View Full Version : LT1 Based Engine Tech
- Studdering???
- msd ???
- Valvetrain clatter... is this normal?
- Breslin Header bolts?
- Pacesetter LT install. How to disconnect U joints on steering.
- Fparts ebayer seller
- Is backfiring a problem?
- 99+ Fbody Gas Tank
- head question
- Installing fuel tank straps help!
- Is it possible to remove the front clip on a 95 Camaro
- lt1 headers
- Quick question to those with AFR heads....
- Whos Installed LT4 starter with Stock Manifolds
- Proform 1.6 rockers
- O2 Sensor Replacement
- double roller timing chain/94Z
- Need help identifying spark plug wire brand.
- Will bbk shorties from a 95-95 fit a 93???
- 434 CID LTx engine?
- 392 rwhp....387 rwtq...is that good?
- NEED HELP ASAP w/running duals and Jet-Hot LT's
- Aluminum for Block Off Plates?
- just a click when you turn the key?
- I accidentally Repaired my Power Door Locks
- What to use to glue FELPRO valve cover gasket to VC
- Can someone take a look at my datamaster/PCM file and let me know what you think?
- Anyone have LE3 SOUND CLIP???
- 94LT1 headers vs. 97LT1 headers
- slow to start, opti or fuel?
- Would you trust this gear set?
- Which Cam?
- help! new stroker has vibration around 4000 rpm
- any point in buying intake to practice porting?
- no o2s
- What kind of horsepower from cutout?
- DS loop Question!
- DTC 63 and 13, left and right oxygen sensor failure
- 1le brake upgrade
- Is this the right part for my car?
- Where are 02's and Radio grounded?
- Connecting fuel lines help!
- Car doesn't start.
- Help me identify stock rod bolts
- where to get a stethoscope(sp?) for rocker adjustments?
- Electrical Problem, please help!
- How long to install LT4 Hotcam Kit?
- Equation for figuring out fuel pressure vs. injector lb/hr?
- Starter problem need help IMMEDIATELLY
- delteq question
- Tranny Fluid
- need a cam
- Now what???
- Low coolant??
- looking for good priced heads
- gains/gearing???
- 1.6 rockers on stock, Also puff of blue smoke on exhaust.
- O2 sensor recomendations
- Mechanical vs hydraulic cam (cc306)
- Spark Plug Gap...HELP!!!
- What kind of hp gain from gm847?
- GM Roller Lifters
- Driver side collector leak driving me insane.
- rocker stud size
- Waterpump: Reman or brand new?
- New owner of an LT1
- Part number for console
- will these springs work with my cam?
- LT4 Springs
- part # for crank balancer bolts?
- rod bolt replacement
- 96 t/a slow start
- is this sctach a big threat on the head?
- Dynatech LT's
- Best cam for 3.42+M6?
- How to get more top end? And Heads Question!
- Car Died, tell me your thoughts on why.
- calling all, ARE/Agostino heads owners..HP/flow #'s???
- What is "throwing a rod"
- cc 305 ?
- Refreshing the valvetrain on high-mileaged LT1 question within...
- Strange Idle Surge???
- lt4 hot cam
- IAC / Idle Problems
- question on pics of true dual set up with 1 chambered flowmaster
- Electrical Issues
- BEST place to buy o2 extensions?/?
- Low oil pressure at idle, Please read!
- O2 Senor simulator
- Potential
- headers or exhaust
- Gear swap times suck varaibles
- 4 bolt main cap questions...
- Ecu ??
- What springs do I need for a gm847?
- why does car run different 2k rps and under after cc306?
- Door tag ?
- can a 95 knock sensor be disabled with 3.9K resistor
- do i need the LT4 KM?
- 400 hp?
- Mac Prices
- need pics of lt1 intake
- LE1 or LE1 heads/with dif cam
- People with Mac Headers, come inside (ground clearance issue)
- Oil filter study- results
- Little help please!
- What mods?
- injector size question
- could someone share xe 224/230 lt1 edit file:)
- upgrading ignition need advice
- possible to raise the compression to 11:1 using stock pistons?
- Help, car won't run after head/cam install
- Where to buy Headers?
- car shutting off
- Combustion Chamber size for 10:1 compression Ratio?
- knock sensor and obd1 conversion???
- 94 z28 pcm communication port wiring
- Problem with spring seats and shims
- LT1 Aluminum Block - Would it sell???
- Hey question about temp sensor in waterpump...
- aluminum flywheel
- electrical question
- Can I use a 239/245 112lsa cam w/my 355?
- Non Vented---> Vented Opti
- Lower gears = multiplied torque?
- Summit X-pipe+Dynomax bullets video
- Need part number for .039ths head gasket
- Trick Flow heads
- Machine shop question.
- '95 Z28 is leaking oil in 2 spots, why?
- Throttle Body
- 95 Z overheating fans not turning on
- Anyone see this? Elec. WP User's INside!
- Injector sizing?
- injectors
- Injector problems Please help
- whick timeing chain kit and lifter to go with a 94 lt1??need help please
- what do you think bout these head flow #s
- swap question
- Vibes @ 5k rpm
- engine swap
- Need Advice:
- Crank position sensor code
- how to pass emissions
- Cold Weather Affect a Fuel Pump
- Air/Fuel Gauge question!
- header and plug wire question
- injectors not pulsing
- CC305 sound files and lope question
- Pace setter Dyno #'s???
- Air intake
- EGR Plates... Do I Really need them????
- Is this my fuel pump, or opti?
- overdrive alternator pulley
- Question on Diamond Racing Pushrods
- when ordering pacesetter lts do i need ??
- Joe Overton customers, inside please....
- coil recommendations for a different application
- Hard Blok (advantages-disadvantages) what is your opinion?
- Aftermarket Options for fuel Line replacement/upgrade??
- Would a bad air pump cause....
- Comp Cams XFI Cams
- My Head Flow #'s
- Ignition problems/questions
- I need a pinout diagram please.
- Hot cam on 119k motor
- 383 What Synthetic Oil to Use After Break-in?
- did all of the 93-97 camaro LT1s have....
- Low Voltage Reading
- what cam?
- cams
- Removing Thermostat???
- Help please, 383 stroker
- Side exhaust and dumping directly ONTO the tires
- to cam or not?
- 02 sensor lean???
- emissions??
- yet ANOTHER header question
- How much power would you need...
- Jet stage 2,do it or not??
- is this the same cam??
- Need help fast please!!
- Who here runs a 10.5:1 or similar 383 N/A...
- Those who have dealt with Advanced Induction inside?
- TPS question, conflicting info
- What the "F" is this?
- bullet mufflers
- Header gasket change HELP!!!
- removing chrome
- Oil leak
- Delteq Question
- 195,000 mile opti, 14.06 @ 100 mph???
- anyone know when Madwolf is coming back
- 4l60e + 3.73 = ??
- Is this an underhood fuel filter?
- Valve spring question: need help
- Ebay valve covers?
- Building a Stroker Motor, I need some advice!
- Info on the Delteq system
- Are Clevitte H-series bearings race only?
- Please help with electrical issue
- Where to purchase Dynatech optispark
- yes another guess my 1/4 mile
- '94 LT1 info.
- 1.65's???? Roller ROckers???
- 1996 Camaro LT1 Emissions
- ram air or not to ram air
- help! car stutters at 2200 rpm
- Need a new damper
- Afr Lt4 210
- lt4 knock Module
- rockers
- porting intake openings to 58mm
- Home Made CAI Pics for LT1's???
- long tube y pipe question
- Jason Cromer???
- Air Bags
- Part Number for the plastic over the guages?
- no keyless after my car was vandalized! got ???'s
- Car does not feel good...
- searched.cheapest place to get pacesetter lts.
- real problems..........car's missing badly
- Stock LT-1 times
- just started car after le2 set up
- camaro guy in town says away with the slp shorties hello to longtubes?
- dual exhaust question
- port the intake or not?
- Vibration.. why?
- current question.. still got problems :(
- How much horsepower gain from LT4 hot cam and headers
- stock HP rating for a 94 aluminum headed LT-1
- How much life did I take from my engine?
- Opinions on this dyno?
- Whistling noise????
- HP advice for an LT1 Chevelle
- Lt1 Swap Into 85 Vette
- Mixed ideas on head gaskets..
- Is a 3000 stall too much for me
- TB questions.BBK,holley,etc.
- O2 sensors sticking?
- Does anyone know where to get a new gasket for a bbk 58 mm TB cheap?
- Blown Motor, I need experienced opinions
- few pictures of my new 383
- Wiper Trouble and Yes I did a search
- Whats your stock time?
- Question about aftermarket elbows?
- Confused what to do with saved money, about 4k...
- Racetronix fuel pump install need instructions
- throwing codes
- jet hot y pipe
