View Full Version : LT1 Based Engine Tech
- O2 censors
- LT4 Knock Module- How can I tell if i have one already?
- I need help guys!!!!!!!!!
- Best place for AFR Heads!!
- Bad 02 Sensor Cause Smoke?
- I'm going to kill somebody
- Throttle body size...
- Is there a way to check timing?
- Any good reference sites for AIR system?
- Plugged waterpump weep hole
- Here's another of these HELP posts.
- does this cap and rotor look bad?? pics
- Cursed LT1...
- heads/cam guys inside
- badlanzhpe electric cutouts.. EBAY
- flywheel bolts?
- '94 LT1 issue...of course
- Found out why I have no oil pressure! Pics
- Question with weekend project
- How to pull codes on a 1995 lt1?
- LE1 heads and LE3 cam?
- Injector Wire Harness
- Will this K&N FIPK 2 fit?
- Can anyone tell me what year car this LT1 came out of?
- 230/236 cam high map numbers?
- getting the t-stat out.....
- afpr problems
- Pacesetter LT/ORY/frame clearance??? <pics>
- whats the best brand of headers?
- Help me pick parts for my shortblock....
- Oily plugs, please help diagnose.
- 1996 Impala Trouble Shooting
- help identify heads
- sooo ........!!!!!!!!!!!
- "Torquest" Cam
- Anyone interested in a car bon fire
- How do I get ahold of Joe Overton??
- Will this wire be okay?
- firebird electrical / stereo issues
- Plz read your guys are my only hope!
- GM Cylinder Head to Coolant Tube Gaskets
- Autometer guages(oil/temp) use stock senders?
- Rebuilding w/stock size bearings/bore good idea?
- Joe Overton LT1 cam 4 sale!!!!
- Opti rotor RPM failure ?
- Just got my car dyno tuned!
- LT4 Knock Modle AND sensor Question
- smoking like crazy~ need to pick peoples brains!
- Computer Retarding Timing :( Knock...
- Installed new MSD opti...still not start!
- got car dyno tuned this week!
- LME head porting work on my AFR-210s
- Removing AC Compressor
- Higher rpm sputter/bog?
- Why is my car still getting hot???
- 96 lt1 hp
- help me pick a cam for 385 stroker
- Who actually has the MSD and how is it?
- resistor to replace low oil level sensor
- Steerng shaft question
- Remove plastic piece in front of radiator or not?
- What's the best and biggest Throttle Body!
- More performance? 96 z-28
- Want to Gut Cats
- looking for answers?
- Scanmaster, LT1 edit, Hypertech??
- After disconnecting battery car runs funny any help
- Cam packages on ebay??
- HOTCam on 110 lsa??
- What will this setup dyno????? Thanks for input...
- Map Sensor Voltage Too High
- Optispark converstion harness problems
- P0135 o2 Sensor code....
- need help opti in my lap right know
- wireing harness problems. Can everyone help answer my questions?
- vibration noise
- rev limiter
- help with crane valve springs
- dual vs single bore throttle body - whats the difference?
- Fuel problem
- Error Code 43 does this seem logical?
- length?
- LT1 coil crisis.....
- valve adjustment hot or cold?!?
- Is it ok to clean and reuse this part of the opti??
- Please, please help beyond frustrated
- Anyone else having problems with this new ETHANOL type Gas???
- Canton Pan Leak
- EGR and AIR blockoff plates from this site
- Continue with installs or search for mystery tap?
- Head Gasket
- Bad sounds.. should we take off the valve cover?
- What's the difference?
- map sensor need help...
- True duals W/O cats or muffler? Will it sound like Crap?
- who is using the magnaflow #15620 3" S.S. catback?
- Running rich, have no clue
- 93 lt1 into 94 3.4
- Delteq Question.
- help with high idle coming to a stop!
- GM 1.6rr clearance?
- Timing/Retard issues, please help!
- The dreaded Lt1 Stumble(long)
- 2 part ?-Gasket Help--Noise Help---
- egr question (header related)
- O2 sensor bung/plug question
- Spark plug wire boot split.
- Optispark?! Alternative?
- bad motor mounts?
- Another firing up problem
- LE2 guys, what are you setting your rev. limiter at and what RPM are you shifting?
- AC fan trouble.....please help
- Distributor problem?
- What would it take for a street tired LT1 to run 11's?
- High Missfire Wot?? Lost
- backfire high rpm?
- OBDII to OBDI PCM Conversion Questions!!
- exhaust noise
- LTCC Codes???
- weight of bare shortblock
- 97 SS Exhaust Cackle (no cats)
- Code 97 VSS Out Put Circuit low?
- Shoeboxes Coolant Hose Diagram?
- Tr55 or Tr6 plugs?
- Need information on block salvaging?
- 95 LT1..do I have an oil cooler???
- Speed Limiter
- need help
- intake gasket
- 3.4 to LT1 swap, need A/C help
- The LT1 is studdering and dying
- Any True-Dual w/dumps and Flowtech Afterburner users?
- GForce is kicking butt on the PEPPE project
- Causes of Missfires?
- Finding a Vacuum leak? Help!
- Car Runs Horrible Very Strong Fuel Smell.........
- Coolant Leak.....from somewhere
- Symptoms of a wet opti?
- wondering if my heads/cam are stock
- fuel pump prime lead plug in??
- A Little Help Please
- PCM gone wacky
- What is a good true dual muffler?
- what is wrong with my Z
- larger valves with the CC305
- What would cause this?
- Performace Question
- New Fuel Injectors installed
- Motor SHake after OPTI install
- Already searched...How do I rewire the LTCC
- Tunning my LT1
- Another "my car surges and dies" thread
- 10 psi intake vacumn pressure???
- Another won't start thread.
- need help
- Meziere water pump(relay wiring confirmation)
- 383 vs le3
- oil pressure higher now
- LE2 383... Auto. not shifting at WOT
- LE3 Head / LE3 Cam people
- Got a problem
- LE2 experts...RPM question?
- Pics of elitesparkplugs OVC wires
- lt1 balancer???? carb related stuff inside
- running too lean
- shortened spark plug socket?
- Overheating=fan not coming on or something else?
- whats best fuel pressure for 385 stroker, SVO 42lb
- Anyone have pics of LS1 Airbox Ram Air to LT1 Conversion?
- Air/Fuel ratio question on dyno tune
- Car dying while driving. Anyone want to take a shot??...
- O2 Sensors
- HP vs. Injector size
- Need Lifters, help?
- really need help..signs of bad afpr..
- fel-pro part # please???
- new top end in my LT1
- hand-me-down upgrades...
- experimental lt1
- What breather for V/C
- How to prevent burned plug wires ?????
- Best fitting aftermarket radiator with SC and Meziere
- 58mm or monoblade on a 440rwhp car?
- need answers quick
- Where does a SLP fan switch plug in?
- vacuum leak? help please
- Comp R lifters clacking around, have a question
- Car Overheated This Morning!!!
- starter install with hooker LTs??
- is there a way to check afpr to see if it's bad.
- LTCC vs Delteq
- Electrical guys. Fuse Question.
- Gm Hot Cam Kit>?
- Need help with my LTCC! The instructions suck and im not that bright. Need advice.
- Vacuum Pumps
- alternator test
- Using stock PCM W/Vic JR Intake??
- Will the LE2 package pass emissions in a stroker?
- Starting Flooded LT1
- cam lift question?
- Trying to replace motor mounts, having a problem...
- 94 LT1 needs healthier cam
- aftermarket radiators
- Cam and bolt on setup's come on in!
- do GMPP guideplates line up well??
- LT-1 Flow numbers vs.LE2 & LE3's & others
- water pump question
- car wont run after valve adjustment
- Summitracing opti
- Cable Cut outs
- temp sensor extentions
- What is this thing?
- 93-95 vs. 96-97 headers
- STD ring set?
- SES light came on- threw 5 codes- makes no sense
- 383 Le2 Backfire Update Again Can Anyone Solve This
- noob / waterpump question
- Jet-Hot LT's checklist..
- LT1 fuel rail dimensions
- Those with all the bolt on's, please step inside...
- Ha! Incredible only this car!!! Window wire harness rocks!
- Need Advice
- GM Guideplates Part #
- What is the difference?
- A little help ...please....????
- Thinking of converting to a Single plane intake
- Pushrods for 383 project...used a checker...have ???
- fuel gauge sending unit
- Is the Pacesetter longtube collector 3 inches outside diameter?
- alternator plug p/n ???
- 93/94 LT1 long block into 95 Z28
- piston question:
- 58mm TB's, what is difference in the versions for 92-93 VS. for 94-97?
- Dyno Run:Had a Problem.
- NewB ? forged I beams,forged pistons,STOCK crank...heads/cam 150shot???
- Stock radiator hose sizes at pump
- Effects of TB soaking in degreaser.
- Code 16 and 36, need help.
- question about intake.. weird..
- Intermitent Tap
- help...my new car wont start
- Edelbrock Intake manifold
- What would make a car do this>>>
- Would you use lifters that have 60k miles on them?
- 95 lt1 engine problems
- Comp Cams Guideplates
- Overheating problem
- Has Anyone tried TSP TRu-Dual Set- Up on LT1 ??
- header questions
- Should I quit driving it, and what could it be?
