cam from 1994 pin to 1995 pin?
- Anyone ever used the CRANE SOLID RLLR LFTR P/N 10510-16
- Oil Pressure sender...Mechanic replacing now..he says..
- Headers Advice
- Fuel filter screw stripped- HELP!
- Tire Width
- Radiator support structural integrity
- is this made for 93-97 f-bodies??
- LT4 Conversion Question
- Any interest in a Bolt On LT1 car
- Wiring question???
- intake and external fuel pump?
- 1.7 Scorpions are in
- quick question about lowering springs - will intrax lowering springs fit LT1 and LS1?
- new setup comming soon
- miss/backfire before shift at wot
- stock fuel pump
- Best Clutch Combination...
- Scanner?
- transmission swap
- OBD1 stall converter issues???
- LPE Super Ram's Available again !!
- X or H pipe for duals which flows better ?
- What do spark plugs come gapped at?
- 350 block?
- 396 stroker question
- LTCC owners inside please
- MAC Header Leak!
- proform vortech roller rockers
- Is it worth it to goto a GM847.
- CFM of K&N FIPK for 93-97 non ram air?????
- HELP!!! connectiong rod... ASAP!!!
- How to lube the new motor?
- true duals
- Lookinf for Fuel line schematic
- ECT (waterpump to PCM)
- Buying a used 94 Z28.....NEED advice.
- Getting better !!! :)
- looking for low priced springs NOW
- Why is my car so slow??
- 47ft/lbs good for 1995 Rod Bolts?
- carrier and gear swap
- Is This Going To Hurt Anything?
- Video of my 9 minute 30 second bottom end assembly!
- starter bad again
- heres my idea
- My New Loudmouth!!
- oil in throttle body
- question bout fuel pressure
- 383 and Dat Pro 1 heads
- Question about plug wires?
- Lost Coolant Sensor Wire
- coolent leak toward the back of the engine??
- what would my car dyno??
- where to get a gmmg exhaust?
- Why you shouldnt run 3/8 valve locks with pics
- ya think these are good for turbo app?
- Help! Car won't crank at all
- Cant drive at night
- any tips on elec. WP wiring schematics?
- Forged pistons
- Help!! Car is surging and I don't know what's causing it
- Question about running open headers with 12" extenstions.
- CM EX612's -vs- Crane 99893's
- HELP! Big tranny leak looks like around Bell housing
- did i hurt anything?
- Dont you wish your Kitchen looked like this (Head & intake Pics)
- Speed Limiter on my car? 95 z28 |LT4 parts Q
- self porting heads
- Car 'jerks' when gunning it at low rpm
- Stock Rev-Limiter RPM??
- Minor miss
- kind of an emergency rounded out bolt
- LT1 Carbuerator Install
- .....Weird Noise
- OBD1 o2 extention length?
- what is the hose in this picture?
- no start all of a sudden
- question bout my engine setup..
