View Full Version : LT1 Based Engine Tech
- worth the $ or not?
- I know I'm just being lazy but...
- Removing the crankshaft hub.
- Anyone using the New MSD Alternator?
- Motor mounts, some one help!!
- horsepower question
- Car dieing upon startup, unless I hold the throttle....
- racetonix fuel system install.
- waterpump project. help
- 383 weird idle problem
- 355ci or 383ci?
- Part numbers help
- CPU wont recognize o2 sensors
- Those using Comp R lifters inside please
- Do pacesetter shortys come with D ports?
- Best place to get GM 847?
- New timeing chain is loose.
- Exhaust flow question
- CANT find the 1LE grills
- I called Comp Cams to get info and...
- Is this the correct part # for the Cloyes double roller?
- Who has had an electric waterpump fail?
- What does DA mean when talking about track runs.
- Hmm, started fluttering in low RPMS...
- Help: How do you Bleed Fuel Lines?
- Removing valve springs.
- head gasket
- cooling system throwing code
- Limits of stock exhaust manifolds
- where to buy le1,le2,le3 cam-head kits?
- Walbro F20000169 Fuel Pump is a direct replacement for stock fuel pump
- LT1 Stroker Advice
- Super charger or 383 stroker
- how to adjust timming on lt1?
- Should i go ahead and remove the optispark?
- Where to get heads flow tested in eastern NC
- need a little help
- What HP can a Walbro 255LPH support??
- Does anyone have the part # for the pressure plate bolts?
- P00008 Code, high intake
- Temp too cold?
- help to pick the proper cam for my setup
- lt1 build up?
- for guys that are veteran H/C installers, what would you do next(everythings off)
- Cannot trace fuel smell. please help
- Will they fit?
- iat sensor question
- Need parts list for Elec. water pump install
- using water instead of coolant?
- Where is the oil coming from...? *PICS*
- ? on injectors
- Tachometer problem for the LT1 experts!!! :)
- Autozone Thermostat
- Stock injectors OK for CC305 or similar and 1.6RR?
- radiator flush
- 93s with K&N directly on TB?
- NEED HELP Finding **OIL LEAK**
- Whats the GM P/N for the AC delete pully?
- Headers/Y-Pipe Ordered...will borla still work?
- 3 bolts and a rusted ECT away from saying screw it.
- Installing motor from the top
- start problems
- What should I do with my heads?
- Where did you mount your LTCC?
- Estimated numbers with new mods ?
- cat delete?
- cometic head gaskets
- what to do ?
- How much rwhp with all bolt ons?
- valvetrain setup?
- Comp XR276HR-12 will this fit a 97? HELP
- replace LT4 KM and Knock sensor?
- Fuel pump problems
- Please look at this autotap log...
- Gains to be expected from 383 Stroker?
- what is it like? 600+rwhp guys?
- Help on compression ratio
- Need help diagnosing Ignition problem.
- Need help with Breslin bolts
- Screw in or press in studs?
- still no start!!
- Trip Odometer, Sort of LT1 Tech
- Best High Flow Cataylic convertor. Where to get?
- Who Is Jason Cromer???
- my cars gone......
- duals and LTs without crossover pipe?
- HELP!! Need a KIT
- Stock Crankshaft Pulley Diameter?
- installing opti on 96Z, how to line it up??
- replaced heater core, 3 days later smells again
- What catalytic converter goes on a 97 LT1?
- Please helpWierd Noise from the Passenger Side
- Deltec, do you still need aftermarket Ignition box still?
- LT's installed; how much should I pay for Y?
- Pulling motor out top,remove hood?
- Technical? Will A/F change with 1.6 RR's?
- Cooling Question
- Video: My Car Blowing up...
- Head swap ?'s
- Intake gasket part number?
- Timing cover question
- Downgrading from 30's to 24'slb injector
- Anyone with 30 pound injectors tuning with only maf translator?
- 1LE elbow?
- Help identifying module under dash
- Looking for prices on and info on 383 Stroker KITS
- LTCC grounds
- Anybody replaced their trans shift cable? Couple of questions..
- Rear o2 sensor question
- Passing AIR Diagnostic on '93 Z28
- money to spend...what to do??
- Pouring out White smoke(fuel smell)...help please
- bone stock dyno..95trans am a4..opinions?
- urgent... 93 TA coolant flush
- High speed vibrations
- P0141 code - bad o2?
- What do i have to do?
- ¿Opti Question?
- Is speed included in any fuel or spark calcualtions
- how to make heater hotter
- Offroad Y for stock maniflods??
- p/n's for rubber vacuum hoses?
- NEED HELP with clutch lever!
- quick question
- Lunati timing chain set?
- SVO 30# p/n?
- Push rods and guide plates for LT4 cam.
- location of fuel pump relay & prime conn?
- Tach doesnt work in 94 firebird formula.......
- low oil pressure/high fuel pressure
- Stripping a '96 to be a road race car - electrical question
- leaky water pump
- time for a new catback
- Cold Air Intake
- LT1 to LT4 Conversion...Opinions?
- anybody chew up some GMPP guideplates?
- MAF flow #'s
- New In Box PaceSetter's Quick Trip Long Tube Headers and Y Pipe - $435, Good Deal?
- Could someone look at this real quick!
- where is the cheapest place to get the pacesetters long tubes
- Is this Electric water pump any good??
- Feeling Guilty About Removing Stock SS Ram Air...
- How much and where to port TB to 52mm?
- what other cars have lt1 engine?
- Hose/tubing questions
- dropped the fuel tank and forgot how carbon canister lines connect
- How to beat '03 Cobra building on my mods
- Valvetrain Questions
- Importance of new timing set?
- running really crappy after cam install
- Ls1 Vs LT1 question
- Oil filter bypass thing, does it need a gasket between it and the block.
- LE3 or GM847
- Long tubes and now car shuts off?
- madz28 tune
- oil level sensor install
- do the pacesetters lts have the o2 bungs in them
- long tubes or 373s gears
- data logged..need advice
- headers?
- Changing Spark plugs
- CAM questions
- Oil level sensor
- Rod Bolt Clearence Issues
- Top End
- Rattling noise coming from in or around my catalytic converter
- Start problem confirmed fuel pressure related, next step? Replace pump?
- Quick! Any difference between ARP and CC 7/16 studs?
- Looking for a 4bolt kit
- Long Tubes and Fuel lines.
- snap crackle pop
- What valve train?
- Forged Eagle + SRP Stroker kit...Good price??
- Little Rubber thing (oilpan questions)
- slp headers?
- What to do with brake lines when going from TCS/ABS rear end to ABS only rear end.
- Torque Converter Questions
- Combination Motorsports ex 612 valvesprings
- Anyone ever have a frame straightened?
- My 355 burns a little oil
- I'm stumped
- Easiest way to pull motor?
- Oil Leak and High Idle
- OIL for winter?
- 235-D Isky Springs.
- Everything i'll need?
- Cars w/ GM847 and P&P Heads
- Exhaust Setup
- 383/396 question
- Anyone EVER benefit from LT4 km ??????
- Problems after Header install, Need Help!!!
- 383 reliability/output/Lingenfelter
- EGR problem
- Cats!?
- lash questions
- Which year LT1 came with hardened pushrods?
- Did my water pump go bad?
- How do these ported LT4 head numbers look??????
- oil half way up dipstick??
- Where can i find a full length article on F.A.S.T. for Lt1 cars? Searched, no luck!
- 13.793@98.48 Good Times?
- headers install with problems
- Best LTs for a 93 LT1?
- Tips on pulling an LT1....
- Shaving Weight?
- True duals with 4 bullets instead of 2....
- Cam Swap and DIY Head Porting...
- Pulled the cat..wierd exhaust noise.. normal?
- Forged pistons and rods?
- ram air
- Will Purple Hornies header mufflers fit, and 28x11.5x15 ET streets?
- Pictures of my new motor!!! She is beautiful :)
- LT-4 oil pump same as LT-1?
- HELP: Car stopped running in the middle of the road
- Hot Cam Specs
- How much HP?
- 383 SC backfire from H*_L
- car runs like crap when cold started!!!
- fuel system wont hold pressure after pump/AFPR install
- wow, my car hates me!!!
- Need valve cover help
- Part # for Timing Set
- Q. about temp and door weather strip
- Going on a road trip?
- $200 for RR's and Lifters, is this good deal?
- cooling issue
- Gutted Cat (not by choice)
- Can Conversion.. Is it possible to...
- Oil pump driveshaft?
- Rpm's stay high when cruising...
- exhaust odor inside vehicle
- Friends cavalier
- fuel pressure leakdown question
- Camming An Lt1
- Will it run?????
- PCM not working.
- Wtf!!!!! Not Again!!!!!!
- help with project selection
- Lingenfelter 383/Superram
- Mass Air Conversion On 93' Lt1?
- gm partsdirect fuel injector???????
- TPIS's external water pump pulley
- Any reason to use 7/16" studs on a small cam?
- Gasket ? stock bottom end.
- High volume oil pump problems?
- Do you think this is any good, or not really?
- Why are earlier LT1 timing sets cheaper than 95+?
- i need to know if i can win
- Wierd noise from shifter region
