View Full Version : LT1 Based Engine Tech
- Read all the Pacesetter LT threads, still have questions
- What Cam? Need Help Here, A Newbie
- Comp Cams XE276HR
- Cheapest place for CSI?
- what is ccp duty cycle?
- Is this a good K member?
- Telling between comp cam lifters 850 and 875?
- Clearance Question
- best off the shelf 383 rotating assembly for the buck
- help car acting up again
- stronger crank nodular iron or cast steel
- How often do knock sensors fail?
- WALBRO 255 L/Hr FUEL Pump problem..
- Bunch of questions hot cam vs. cc306!
- Oil smell under high acceleration??
- Should I be concerned...Please help
- What injectors for this set-up
- Engine builders.. inside
- Need Programming After High Stall TC Install?
- up grade alternator 93 124 amp to 94-140
- Question about cold starting the car after it has sat a while...
- LT1 radiator removal and replacement
- Cam End Play?
- exhaust
- I know call myself, king of breaking bolts =/, need a part # please...
- Service Engine Soon???
- Slightly bigger injectors with the stock tune?
- 97 Z28 with 5.7 pre-ignition/ping
- Best plug wires?
- New to the LT1 World ??? for everybody
- **dont Buy Lokar Dipstick**
- Alternator question/charging question
- Cam question
- Crane Rocker Spring Clearance
- Major problem after Cam install, please help...
- Anybody tried removing cylinder head coolant passage plugs?? Successfully???
- how difficult to swap ls1 engine in 93 formula?
- are these good
- making 1 good opti out of 2 bad ones
- Keeps shifting later and later
- Cam Lift
- Stock lifters and GM847
- Worth hacking up GMMG to make a custom dual setup???
- What to paint exhaust with that will really stay?
- Exhaust Question, 3in Y w/dual QTP's or Dual 2.5's with QTP's?
- Chamber Size of GTP LT4 Stage 2 Heads?
- any1 know much about loading a program onto ur pcm?
- 2 - O2's 1995Z, stock manifolds - HELP!
- what do u 6 spd guys launch from with minor mods?
- good high flow cat?
- What do I need? (roller rockers)
- How much HP will my new bottom end take?
- Ok now I think I messed up my MAF, here are the symptoms..
- Exhaust Leak?
- Balancer stuck?
- O2 Question
- whats the throttle position sensor mod?
- every problem is fixed, but one very odd problem
- Doing a TB bypass and noticed something like oil, and hose broke..
- Kook Headers are in!
- Power increase adding 1.6 rockers to LT1?
- <-- newb needs a part #
- help: high pitched whine
- gm847 dowel pin?
- Fuel Filter / Air Filter
- Can I reuse my header gasket?
- dissapearing dexcool
- 5v ref erence and distributor
- where to by ASP underdrive pulley?
- Help! My Z28 won't start
- Help! Transmission fluid everywhere!
- Dyno #'s
- Starting problem...
- Nees honest ans. to cam ?'s
- Downsides of springs that are overkill?
- White smoke and Pools of oil
- slow start sometimes and huge bog
- water pump question... i'm lost
- alternator lead?
- Cleaning of IAC recommended?
- Solid motor mounts. Does it eliminate flex?
- Tapping noise from under car???
- Whats a quality/cost effective 355 kit?
- Catastrophic Oil Failure
- Clock spring / Sir coil part numbers?
- I'm stuffing an LT1 in my '89 RS...PLEASE HELP ME MAN!
- Different size tires
- 3" into 4" y-pipe
- plugs/wires
- high rpm miss - think the KM
- Is there another bolt hole on the pass. rear side in the head for headers?
- P1134 Code
- Is this sound clip of an LS1 or LT1? Take a listen...
- hardened or chrome moly? why the HUGE price diff?
- No acceleration when gas pedal is pressed
- Getting an LT1
- cam swap. help w/V. springs
- Can i get 400 rwp or 11's w/ out stroking the motor?
- part number for throttle body plate gasket?
- about time to change the o2's?
- A4 + 4.10 videos!
- MSD has an opti for us?
- attention Mr. Racetronix or those who have installed Racetronix injectors....
- Weight reduction?
- Quick TDC/Valve lash question...
- rotor button shattered
- 1997 Camaro Z28 nightmare Help read my story.
- Post your H-pipe pics
- dropping oil pan???
- Long block
- Highest Streetable HP? 400 RWHP?
- TPS Problem?
- A4 4.10 track times
- Best Plug Wires for Stock LT1
- Loud Ticking on Startup....
- How many of you run Mcleod....
- Gauging Interest in Billet LT1 Steering Shaft
- Bent K-member.
- electrical problem (Lights)
- how far can you take 30# injectors??
- 93-94 Optispark difference from 95-97 Optisparks?? pics?
- Failed Texas State Inspection Emissions Test Today, any Ideas ?
- bad air pump
- put my car on a scanner today
- Help me with cleaning TB? Clean intake at all?
- Don't believe in factory freaks?
- help with cai
- How much HP w/ 30# inj. & 58 mm tb?
- Got a Prob!
- What springs out of these two?
- Hypertech Power Programmer question
- How much N20 w/ this cam?????
- Rattle at idle?
- Bad o2 sensors, I think.
- where can i get these sensors cheap?
- bbk u/d pulleys..need help
- Are 3.4 and lt1 y pipes interchangable?
- What causes that popping sound in our exhaust?
- cam spec question
- Lt1 idle acting up
- A4 Lt1 RMP take off
- Do all duals rattle?
- TV cable broken??
- Alterative to K&N kit
- oil pump shaft?
- Rocker stud snapped--Need Help....
- Brake Light on Cluster Stuck on??
- Replaced opti - dynoed again - same graph
- AS&M Headers, What Size bolt to fill the hole?
- help plz
- car bucks, misses, stumbles, help???
- 93 LT1 cuts out when throttle pressed.
- Those With LT4 Hot Cam Kit....
- Engine cut out with nitrous...
- Smoking on Deceleration
- gas tank fix
- putting stock injectors back in?
- Long tube question
- most hp out of heads and cam motor
- 58mm TB w/A4 on the street
- Best place to buy all forged bottom end?
- Bad O2's will they make a car sound different?
- Jet-Hot LT's or Hooker LT's???
- Anybody swapped to 95+ Opti?? Please read...
- LT4 intake on LT1
- Can U rewire 92-94 Optispark to 95+ connector?
- What's needed to make a 94+ cam work on a 93?
- Quick Wiring Question
- What should I BUY NEXT...PLZ help me out
- Problem with gauges, i need help from electronics expert.
- starting problem
- Ahhhh Summit!!!
- clunking in rear
- oil filler neck?
- somethings wrong with my motor
- TPI type intake on an LT1
- I need a rear Main Cap
- What lifters???
- Problem after OPTI install (ive searched)
- How's this porting so far?
- Need help with locking header bolts
- Part number for Harmonic Balancer bolts...
- pcv valve
- Another what mod next post :)
- This is getting old..
- little carried away with homemade short stick...
- TA Starts hard, puffs blue, smells like gas!
- what oil to use?
- True duals are on!
- Next Mod??
- What is the tube size of the AS&M Cai?
- Cam install!!!HELP
- Is there an open port for Tranny temp guage??
- have a slight vibration!!
- Rough Estimate
- Engine stutter
- Removing hardlines from fuel rail?
- running rich and car dies at idle?LONG!
- Converting return fuel line to -AN?
- Exhaust?
- 1/4 time question?
- 93 Coolent flush! (not a commmon question)
- What is the laudest exahust for an LT1?
- Help in Albuquerque
- stock gears or better?
- Which Sub Frame Connectors?
- Do I need longer PushRods with GuidePlates?
- device to stop oil in throttle body
- fixed the miss finaly
- Header install on 94 (things your momma never told you). useful Info inside.
- How quickly should fuel press. drop off after priming the pump?
- ASR + OBD1 Conversion
- error code P0140 after tune - any idea?
- Timing gears
- Dyno #'s lower than I hoped, any ideas?
- Exhaust flange gaskets...
- Pacesetter Headers- AMAZING fitment!
- Got working on the Firebird a bit some more tonight finally.
- Need waterpump bolt measurements.
- BRAKE light wont go out.. why???
- Underdrive Pulleys
- How much HP should i be getting?
- Destroyed front suspension + other stuff
- Need Help fast!
- headers on a 96
- so i changed my iac valve today
- clutch replacement
- Code 32 - EGR System
- Need a new oil pump drive gear/stub, where to look?
- what size injectors to use?
- Popular Free Stuff
- Free T-Shirt
- How hard is it to get too...
- PCM auto shutdown?
- ses light!!!!
- need help with a y pipe issue/ identification
- JetHot LTs and odor
- Few questions??
- fuel leak... ?
- Rattle at 3K+ rpm
- Ok what should I do..take it to the dealer or replace IAC?
- Tach Install
- 383, cam, and California emissions questions
- Port heads or 1.7 rr's????
- Engine Problem
- Pacesetter LT's, what catback?
- Ideal diameter for homemade CAI?
- ABS -Non ABS rear
- Shop for a good Swap?
- Could a blown head gasket cause a miss?
