View Full Version : LT1 Based Engine Tech
- New Motor Wont Start PLease Help Guys
- Aftermarket Throttle Body
- Do I need to drill intake holes
- What all is below the block on a fully assembled motor???
- How to Make A Cobra Killer
- Has anyone heard of Speed-o-motive?
- 4l60e for t56 swap,central,ny anyone interested?
- LT4 Valve Springs.
- Motor dropping entire driver side cylinders - pass. side firing ....
- car overheats at low and highway speed (fix)
- opti vent line?
- SES light
- Can somebody help identify injectors?
- Low Rpms at idle.
- Cant get my engine to start, help
- Moroso Cold Air Kit
- My car hits rev limiter before is shifts out of first gear.
- lifters for k-800 springs?
- I think I found my oil leak
- 93 fuel lines on a 94+ intake?
- Takes a while to return to idle
- File Fit Rings?
- LT1 Intake on backwards?
- quick question
- Something is in my oil pan
- what length O2 sensor extensions
- Tunercat EE file
- Another CC306 swap post....
- .504/.521 lift too much for LT4 springs?
- 97 Z28 Cam Specs
- I need some bolts. WHere to get them??
- New member hunting a good Z28
- Jet Hot LTs Not What They Are Cracked Up 2 Be PICS INSIDE!
- Rebuild is in the near future, Need suggestions 400rwhp N/A, LE2 h/c already on....
- Rpm's Rev Real High Before Car Kicks In
- Anybody Sell HiFlow Cats for 96 Dual Cat Z28?
- Would it be possible
- Wiring harness question
- Changing to a higher stat give me better gas mileage?
- Ai Heads/Nitrous Cam Idle Video
- shaft mount or regular rockers?
- Got my headers today...
- LE1 Package Sound Clips
- Airbag...toss it or keep it?
- Where oh where did my gas mileage go?
- 4" Mufflex or dual 2.5" exhuast?
- trivial question.. re plug wires & clips
- Swapping #4 & #7 on the cam
- ICM grounded?
- What is the best exhaust for my setup?
- Post opti swap (first ever!) car still runs like crap :(
- Do I need simulators or extension with off-road y-pipe?
- Gas in the Oil
- Aftermarket Coil
- how often do you guys adjust your NSA rockers?
- Computer Swap
- In-line FP choke a higher flowing In-tank pump?
- Question for ya??
- The K&N filter fell off my MOROSO CAI. Need part #
- stock rods
- Port Job - Gave me 63cc Chambers! What do I do?
- anyone notice a hole under the plate on the bottom of their intake?
- possible that opti drive gear thinggy fell out of time?
- checked fuel pressure, this sound ok
- drain plug seal
- Problems wiring reverse lockout
- Replacing stock(plastic) oil driveshaft?
- Bad Oil leak ON my OPTI spark Help
- injector pigtail replacement
- valve spring identity?
- Two (possibly related?) problems
- Installing motor from the top??
- OBDI with OBDII style connector cable
- 2400 stall with comp cam 306 too small?
- Will this work??
- how can i jack this up this high?
- an opti? / problem / i dont know
- Who Does Head Work
- Whoah....Thank you please drive through (comp cams)
- high flow cat...
- delteq question
- True Duals & Long Tubes?
- 96' z28 needs help quick!!!
- wingnut size for summit 3" cutouts?
- So I decided to disassemble my opti
- stud size?
- my frame is bent
- Mac mid's with lm exhaust?
- Misfiring issues
- 93 Camaro with Pacesetters LT's Video
- guys with griffin rads where did you buy them and how much?
- What next!
- Lloyd Elliot vs Advance Induction (AI)
- Rear main seal question
- Question on the balancer/pully
- power loss problem.
- comp oem lifters
- Trans Am Hates Rain!!
- LT1 Cam Question!
- what hose is behind the crank pully
- LT1 keeps randomly stalling at times!! help!
- LE1 worth it?
- Flywheel/Clutch/Bellhousing combo w/4.30 gears
- high idle in park
- injector id
- Stroker Kit. Need Opinions
- Compression Increase going from -16cc to -7cc dish pistons
- What's up with my rear brakes?
- Question about HPP3 programing.
- what shortblock to build? blew my engine
- LT1 Rebuild...parts advice needed ASAP..car getting dropped off on wednesday!
- Starting problem
- Is this safe?
- Car Cuts out.
- Question about magnum roller tip
- old headers wont come apart
- help with messed up idle
- BMR K-member and SLP shorty headers??
- Would poorly adjusted rockers cause this?
- Injectors
- got my stroker started...but have a 3k RPM idle
- What PISTONS?
- 383 pics
- 1.6rr and impala lift
- quick plug question
- Crazy Idling...Any Suggestions?
- LT4 composite valve cover gaskets
- oil pressure sending unit
- LT4 Starter
- Take a look at my cam swap parts list and tell me what you think
- what size injectors needed??
- LT1's are SOOOOO EASY to work on!!!!11
- 97 tach wont work
- cranks but won't start
- hollow popping backfire at idle? and performance loss
- slver bullet, gotta question 4 ya.
- No start! when i turn the key, it clicks....
- No oil pressure after 2 yr resurection
- IAC Position = 0
- Stock LT1 cam timing, duration and lift?
- do felpro water pump gaskets require black/orange RTV?
- Cloyes cam sprocket rubbing on the cam retaining plate?
- Engine stand bolt size
- what x-pipe for pacesetters?
- part number on serp belt w/ underdrive pully
- Squeaking Noise
- Need to confirm Hooker Aerochamber part number
- car is back on the road with 847 and ported heads
- takes a while to start my car
- Max stroker kit?
- What causes the PCM to shutoff fuel after startup?
- Fuel pressure regulators
- Fuel Pump
- Is this normal?
- Bare essential gaskets for cam swap
- O2 simulators
- installed the delteq and car only ran good for a few days!!!!!
- Lifters bleeding down fast - what could cause this? RR install
- car still missing!!!
- good upgrades...
- I think I have an Opti problem?
- knock question
- Codes
- !!! Vibrations กกกกก
- problems with spec fly wheel/need advice
- Fuel Line Connection
- LT1 Block to LT4 BLock will it all work??
- Installing headers got a Q
- tuning causing backfire?
- Anyone ever have an air filter dent before?
- Opti/Cap & Rotor same thing??
- What size bolts hold on the metal plug wire separator on the passenger side 97 Z?
- water pump gasket removal (did search)
- Mix rocker brands????
- slp lm help!!!!!!!!!!!!
- Squeaking Sound
- It Cranks But Won't Start
- coolant smell in cabin
- Timing cover bolt sizes??? i need help!
- Battery Cable Length
- Symptoms of bad O2 sensors?
- Dynoed my LE1 Setup.
- Rocker Arm question
- need inlet valve closing in degrees ABDC ( o* to 90* ?)
- Charging Problems
- Pistons...
- weird idle and car feels like its on 7 cylinders
- Size of low oil sensor
- Coolant plug in head
- Cooling fan question
- Thanks shoebox
- Dynaspark Install question
- Who currently has the best price on Mallory 685
- car died....help
- is the LT1 roller rocker stock?
- 425hp !!
- G-tech SS? How accurate as far as the dyno numbers?
- MSD 6a installation help
- Help!!! Rocker/valve metal on metal nasty noise
- cheapest way to change tire size
- which injectors to get
- Has anyone Rewired entire car using painless harness and switch box?? How did you do?
- Front and Mid mount motor plates, any significant advantage?? Who uses them??
- Belt tensioner pully, help !!
- Compression calculation correct?
- I'm Confused- high end miss - Iat Sensor
- car problem
- LT1 rebuild
- distributer problem please help
- Problem with Camaro 95' LT1
- what next
- spark plug not getting enough spark from wire?
- Solve my overheating problem
- Overheating and coolant issues
- spark plug thread repair kit??
- Retainers & Locks(Which Ones)???
- Dynomax Super Turbo Muffler
- Opti/ Delteq questions and suggestions
- Bad miss, stumble, surging
- Knock sensor thread size
- Head Gasket Question.
- What parts to buy with 1.7 Roller Rockers
- Header gaskets
- APE shortblock GP, and related problems
- 94 Formula Runs Like Crap Around 200 Degree's
- Intake backfire, slight studder..
- Help w/ codes 1641 and 1642?
- need good crank...scat ok
- spring retainers for 918's
- Crazy Dyno = Bad Opti ???
- Wheres best place to mount MSD 6AL inside car?
- Code 48 Mass Air
- Recommend some 3" (copper?) collector gaskets
- any pics of the brake booster
- Power steering pump elimination?
- April Fool.
- motor swap ?
- lt1 won't start, but when it does it runs fine.
- Paging Shoebox- fuel pump relay problem
- What is this sticking out of the Head?
- Do Accel Injectors Stink?
- Can Open Headers Cause This?
- Part number for NON-1LE elbow?
- Engine prep for supercharger
- More Car parts... What to do?!!?
- stout 1.6 rocker setup on stock cam (for now)
- Are summit brand rockers sa or nsa
- True Duals???
- battery doesn't seem to be charging
- 93 to 94 PCM HARNESS Conversion HELP!
