View Full Version : LT1 Based Engine Tech
- q about adjusting rockers
- pistons "cc"
- Best Heads?
- Please Read Need Help
- injectors
- Adjusted rockers, wondering if this method is acceptable.
- Need Mods advise
- What are you HOTCAM guys' trapping?
- EGR valve removal - 94 Z28
- best spark plug wires
- How many o2 sensors on a 93Z
- need 1 o2 sim
- Ordered custom pistons...need pin fit??
- Please help with header install and smog/air pump lines..
- what can it be need help ASAP
- 383 times and broken timing chain
- I searched the forum.. and I still have find whats causing this noise
- Just installed new opti. p0336, p0100,p1371
- Which regulator needed??
- Went to dyno this weekend.
- cc306 in a 383?
- Vavle Lash
- Why Is The Nx Kit Better?
- New Optispark? Is this the entire Opti?
- LTs vs shorties
- 2 error codes, misfire, and catalyst
- weird knock/tick
- CC305 w/1.7 rockers????
- Stumble/Sputter, especially when cold.
- How much to shave off of head for a 12:1 comp..LT1
- Problems with BBK shorties?
- Installing Intake 3rd time - Help me get it Right
- Trying to make final (lol, yeah right) decission on major upgrade.
- Under Drive Pulleys Yes Or No?
- Exhaust Question
- sound clips wanted.... hottcam or cc305, and cc306
- Cleaning Throttle body and Intake
- What is this?
- Installing cat-back questions
- Help Splayed Mains
- AFR hydra-rev
- Rocker Arm Studs
- Keep blowing ignition fuses HELP ????
- Cheapest place to get Ac Delco O2s
- Just installed Pacesetter LTs... Couple Q's
- Temperature Gauge Problems PLEASE HELP
- Lost oil pressure while datalogging
- shoebox.. need a pinout bad
- Stock Exhaust, No Muffler
- What sort of Heads to match Hot Cam
- Who sells and balances dragon slayer cranks.
- So what do you think?
- Cruise Control stoped working...
- camshaft
- R134?
- 80K and what is this junk I have to fix now?
- LS1 exhaust on LT1
- will any 700r4 fit in a 93 camaro
- Holy horrible road test!
- Fuel pressure bleeding
- Gorrilla Chips?? How Are they
- Will a throttle body for a 95Z fit a 93Z? help?
- Can I put a 97 Wiring harness/Computer in my 95 and be ok?
- dual exhaust pic's please.
- i need the head bolt torque order
- help an impala guy out...
- Radiator cap tech
- compression
- Need sims and tune for !cats?
- Who here has bought a new Corsa exhaust lately?
- OBDI/II Which is better?
- Checking for bad lifters... manifold off.
- Do I have the signs of valve float?
- ? about 1.6 self aligning roller rockers
- It didn't overheat, but it pissed coolant...
- Z-28 having problems at start up
- Please help, info needed on o2 sensors and header install
- Opti help? shoebox?->
- Advise on my budget heads/cam set-up and valve spring help needed
- Wiring up CSI water pump?
- Will ZZ4 valvetrain work on an LT1?
- problems please help
- HELP - car overheating after gauge temp install...
- car messing up
- 230/236 install on a buget/ got ???'s
- what header gaskets for asm 1 3/4" jet hot coated?
- retarding cams
- engine squeal non belt related
- Help me choose head gaskets
- Can unvented opti's dry out?
- lt1/lt4 knock sensor
- Do all lt1 cars get some knock on scanmaster?
- What's mod to do next...
- what do I need to consider when going with a solid roller?
- Not getting spark to ignition coil/out of coil
- 94 and 97 tb bypass
- 4 cut wires
- won't hold idle
- Need help/EGR advise!
- Need Help Please!!!!!!!!!!!
- rocker arm keeps falling off
- To those who have removed engine from bottem?
- Still smoking.. pictures inside!
- need to get rid of ses light
- No Heat?!?
- true dual exhuast options...
- fuel pump wont turn on?
- Ticking sound?
- Thunder Racing
- Corrupt PCM by interrupting a Tcats READ?
- Noise after new pads
- Stroker + charger or solo charger? Need expirenced People
- Would broken gauge temp throw SES light?
- Thinking about a cam
- 85 Mm Maf
- What do you need to put comp 987 springs on stock untouched heads???
- Powder coating headers
- When is a head flowing too much?
- dyno and tune
- dyno and tune
- Replaced coil and icm, problem still remains
- I havent posted in a while... Help me finish my 355.
- Csr Ewp
- Ahhhh, the money pit
- oil tube & dip stick
- fuel pressure?
- tick tick tick?? what could it be?
- I think I spon a cam bearing
- 2 bolt / 4 bolt main how can you tell??
- What throttle body do I have?
- Is it okay to drive to the auto parts store without valve cover gaskets?
- problems with FLP LT install...HELP!
- hp from tune?
- First post from new member
- Pics of the OLD STYLE alternator relocation bracket from Speed Specialty?
- Cerious as to did my heads flow decent? numbers inside
- Random no start condition
- Which injectors to use?
- Where to get fuel injector retainer clips?
- jet hots vs. pacesetter lt's
- oil????
- LT1-edit
- 1st Lt1 need help with hop ups
- Heads are off... how much do I need to torque them down?
- Hot Cam Kit
- TB Bypass, Service Engine Soon???
- LT1 crate motor
- Timing retards 10-18 degrees at WOT!
- Which opti vent hoes goes where?
- Shims for an LT4 Starter?
- Rear crank seal replacement?
- smoke, rich or oil blow by
- last minute checklist.
- LT1 Rebuild, What to do? (Bore, internals..)
- Car has serious power loss, limp mode?
- compression
- need help choosing fuel injector size
- Replacing Lifters.... are these good replacements?
- I did it, first ever throttle body washer tank pass. PICS
- pacesetter y-pipe
- need opti for -95Z28.
- Here is a doozy! (no start)
- Expert advise needed
- How many O2 sensors on a 1993 LT1 camaro...
- Need help ASAP in the middle of a motor mount change
- Found a solution to the EGR problems.
- ECT sensor help needed
- What spark plugs to use info needed
- How much abuse can my stock T-56 take?
- Oil pan leak experts - pls share the wisdom
- Please help, how do I get to these 2 bolts on header install.
- 96-97 Mac Header wire routing
- Mission II Pipe
- WTF!! o2 sims problem
- Where to buy Mr. Gasket 5716 Head gaskets? (26 thick)
- Knocking after Spark Plug Change?
- 1/4 ET Guess
- Looking for new tb ,opinions on recent quality?
- 200,000 miles...what maintenence should be done?
- APE: Does Anyone Know How they balance ther motors?
- 02 sensors?
- Cylinder head torque question
- Need to find a wire that is comes on only with engine running
- Jet Hot V.S. Hooker PICS INSIDE !!
- Need some measurement help
- what gaskets for hooker lts ?
- PCM code help?
- Alternator ate threw my AC line
- ? about recalls
- Need Help Quick
- fuel cooler
- Throttle Body Bypass
- Hot And Cold Plugs?
- Real Quick Question
- Slow Top-Tuner LT1s
- Maybe asking the obvious, but still...
- Replaced Opti Already Starting to Miss Again
- Can I use 2 different spark plugs?
- Need Help
- v6 died :-(
- Where to get a gm847 ground on a 110lsa?
- Mac mids.much noticeable ticking..?
- Choosing a Catalytic Converter
- God and Guru's PLEASE HELP ME, I NEED YOU
- Where can I buy a stock PCM?
- How much for a custom exuast?
- Can arching plugs/wires cause knock?
- True Dual Dump Owners...
- Header Bolts...
- 1/4 mile times with...
- computer chip mods
- Heat resistant sleeves
- calling out brett bauer
- heads/cam parts cost
- Pics of Taylor ovc wires...
- My car is sometimes taking longer to start then normal.
- used some seafoam tonight and have some questions
- question about a code
- No muffler=Lower HP????
- 396 LT1 miss at operating temp.
- Besides for N20, when is an Ignition box needed???
- Injector sizing if you are uncertain as to eventual mods.
- car wont start, need help
- what seal is this?????
- Anyone have stock LT1 head flow #'s? My homeported flow #'s inside.....
- SVO injector question
- Odd Electrical Problem, Please Help!
- installing coil and icm
- x pipe
- ported intake manifold needed?
- leaving out the ICM Bat fuse?
- Thinking about GMMG, have a few Q's
- Exhaust Question?????:shrug:
- stainless works 96-7 y-pipe?
- any dyno tuning difference between tunercat and lt1 edit??
- pacesetter long tubes and true duals
- Pacesetter Header Passenger side problem for install
- NGK recommendation
- Has anyone seen or tried the new MSD Opti cap/rotor?
- How to install injectors???? (searched already)
- car runs [poorly] when idling in traffic
- coolant everywhere ! ! ! ! !
- Who has passed emissions without cats?
- Cam Help!!!!!!
- Installing new valve seals
- O2 Sensors and Alcohol
- Easy head removal/acc. bracket question
- Can someone measure something for me??!!
- headers and such
- A little confused about these pistons & stroke.
