View Full Version : LT1 Based Engine Tech
- head work. need advice
- i cant even bypass my tb!!!!
- Time needed for header install?
- Ripping off Intake Manifold
- good time to replace plugs and wires?
- owned
- O2 sensor extensions?
- Help adjusting stock rockers.
- Pcmforless Tuning Vs. Madz28
- quicky about metal cooling lines
- Wants to Die when shifting to drive (A4)
- scanmaster ?s
- most reliable springs for le1 cam
- Does the Opti-Spark control FI Pulse?
- advice on y pipe to catback connection
- Rich running after "hot cam" install in 93Z
- ich running after "hot cam" install in 93Z
- What spark plugs?
- what is the code p1371?
- already did a search... but GM LT4 heads vs AFR 195s
- Lt4 Km
- what do get for a dipstick tube??
- What Plugs To Use With My New 383 Le2
- GM847 guys come in here
- Fuel Pump Wiring Question - Carb Conversion
- Shon Herron's Bolt On 97 Z28
- Can I run 24# injectors in my 93Z.
- Trying to figure this valve spring thing out. What will/won't fit. Valve float on 847
- stock heads, cc306, 100shot, injectors?
- Heres a question for those of you with knowledge of engines.
- wp/timing cover ?
- header bolt length and quantity question
- Ways to increase Hp for emissions people
- Tell me my LT1 didnt just blow up
- what paint to use on an engine block?
- has anybody herd this?
- different belt path, for more room under hood
- Dyno Tune, South east area??
- Anybody heard from Madwolf?
- Polishing Piston Tops
- Performance REAR Main Seals, anyone make 'em???
- Noisy Pro-Mags?
- Bolts
- Planing on doing a 383 n/a
- afr heads
- hooker catback
- Intake manifold
- Should I be worried??
- NGK Spark Plugs
- 383 clearancing (cam)
- No more leaks!
- Wanting to build a Solid Roller 383
- Another dumb opti question.
- HELP! Just installed Japer Engine....no power to drivers side fuel inj rail??
- Electric water pump Question
- Trick Flow Elbow
- Q about timing chain for LE2 package.
- estimated lifter install/expense=>
- throttle body question?
- ac delete
- No spark situation. Here is what I have so far.
- Got tracking number for an Accel Opti, anybody else?
- Datmaster + CC306
- injector question
- I have a 95z roller and I want to put a motor in it, can I
- Low Resolution Pulse
- Rockers too tight.. Cost me a couple MPH?
- header gaskets and bolts
- What is up with 3rd gear?
- Low oil sensor?
- Another 2 thumbs up for seafoam.
- Crane 210/224 cam
- "K" Member???
- header/spark plug questions
- LT4 intake
- Extrude Hone, anyone tried it?
- Oil Pressure Gauge
- GM847 on stock bottom end?
- Crank Hub Problem... Suggestions Please
- Lucas Fuel Injector Cleaner
- Ticking
- Anyone ever use these wire looms?
- running rich (pig rich)
- Just got back from the track. Is this a good time for my car.
- am i suffocating my engine with this exhaust
- Thinking about throwing h/c on
- Quick question re: water pump install (pics inside)
- next mod??
- Computer tuning and fuel pressure
- Corrosion on coil plug
- Maximum Lift
- scanner min/max reference table
- elf motor oil
- '94 Oil leak somewhere around timing cover
- Where to hook up Seafoam
- Some 383 questions
- cam question
- heads
- stock injectors and fuel pump w/ lt4 cam kit
- Car wont start
- some simple questions?
- cam bearing question
- Cam swap question
- which opti. vented or non vented
- Datamaster
- electric water pump?
- Delteq ignition setup, Round 2.....PICS !
- knock sensor question
- home porting is going pretty good...
- 95z28 exhaust
- Air pump removal question
- Need help Bad!!!
- Cam
- cam install problems need help.
- Delco platinums suck.
- throttle sticking with high idle - help please
- Anyone know lengths of brands of OTVC wires?
- Opti help
- Oil pressure question
- torque to spin crank?
- Why would anyone splice into Injector #3?
- Spark plug arcing? shorting out?
- How to troubleshoot engine "Loading Up"?
- Fuel line questions, conversion from stock to AN
- Starting the car without coolant
- Drivers side head won't budge
- Early & Late Fuel Rail Styles
- Lifters
- Anyone received the msd opti
- Knock Knock! On my LT1
- AC Delete pulley
- Should i replace my motor mounts?
- Headers Installed
- Everyone who installed Pacesetter Longtubes on a 96 .. In here!
- running super rich, valve lash wrong??
- How bad do you beat on your Stock Bottomed car?
- Exhaust bolts
- Which oil?
- any one runing cc306 and spray
- difference between 94 and 97 LT1?
- CSR Pump Rotation
- ? About Lt1 blocks with 4 bolt mains
- Pacesetter headers
- Question about running a valve cover breather... do I need to block the PCV valve?
- Fast 60'--slow times?
- Cam Question For GM 847 Users?
- getting compression ratio??
- Long tube question
- Lt's and cats = pass emissions
- adjusting valve lash, TDC help
- Comp Cams XFI
- Spark Plug Wires
- Lift Question
- can I run 7 Cylinders?
- Bad wristpins with 131k?
- MAC shorty header owners please help
- Cam Install
- "Low Oil" Light when car is cold
- 93 z28 misses and backfires when floored,help?
- tranny trouble when shifting at high rpms
- motor combination worries
- accel performance replacement opti?
- How much HP on this set up??
- Tips for Installing a Trans Cooler?
- did I make a good selection on bottom end?
- lt1 cold issue
- having a hard time getting my optispark in
- My next mods?
- 2 plates on the front of the engine ....where do they go?
- Pleae help. No spark.
- Train Horn
- Best spark plugs and wires?
- 93 Corvette water pump on a 97 camaro LT1
- LT1 ODBI to ODBII conversion
- My coil is shorting out - burnt wire, plug?
- LE head?
- how much HP gain?
- Aftermarket harmonic balancers
- Removing Valve Rocker Arms Necessary to remove heads?
- Reinstalling cat and AIR system, can I get some help?
- Spark Plugs
- Ignition problem...???
- Opti dead at 86k
- What size exhaust to run?
- Serpentine Belt Replacement
- What is the best 350-400 rwhp setup that is emissions legal? im in cali
- looking to build a 383 stroker
- I give up!!
- LE1 package in a daily driver?
- Weird noise on start up??
- Pics of my VRE 383!!
- so i left the spray off carwash and now car...... ?????
- getting ready for cam swap-question
- air temp senser help
- CC306 vaccuum question
- Valve train Check Please ( Pic inside)
- temp. gauge/sensor issue
- help with build please
- catalytic converters
- best plugs and wires for..?
- No fuel pressure?
- Anyone use Valvoline MaxLife synthetic?
- Need some help please! i cant get this thing running
- In----credible
- let's see some pics of painted intakes
- Header/Exhaust checklist
- ?? on main stud girdles
- roller rockers
- Am I wrong in saying these aren't AS&Ms?
- Cut outs worth it?
- Bad Quad Driver in ECM?
- Oil pressure drops to 0 at stop light, new bearings & pump
- Thinking about RR's
- started 383 today.
- throttle NOT retuning ALL the way closed BBK 58?
- Calling all LE2 users...
- 918 springs on LT1 heads
- should I get magnaflow??
- What does this wire go to?
- 5.7 hemi - 5.7 lt1 ?? why more horses on the hemi
- super ram intake for lt1
- Cc306
- first things first
- Hesitation, low idle problems.
- New Best ....12.09@112.2
- Track times!!??? Irked!!!
- New guy
- Terrible vibration from 3k up till about 4.5k
- any idea what this could be ? *pics inside*
- Black stuff in coolant resovoir?
- 95 lt1 engine wiring diagram
- oil in the intake
- Stumbling, erratic idle, dies
- what do you think. does a msd box cure opti
- lifters
- AFP regulator
- Weird Ticking inside car ...
- Need Help with EGR Code 27
- Car won't start.. battery is fine, gauges don't move
- video of my new exhaust
- Electrical Experts, need Help with coil/ICM, long
- Heads please help
- can I reuse valve cover gasket??
- Spark Plug Diagnosis
- tb bybass?
- 1.7 rrs
- oil pressure question?
- What is LT1 idle speed....
- Fuel system questions
- handling LT1 vs. LS1??
