View Full Version : LT1 Based Engine Tech
- Overheating!!!!!!!!!!!!!!!!!!!!!
- Sparkplug wires and routing
- are felpro head gaskets 1074 gd for 30 0ver bore
- LT4 springs w/ 847 cam?
- Why do lt1 have a bed rep up high?
- Why am I adding coolant/water frequently?
- What is this noise?
- cooling problems?
- oxygen sensor hesitation
- problems after header install
- Few Opti questions....miss still happening...
- OBDII Scanner/ Scan tool
- Oil Filler on Valve Cover..
- What next?
- Why NOT to use Accel Injectors video...
- Should I replace the coil??
- Stock Plug Wire Routing Help
- LT4 Intake with no other mods?
- Leaky intake
- is it worth it?
- flexplate ?
- Fixed my hesitation
- what size freeze plug?
- Completely Stumped (Rocker Problem)
- bad thermostat/cooling question
- ordering cam kit..which one?
- Got it dyno'd, am I getting vavle float (graph inside)
- Help!!! Pcm???
- Is there a way to test the evaporator core itself?
- Best CAI Lingenfelter VS SLP
- SVO injector guys inside
- Dielectric grease
- Need help with wires leading to low oil sensor
- no start
- How to route wire #7
- Intake gaskets?
- Heads or Cam?
- D@MN Intake Bolts need help asap!
- Flowsheet question / Poll
- RPM range
- engine whistling?
- Best Flowing Exhaust Setup?
- Burnt PCM
- Question about the intake.
- Fried PCM?
- Is it possible to make 500 rwhp N/A with...
- Is my IAC sticking or is it my pcm?
- Electrical taping a ground wire...
- why are the four back ports of my heads black?
- LT1 problems
- Ever shipped an engine?
- Curious off idle misfire after w/pump replacement
- Serpentine belt question.
- Rebuilt WP vs New
- stumble/hestiation
- Found My Lt1 Stumble/hesitation Problem
- Dilemma
- Need ignition opinions! Delteq or MSD box?
- A.I.R. pump fixed yesterday-recall!
- New plugs cause p0300
- Most stupid question about true dual
- Windage tray questions...
- p0300 @ WOT
- Who here has done a auto to M6 swap?
- Misfire Problem Almost gone..... (Pics)
- Intake bolts don't fit....
- Are LT1/LS1 radiators interchangeable?
- Running Rich and Tuning Questions..
- intake to match the heads?
- pacesetter gaskets
- Rocker Tapping question
- Anyone considering buying Brisk spark plugs?
- Accel 375+ trouble shooting question
- Double check rocker arm install
- Rattling at low rpms...tranny?
- Rocker arm question
- PCV path?
- Dented Y Pipe (Pics Indside)
- Knock issues
- Need some cam help. Adding 1.7 rr's to CC306?
- Does the LE1 heads and cam use 1.6 RR's?
- header reviews
- 94 Forumla problem.
- Carp, piece of starter stuck somewhere in the flywheel
- Does Golen offer just reconditioned engine blocks?
- Good oil and filter?
- How to reconnect throttle cables?
- What are these hooks/tabs on the framerail in the engine bay?
- Anyone seen the TPIS Mini Ram for the LT1?
- Cannot get drivers side motor mount bolts to line up, any suggestions?
- Dumbest mistake EVAR!!
- Leaving HP at the track
- Need help ID'ing a flywheel I have.
- Injector debate, on another forum.
- How to break in a new motor?
- How many quarts of oil for a Canton oil pan?
- have spark, have fuel pressure, NO FIRE
- Rear wheel stud
- Size of muffler in Mufflex
- Tranny mount keeps busting....
- What is an F1 kit?
- Best place to buy a centerforce 1 ?????
- turbonator
- EGR block plate templates
- Spark Plug Question
- True Duals
- 94 LT1 Camaro, dieing randomly
- Which one is best and more reliable? LT4-blower-or nitrous
- EGR Slightly Clogged -Advise Please-
- Only One Cat..?
- Lean condition passenger side
- What misc. parts are needed for rockers & valve spring swap?
- Another Exhaust thread... newbie here
- What specifically makes the LS1 better than the LT1?
- is this good for 420 hp? what ya think
- Ned help with car runnning extremely hot
- Which valve is intake/exhaust
- Knocking/Ticking sound all the time?
- Idle probs after driving
- Your opinions on my planned mods?
- How much is my LT1 worth?
- TransGo shift kit of ebay, another ebay scam or not?
- Help!! I need presure plate bolts fast
- How important is having all 3 bolts for the alternator brackets?
- Bottom of roller rocker arms are rubbing the nut on my studs?!
- how much would this cost to install
- best lifters??
- general rebuild gaskets/bearings
- Stuff comming out the Exhaust???
- steam tube delete??
- fuel pressure?
- car noob with an auto 94 z28
- Have any of you had problems with Edeldrock TES headers?
- LT1 misfire after new opti, plugs and wires...
- oil pressure
- cloyes double roller and cps ?'s
- Hooker y pipe?
- please help with engine codes!!
- MSD digital window switch wiring/install
- Relay box Wiring
- Part number look up PLEASE
- how do Groty LTs rank??
- optispark plug in connection question
- Who builds a good stroker short block?
- Can an exhaust leak rob you of power?
- same question over and over
- gm846 + 1.7's + crane 10308-1 springs + le2
- what compression
- Auto Zone ReMan. Waterpumps are @#$%
- Two Questions: 160 t-stat & motor mounts
- How good is the stock fuel pump?
- Sweet thunder mufflers
- um a Newb question here
- Can I use a 1996 Hooker Cat-back with pacesetter longtubes on a '95 Car?
- Engine felt like it was about to seize...
- catalyst inefficiency SES code
- 306 cam in a 383??
- AC compressor?
- Lifter Placement
- Do i need to extend O2's on MAC'S ??????
- LT-4 Springs and Crane 104227 ?!?
- Best OTVC Plug Wires and Looms?
- Oil Change Intervals w/ car in storage...
- New LT1 owner, have Qs
- 100,000 mile tune up
- Might have mixed up my ls1 and lt1 mafs
- Jethot install How do you get these 2%#@ bolts?
- pilot bushing won't come out help please!!!!!
- LT4 Hot Cam install
- Where do I get a 160 Tstat
- Obd I/ Ii
- Need a part number
- Ready to start planning my stroker motor>>>
- Failed emissions PLEASE HELP!
- TCI 3000 didn't come with bolts
- lm 2 vids yet?
- Whats next for more HP?
- AIR and EGR removal, good or bad idea?
- need some help with wiring
- Installed motor. Have a motor mount ???
- cut fans to fit csi h20 pump
- Just got a scanner.....wondering about the results
- o2 problem AGAIN HELP!!!
- Split BLM's only at idle and deceleration?
- A.I.R hose cracked causing problems??
- Mac Header Air Fitment Question
- Is it ok to clean O2's with TB cleaner ???
- Knock sensor delete?
- Are these symptoms of an intake gasket leak?
- 230/236 with cm-612 springs.. good or not?
- Cat flow and exhaust sound...about to buy
- Just got a camaro z28. few questions
- Piston Rings
- What does it take to get to the 12's
- Anyone have side exit exhaust (in front of back tires)
- I have a geyser......
- LT1 intake on LT4 heads
- valve cover to TB tube... whats it actually do?
- Need help ODB1 Code 42
- valves-zero lash
- The new Jethot installation world record!
- Weird problem
- Thoughts on stock timing chain for LE2
- plaining exhaust header (SLP)
- Bolt on Help
- Which injector?
- Headers InstallED Now Questions!!
- LT4 Starter fitment
- I think I figured out my misfiring problem
- Is removing and reinstalling (Torqing) the heads possible with the engine in the car?
- Telsatar people please help!
- Putting a carb on an LT1
- gen 1 blower on lt1
- Difference between lash and preload
- So where did all his oil go?!
- AFR Head & Stock Accessory Bracket
- Computer wont run tests...
- i think i [edit by moderator] up my 94 z28 please help
- Info needed on temperature sensor, can't find the right one...
- 12's
- Could I have really screwed up?
- Would i see HP/TQ gains from tune?
- What happened to the Sam Taylor Buick website?
- LT4 springs
- Valve covers w/ breathers
- McLeod single disk problem
- 96 vented opti???
- Keeping up with a LS1
- Mid length headers
- What would you do if this were your goal?
- gears needed before stall?
- cc306 cam / AFR 195's
- quarter mile times?????
- Parallel Fuel setup
- Data logs on my car needed!
- ? about nitrous piston (thickness of the piston)
- where to get injector caps???
- emissions with a big cam
- will loudmouth from 01 fit 93 ?
- Manual Bypass to turn starter?
- Tb Bypass Does It Work?
- LT1 block questions
- HELP!!! stripped bolt
- oil leak !!!! need help please
- Sealed power plasma molly rings
- Why does it....???
- Wtf!!!???!?!?!?!
- Timing gears
- fuel rail removal
- Edelbrock Catback?????
