View Full Version : LT1 Based Engine Tech
- Car does wierd **** when turned on in cold
- 1 1/2" primaries w/ cam??
- RK Sport / AS&M header install HVAC box clearance issue...
- ls1 in 1993 z28
- fuel tank size on 94 z? (gallons)
- Everything for a bullet proof valve train?
- OBD-II Owns!
- 95 lt1 problems... ign? fuel?
- 94 z28 motor rebuild...........
- SLP-Single Cat Mid's-Starter replacement
- Lt4 springs
- LT4 ED Timing Set Failure...what needs to be done??
- -AN Fuel Line Conversion, Fitting sources?
- output driver module?
- Bad Fan Relay?
- running very ruff
- fuel pump or fpr
- engine problems
- Cc503
- Pulley Question
- Is my alternator dumping?
- LT4 Valve cover studs fit LT1 valve covers
- ported LT1 heads ( 53cc????)
- Part # for Thicker intake gaskets?
- need some help on this one big tiem
- LT1 to LT4
- 95 Z28 Camaro Headlights problems
- Intake gaskets
- LT1/LT4 stroker info and help
- new cam
- Few Vids of My Lt1
- Crane 104227 Idle Video
- I started porting my DIY heads, thought I'd share pics
- 94 lt1 block in 93?????
- LT1 Wont start with out jump?
- 96 z28 with Maganflow want more power
- what size water pump ~~Meziere
- Columbus, Ohio
- Factory Oil Cooler
- any info on dual sync dist's.?
- complete valvetrain list for gm847??
- What are symptoms of a bad Cat?
- Question about removed engine
- Mods This week.
- piston question
- Thoughts/Comments on Painting my already coated Jet Hot LT's
- common rebuild
- could work for LT1
- 383 stroker kit question
- What's the fastest stock LT1 1/4 here?
- folks with '93 f-bodies inside please
- Will this coil work on my car?
- high rpm miss(stumble)
- K&n Cai
- header flanges
- 94 Z28, Water Pump Torque Value???
- Converting SBC Heads
- Which plugs to use with AFR Heads????
- Gas mileage - Programming
- Mac Headers And Possible Overheating Probs????
- My new x-pipe setup *pic*
- Need HELP FAST
- Headers w/ cats?
- potential flow #'s on stock castings?
- Block heater.
- z28 wannabe
- spun bearing, whats this sound?
- Injector size for 355CID @ 450hp+? And other question.
- best LT1 fuel pump
- header choices? and what y-pipe to use
- Lope and tuning question
- so how do you install a cam
- guys who have sumped the tank????
- 1997 z28 vs ss
- Hooker LT guys
- Spark question
- the best headers, dual CB exhaust, and PCM tuning ???
- elitesparkplugs.com contact info
- LT4 spring part #??
- whats the difference in lobe seperation of 110 or 112 on a ....
- Is 240/246 duration...
- Lt-1 Difference
- 94 z28 problems with starting
- Cold Engine woes
- Please Help!!
- Header Wrapping
- Hit brakes...rpms drop!
- Long tube headers horror stories. . .
- Is there a Difference between 95 and 96 spark plug wires?
- Big LT1
- Misfire once warmed up, runs fine with SES light on
- Keep blowing 20 amp fuse for fans
- Bad
- 02 sensor part number help
- How long, miles, will a 97 LS1 last befroe rebuild
- solid motor
- Need help fast...Alternator bracket replacement after header install
- Formula to run mid-12s?
- 1/4 Times!!!!!!????!!!!!?????
- Cat/no cat?
- Will an LT4 bolt right into a 93 Z28?
- anybody got any?
- loping?
- please help! LT4 hot cam kit
- need help with headers
- Christmas came early this year!!!!!!!!!
- whats this?
- would i benefit from head work with the crane baby cam 210-227?
- Cheapest O2 sensor extensions (flat type)
- IAT location
- all with a magnaflow CB
- Sprak plug wire and Thermostat Questions within...
- Diagnosing MAFs?
- Blowin Cooling Fan Fuse?
- Help Me!!!!
- Single cat Vs. Dual cat
- Does this sound like a good 383?
- Hydraulic cams and Solid cams....What is the difference?
- Which MAF to use?
- Fixing blown head gasket. Changing cam?
- Hey Mindgame...
- Where can i find???
- Not your average GM 847 thread... track / dyno results on stock bottom end?
- Headers ??????
- so...where can I get some custom pistons...
- Visible Spark from Spark Plug.
- Fixed my missfire/opti problem
- unequal header glowing problem
- So, valvetrain that would handle 9,000 RPMs?
- LT4 hot cam ported heads???
- Mass Airflow Meter
- Gas on fuel rail bolt
- Any carb'd 383 LT1s out there...
- Comp Cam 07-502-8 ?? Good For.....
- Crankshaft scapers
- Building new motor: Heads / compression ?s
- adjust rockers without TDC? quick question
- LT1 Nitrous question
- Buddies car has super low idle and wont rev out of it.
- h/c setup how much fuel?
- exhaust help plz
- OEM Computers Limits
- CC'd intake runner on heads, is this normal?
- Fuel system help!!!
- Alarm wiring kit / mod for electric H2O pump
- Question about a fuel line
- how much power to expect LT headers
- Installing headers. OMG what a PITA
- Quick Header/Y-Pipe question?
- lifters bleeding off
- ses light flashing need help
- should i get an electric WP?
- LT1 Head gasket question
- LT4 Cam kit
- Racetronix 32# injectors
- Quick header question
- slight circle imbedded into optispark gear?
- Fuel Problem please help
- Opinions on My Heads:AFR 210s on Stock Displacement Engine
- help.....fuel leaking in the rear
- need serious help...my car died this morning
- Can you swap in new bearings by dropping the oil pan?
- 94 headers on a 96-97?
- Help with IAC
- crank seal gone
- Is this a High Flow Catalytic Converter
- True Duals
- Texas Speed TD's
- Bad motor ticking
- exhaust ?'s or need pics of set ups also sound clips!!!
- what cam?
- best way to check valve seals on lt1?
- Anyone ever seen 255 degrees of spark advance?
- I am stumped.....
- Confused about LT4 knock module...
- pistons and compression height
- How to get into the 12`s?
- MSD Pro Billet Distributer
- Blew up a Z28..now trying to fix it.
- paint for lifter valley
- Catalytic converter install help needed.....
- 93 z28 check engine
- Blower/Nitrous cam suggestions?
- Pics of my new 355 installed.
- What size vacuum cap.
- SMOKIN!!! need help soon please
- head gaskets and compression ratios
- stupid rocker question...
- Does this sound like a decent short block
- what's the next cam from the crane baby 227?
- Head porters do you use
- Melling M55A - M155 oil pump difference?
- Anti-sieze on the header bolts. Yes or No
- will 1.6 SA rockers hold up on 570 lift?
- Header gasket break in question.
- False Knock.....
- DTC 48 MAF circuit?
- Got my GM LT4 LE2 Flow #'s
- KS and O2 Sensor wiring question
- Couple of questions about LT1 build up and cost...
- morel lifters
- Getting ready to swap engines.. looking for some advice
- About to start my 383
- Impala SS motor into a Camaro
- Temperature problems...
- simple valve adjustment question.
- Getting my 355 Rebuilt Questions REgards to BLOWER??
- be cool rad
- Reusing arp head bolts.
- big heads and small cam
- What to do with a crossthreaded bolt?
- Gas in Oil
- Finaly got to Dyno My car on the Bolt-On's
- High temp RVT sealant.
- Would you say this is piston slap???
- Year for hardend pushrods?
- 93 z iat sensor reads 317 deg F ?
- Problem With LT1
- Water Pump R & R?
- Why are my Hooker LT's hitting on the drivers side of the engine compartment??
- Crane "baby cam" 227
- O2 simms and emmisions
- Bunch of Questions
- Back on the road
- O2 sensor tune?
- My 383 LT1
- bbk headers
- Will 95 LT1 heads fit
- Need O2 extensions
- How many lb injectors for LE3?
- Burnt plug wire
- Stock Cam
- 130,XXX miles on a LT1
- How to reset idle?
- Relocating the altinator on LT1..
- Some kind of stud where an exhaust manifold bolt should be... maybe???
- Oil Pan part number?
- Did 95 LT1 have hardened pushrods?
- Opinions on mufflers for True Duals
- Hardbloc
- lt1 power level
- common oil leaks?
- Diff. in high and low pressure walboro pump?
- Where to get all my parts!!!!
- Scat stuff?
- Do I really need a FPR??
- What do I need to change for 306 cam? ???????
- stupid head bolt ?
- Datamaster not working...what am I missing?
