View Full Version : LT1 Based Engine Tech
- 411rwhp/492ft-lbs on stock motor
- A4 vs M6 vs 94 vs 96 wiring harness
- List of upcoming mods...Thoughts? Guesses?
- ls1 exhaust on lt1
- Lt4 springs good for this cam?
- Another oil pressure problem
- Scanning for codes in a 93?
- What is the correct oil pressure?
- Can't get my Z28 better then 14.5!!
- How much does a Z28 Convertible weight?
- o2 question
- Couple Questions about my rebuild
- What lifters are you using?
- Are 11s possible...
- Questioning a couple of possible mods...Do it or Don't Do it???
- Bleeding ABS need Help
- Oil Pressure Problem
- Blown Head Gasket? (
- Over valve cover?
- Different year Z28 LT-1s?????
- pro's / con's
- installed the bbk 52mm tb and i have got a question?
- please help!
- Anyone having clearence issue w/ Spohn Torque arm
- Lingenfelter cai?
- Could a backfire bend a pushrod or mess up a lifter?
- filling out form for madz28 tune
- how do you tell the year?
- Replacing plug wires
- AS&M Header install
- Looking for LT's with good ground clearence.
- Timing Chain Questions
- comp 987's?
- "More Performance" LT1 ignition wires...
- gas pedal feels sticky...
- Car won't start after LTCC install. Help
- Low fuel pressure bad?
- Miss-stumble ANSWERED!!!!
- Anyone use factory plug wire routing on Pacesetter LT's
- How can I tell if I have weak valvesprings or valve float
- NEED HELP!! Fresh rebuild, Fuel in oil!!
- Where is Nu-tek motorsports?
- 1995 OBD1 Scanner issue
- What should I be expecting from this?
- No fuel pressure?!?!
- Best 355 Rebuild kit?
- valve guide seal to retainer clearance?
- Average running temperature?
- Did anyone ever get hard numbers between LT1/LS1 intake ducting?
- Cloyes New Timing Chain...?
- OVC's and Fuel Rail Covers
- Need to see some carb pics please...
- Sigh, I knew this would happen, but not this quickly.
- What is the third fuel line under the hood go to?
- what to buy
- Shorty headers
- Cam Reccomendation.
- Please Help!! Car wont Start!!
- fuel pressure on stock lt1
- over the valve cover plug wire setup
- Help cant find a 396 stroker kit
- are these the correct part numbers for comp springs and lifters?
- Cooling problem, help with Freescan
- How to check if injectors are firing?
- Bigger cam guys: Tell me what cam you have and if it passed emmissions or not.
- Finished cc306 swap! (pics & vids & a couple ?'s)
- Idle problem
- LE2 or LE3 sound/vid clips
- Fuel Pump Schematic/Wiring
- bolt on's
- exhaust
- should i change my plugs with LE2 setup?
- LT-1 video
- will this exhaust setup work?
- is this the right cat?
- What kind of Intake to Get
- I Broke it!!
- question on my fuel pressure
- Clacking on new valve train, video of sound inside, EVERYONE LISTEN PLEASE :)
- Failed emissions, what do I need to fix?
- Intake and head questions??
- Tach is off
- Proper way to prime the LT1 oil pump
- HELP on emmisions (2nd time failing)
- Re-Tightening of Exhaust Bolts and Other Exhaust Questions
- starter/header question
- Driving a 6-speed with an A4 computer?
- pcm calibration question
- Is it worth it to switch?
- What's an M29 tranny?
- Compression ratio
- Need Help!! Cam Walk?????
- Headers
- ECM Harness Connector, where to get?
- Gain from Isky cam
- Ugh, Fuel Pump Question...
- Head Gasket rumors
- Time for the high mileage oil?
- uh oh, another pacesetter lt question
- What will LS1 injectors do for LT1?
- Supercharger Or Heads/Cam best HP while retaining gas mileage and low rpm torque
- installing fuel injectors.
- Vortech t trim supercharger for LT1
- 383 oil pump options
- benefits of swtiching to a solid roller and the differences?
- Speed Chip
- My dyno sheet...
- HOT CAM excellant compromise for driveability and performance
- What all is involved in LT1 edit??
- Very wierd engine noise
- Timing chain
- Steam Pipe routing...
- One last question about lifters
- found unplugged connector
- Long Tubes, KM, & False knock ??????
- who has or has had headers with a stock catback?
- Help with water pump on 94 trans am
- 400 rwhp
- Are F-body LT1s the same as G-body?
- Unlock trick
- Really need help with Y-pipe question....
- Harmonic Dampers
- Just double checking...
- 1 LE elbow?
- Del tech coil kit
- do taylor's suck or is it me?
- getting cc306 what valve springs lifters and rockers?
- Do stock tachs lag behind at all?
- Failed emmissions. Need help.
- Who said the CC306 isn't streetable?
- NSA crane roller rockers
- heads and cam???
- heads and cam ???
- only closedloop?
- Hole in throttle body?
- Spark Plugs
- priming oil pump
- Another "My head studs are leaking" thread. Need advice.
- elec water pump warning light
- valve spring problem in a 93/94
- trying to extend the life of my poor 7.5"
- Header mod. Can I do this?
- Intake Elbow Clamps
- Does anyone have the part # for the inspection cover on the bellhousing?
- Coolant temp!
- Driveability of a Stroker
- LT1 Engine Swap HELP..............
- Broken rods?????? Please help me!
- Where to order twister mufflers
- Cheapest price TA cover?
- Just received Vortech elbow, thoughts...
- First start on new motor video, come watch!
- where to shift stock LT1 zwith 100k,bone stock
- Need Interior Part Number
- Stock cooling fans can cool to what hp?
- help with spark arc
- engine rebuild cost estimate?
- SJM Alternator Relocation Bracket anyone run this?
- What Gear?!
- Preparing to Fix Intake Gasket
- lt1's and lighter flywheel??
- SES Codes (26/63/77) and Freescan
- Tune or MAF Translator?
- Heads ? for those with the Comp Cams 236/242
- Part number on BBK throttle body?
- replaced entire ignition, still stumbles, totally clueless
- Need help whistling is coming from under the hood
- popping in the exhaust
- Why is the Lingenfelter SuperTube so cheap?
- Important question regarding 94-95 and 96-97 Pacesetter LTs.
- trickflow heads and 224/230 xe
- Any Differences in LT1 and LS1 Radiators?
- Who bores stock TB to 52mm? (did a search)
- SLP Y-Pipe
- What Causes an Irratic Idle (Surging/searching))
- Bad vibration under braking, and cruising, new brakes and alignment... what else?
- Worth it to do LE heads with no cam?
- Vibration over 90mph???
- gains from tune after cam?
- Exhaust help, what to do.
- worth replacing oil pump
- Simple header question...
- Magnaflow Exhaust
- Change o2s or not?
- How much will cutout do after dual cats?
- How Much will this help?
- Help..eng burning oil missing plate under intake
- Kook's headers installed. Comments within.
- any benefit to deleting AIR and EGR?
- Is it possible
- Pete Jackson Vs. Stock Timing Chain
- Need advice regarding header install
- Y pipe question
- Burned out on plug wires
- 70psi oil pres at startup on new motor, is this way too much?
- what programer should i buy?
- A/C compressor bypass?
- tune before or after??
- Car won't start, please help!
- blue smoke
- Help Quick - Bleeding Coolant Lines
- Falken tires any good?
- Retrieving SES Codes on 1994 Z/28
- LT4 Rocker Cover Pics
- 383 stalls at 5700 come help
- Taillight issue
- Already had it with my A4, LOL! Was your M6 conversion successful?
- Need Help...Lets get this over with...
- Lifter needle bearings
- Aftermarket Y-pipe, any powergains?
- who can port my TFS heads?
- Question about Automatic Shift Programing, Mad Wolf, Biran, Somebody.
- the real deal: gaskets and RTV
- How do I replace this seal??
- 95 z running horrible. feels like a miss, but getting DTC44. help!
- Coil spark???
- Stainless steel hoses for radiator
- Edelbrock header gains
- Clean Pro Mag rockers?
- Alternator rebuild
- Need Help I think I Broke something
- Need some help with decideing what to do with the opit prob.
- Reading the O2's
- will it run??
- want to spin engine to 6300 reliably
- Does anyone have a SLP loudmouth video of an LT1?
- Stock lt1 cam specs want to do some compariing
- got some ?'s about rebuilding motor for H/C??
- rearends
- TPS issue, replaced, still having issues
- Borla Pro XS transverse muffler
- 24 lb. FMS injectors = rich on stock tune?
- need advice:adjusting a loose rocker arm
- in need of a 10 or 12 bolt rear end where to buy
- Putting a Gear Drive on an LT1
- Putting a gear drive on a LT1
- Rod bolts...?
- Problems with installing Hooker catback
- LT4 Rocker Covers = Nice :)
- Tune?...or no?
- help?
- cam
- Pacesetter Headers Summit Part # Question
- Need help Please!!
- engine trouble need help
- NEED HELP! engine problems
- Do I install the rear main seal dry?
- need help IDing vacuum stuff
- desktop dyno... i need lt1 cam files!!!
- would cut outs trick the sniffer?
