View Full Version : LT1 Based Engine Tech
- which rocker stud to use?
- cheapest place to buy 1LE elbow?
- Hey Mr. Shoebox , Opti ?
- Y Pipe for Hooker Shorties?
- starting problem
- Can you drain just the radiator to pull the waterpump?
- Remove CAT Yes or No
- getting the most out of my lt1
- Fuel pump Problems!
- opti disection "shoebox"
- Stumble and revving at idle
- Impala MAF difference
- Where can I get a 1/2" vacuum cap?
- can't disable OBDII knock sensor, help anyone, madwolf.....
- new RR studs?
- Help, engine died and will no longer start.
- Progress on my DIY head porting job :D
- Hot Cam kit for 1994 LT1 a Direct Bolt In?
- header question?
- Could somebody please help me out with a pic and an answer??
- Price for jet-hot LT's?? $500 shipped to me good?
- LT-4 hotcam kit on a 355
- !Motor not running good.!
- Lt4
- Help with cam install & timing chain
- Heads/Cam RW Power Numbers
- cables for obd1 computers
- T/A Tech question(oil press & steering)
- Heads off
- Stock Rebuilt Lt-1 60 Psi Oil Pressure at Idle
- Intake hose?
- Sputtering, Backfiring, and Falling on its FACE
- Need part # for 224/230 ex cam
- Kool Blue Part # ????????
- Walbro 255 plus an inline booster?
- Can you buy German Castrol motor oil online?
- Belt Tensioner ????
- Easy questions?
- Pacesetter Help!
- lm wont pass sound?
- TSP Rumbler exhaust
- Aligning or Non Aligning
- question about stock oil pump
- What is the part number for LT4 valve springs?
- What's your favorite nitrous system for LT1
- Castrol Syntec On Sale!
- What rod size for 383 with future planing in mind?
- Repairs that need to be done to my car...
- More info
- remember horrible dyno numbers well got leak down take a look!
- Signs of a collapsed lifter or loose rocker?
- rust flakes in coolant?
- vibration with new motor
- Hard to start, won't idle and unable to get codes.
- Opti install Q
- ok i give up trying to find the prob.
- $#@%^$#....oil coming from dipstick tube...
- New combo...should be stout...any thoughts?
- 500 rwhp
- how much can you mill a head?
- compression ratio
- callies compstar rods
- How bout this setup?
- Extra valvetrain noise
- waterpump worries
- TR55 Gapping Recommendations Please...
- Why on Datalogger does my car say 50 rpms when the car is off?
- Could bad fuel delevery (I.E. bad pump/filter/fpr) cause detonation/knock?
- cc306 and all parts
- Looking for an engine rebuild.
- Stock fpr w/ 383?
- 9.5 Compresion Ratio enough or not.
- Tru Duals
- Steering wheel not center
- Loose steering?
- Do I really need to re-route fuel lines for True Duals?!
- TH-350 Dipstick
- Bad miss at WOT??
- valve spring help already did search
- Just curious, how often do you all clean your CAI air filters?
- Just ordered some Mac headers for my '95...
- Will my K&N filter fit on one of these?
- intake and exhaust help
- Gear install question
- My brother just bought a camaro.
- head gasket problem
- Should I start this motor?
- pistons matching heads
- Possible Blown Head Gasget.......Please look....
- Crank hub issues...........
- Clutch Master Cylinder issues
- Guage Cluster Fuse?
- Where to buy Stock manifold flange gaskets
- heating question
- cometic head gasket
- Have You Guys Seen This!? Opti Replacement Msd
- Which header bolts
- all i want to do is install my opti
- Block clearancing on used 383 LT1
- What kind of cam is in an LT1?
- Did I order the wrong header gasket??
- Pounding under my seat during hard accel
- Thinking Of A 355
- Programming in S WI or N IL
- What numbers to expect? Dyno Friday
- Dyno Numbers are In!
- Air Pump or what?
- Head Chamber Volume
- How far from 12's should I be??
- Dyno Tuning Options in SoCal?
- oil pump or oil pump driveshaft, how can you tell?
- Is it possiable...
- Stock cam specs?
- PCM auto to M6 possible?
- Emissions - Bad Numbers **Please Help**
- Distributor
- MAC header bolts
- Cold Air intake vs 96-97 Camaro SS ram air
- Part # stock cam
- Original Opti
- LS6 lifters in LT1??
- Optispark suggestions
- What Spark Plug Gap should I run with this setup?
- Help, High pitch noise
- oil sensor in pan?
- Wheel bearings/Brakes smelling?
- best cai
- I give up...
- sorry if this is a dumb question...
- Really Dumb Question
- simple question.ANYONE
- BBK 58mm TB question
- Do I need these?
- LT-1 sputtering
- I hate my car new opti still garbage
- Which Octane for which Compression....??
- oh my god!horrible dyno numbers cc306 take a look!!!
- LT1 w/ SLP headers? READ NOW!!!
- LE1 or LE2
- easy tb bypass question?
- 1993 hp and tq?
- Strange Electrical Problem
- What all needed for a 1.7 rr upgrade?
- What rod bolts besides ARPs?
- True Duals with MAC headers?
- LT4 springs on stock rockers?
- Strange intermitent miss under load when motor warms up
- Arcking from plugs
- need help VERY fast!!!!!
- Would Multiple Bullet Mufflers significantly quiet my exhaust down?
- questoin about electric water pumps
- Removing U bolt out from the master slave help!
- Where's that Expensive timming chain at?
- Would like some info on this kinda of custom cam.
- Throttle Body
- A Soldier needs Performance advise !!
- How many SERIOUS buyers would there be for a plastic intake manifold?
- My Car Died On Me!!
- How much power gained (mail order to dyno tuned)?
- HPP w/Powerscan PC-Uplink Software
- opti wire clip, crank sensor??
- all parts for gm 847 or cc 306
- A4 Trany leak!!
- Water pump d/s seal
- Where do I hookup O2 extension?
- Will an opti cause severe power loss??
- i have a coulpe of random ques? any help
- Car is driving like CRAP, ran datalog and need some people to look at it. PLEASE HELP
- roller rockers, P.R. length, noise
- 95Z Cranks kind of fires, let off the key and it stumbles
- jump in compression worth it?
- always different dynos mustang dyno dynojet whats the difference??
- Plug wire replacement
- No power when hot
- Timing Chain?
- stall converter
- I SWEAR my '95 Single CAT LoudMouth is Louder than my '97 Dual CAT LoudMouth!!!
- Please settle a debate... 97 Z28, hp and tq, from factory
- HD timing chain--waterpump gear????
- thinking about 58mm throttle body should i
- got a flush. NOW NEED OPTI WTF!!!!!!
- Serviceability with Tube K member??
- cam question
- Oil pressure problems...collasped lifter? (Kinda long)
- 1.6 and tuning
- 97 Z28 heater hose?
- 383 high-rpm warm startup??
- header question for a 95z28
- Questions on upcoming project
- Dyno numbers inside
- Custom Y pipe
- who here has goodyear hi-miler hoses?
- Car is misfiring pretty bad!
- What do I need to get into the deep 11's?
- LT1 alternator amperage?
- Feul pump vendor
- Header AIR tube leak ?
- Dana head bolts. . . JUNK?
- car stoped running. HELP!!!
- Gearing/ gas mileage
- O2 Sensor question, DTC's
- Help on SLP header install
- MAF Sensor Question!
- 94 Z/28 Camaro Alarm Install.
- Stumble with Delteq, any ideas?
- Got my T56 install done yesterday!
- do any 94 Z28s have dowel drive opti's ????
- Master slave install
- Jet hot longtubes w/hooker y pipe
- Please take a look inside this collector
- In open loop, what could cause a rich condition?
- Stage 3 heads on this setup.
- Has anyone ordered form R&E Racing
- loose O2 sensors on 94 lt1
- Hooker shorties question
- LT1 Catalytic Converter removal
- Big cubes without big cam/heads. is it worth it?
- screaminchicken!why the fuel pressure regulator???
- Water pump on but no flow...?
- does weight affect dyno??
- A/F Ratio
- valve train parts
- Thunder Racing OTVC kit.
- Cruise Control not working
- Whats the difference between Self aligning RR and regular RR?
- Disabling the Traction control?
- lol fuel pressure 30psi lol
- Grounds
- Why my car wouldnt start - not the usual fix
- I need pics of triple pillar in 93-96 camaro !!!!!!
- Error - Then car died
- LT4 valve covers?? How big of cam?? Clearancing alternator??
- Good Dyno Shoppe
- power steering?
- Pcv Tube Leaking Oil?
- any engine builders on LI
- Fuel pump?
- were can i get these seals from?
- Max bore size?
- Electric Vacuum pumps for big cammed cars....
- vac lines
- lt1 main caps
- Opti venting tubes...
- Which O-rings are for the W/P drive?
- resistor
- What Might This Setup Make?
- Bad night at the strip
- Can you read a Lobe chart?
- homemade fan switch
