View Full Version : LT1 Based Engine Tech
- o2 sensors
- Code 27 EGR Problems
- My coolant temp sensor snap... What to do?
- Need help bad! cars falling apart and can't figure it out
- Where to start? help my LT1 plans
- We need a performance LT1/LTX intake! 2007 SEMA maybe?
- very rough Idle
- Roller Rocker Advice Needed
- which long tubes are best for 95 LT1-With emissions
- 383 Crank from Ohiocrank.
- I need a little cam help
- Which Gasket
- Header rubbing steering shaft....
- Not getting a charge
- Pacesetter Header Gasket????? HELP
- Engine Runs Rough when Cold
- hypertech ?
- Air Pump Removal w/o a tune, hurt performance or just SES light?
- Offroad H with 12inch bullets under axle out back too loud?
- Goodyear Gatorback Belt with A/C Delete Pully
- Valve Adjusting
- Spark Degrees/Timing
- 02 Sensor Readings
- 383 and stock PCM
- cam bearings
- Search doesnt work? Quick Spark Plug question.
- Texas Speed and Performance "Rumbler"? Opinions Please.
- what to do with 94 formy
- valve cover clearance
- Passed Smog in Cali w/ CC305 Cam
- PCM Related?
- Anyone running a Pace Setter - X pipe - sweet thunder combo
- Bone Stock 94 formula mods
- Car won't start now... please help
- XE 230/236 - 800 rpm idle vid
- Power before engine breakage...
- Changing Rockers
- Opinion/experience w/ fuel press reg vs higher pound injectors?
- 383 Mpg?
- Voltage Wire on MAP?
- What size nuts do I need for the bolts to the Y pipe on my Macs?
- Emissions diagram?
- tempature climbs after engine is off?
- valve cover ?
- stumped over radiator sensor???
- alternator question
- What engine damage could this cause?
- When draining the block..
- cam question on smogability
- post pics of ovc wires please
- Lt1 idle then death
- cooling problems
- aprox times with current mods
- Quietest Muffler
- Solid Roller questions (valve lash? etc)
- No oil pressure if I do an abrupt stop
- How can water(not coolant) get in oil?
- front damper
- Carb?
- SFI flexplate for LT1?
- what to expect wiht this set up
- weird ?
- Comp Cams Dowel Pin
- Bogging/misfireing off the line..
- Quick question about overlap (hotcam/cc503)
- Rods hitting the cam....
- Streetable, easily tuned, fast, LT1 combos
- hey guys i need help asap oil pan gasket
- intake questions??
- Vibration in a 355 forged lt1 with le2 setup NEED HELP
- Need Help Exhaust manifolds are cherry red
- Spec stage 2 install problem! HELP!
- Shop said longtube dual cat not possible... need pics
- Lt4 WTB
- Need help picking spark plug heat range on my heads/cam combo
- lt 4 starters
- Pacesetter collecter length?
- what year parts will work in 93 formula ??
- Oil pump pick up tube?
- More Gains?
- Timing Chain
- pacesetter quick trip header pics installed needed
- Best Way to Test for a Detonation Issue
- idle
- A little help on upgrading for some speed!
- lt4 valve springs?
- how to change idle speed on 95 lt1?
- Hard starting..leaky injectors ?
- Interesting FuSe Question.
- ARP Accessory Bolt Kit
- loudmouth, no cat, & headers... anyone have this setup, or equivilent?
- Faulty coolant light and random overheat
- Fuse Relay Cover!
- opti replaced, but weird things going on
- 396 stroker misses badly and primaries are glowing
- closed loop,? need some help?
- Need valve covers?
- Missing badly and glowing headers on 396 stroker
- 94 pontiac trans am
- 24lb SVO Injectors Throwing Codes
- loud mouth w/o cats
- need help fast
- Help me to Buy 94 Z28!!!!!!!
- CC306 w/stock short block?
- Header gasket install advice....
- update: car wont turnover but cranks - mystery
- Testing a starter?
- LE afr LT4 flow numbers
- ATI super dampner
- Just bought a 1997 Z28...
- help please..misfing, not driving right..help
- elitesparkplugs.com wires
- Please help with 94z
- Convince Me To Stay Lt1/lt4!
- rocker arm's rubbing the top of springs ,why?
- Car almost caught on fire....need help ASAP
- Those of you with poly motor mounts, question for you
- Moroso CAI Question
- Anyone have any sound clips???....
- New bolt on times
- Where is the feul pressure regulator
- How does this airfoil install?
- Car Hesitates And Dash Go Crazy At Wot
- Overheating.. but not hot
- Car almost shut off at WOT..WIERD!?
- LT1 intake ?
- new best ET 13.1 @108 mph
- vaccum leak check
- Dynoing the Speed Secrets project car..
- Interesting Opti Failure & QTP E-Cutout
- anyone have these valve covers?
- Are you happy with your solid roller?
- boltons and no tune
- Best Place to Put EGT probe?
- cleaning rocker arm bearings?
- 5w-30 ok for winter?
- injector identification?
- tuned for 93, but running 91
- Cam Question
- 1.7 rr ?'s
- How bad is it (video)
- Dr. Gas X-pipe & Kook's
- Did I install the wrong cam for the Street??
- Does A/C condenser need removed for cam install?
- Which oil to use?
- Flow #s
- Bad batch of O2 sims???
- Sound clips of different cams?
- H/C car with Dynomouth exhaust and stock I pipe? Is it hurting me?
- Heads? Differences 93-97?
- Scottslt1z28 GREAT SELLER
- Unexplained knock retard.
- looking for info y-pipes
- Strange problem, need help
- big cam?
- Whats the difference in the RR Studs
- Rocker and false knock questions...
- need info on timing gears
- pop then smoke
- Longtubes
- car cranks but wont start
- LE3 guys inside - shifting and tuning questions
- so many exhaust, so little time!
- Few problem, Feul pressure regulator?, bearings? Help!
- 383 Woes continue, what do you think?!
- Carboard on radiator for better heat?
- TFS Head Guys
- MAF Do i need it or not?
- New battery, new alternator. NO START
- important exhuast question..
- motor replacement
- Help!! Low Oil Pressure After Clutch Change
- update on car problems
- Need help for 94z
- Valve Seal Size (aftermarket valves)
- *Pics* New MSD Cap&Rotor
- can someone measure a LT1 radiator for me?
- just making sure im understanding adjusting RRs
- opti faulty?
- New Build underway, what do you guys think?
- Proform Cam Checker Tool - Dumb Question
- Headers with no EGR???
- Drivetrain problem need help quick
- 1.7rr and 1.6rr on stock motor...?
- Power for my electric water pump??
- Longtubes, cats and O2's?
- Could I be okay with SLP shorty on a 396 stroker???
- I have shorty headers, looking to get long tubes.
- removeing oil pan
- OBD1 to OBD2 on a 94
- camaro 96 Overheating : plz help
- How To Pull Powersteering Pulley
- part number for 96+ crankshaft reluctor
- Electrical in 93 LT1
- Car won't start, sometimes?
- ignition maybe?
- help my car sucks
- installed new cam, now I have clutch noise???
- TPI 305 heads compatible with lt1 block/intake
- exhaust idea
- Understanding Injector Tuning
- Oil plugs behind timing chain
- plugs with MSD ignition
- Intake
- Long tubes or shorties?
- Which torque arm with X-pipe?
- Radiator tank crack (small leak)
- Redoing header install.
- MSD Complete Opti
- heater hose ?
- Passenger side plug wires
- New Mods on a 96 Z
- 383 woes... please help if you can
- Help..Ignition Problem..
- Header install ?
- Valve guide seals for 93 LT1
- Who has Sweet-Thunder's
- ltcc/delteq + blaster coils?
- Timing @ Idle ??'s
- OVC spark plug wires mounting hardware
- Check engine lite & Safe Mode?
- LT1 stock exhaust port deminsions.
- 0-60 difference
- Headers ordered...Need ideas for better bolts and gaskets
- Misfire 5,6,7
- reman opti vs oem opti need help asap!
- car died last night, ignition switch?
- lt1 dies when hot
- VID: 11.70 at 121 n/a lt1
- Upgrade from LT4 hotcam
- 87 Hyd Roller cam in a Lt1, whats it take?
- EGR Simulator Schematics
- SLP CAI over other CAI's?
- FAST with opti and or LTCC?
- Harness & PCM Identify
- Pacesetter LT's Vs. Hooker LT's
- Cam question....
- Dyno Results....Need help
- Is it a bad Knock sensor or bad knock module???
- Exhaust popping
- Help with EGR and AIR removal.
- slop in new LT1 timing chain?
- dowl pin question.....
- i think i "fubared" my opti
- 97 running poorly
- stock deck height lt1 block
- Hmm maybe I shouldn't have done that....
- Car drives great ...then just STOPS!
- Mac mids - Can you pull tranny with out removing y pipe?
- 94-95 FPR same as 96-97?
