View Full Version : LT1 Based Engine Tech
- Are these the correct rod & main bearings?
- Well the bird is running after much sacrafice....
- need help, sounds like lifter tap
- opti questions... just replaced no start
- 1993 Firehawk dyno predictions?
- rad not full when cap is taken off
- Got a question about a motor.
- 94Z Bucks at 1500 rpm
- starter wires
- Coolant level in Rad Question
- Coolant temp sensor
- Temp Guage at 3/4 mark in stop and go traffic... Normal?
- 1994 z28 coolant problem
- Head Gasket and Other Issues -- Need Avice on Keeping or Selling my Z
- Mass Air flow sensor..
- Car wont start, what could be the issue?
- fuel filter ?
- Head job on 96 Z28
- Cooling question
- Problem with engine, stumped on issue.
- New member need help
- Driver's side door removal in a '93
- Pressure plate Bolt ?
- the car finally runs, slight issue though
- 1996 Z28 bouncing off rev limiter before shifting and now has a miss specially in OD
- crank pulley can i blast and paint?
- opti and starting problem
- Another "name that sound" thread + video
- upgrade 93 Z28 O2 sensors to heated
- need a few tips
- LT1 Crank Hub Washer
- what bolts to replace on longblock
- spark plugs
- cold air intakes
- pcm problem!!!!!!!!!
- converting '94 opti to a '95
- lt1 black oil on initial break in
- S.O.S. Air intake elbow and smog pump diagnoses
- ABS Light, followed by loss of voltage on gauge, motor won't start now...
- Can't find .011" undersize bearings
- What kind of HP?
- starting issue
- electric fans
- Air intake design for high hp LTx
- Pro mags hitting rocker studs
- LT1 Mail Order Tune ???
- Cc503 vs. Cc306
- Crankshaft pulley how to
- Dropped valve, do I need full rebuild? (pics)
- factory lt1 springs
- cleaning engine
- lifter tick/low rpm stumble
- Champ Oil Pan Help?
- pcv line
- Oil pump drive gear
- first start of my lt1! wont stay idling
- air filter
- 1.6 full roller rockers
- Code 43 Knock sensor ...need help
- Need help selecting a cam for my stock 95 z28
- 94 lt1 into 96 car
- AIR check valve and SS air box
- Oil filter adapter
- Mail order tune for solid roller 383
- granatelli wires. bad coil wire
- Belt Squeek Only When Shifting
- oil leak, need help asap!!
- 02 sensor issues car throwing code 63
- What voltage should I be seeing on each pin of the fan relays?
- help camaro boggs
- I Installed opti wrong did i ruin it?
- Balancer/hub question..
- LT1 HP gains??
- e-waterpump temp controled
- Blown head gasket
- Crankshaft identification, letters "CS"
- datalogging for 96
- A.I.R. check valves on exhaust manifolds...
- just wanting opinions
- Crossover steam pipe seals
- how long should it take
- Kickdown/shift cable hook up
- lt1 flooding?
- Dyno Numbers from my 383
- Driveability problem
- Dyno Numbers
- Oil Cooler Delete - 95 LT1
- Surge
- 1994 camaro backfire/sputter
- Pushrod recommendation
- ok i know i have asked aout rocker arms and push rods but they confuse me
- water coming out sparkplug hole????
- GM veggie tabs: What part of the cooling system are they supposed to 'seal'
- TR55 plugs w/ AI heads?
- LT1 Head Porting?
- Intake Manifold Removal Question
- Power Steering Pump Removal help
- Starter 1993 LT1
- oil pressure drops to NOTHING while driving
- Timing Cover Trim
- OBD2 Tuning
- Low Voltage problem 97 Camaro LT1
- Ultra Pro Mag install
- Motor installation advice
- can't get cruise control cable re-installed -- lost part?
- my lt1 quit running. won't start
- bad icm ground
- o2 sensor location on my 94z
- Car wont start
- New (to me) 94 Z28 running Rich
- Installing headers on a 97 camaro
- rounded flywheel bolts with some kind of threadlocker
- replacing things!
- reinstalling throttle cable & cruise cable onto bracket help
- P0132 and P0152 while failing emissions test
- valve spring question
- lt1 383 stroker help
- Best type of Gaskets to use
- pulled motor and tranny need advice before new motor goes in
- Intake Manifold Gasket Replacement
- Proform roller rockers
- Pitting around water jackets
- Hand tuner/base tune
- oil pressure
- Need to disconnect and the reconnect the battery to make car start
- I really screwed up. Need some advice
- difference between production and service bearing clearances
- Intermittent Starting Issues
- New Starter Problem
- Quick Advice Please.
- Delphi optispark (1104032..CZ20003) any good? mitsubishi optical sensor?
- "free mods"??
- can i drive my car with out it being tuned
- Cam Install Question
- cc306 cam what heads?
- Potential Hydro-Lock need Help!!
- Lt1 Refresh Questions
- MSD optispark. good or bad?
- What could cause this
- best cam on stock heads ???
- More Horsepower
- Torquing with an extension
- School me on two things:
- overheating while sitting in traffic
- Cooling system concerns please advise
- oil leak question '95 LT1
- step by step install power steering pump
- Help Needed
- Temp gauge issue...need help
- just bought a used motor & transmission have questions
- Switch to closed loop and LT1 dies
- this doesn't make sense
- Balance question
- HP anyone?
- Yes, Another opti question.
- ACDelco remanufactured optispark (dift color) these any good?
- ICM Connector Not Grounding
- My Camaro had a bad day
- transmission and fly wheel bolt sizes
- Unsure what direction to go with my car (bolton LT1)
- cam selection help.
- Backfiring when Accelerating
- Stock rocker arm issues.
- Throttle Cable Ferrule -- size?
- lt1 rebuild ??
- 96 Z28 Tuning
- 1994 camaro z28 LT1 motor mount bolt size
- Looking for tools to check bearing clearances.
- datamaster q
- Cruise Control -- T56 in a conversion...
- car wont start
- trying to figure out what rocker arms to get
- Quick Question
- What oil pump
- need help with new problem with z28
- Water pump drive oil seal
- 1994 z28 problem
- Cam question
- 96 impala lt1 in 94 z28 camaro body
- carbureted lt1 help please
- Need some ideas....
- Using a double roller timing chain/vented, non vented opti
- What head Gaskets you running??
- #2 and #8 plug
- Lt1 stalling out
- 94Z Instantly Overheating Help!!!!!!!!!!
- Where to buy fully assembled OTVC plug wires?
- need help advice appreciated. new to forums
- ongoing weird issue...
- hook up a LS1 air box to a LT1
- needs some advice
- Running Rough...
- Roller Rockers
- 1995 z28 dyno run
- Blowing dipstick out of tube
- MSD 6al
- Seldom used LT1 won't turn over
- 5300rpm stumble after new opti
- wana go fast
- Surging TPS Volts
- Overheating
- LT1 rebuild parts
- Performance upgrade questions.
- Tb
- MSD Ignition box 6A... NEED HELP!
- oil pump noise
- took heater hose off, Need help
- Up and down idle driving me MMADDD
- intermittant engine codes
- 94 z28 tranny problems, car running sluggish
- Camshaft Question
- ARP 134-1802 Oil pan bolt kit
- New Engine Trouble !!!Please Help!!!
- New Intakes
- Oil Pump Replacement
- lt4 stall requirements
- Help with a stalling 93 z28
- 94 z-28 no start
- temp fluctuating rapidly, overheating, low water light, coolant full
- TBI starter on my 94 lt1
- Valve Cover leaking
- Passkey VATS problem, I think...
- How to check for exhaust manifold leak?
- 1997 lt1 ewp timing chain options
- Rocker studs
- random misfire code p0300
- MSD LT1 Distributor....
- brand of cam?
- K&N Fuel Injection Performance Kit Gen2 Air Intake Kit
- Won't idle
- some stupid noise.
- LT1 Valve Covers
- Low compression #s
- vented & non vented Optispark
- Picked up my first 96 z28
- Low idle when in neutral and coming to a stop
- Possible rocker arm ticking?
- New PB 1/4 CC503
- blew heater hose - 95 z28 m6
- 97 LT 1 High idle problem
- blasted LT1!! New Member to the site...long
- performance chips
- LTCC installed (correctly this time) sheesh..
- Bogging Down... Help!
- Got me a 4th gen
- Transmission / Speedometer Problems
- Starter will not disengage LT1 swap
- Cooling maintenence
- lt1 only starts under WOT
