View Full Version : LT1 Based Engine Tech
- what should i do next
- AFPR & Map Sensor?
- Better throttle cable for the LT1? Lokar?
- Front Clip?
- Opti Dowel Pin
- Headers....SLP, RK sport or MAC
- New parts installed
- Low oil pressure after uphill burnout
- Best starter and best battery for lt1??....
- Motor Mounts (did search)
- Security and ABS INOP lights??
- Oil pump drive shaft
- computer turned off while loading tune
- i must complain about my pacesetter lts (a little long)
- Will this fit my LT1
- Help me diagnose this sound?
- Waterpump Driveshaft install.....
- Hooker LT vs. Wire Harness
- waterpump and r.p.m.-what's the limit?
- OVC wire questions!
- Can I Put The Ls1 Ati Procharger Ram Air Box On An 1996 Lt1 Ws6 Ram Air D1sc???????
- Nasty Noise in the front of the engine?!?
- Optispark rotor and cap
- Runs lean at idle
- Size of Bolts for Stock Valve Cover
- 383 LE3 Setup
- Fuel Line after fuel filter
- CC305 in a 1997 z28, whats the size of the dowel pin?
- opti vacuum
- Need some help!
- Two part #'s for rear main seal, which one is right/better?
- New Oil Level with 383 stroker?
- My car is a turd (bad dyno warning)
- Need help with Opti/code problem
- Symptoms of optispark failure
- Wana use a 97 opti on my 93 motor
- Hotcam vs CC305 vs XE503 vs gm846
- ram air Vs. cold air
- Oil Cooler caused it
- Knock Retard only when car is Warm/hot?
- started my new motor lastnight and it got hot
- Fuel Pressure
- o2 sensor values in datamaster
- fuel parts needed
- symptoms of bad motor mounts
- Acell DFI Part num
- Fuel Filter Replacement
- Still missing????
- shorted o2 sensor
- What windage tray options (other than stock) do I have?
- Checking O2 sensor wiring
- Please help I must have a miss. Right?
- Fuel Line low down
- How fast is my setup capable of?
- 383 dyno #'s
- car flooded by katrina
- need advice from the engine gurus
- Is this cam too big?
- Oil Question...
- Spark retard = knock retard?
- knock retard Q
- Ignition problem
- Quick tech question
- Header help
- How to tell if you are getting Knock retard?
- Hard to replace valvesprings at home? (heads removed)
- BOW DOWN to Madz28!
- So much for just "getting in & driving" the new toy...
- opinions on afr 190 heads
- Any gains possible from LT4 intake?
- Catback Gains: 17HP - 42 ft/lbs TQ
- cleaning intake manifold
- 25% mpg increase from new K&N
- Freescan errors out on startup????
- Where can I get LE packages?
- I need help...may be computer related
- 1/4 mile run @ only 94 MPH????
- Car shutdown on me while driving!
- Jet Hot Catalytic Y Pipe
- help me pick a cam
- Possible to OVERHEAT your car and NOT have DAMAGE?
- minor trouble
- Running rich problem
- Can I take heads/cam from a stroker and put it on my 355?
- Quick Easy Question!
- Estimate on cam bearing
- anyone sell a true dual kit?
- Can I test an Optispark out of the car?
- car's overheating. Tried doing a search and came up empty.
- question about lifters
- How fast will 400rwhp and a 300shot take me in the 1/4mile?
- distributor question
- Any bright ideas on replacing the front cam bearing with motor in car?
- how to set throttle blades open a tad?
- glasspaks on an LT1..?
- racetonix fp harness?
- new starter twice and car fails
- pcmforless vs. madz28
- msd distributor
- LT4 TB on a LT1?
- Tune Up Components?
- lt1 hooting noise at idle?
- cc305 cam, 1.7 rr, ported heads, only traping 106 mph???
- Tranny Mount
- Low oil pressure????
- BAD SUMMIT waterSKUNK BAD
- Oil pressure sending unit
- What size injectors?
- 94LT1 into 93TA.... help
- How much lift?
- Ticking at idle
- Please HELP...Anyone...
- I need my factory exhaust hangers back!
- cam removal
- polished intake fittings
- Flowmaster Super 40's - Anyone runnign them dumped before the axle?
- Dfi
- !HELP! strange noise (LONG)
- tci 3000 enough for this cam?
- need some input on my time slip plz
- arp ntake manifold bolts...
- 11's on stock internals?
- Help, Timimg problem, ChangedOPti, Won't run
- proform water pump
- Need Help Fixing Oil Leak
- Pro,s and Con's of distributor in an LT1 (rear)
- help! 383 stumble putting in gear...got some Tech II scanner info included
- Car extremely down on power!! Please help!
- Itching for a hotcam kit!!!
- RR's Lift?
- Short belt length??
- Engine power making combo?
- Cam surge...turns out to be EGR
- darn I think I shouldnt have bought my 94z
- Any experiance with Beck Mechanical ?
- Trouble Code 26???
- New opti and new stumble, heating gone too
- check valve for as&m header?
- Its almost back together!!
- A/C Compressor Oil Amount?
- Which intake bolts/studs go where?
- How much to mill heads to adjust chamber CC's
- largest streetable cam?????
- Suttin is wrong...NEED HELP
- Remove timing chain cover = dropping the oil pan?
- intake elbow related...
- stand alone
- quick egr question
- aftermarket cam?
- This Is Customer Service
- anybody ever seen these intake gaskets?
- How much for engine rebuilt?
- Removing Shaft from Waterpump?
- crankshaft position sensor with a double roller Timing Chain?
- Test fuel pump hookup
- Maintenance questions
- anybody here run a 4/7 swap cam?
- HELP with engine codes!!!!
- Ok another what is wrong with my car threads!!
- Tensioner
- No power Anywhere
- Headlight assembly Part #
- Where can i get a low cost roating assembly kit plus a few more questions
- No oil from rocker arms
- New Tune, No Run
- cooling fans not turning on
- (non-camaro)OBDII codes for tranny
- Granatelli adjustable MAF any good?
- No Odometer, but speedo works???
- how to relubricate engine since I possibly waited to long to install
- 160 thermostat
- rev limiter
- Who was looking for a valve spring compressor for clearance in the back?
- Starting issues (maybe heat related)
- Stock Injectors
- '94 camaro 6 speed manuel missfiring
- Flashing SES
- Used 1/4 tank of gas in 30 miles!!!
- My car 13.91, another z, 13.69 ???!!
- Looking for good electric cutout.
- These numbers seem right?
- problems after LT's and y-pipe
- Parts store didnt have NGKTR55, will Champion 13 RS14YC6 work well?
- Ported heads with the stock cam....
- TPS @ 32% with car off?!?!
- quick IAT question(s).
- estimated rwhp?
- ARP Wavelock or ARP Standard rod bolts?
- Building semi-budget 396; what parts to get?
- Cam question
- Is 400rwhp possible with this combo?
- Car still burns oil!! [edit]! Help me please!
- Thermostat
- Coolant sensor
- Valve Covers
- Changing the Opti
- Wow this really sucks
- Car Problem
- Single exit vs. Dual exist
- My heads/cam (GM847) car at idle... video 56Kwarning
- Super Vic and Elbow not lining up?????
- shorty spark plug part #
- Cam help...gas mileage
- sensor name
- Voltage Drop under Load while driving
- RPM limit of Dynaspark according to your instructions?
- Car started stuttering yesterday
- with AC on car almost cuts off???
- Maf Code
- questions about lt4 knock module
- 383 daily drivers....what are your idle speeds?
- ...stock fuel pump, good to what hp?
- Stock Belt Size?
- Very bad Hesitation @ W.O.T
- i should be alright shouldnt i
- real quick hp question
- 1.7RR + Stock Cam = Specs?
- diagnose this tapping
- Cooling Fan HELP!!!
- O2's needed?
- LT4 knock module install??
- Valve Cover Cheat
- Oil leak at Optispark?
- Underdrive help
- I Need Help Asap!!!!!!!! Thanks
- bolt in steering linkage hitting my ceramic header... help!
- idles nice in neutral, but stumbles a bit and surges a little when i put in drive
- le1 times and hp
- R.a.p???
- Optispark
- Fuel Pressure woes...
- HP Gains on this Maro
- Alternator support brackets on intake manifold, can I leave them off?
- blown head gasket?
- leaky collectors?
- LT1 engine sound library
- TIP: Before installing heads...
- still getting gas in oil on new engine
- What year lt1 do i have
- Pulling the motor out the top
- install help
- Oh so many header threads! (here's one more)
- Loud ticking under load
- TCS on a 93?
- should i get a lt4 km????
- beginning mods...what areas to target??
- Backfired once at high rpm/mph...why?
- crank case pressure
- Which bearings/rings for a mild rebuild?
- What's the difference in a regular 350 SB and an LT1?
