View Full Version : LT1 Based Engine Tech
- Motor dies and then refires while driving
- Pressurized coolant tank & connections question
- Need some help with these Fuel pressure readings
- Opinions - Radiator Replacement + Oil Cooler
- What's up with this wiring
- LT1 Wont Start Help ASAP!!
- Oil pan swap on 95 LT1 engine
- Lt1 Won't Idle (New motor)
- Cat or no cat?
- 94 engine swap into 96 car
- Changed TPS now car won't start...
- New to Camaros....quick question
- Wiring Harness
- Help me find my oil leak!
- Lt1 Swap Meet
- 396 "Stroker Clearanced" Connecting Rod Question.
- computer ground wire brunt.
- valve spring help
- Went to get 383 build priced...
- My first top-end “Craigslist” build (build sheet and dyno results)
- 95 lt1
- need help on bugget build
- What mods should I do next?
- What are the first mods you would do to a stock LT-1?
- Kocking noise/ gas in oil
- an update on progress
- No start
- Is my flowmaster costing me 20+ rwhp?
- code 36
- A4 to M6 conversion problems help!
- Please help failed smog nox
- Rev Limiter and Cam
- Cylinder head torque spec or degrees!?
- Break in oil additive
- P0106 Code
- Knock Retard Suggestions?
- weird problem. Hope someone can help..
- need help
- machine shop called
- crank sprocket
- LT1 Water Pump / Opti Spark 'fix'
- 94 B4C Build
- 1994 camaro z28 1400-2200rpm problems
- opti help asap please
- random start and shut off
- OTVC wire install
- Losing my mind. Arcing problem
- christmas in july......
- Issue?I have a question
- Attention lt1 single plane guru!!
- camaro z28
- Cautious about getting cold air intake for 94 camaro z28
- Help please!
- msd ignition problem
- dual oil filter
- stall converter
- slp exhaust
- Low dyno numbers
- 94 z28 o2 sensor ?
- smog and egr delete
- Rookie- Looking for Advice
- Oil cooler
- Car Dies When it's Very Hot and Humid Outside
- engine noise
- 96 z28 lt1 tuner
- car shifts from 1st to 2nd at 3000rpm.....tranny problem???
- manual to auto
- No start situation - need scan tool and advice
- pushrods
- what are healthy datalog #'s?
- P0122
- Main Harness ECM pics PLEASE!!
- K&N CAI question
- 94 LT1-won't start-no spark?
- 97 Z29 shutting down still....
- trans??
- rering an pistons...
- power loss with humid muggy weather
- Alternator amp output overkill?
- head/cam matching
- Blown head/gasket -- rebuild turbo? '96 LT
- is it pcm trouble????
- noise after 3.73 gear install
- 95 z28 m6 ignition problem
- tunerpro with 1994 z28
- 97 Camaro Z28 suddenly shuts down after driving
- what are my options..
- Rebuilding my 385 LT1...
- Speed limiter on 95 z28
- closed loop going to open loop??
- 95 Z-28 runs fine and then dies
- Torx bolt sizes
- Help with Fuel Cell trims on data log... am I lean or rich?
- 95 LT1 overheated and now tapping????please help
- INJ big enogh for NOS????
- What type of Headers?
- Headers?
- running rich
- Need a LT1 "alternator only" mounting system
- low RPM miss and codes
- Heads and cam
- Engine swap for a beginner?
- 97 Camaro to OBD1
- what are the chances of a stretched timing chain
- Engine shuts off after running for a while
- distributor problems
- Did an auto to manual tranny swap, now probs! Help!
- Cooling System Help
- help
- oil "change"
- Code 33 Issues
- Help with shifting issue please
- help !! no fuel pump
- 95 speed
- Alternator Temperature
- header install seems to close to fuel lines
- Engine Swap
- 95 z28 air intake elbow
- Belt problems
- LT1vsLS1
- Code 43 and some driving issues
- relay
- 1LE elbow ?
- Lt1 bored 383 and 383 stroker horsepower ?
- weird hesitation issues
- 95 z28 engine surge, bog,ruff idle
- Not Starting
- weird issue.-95 z28-obd1?w/obd2 dsl port?
- Possible knock
- Dissecting the bad opti - pictures!
- LT1 Oil sensor(s), wiring, & oil pan conversion
- looking for the right headers: recommendations
- Engine knock-gas in oil- need advice
- Car stutters and bogs down, then drives fine the next day??
- Balancer Wobbles
- Free 94/95 LT1 Scanning Software - PCM/ABS/SRS - For 93 Also (Except SRS)
- Original style racetronix wiring harness.
- Hugger headers on LT1 engine?
- 1996 Lt1 wont start
- ls7 lifters pushrod length
- My 95 Z28 won't start
- Aftermarket TB and lumpy cam at idle
- 94 z28 stalling
- Car bogging and stutering please help!!!!
- 1995 Z-28 Head Gasket - Worst Road trip ever
- changing oil pan gasket
- 95 LT1 accelerator cable differences
- I've read & researched the cam threads...503 or 306...
- Thank you Will.B.Brown
- Evap System Problem/Question
- New Car and Horsepower question
- intake - quick question
- trans & motor didnt tilt when jack was lowered
- Clean air emission test help needed
- '94 LT1 cooling system problem
- 95 z28 bogging out
- PCM - Dead or Alive?
- Rocker arm issue
- Not turning over need some help
- Low torque vs Hp number on dyno today
- Lifter tick? (Clip inside)
- 96 Z28 Spark PLug Wire Loom P/N?
- '95 Z-28 LT-1 starting issue: crankcrankcrankcrank Vroom!
- Still Struggling, experiencing KR
- Cam help
- Weird Idle Issues
- Msd opti spark
- Looking for some advice.
- timing set compatibility
- Husrst shifter
- Plastic on steering knuckle
- Coolant from throttle body?
- g05 coolant in 95 z28 lt1
- Name of Part below EGR Valve
- 1969 Camaro Oil Pan Leak
- egr failure
- Identifying which 02 sensor connector is which...
- losing coolant
- What's a 95 LT1/Auto drive train worth Parts Car Donor
- Pulling timing for no reason?
- MAF pigtail roached
- cast iron or aluminum heads??
- low fuel pressure
- Changed timing cover seals, opti, damper, now runs rough
- please help with trouble codes. 13, 29, 41, 48
- Intake restriction on 383
- lifters
- heater delete questions
- Optimax and Tune Up...160K milage...
- About fed up!!!!
- Bad O2s?
- Best Way to Hook Up Nitrous Fuel Line and Electric Fuel Pressure Sensor???
- Need Valve Spring/caps/locks suggestions.
- Temp guage (head) / SS spoiler conversion ?s
- Lifter oil feed hole direction?
- would I need new valve springs?
- tcs motor relocate
- Trouble codes
- Edelbrock LT4 manifold
- Poor Acceleration on '94 Camaro Z28 LT1
- 94 z28 cuts off going down the road
- starter pinion gear kicks out while cranking and reengauges wrong and grinds
- stock rebuild high oil pressure
- Help !!!!
- *courtesy short*
- What would cause the cam bolts and dowel pin to snap??
- Motor mount bushing question with picture
- car boggs and just down and die need a little help???
- oops, now what?
- best cat back for lt1 engine with stock manifold and cat.
- [edited] for sale
- 96 to 94 z28 electrical differences help
- coolant in oil
- which retainers / seat cup
- squeaky A/C compressor clutch
- Tip for getting the final motor mount bolt back in?
- Where's the place to get LT1 engine parts now?
- what spring compressor
- Stalls when stopping
- high beam switch
- lt1 stalling after warm up
- Need Help badl misfire after no start
- ISSUES on 95 z28 heater/radiator hose replacement?
- Change gasket, rebuild or low mile used motor??
- O2 sensor clip repair/replace?
- LT1 Misfire after new plugs & wires
- Strange Ignition Issue
- been having troubles..
- Too hot or not
- Save me from the miss
- Coolant in CAT - problem?
- no start after sitting for a while
- What next?
- 94 z28 backfiring
- LT1 problem
- Changed water pump, now oil leak
- obd1 or obd2 aldl cable
- lt1 issues
- LT1 cam shaft question
- permanent fuel gauge
- Engine replacement options?
- lt1 head bolts sealant?
- Fuel Pump or FPR ??
- 95 z28 Fans not coming on and what scanner to buy?
- Engine Swap.....
- Heat Tape on Spark Plug Wires?
- Raising motor and tips for pacesetter lt install?
- Spark Plug Replacement - FLP longtubes
- Lt1 no start help me!!?!?
