View Full Version : LT1 Based Engine Tech
- 1996 LT1 Camaro mssing after warming up and p0300 code
- 94 383 noise, and smoke from tb and video
- Mostly stock LT1 falls on its face in performance after 3krpm or so (log included)
- pushrods
- Main stud question.
- All-New 2014 Corvette LT1 V-8 a Technological Powerhouse
- Cost of 355 build
- idling weird
- Hub and damper problems
- intake question
- Cc503 vs my TPIS
- 94' Trans Am warms up and dies
- Will I make my goal?
- head studs between rockers
- LT1 misfires.....grrrr
- overheating
- 383 Strker Spark Plug Gap?
- water pump shot??
- ? about LE2 H/C
- brake line nut replacement
- 94 z28
- Lloyd does it again!
- For anyone looking to buy preowned LTx AFR heads
- Got a question
- reocurring starting problem (car doesn't want to start)
- sold my iroc now i have 96 t/a ws6 woes! HELP
- thread locker on rotor
- Help!
- Wiring a override switch to the stock electric fans..
- Autolite 104s
- rear mail seal install tool?
- Misfire when warmed up...
- Miss under load - need some advice
- internal balancing question
- misfire at low rpm
- Flywheel balancing
- 1995 z28 lt1
- Starting Problems
- Tps ?
- Dyno Tuning ?
- What would I make
- Backfire question
- help guys bunch of codes
- 95 thowing code 29 and more problems
- Some minor problems, need experienced advice.
- 94 z28 WHOA's
- My LTCC SETUP
- Smoke Coming from exhaust
- new opti and still dont start
- Low Baro reading
- Trying to remove Knock Sensor from block, center spins...
- crankshaft pulley
- motor
- got a code and cant read it 95 obd2/obd1 car
- cc503 questions??
- Issue with LT1 stumble..
- Traces of anti freeze in my flywheel dust pan
- Waterpump shaft play
- Seafoam in the oil?
- engine swap
- Clean the intake?
- Engine builder
- I want to run 11s
- Alright.. I'm stuck.
- ODB1 and emissions
- What lb fuel injectors will i need with my H/C set up
- regarding stalling
- OTV Spark Plug Wire Recommendations
- 1997 Z28 LT1 Getting Gas In Oil
- low oil sensor
- need some advice.
- A/C Compressor went bad, Lost PS 20 min later
- What is the Correct fuel pressure for stock 95 z-28
- Thinking big block swap .
- '94Z28 periodically running bad, mostly when cold
- Oil leak at oil pan gasket. Replace oil pump, etc?
- Reinstall EGR and/or AIR systems
- obd code
- got the p0410 secondary air injection system
- new cam and intake
- optispark/timing question
- Turns over but no start
- Dtc 36
- 1994 camaro running bad, need help
- Code 13 44 55
- VERY random code 36
- bigger throttle body question
- Mild build recommendations? 1.6RR's? Cam?
- 94 Z28, ABS inop light with engine running rough
- Coolant leak on my 95 Z28
- oil pressure problem
- 96 lt1 has spark/fuel no start!
- 1994 ECU Problem...
- 95 Z won't start unless jumped
- How do I pull my LT1 out of the Camaro?
- Whats a good cam upgrade with stock heads?
- 96 long block into a 94 - Starter problems
- 94 formula runs good until it warms up
- need help
- Question for anybody how has done a single plane conversion.
- Fuel pump going out?
- melting rotors on distributor help!
- Engine drop question
- Need 2 coolant hose part #'s/names
- battery voltage...
- t56 tranny removal
- A few problems, are they related?
- New tune up and now high idle
- Oil leak after change to synthetic oil
- bad opti?
- Code 51 after mail order tune
- What temperature should the fans start wrkn..
- Bearing Clearances
- Intake manifold leak repaired but now low idle rpm and back fire when I rev in park.
- desperate for help
- K&N vs SLP?
- 1995 z28 sluggish on low rpms
- 94 lt1 cranks over, no start, motor then turns backwards
- EGR valve test
- Flowmaster 40
- water leakin from driver side rear head
- Engine groggs, backfires, and wont accelerate after right turn
- cooling fan issues
- Stumbling at idle after Mail Order Tune!!
- flex plate ruined?
- Engine out the bottom
- '94 Z28 bad opti/swap/still bad opti
- Mod help
- Need help, 95 died and will not start!
- lt1 97
- question about rod bearings
- What puller to use to remove March underdrive pulleys?
- What's up guys
- replaced head gaskets, coolant leak.
- New problems to me, need some help with were to start trouble shooting.
- Bone Stock 1995 Z28 Camaro Mod Suggestions
- acceptable afr on high idle breakin
- LT1 tacking noise from under the car only when warm 1300-2200 rpm
- Lunati Pressure Fed Solid Roller Lifters
- Optispark drive pin length
- need lube oil cooler line
- Reusing Pistons
- knock retard
- parting out car, engine out top without happy hooker?
- Transmission fluid change
- head gasket repair, or rebuild?
- trying to run without MAF??
- Cam Question
- crankcase tube connector?
- engine swap PLEASE HELP
- gauge qestions
- 96 lt1 ICM where does pin D get its 12V from??
- silicone hose for EGR?
- leaking coolant and overheating when idleing.
- Southern California Engine Rebuilders -- anyone to recommend?
- Bad head/intake gasket??
- LT1 F-Body Cooling System vs. B Body
- 96 Z28 build
- Running rich and dies once warm
- LT1 alternator options?
- Gas smell, poor fuel economy, weeping and gnashing of teeth
- coolant restrictor valve ?
- pressure control valve
- sbc head gasket on lt1
- My Very First LT1 Mod/Upgrade!
- 383 LT1 Vacuum issue
- trickflow heads cc503 power gains?
- Engine removal 95 TA
- my 1st question...batt not charging
- Engine has either a dead cylinder or severe misfire under load
- opti and crank hub location
- how to wire a mallory 667 s CD box to work with a 1997 firebird lt1
- hesitation??
- Bleeder Valve Wrench Size??
- Ignition fuse keeps blowing!
- Hot,hot! ????
- 95 lt1 swap start issues help please
- Gmpp cai
- starter issue
- sts turbo vs cc503 set upp
- Bad Battery??
- scan master install
- oil pressure ???
- How hard?.....LT1 rebuild
- longblock reinstall parts what order
- New Walbro Fuel Pump Installed....
- LT1 383 camaro 97 tune help
- Won't Stay Running
- fuel issue
- Dyno Results, OMG!
- And the headache continues
- 7'11" ceiling in garage lt1 removal(bottom)
- Oil pump drive gear
- LT1 engine that could but doesn't....
- 95 LT1 smoking out pass. valve cover
- Closed my thread for no reason - thanks
- wont turn over
- Golen 383 pilot bearing ? - Vigilante
- LT1 troubles....
- main girdle or splay caps?
- LT1 Swap Start Up Problem
- My 96 Z28 - Engine rebuild - problems
- New Car. Need Some Help
- Help please...LT1 stumble, then stall, now won't start
- Friends LT1 overheat issue
- odd starting problem
- Non Vented Opti spline drive shaft help
- Need alittle Help with water pump....
- must have upgrades?
- LT1 top-end chirp/squeak...
- lt1 mail in tune
- Stock Cam Identification
- Harmonic balancer
- Comp test woes (how to connect to #2 cyl)
- 95Z radomly dies then hard start
- Alternator noise
- Remanufacture Engine Help!!!!
- 94 lt1 missing, sometimes at high rpm.
- Headers????
- Power steering pump plug?
- Exhaust pops at idle, when driving.. randomly
- Engine cranked, but wouldn't start
- HO2 not ready
- 94 vette LT1 into a 96 Z28, What surprises can I expect?
- smoking-HELP
- EGR Delete Help
- Need Headers and help
- Rad hose collapsing after water pump install
- Hard start problem solved--finally!
- Z28 wont start after plugs and wire change.
- engine install
- Electric harness identification
- What do i need to mill the bolt holes in my single plane to convert to lt1 patern?
- Starter wire routing originates from rear or front?
- 1994 into a 1997 camaro z28
- 96 Z Clutch Question
- Oil pump and valve spring question
- Stock crank hub
- Dreaded P0300 multiple misfire
- 94Z wont start issue
- Replacing PCV valve (Rookie question)
- 95 Z28 Camaro Missing Stalling Etc.?
- Opti-Spark best source? '94 Z28
- Overheating at idle - help!
- LT1 dyno tune in atlanta?
- Another smog/emissions thread
- LT Header install, Need some HELP!!
- have an heat sensor problems with my 1997 camaro z28 30th edition
- 94 lt1 failed emission test
- removing the cat!
