View Full Version : LT1 Based Engine Tech
- Car pulsing almost
- Vette [edit]!!!!!!!
- Are LT-1's made to be high rev motors???
- Part Locator Help
- AFR's customers here..
- Pcv Valve Help
- Fuel Filter Help Please
- New TEFLON Rear Main seal won't slide on!! HELP
- Feedback on TB Bypass
- Flexplates
- do hooker lt's have o2's?
- anyone use oil accumulators on their car?
- which mids suit you best
- Best flowing muffler?
- Isky Rev Kits
- Please help with header install, need all your advice.
- knock after waterpump removal
- Possibly a stupid question....
- Head Gasket ? Mr.Gasket 5716......
- High RPM Studder
- hermonice balancer????
- Dyno update!!!
- need some advice
- Anyone heard of Pacestter LT leaking?
- What plugs do I need?
- Engine Swap
- overheating i think!!!!
- Who has the best prices on T&D Shafts?
- asap help! hooker v.s. jet hots, quick Q.
- pictures of whats left of my engine
- Opinions on Autolite 106's for heads & cam cars
- bolt on dyno #'s
- Installing new radiator
- What does it feel like when......
- Will adjusting the throttle body stop bolt adjust the idle?
- No Start, Code: 15 ECT
- Best way to custom tune
- Keep burning up ICMs
- LS1 compressor
- Low idle after comming to a stop
- ICM and Coil...
- Final flow #'s from my AFR 210's...not to bad.
- find my HP
- LE 1 head/cam with big shot or LE 2 head/cam with smaller shot
- Electric water pump and timing set questions...
- anyone ever have a valve seat fall out??
- Wiring tach and air fuel gauge need help.
- Which are better...
- vibration problem
- Broke a header bolt...
- Switching out Magnaflow muffler
- fuel injectors
- coolant light.. no coolant leak?
- Motor mounts
- LS6 into a '97 Z?
- Comp 986 springs...
- Cam Specs?
- Worth the $ for O Ring?
- Broke Off A Torque Converter Bolt
- air filter help quick
- Cam Install
- coolant problem cause power loss???
- Is there a good way to seal a OPTI
- Engine Oil Help
- y pipe for 96 dual cat
- Leakdown & Compression tests
- 1994 z28 install guide links
- spark plugs
- help please i just got my first z28 and its running like crap
- Anyone run aftermarket rockers with stock valve covers?
- [Edited by Moderator] Piece Of Crap Opti!!!!!
- Who makes taller valve covers for a LT1?
- Light on dash...
- 96-97 cars, please come in, help needed
- lt1 valve size
- MILKSHAKE in the valve covers HELP!!
- Car Won't start, crank, no lights in teh cluster!!!
- Cat options
- Borla + Mac - cats = ?
- Where can I get the Window Rivet Retainers?
- Hot Cam
- Need to see Tru-Dual Exhaust Pics !!
- Which ARP bolts?
- Where to get LT1 OIL PAN SIDE RAILS (Keep pan striaght) and part #?
- Why won't IDLER GEAR TIMING SET work on Knock Sensor equiped cars?
- smoking from the door?!?!
- What does a bent pushrod or a weak valve spring feel like???
- Need help selecting a header
- Cometics with copper spray?
- Having a few problems, could use some advice.
- newb question about CAI
- Batt gauge bad??
- NGK TR55IX Iridium
- vribration why????????
- CC305 clip
- total seal second ring
- oil on sparkplug
- comp "503" cam will this pass emissions?
- true duel exhaust Q's
- LT1 help
- what sparkplugs nd what gap?
- Help me find my problem please?
- competition valve job
- valve stem seals won't go on all the way
- Looking for 1993 lt1 pcm pinouts (wiring schematic)
- trans grinds when shifting.... What is it?
- Port intake openings?
- Cam selection
- Another Exaust ?
- My LT1 head flow numbers
- Help: Blow head gasket... which side?
- Open and Closed loop?
- Hydrolic Roller Cam Specs
- Cam help
- Anybody have experience with MAC springs?
- which cam??
- Cast heads and CC306
- Broke a stud, bent 2 push rods cant find the rest of the pushrod..
- dropping motor need help
- LT's or Stall?
- Where do these go?
- Where can i find raised valve covers?
- intake porting
- wiring Meziere water pump
- erratic idle....
- anyone side gap their plugs?
- NGK's came pre-gapped at 0.055, is this too much?
- checking coolant level
- Not sure if I posted this, but 383 is progressing nicely
- Compression Ratio Calculation
- Cam swap: Are RR's a must?
- Anyway to clean injectors?
- CSR Waterpump install
- Headers
- code 16
- Running a Granatelli Intank Fuel Pump?? Look inside
- Airbag questions
- Fuel line size on the rail.
- Header part
- Magnaflow or Borla?
- cc306 with heads or LE2 heads and cam?
- Best LT1 Dyno and Tune in Houston?
- Copper Gasket Spray
- suspension question
- engine trouble
- Cooling System Flush - methods?
- Removing T-rex inline pump??
- Sound clip of my Joe O./LE setup
- After accedent few problems
- car stumbles during acceleration in 1st
- OIL Pump
- MSD-6AL, worth the upgrade?
- Don't Unplug Your Batteries!!!
- Will extra weight of STB conflict with ET improvement?
- XE 224/230 installed!!!
- speedautomotive???
- Before puting in the 383...?
- Oil Pressure Sender
- Need advice on my street and n2o friendly cam choice
- SLP 97 style Header Install HELP!
- TB Bypass and Chicago Winters...bad?
- Gas in the oil... tried everything... Help!
- Do I have enough spring for my cam?
- Coolant hose question
- What problems could doing this cause.... (read inside)
- question about head springs
- custom Y with cats.. how much????????
- Taylor thundervolt 50 vs. msd super conductors
- HELP.....MSD 8.5mm wires
- Oil Leak
- Occasional Spudder.....what can cause this?
- Beehive 918 users (with titainium retainers) inside please.
- MOdifying stock valve covers to fir comp 1.6's
- Hypertech Questions
- Thinking of installing a bigger cam. Would it be worth it?
- EGR? Trouble code #32
- LT-1 intake gasket problem
- How Do I Tell if I Have a Dead Cylinder?
- Pictures of my 385 LT4 motor.
- Whoa, no muffler.
- Is powder coat an alternative to Ceramic coating on headers?
- Oil pan sensor
- o2 sim location
- Borla cat-back, what do you think?
- 30 over bore ques
- 94 Z 02 Sensor help (Passenger side)
- Having Issues....
- Can you replace just the lifters?
- ? about ford injectors
- Engine Knock HELP
- Quick GM847 ?
- what cam for me?
- Problems with headers
- A few questions...
- Mass air flow rate
- Problem with Eagle H beams
- Question about Accel DFI Gen VI...
- Replacing Rear Main Seal, How? And What Do I Need?
- New best for my 93 T/A
- Custom made X pipe.
- power steering pulley
- Emergency help with jet hots..!
- 1 5/8 or 1 3/4
- rwhp guess
- MSD Ignition worth it?
- Trick flo vs 1LE vs vortech elbow
- messed up plug wires cause this problem?
- Look at these Pictures- Are these Mac headers?
- Engine is on stand, oil priming not coming thru push rods.
- short block help
- AS&M Headers..?
- What kind of oil for fist time statup after cam install?
- clicking noise when throttle pressed? only after check engine light comes on.
- Help with multiple trouble codes
- knew it was gonna be my turn sooner or later
- valve spring ???
- Do they sell mac headers without egr?
- 160 thermo sounds non beneficial
- Creative a/c delete
- Leaking gas cap?
- Water pump ??
- Water pump ??
- LE2 Dyno & Track Numbers
- new 355 rebuild w/ rough startup....jumps to 3K rpms
- Mac Header Air tube
- Should i go with a heavy duty timing set?
- how high do you rev your stroker
- Those with 224/230 cam...Inside!!
- no pick up on last gear?!
- ahhh, a little progress.
- Rpm Question!!
- Question about coolant lines.
- ? about Felpro intake manifold gaskets
- Filthy Rich!!!!!
- Trouble changing out valve springs!
- Name of the rails that keep the pan straight on the sides and where to get them?
- LT1 Parts
- installed F.A.S.T. no start!!
- Mac Headers Help Fast- Install
- Mac Header Egr problem
- cc306 track times.......little disapointed
- Track times...what do you think?
- What coil to choose
- slp lm +lts +no cat =?
- plugs and wires suggestion
- Not drivable. Need suggestions.
- 2 Problems.. O2s and Coolant
- bigger throttle body?
- GM ESI online for a limited? time
- Coolant Problem/Leak
