View Full Version : LT1 Based Engine Tech
- CC 918s?
- MT ET Street sizes
- what about these specs on a cam
- 130,000 miles
- conductive thread sealant?
- what headers?
- Decent piston
- Help me find a replacement for my lil Hot Cam!
- Top End 5k+ is losng power??!!!
- Any Interest In A Gold Double Spring LT1 Kit
- Who here hit mid -high 10s on just motor
- transmission??
- This x-pipe any good????
- AFR LT4 H/C dyno results.
- ZZ4 crank
- Gapless Top Ring Sets?
- 94 T/A missing, where to start?
- Need tech help for pacesetter shortie install
- oil leak from intake
- MAC header install in progress
- knock sensor vs. Forged pistons
- installing new rockers
- possible to hit 10's with a 396 stroker??
- NGK Plugs & Super Glue???
- Easy way to roll stuff around! (Esp engine cradle + trans)
- NEW loudmouth question (be gentle)
- Blown catalytic converter
- MSD Cap and Rotor
- Valve Springs?
- Rebuild kit question...
- Opti trouble
- Pro's and Con's of Long Tubes???
- 3.42s from a M6?
- will this work/fit the right way?
- Poly Engine Mount Orientation?
- Couple SES light questions??
- is my tps voltage right?
- okay heres the valvetrain setup
- Best headers
- Gonna attempt putting LT1 in tonight (GARAGE CAM for your viewing pleasure!)
- I really need help on this simple problem...
- Mac Headers on 95
- Symptoms of bad Optispark?
- 32# injectors on stock motor?
- Is there a way to make an interface cable yourself
- will 94-95 headers work on a 96
- ASM Header Guys
- hydraulic lifter into solid lifter
- Injector Sizes - When is big too big?
- 227/233 starting problems w/o tune??
- 4.33 or 4.11 for a heads/cam
- Corvette Brake Purchases
- cam useable on stock lifters
- Wheel bearings
- LT1 Swap no Injector firing
- Anyone try the New C.Cams FXI 230-236 cam?
- spring locator vs shim
- Throttle Body? MAF? Cold Air????
- CC 306 with 1.6 rockers ? Is this too much ??
- Ported Intake questions...
- Now how did that happen
- 2 pitted lobes on cam?
- Where can I purchase a radiator hose?
- Anyone wanna call BS on this Lingenfelter 383?
- are all cats created equal?
- Head Question?
- Cam swap question
- low oil
- quick help please
- Blackened Rocker...?
- engine wont start
- What intake bolts go where?
- Which Head/Intake will work on my '94???
- head gaskets leaking?
- How did I mount my digital 6?
- Help, idle problem
- Anyone running the 209/217 Isky cam
- threw a rod tonight....
- Porting the stock intake
- Msd Blaster Coil for Obd2 Cars
- Cooling Fans NOT Coming On
- any A4`s with 410`s
- anyone with the CC230/236 got track times yet?
- anybody running a 255 that isnt racetronix
- have a qeustion about poly urethane tranny mounts!!
- Where can I find some parts..
- Someone tell me what they think of this kit from ebay
- quick oil question!!!?!?
- Chaulk another rear up with the new motor.. 12 bolt?
- Volt Booster - does it work?
- Most lift on stock springs?
- 383 LT1 as a daily driver?
- CC306 cam swap done, almost a complete success!!!!
- stock 94z28 need tips
- bumping up fuel pressure in regards to performance
- What is the differance?
- NEED HELP! Thermostat Question!!!
- Drag strip time
- Maybe a stupid question but????
- Installing Electric Fuel PRessure gauge...
- Can someone show me a picture of our rear suspension?
- 132,000 Miles on Injectors. Do they need replaced ? Details inside.
- BBK Shorty Headers?
- What's this wire on passanger side harness?
- Check this if you have corsa.
- New noise coming from engine bay.
- -Video of Hooker Catback Interior Sound-
- Need more mods. What to do?
- Backfire in intake.....WHY?
- Wiring Harness msd 8876 or 8877 for msd 6a?
- Scanmaster DTC CODES: 16, 29 and 53....Shoebox?
- rocker install time!
- Moser 12 Bolt Axle Seal ???
- SES light code 23 MAT sensor too low?
- Does TCI make a stall for lt1's??
- Which crank for 7000rpm nitrous motor
- Raised and Flat Guideplates?
- is there a termporary fix for burned plug wire?
- Strange BLM Readings
- Best 60' for Stock Suspension LT1?
- why does my graph have a loop in it?
- March Performance Pulleys
- rod journal size
- Need pics of fuel pump install..Walbro 255 lph..
- Stock lt1 to 396?
- Engine ticking (not exhuast)
- Changing plugs after shorty headers. Easier or not?
- most ci out of .030
- how long should SES codes appear after pulling the PCM BATT fuse for 30 seconds?
- underdash ground cut, where does it go?
- Signs of clogged or dieing injectors??
- ???'s about LT4 Hot Cam
- Mr Gasket 5716 problem
- what # injectors are these ??
- Smells like a gas station
- Build a seperate block, or rebuild my current?
- header gaskets
- o2 sensor question??
- Differences in the LT1 Aluminum Head Castings??
- Did Some 95 Cars come with 96 Casting # Heads
- Disappointed with new times.
- what the **** happened????
- Need some help from a 97 Camaro owner.
- Bolt-on beginnings
- Wiring Speedo gauge!!!???!!!!
- Common maintenance needed?
- No Heat!
- 97 transmission in a 94 car
- Hawaii residents, please read!
- !AC Evaporator pics
- Part Number on GoodYear High Miler Hose Kit
- Strange noise when starting up...
- Can coolant "disappear"???
- Code 29?
- Quick question on K&N FPIK
- What's my new oil capacity with Canton 242T pan?
- Dual Fuel Rail LT-1 setup...
- Need opinions
- what all is needed for S/C?
- Reseal LT1 Help
- Diameter of Wires?
- write up on how to install a rear mounted distributor on LT1
- Cam Break In?
- Changing Wires!!!
- Does anyone run cats?
- Lifter wear?
- Oil Temp Sensor Location?
- !AC Condensor
- Another "where do these wires go" thread hehe
- Taylor Spiro Pro (cut-to length), Jet Hot Headers, & Delteq - How I ran it!
- New with this help me out
- Fuel odor uncovered!!!
- Small question...
- Which LSA for my cam?
- Service Engine Soon Light
- oil pressure question
- Stage 8 Locking Fasteners, what size?
- Anyone ever done an opti on here before?
- GM 847 Cam question
- ASAP.. need sbc conversion help kinda
- 72 Buick Skylark with and LT1 question.
- Anyone useing standard SBC heads on there LT1???
- cap and rotor opti
- Converting '94 LT1 to speed density
- Taylor Spiro-Pro's: 1 - 1.3 K Ohms, is that OK/Normal?
- Can/Should i procharge?
- Quiet my Loudmouth
- Need help with possible ignition problem
- Cam Rataining plate
- Gonna change plugs.. Any tips?
- Will someone explain to me head flow numbers?
- Exhaust sound issues
- is my maf shot?
- Taylor wires: which boot am I using?
- stock rod length?
- Oops, I snapped the knock sensor wire
- mailorder tune q's??
- Keyless Entry Programming?
- 96 LT1 woes
- LE2 heads?
- New times with crane 210/224
- Best way to clean deck surface?
- Price of Re-doing Valve seats
- Whats this exhaust
- Need to move my header
- Jason Crower Contact number?
- how do you get to the rear main seal?
- small short from gauge circuit to pcn grd
- K&N Air Filter for 97 Camaro SS
- Kook Header Pics Installed!
- LE2 Flow Sheet
- Free obd1 scan program?
- Heater hose leak at firewall
- Opti-Spark Info
- ported heads and 1.6 rockers with stock cam
- chargine issues
- Weight of LT1 engine?
- rwhp/tq guess's?
- Rattle when engine is cold.
- 1st Lt1
- Delphi O2 Sensors (afs-75) Acdelco???
- Bad/Failing O2 sensors always throw code??
- what does this connect to???
- help! lt1 wont idle right
- How do You Change the PCV ?
- Camaro/Impala MAF
- ET Performance Cylinder Heads? Any Experience with them?
- Heads Cam with Stock Throttle body.
- Does your AS&M hardware rust like mine does???
- Can SOMEONE please hlp with a trans problem for a Z28? thanks.....
- need data monitoring help
- HELP! Engine Noise under passenger valve cover.
- Flushed heater core
- Good Day!
- Valvetrain interference problem.
- Those who removed factory oil cooler.. help
- Pre-Assembled 383 Short Block
- scanned, are these #s normal?
- Question for anyone with a heater core from autozone.
- Bare necessities
- '97 and newer guys...
- Where Can I buy the cable for lt1 edit, and the software????
- MAF "sensor" Only
- Random Tech Dual cat y-pipe or Custom w/Catco cats?
- MSD ignition installation
- Signs of bad tranny?
- Quick Easy Question!
- Smoothed out lifter valley
- replaced optis distributor...didnt help
- What Stall to use
